[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
drück mal fünf mal die grüne taste, dann zeigt der LG an welche Auflösung ankommt und wie viele Frames
4096@2160P@120 RGB 12b 4L12
https://www.reddit.com/r/OLED_Gaming/comments/pgmq5x/lg_c1_w_3080_ti_showing_black_bars_on_sides/ hilft das vielleicht?
"This issue has nothing to do with scale size and proportion settings. If you set up to "fill" the screen or no scaling, image gets distorted as the driver thinks the panel is 4096x2160 native and don't actually send 3840x2160 pixels to the TV."
Das ist mal interessant. Warum ist mir das früher nie aufgefallen?
Also ich hatte letztes Jahr mein anderes Problem, wenn ´3840*2160 augweählt hatte kamen immer 4096*2160 an... ich hab dann einfach mal ddu im safe mode laufen lassen, treiber neu installiert und der Spuk war vorbei
Wahrscheinlich hat der Treiber da Probleme mit dem Pixel Shift des TVs, also wenn ich jetzt die Ursache "raten" müsste
Würde mich mal über Feedback zu dieser Karte freuen. Ich hatte damals die 2070 EX Super und die 2080 EX Super von denen und war echt begeistert damals, leise,kühl, kein Zirpen.
0:23: "+ 25% Airflow" "+50% Air Block" -> Ja wat denn jetzt ^.^
Hier haben bestimmt noch einige mehr ein HDMI-4K-120Hz Anzeigegerät.
Mir ist heute morgen aufgefallen, dass ich mit der Einstellung 3840x2160 rechts und links Balken am Desktop habe. Erst mit der Pseudo-Einstellung 4096x2160 die mein LG in den EDID-Daten hat, wird der ganze Desktop gefüllt. Keine Verzerrung, wird nichts abgeschnitten.
Ein weiterer LG-User hat das bestätigt
https://www.hardwareluxx.de/communi...bildschirm-hdmi-2-1-vrr.1246942/post-29503895 (und folgende)
Haben das von euch auch welche mit anderen Anzeigegeräten? Ein Treiber-Bug (was ich vermute)? Ein Feature?
Ich hab die Skalierung im Treiber gestern erst verboten (weil ich ganz gerne mal in 3840x1600 zocke in 21:9 wenn es das Game weiter bringt), wahrscheinlich ist es mir deshalb nicht vorher aufgefallen.
Hab ich bei meinem LG 55NANO889PB nicht.
Habt ihr das auch, wenn ich HWInfo64 starte, fällt bei mir immer das RGB Licht an der Karte aus?
pixel shift hab ich aber auch an
Heißt ja nicht, dass das Problem bei jedem auftreten muss, evtl ist es auch eine Kombination der Treiber Settings und dem Shift... da gibt es ja genug Konstellationen :d
7.30? nutz mal die Beta... 7.30 blockiert gerne Zeug, u.a. Temp Sensoren :d (bei mir is der CPU Temp Sensoren "hängen geblieben", hat die Beta gefixt)
Ja Spuprim RGB Sofware habe ich immo gar nicht drauf ....
Zum Thema Spulenfiepen bei den MSI Karten: Könnte man deren Werbung mit besonders leisen neuen Spulen dahingehend auslegen, dass starkes Spulenfiepen einen Mangel i.S.v. 434 Abs. 3 Nr 2b BGB darstellt? In dem Falle müssten die Händler nacherfüllen: Werde das zumindest mal bei NBB versuchen …
Die werden dir eins Husten... aber beschäftige mal ruhig den Support, denen ist bestimmt total langweilig und freuen sich über solche Fragen. Aber hey, wer nicht wagt, der nicht gewinnt...
Naja das ganze hat etwas mit Rechtsauffassung und Auslegung der werbeäußerungen der Hersteller zu tun. Wirbt jemand in der Vertragskette mit bestimmten Produkteigenschaften hat er auch für diese einzustehen. Da unsere Gerichte sehr Verbraucherfreundlich sind hätte bei einer Weigerung eine Klage durchaus Aussicht auf Erfolg. Das müsste nur jemand einmal durchziehen bzw. seine Rechtsschutzversicherung damit bemühen, da lässt mir nur mein Studium keine Zeit für
das will ich ja gar nicht bestreiten... aber zum einen kann das Produkt auch so problemlos zurückgeben innerhalb von 14 Tagen und zum anderen, ist dann nicht der Hersteller in der Haftung?
Nein, so lange der Händler sich nicht exkulpieren kann, nichts davon gewusst zu haben, steht dieser mit in der Haftung. Problem ist ja, dass ich für 2.000€ keine neue Gaming Trio bekomme. Zumindest nicht direkt. Deshalb ist für mich die Nacherfüllung die interessantere Variante.
Wo habe ich das denn erwähnt?
Mein höchstes war „nur“ +1700 MHz. Siehe https://www.hardwareluxx.de/communi...handeln-sperre.1323338/page-360#post-29500611
Aussage gegen Aussage. Ich kann ohne Probleme einen run machen mit Handyvideo. Und du willst nicht. :)
Belassen wir es einfach dabei und sehen was Futuremark für ein Statement abgeben wird 👍
Viel Glück weiterhin beim Benchen
Ja mach mal das Handyvideo bei +1700 spannend das du keine 100MHz mehr hast wie ich und ich es mit +1575 laufen lasse.
Du musst aber nicht, weil ansich ist mir das Wurscht …
Haken dran und gut…
Dem Statement von Futuremark sehe ich gelassen entgegen. Weil da eben nix ist was ich getrickst habe.
Ich wünsch Dir auch Glück beim Benchen, ich glaube du kannst es mehr brauchen als ich …
Die nimmt der Hermes Fahrer xD
Ähnliche Themen
