[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Da ich schon eine Tuf habe ist das Zittern zum Glück nicht mehr so groß. Aber wenn es klappt habe ich 300 Euro weniger ausgegeben und habe endlich eine Karte die auch einen Teil der warmen Luft hintenrausbläst und nicht im Gehäuse lässt. Und dazu noch schicker aussieht und kleiner ist. Die Tuf ist allerdings auch geil. Unhörbar und 2x HDMI.
Es wird dich überraschen, aber seit ich die TUF im Case habe sind meine Komponenten eher Kühler als wärmer geworden, Chipsatz, und NVMe SSDs haben ordentlich profitiert, CPU juckt das garnicht :d
Das ärgert mich echt hart... hatte die ganze Zeit immer mal zwischen meinen Terminen geschaut und dann war ich in einem und in dem Moment dropt die FE. Ich könnte so richtig fett :kotz:
@SH muss ja irgendwie wieder in TOP10 beim 3DMark Speed Way er hat vermutlich Nvidia und Asus angerufen die sollen noch ein paar Karten raushauen 😂😂😂
Du bist hier im Luxx, da bestellen sich viele mehrere Karten und suchen sich die Beste raus. Bei dem Preis und dank FAG legitim. Hier muss man nicht gleich Scalpen unterstellen.
die gier ist halt bei beiden vorhanden. ich finde das beste aussuchen und FAG nutzen sehr bedenklich. anstatt mit einer zufrieden zu sein sucht man sich das ü ei raus und schickt karten die eigentlich top sind in einem inakzeptablen Zustand zurück.
Kommt ja drauf an was Du vorher drin hattest??? Ich hatte eine 3090 drin. Da war es auch wärmer.
Aber ich denke mit der FE wird es noch kühler.
Oder hast Du einen direkten Vergleich der Tuf zur FE?
Vor war ne 6800XT MB drin also Ref. Design, nein ich hab keinen Vergleich zur FE, aber viel besser wird sie es wohl nicht machen denke ich, weil die TUF gut Luft nach oben überall vorbei transportiert.
Aber gut, hätte ich ne TUF OC gekauft würde ich es vielleicht auch mit einer FE versuchen, aber da ich ne non-OC zum Preis der FE hab seh ich keinen Grund.
Keine Chance bin bis zu Amazon Pay gekommen danach irgendein unbekannter fehler..
Das nervt total. Hätten sie ihre kack Karten mal 3 Monate gesammelt. So ein Dummer Zirkus. :Böse:
Ich war im Bestellvorgang bei Paypal und bei AmazonPay und auf den Button bezahlen und danach der Fehler bei notebooksbilliger.de
Habe gerade angerufen und erfahren, dass die Karten weg sind.
D.h. auch hier war wieder nur ein gewisses Kontingent vorhanden.
Traurig!
Das ist krass. Und da vorbei kannste wohl nicht oder?
Leider nicht.
Erster FE Drop kam nach 3 Stunden der Storno und die Ratenzahlung ist immer noch nicht bei PP raus.
Dann letzten Donnerstag ne Suprim X gekauft, welche aber überverkauft wurde. Als Alternative dann von MF die Gaming OC bekommen.
Und jetzt schludert DHL noch.
Bestimmt Karma weil ich die 3080FE bei einem der ersten Drops bekommen habe :unsure:
Ist auch mein Plan.
Wenn sich abzeichnet, dass die 1950€ Karten, egal ob FE oder Tuf, in den kommenden Tagen besser verfügbar sind, geht die Tuf OC (natürlich ungeöffnet) zurück, die gesparten 300€ fließen dann direkt in das geplante CPU Upgrade.
Imho lohnt der Aufpreis für die OC Karten null, aber die Tuf war halt quasi nicht zu kaufen.
Mfg
Kiryu
Ich habe bei Alternate ne Zotac Trinity OC im Warenkorb, wenn wer will...
Die ist so hässlich und auch 1 cm zu lang, daher nix für mich...
Die Zotac wird noch depressiv und nimmt sich einen Strick wenn ihr die weiter so mobbt.
Ist auch mein Plan.
Mfg
Kiryu
Ich werde meine tuf dann hier und oder ebaykleinanzeigen anbieten. Zum UVP.
Ich werde meine dann
hier und ebaykleinanzeigen anbieten. Zum UVP.
Wäre natürlich auch ne Möglichkeit, aber imho bei guter Verfügbarkeit eigentlich auch nicht mehr nötig. Dann muss sich der Käufer im Zweifel auch nicht mit irgendwelchen Probleme bezüglich Garantie etc. rumägern.
Mfg
Kiryu
An die FE Besitzer, der beiliegende Adapter ist 3 x 8 Pin oder 4 x 8Pin zu 16?
Mfg
Kiryu
Kommt drauf an ob der Käufer woanders eine bekommt. Was ja momentan nicht ganz so gut klappt. 50 Euro weniger wären mir aber auch egal. Ist mir lieber als sie zurückzuschicken. Kann ja Saturn nix für...
Ähnliche Themen
