[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
  • Danke
Reaktionen: bRv
Heute gibt es aber massig Drops. 😝
Hoffe alle werden glücklich und bekommen eine.
Bin froh wenn ich mein Cashback bekomme.
Holen sich hier alle mehrere zum Testen?
Hört sich so an 😅
Hört sich so an 😅
Nachdem es mit der FE am Mittwoch nicht geklappt hat, hab ich mir eben ne TUF bestellt.
Aber eigentlich will ich ne Referenz oder FE wegen dem kompakteren PCB.
Hat jemand seine 4090 mit einem fractal ion+ 860 befeuert?
Im Lieferumfang sind 3x 6+2Pin Y-Kabel für PCIe dabei.
Ich könnte somit 3 Anschlüsse vom 12VHPWR Adapter anschließen (450W).
Meint ihr man könnte den 4ten Anschluss mit einem 6+2Pin Y-Anschluss nehmen, dann wären 2x 8Pin Anschlüsse an einem Strang vom Netzteil. Oder lieber zusätzlich ein neues 6+2Pin Kabel kaufen?
Let the games begin :d
Das stimmt schon. Allerdings wird hier mit dem Begriff "scalping" eh inflationär umgegangen, es ist eine der am häufigsten verwendeten Beschreibungen hier und in mehr als 80% der Fälle eigentlich unzutreffend. Aber es hilft wohl vielen Frust abzubauen, in sofern würde ich das nicht so eng sehen ;)
Geht mir genau so und ich habe mich in meiner ganzen "Karriere" noch nie daran beteiligt, mehr als das zu bestellen was ich brauche. Für mich gab es immer nur eine Karte (bzw. zwei zu SLI-Zeiten) und dann war Schluss, dann lebe ich mit dem was ich bekommen habe. Eine Karte schicke ich zurück, wenn sie defekt ist oder eindeutige Mängel aufweist, schlechte OC Reserven sind aber kein Mangel und daher für mich kein legitimer Grund sie zurückzuschicken.
Wenn man sich selbst Regeln auferlegt und dran hält, schränkt das zwar manchmal die Möglichkeiten und Chancen ein, dafür hat man aber in der Regel weniger Stress und wird langfristig zufriedener mit dem was man bekommt :) Aber das ist nur meine Philosphie.
Ich hatte aber mit meiner Suprim X auch Glück, sie ist zwar kein absolutes OC Monster aber liegt doch auf einem sehr guten Level und auch diese Reserven habe ich mir nur aus Neugier angeschaut, ich nutze sie im Alltag nicht. Im Alltagmodus ist sie bisher eine wunderbar performende Karte, ohne Zicken, ühbermäßigem Lärm oder Hitzköpfigkeit. Ich bin sehr zufrieden.
Was hast du denn für Werte? Einfach mal so als Vergleich. Meine geht bei +1.000 V auf 2925MHZ +450 Mem. Bei 1.050 schafft sie die 3 GHZ Grenze war aber nur mal spaßhalber. Alles darüber macht keinen Sinn, da +500 W sehr häufig ansteht. Bei den Temps bin ich mir nicht so sicher. Liegt ca auf dem Niveau meiner 3090FE bzgl. Temp / Leistungsaufnahme und Fan %
Alter, was NBB da abzieht!
Bots sind halt schneller... und sobald ein Scalper eine 4090 hat, kann er seine AI mit dieser befeuern...
Kam grade storno
Bei uns im Unternehmen gibt es damit auch immer wieder Probleme.. als Endanwender bzw. Käufer wäre mir das aber auch unverständlich. Die verschiedenen Systeme ERP/Shopsoftware etc. in Echtzeit Synchron zu halten ist leider echt nicht so einfach in der Praxis. Auch wenn es eigentlich keine Raketenwissenschaft ist. Bei der 3080 FE gab es aber gefühlt nicht so viele Stornos.. oder?
Bei uns im Unternehmen gibt es damit auch immer wieder Probleme.. als Endanwender bzw. Käufer wäre mir das aber auch unverständlich. Die verschiedenen System ERP/Shopsoftware etc. in Echtzeit Syncron zu halten ist leider echt nicht so einfach in der Praxis. Auch wenn es eigentlich keine Raketenwissenschaft ist. Bei der 3080 FE gab es aber gefühlt nicht so viele Stornos.. oder?
Doch doch gabs auch. Seitenweise nach einem drop 😆
Wäre auch zu schön gewesen.
Ist echt lächerlich das System.
Vielleicht wollen die einfach nur die Nachfrage abchecken?
Immerhin wurde bei PP nicht abgebucht.
Jetzt werden wohl wieder alle Artikel bei EK verschwinden :-)
Ähnliche Themen
