• Wir sind dabei, den Suchindex des Forums neu aufzubauen. Bis ca. 6 Uhr morgens kann die Qualität der Suchergebnisse variieren.
[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Wieder ein japanisches Kinderzimmerdesign!
Das ist der Persocom Chi von Chobits, einem Anime den ich damals mit meiner Frau gesehen habe, als wir uns kennenlernten und ja seitdem sitzt Chi immer mit im Rechner.
Ich hoffe sie kann sich an das schlanke neue Kabel korrekt anlehnen. :LOL:
Ich hoffe sie blockiert nicht den Luftzug
sie ist wesentlich kurviger und windschnittiger als diese NVIDIA Adpater-Kabelblockade.
Ohne eingeschalteter RGB Beleuchtung schon fast schlicht, im Gegensatz zu anderen Customs.
Vor allem keine hässlichen Gaming Brand Logos oder Schriftzüge.
Aber die Ausmaße zu der KFA auf der ersten Seite scheinen nicht zu stimmen. Laut Hersteller 352x153x74mm und nicht 336x138x74. Also scheinbar auch einer der größeren Kühler, so das die Karte nicht so einfach in viele Case passt.
Dimensions:
  • Dimensions(with Bracket): 352 * 153 * 74 mm
  • Dimensions(without Bracket): 336 * 138 * 74 mm
  • 3,8 Slots
  • 22 "phasen"
Hätte ich genommen wenn es dafür einen Block geben würde. Scheint ja kein Ref zu sein
Die KFA2 scheint top zu sein 22 Phasen im 18+4 Design, 4x8 Pin, 600 Watt bios und UVP, ist somit in meinen Favoritenkreis gerutscht
Versuch mal den Treiber Clean neu zu installieren und Prüf den Sitz der Kabel vorher vielleicht nochmal :)
So, ich habe gleich die Kabel gewechselt, weil ich mir neues Netzteil geholt habe. Treiber. Auch neue Clean installiert mait DDU Problem besteht immer noch
Lg
Mein Grafikschinken sitzt jetzt auch endlich im Nest :)
Musste allerdings vorher von dem CableMod Vertikal Mountig Bracket noch etwas wegflexen, weil das Bracket nur für zwei Slots an der IO der Karte gedacht ist. Aber jetzt passen auch 3 IO Slots aufs Bracket.
Für die Kurvaner unter Euch:
Stock default voltage curve
1,05V = 2835MHz
1,10V = 2910MHz
Auch das erste Mal, dass ich im normalen TimeSpy "Legendär" angezeigt bekommen habe ^^
Jetzt hoffe ich nur noch das Fractal Design sich auf meine Anfrage äußert, ob die ähnlich zu be quiet! auch einen 12VHPWR Kabel für ihre Ion+ 860W anbieten werden.
Bissel Spulenfiepen hat meine SuprimX, hörbar ab 230+ FPS, ohne G-Sync aber nicht mehr ganz so stark.
Hat da schon jemand Erfahrungen gemacht, ob sich das Spulenfiepen ändert/reduziert, wenn man statt des Vierzacks das neue be quiet! 12VHPWR -Kabel nimmt? Würde mich stark interessieren.
Lg
Was mich auch Wundert sie, zieht ja die Leistung, die sie brauchen da gibt’s ja den zurücksetzen in Afterburner dann sind es auf 100 % ich komme im Stock auf 460 W und wenn ich auf 1,1 v gehe dann nimmt sie sich auch ihre 520 w
Lg
So meine Suprim hat jetzt auch ein 600 Watt PT 😍
Hier noch nichts aus der Bestellung Asus Webshop von 14:44 gestern, mal schauen wo ich da wieder reingelangt habe🙈
Jemand das seasonic Kabel schon? Ist das vom radius besser als das stock Kabel dass bei den gpus dabei ist?
Krass ich hab 15 min nach dir bestellt, wurde heute verschickt.
Stimmt, mail fehlt mir auch aber sendungsnummer steht auf der shopseite
Welche Bestellnummer hast du, die letzten 3 Zahlen reichen? Hab die 809 und steht immer noch auf Bearbeitung, vorhin schrieb ein User der die 808 hatte, dass seine Karte im Versand sei. Meine Bestellung ging gestern 14:28 Uhr über die Bühne. Ist ätzend, Cyberport und NBB haben storniert und bei Asus gehts auch nicht weiter. Hab jetzt mal den Support angeschrieben.
Nur Status in Bearbeitung thats it. Ich hab da ein Händchen wenn Pech und Unglück zusammen treffen 😂
873 aber das läuft alles willkürlich glaube ich. Je nachdem was sie da verpacken usw...da herrscht bestimmt Hochbetrieb. Ein Hoch auf die Mitarbeiter 🙏
Meine dümpelt seit gestern 20Uhr immer noch in DHL Krefeld rum.
Ist aber eine Strix.
ist wohl ein Trend LIFO Prinzip :fresse2:
Wo hast du die Infors her?
Würde die ja mal testen aber hab so meine Bedenken das es dafür ein Block geben wird.
Direkt auf deren Homepage steht folgendes:
Reign with the dominate 16384 CUDA cores, 22-phase power design and the all-new PCIe Gen5 16-pin connector, KFA2 GeForce RTX 4090 Serious Gaming
Ähnliche Themen
