[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Ich hab seit gestern das bequiet Kabel drin und seitdem leuchtet die rote LED der Asus TUF nicht mehr wenn der PC heruntergefahren wurde ! 🤷🏼‍♂️😳 Möchte uns diese LED etwas mitteilen, und wenn ja was ? 😅
Ich hab seit gestern das bequiet Kabel drin und seit dem leuchtet die roten LED der Asus TUF nicht mehr wenn der PC heruntergefahren wurde ! 🤷🏼‍♂️😳 Möchte uns diese LED etwas mitteilen, und wenn ja was ? 😅
das würde ich auch gern wissen. meine tuf leuchtet auch wenn der rechner aus ist
Aloha zusammen. Ich habe mir eine Zotac 4090 sichern können. Nun habe ich noch ein 1000w Netzteil liegen, welches ich gern für die Karte verwenden möchte. Dieses NT hat allerdings nur 3x PCI-E Kabel beiliegen. Der Anschluss der Zotac Karte benötigt allerdings, im Gegensatz zu anderen Karten, nicht 3, sondern 4 8Pin Anschlüsse. Glaubt ihr, ich kann eines der Doppelkabel, also 1 PCI-E Kabel mit zwei 8 Pin Anschlüssen verwenden, oder sollte ich mir ein viertes Kabel nachbestellen?
Man kann eigentlich die 3x8-Pins ohne Probleme nutzen, nur ist die GPU dann auf 450W gelocked. Laufen tut sie ganz normal, nur gibt es kein OC.
Wenn du ein gutes NT hast welches 300 Watt statt die 150 Watt mindest über so ein Kabel jagen kanngeht das!
Ja wenn der Pc aus ist gibt es keinen Strom, ergo Lampe an. Stimmt doch alles.
Die GPU wird ja noch über den PCI-E-Slot mit Strom versorgt, deswegen gibt es Strom für die LED. Um das zu ändern, müsste man es im Bios umstellen. Es gibt Einstellungen, bei denen das Mainboard auch nach dem Abschalten des PCs 5V und 3,3V abzeptiert und man so z.b. das Handy über USB laden kann.
Wie sind die Erfahrungen bis jetzt mit der Phantom? Habe eine ergattern können und hoffe, dass die Spulen leiser sind als bei der Gaming Trio. Wie sehen da bis jetzt die Erfahrungen aus? (knapp 400 Seiten sind sehr viel, gerne auch als PN)
Die Karte läuft auch mit 3 PCIe. Du bekommst nur nicht die vollen 600 Watt.
@SH
Kannste nochmal bitte was über die KFA2 berichten. Temps, Geräusche, Qualität, Takte etc.? Hast du vielleicht Bilder oder ein Vid in Action?
Die non GS ist auf 450W begrenzt. Spulenfiepen angeblich nicht vorhanden aber dafür komische Lüftergeräusche wenn es nicht nur ein Defekt einer bestimmten Charge war. Ansonsten scheinbar solide. War in meiner engeren Auswahl aber aufgrund der Lüfterthematik habe ich sie vorerst gestrichen.
Er hat gestern 2 Videos angehangen und die Karte schon verkauft
Oh hab ich wohl übersehen. Dann schau ich Mal zurück.
Also Vids oder Bilder von der Karte hab ich keine gefunden.
max. PL 510W
Kein Coilwhine, leise Lüfter. Mem Takt bis zu 1800Mhz. GPU/Mem Temps wären noch interessant.
Bis jetzt gab es nur zwei 4090 FE Drops in Europa oder habe ich einen verpasst?
Ich bin mir sehr sicher, dass sie die FE mit Absicht in so geringer Stückzahl auf den Markt bringen.
Zum einen um den Hype auf das Produkt zu fördern und zum anderen, damit sie die Boardpartner nicht ganz vergraulen. Vielleicht wollen sie sich zwar langfristig von diesen lösen, jedoch sind sie momentan noch auf diese angewiesen, weil sie die alleinige Produktion noch nicht stemmen können.
Und die FE bietet einfach das beste P/L Verhältnis.
Wenn die FE gut verfügbar wäre, dann würden die Boardpartner sicherlich auf einem Großteil ihrer Karten sitzen bleiben.
Hab die Kampagne auf Veteran fast durch und die Grafik ist durchweg scheiße, weil die Beleuchtung einfach Mist ist.
Irgendwie hab ich MW2019 mit Ray Tracing Effekten in besserer Erinnerung.
Aber ja 4090 langweilt sich auf 1440p 21:9 selbst mit Undervolting auf 0,875v.
Die 3090 hätte das nicht mit durchgehend 120 FPS gestemmt.
Echt ne geile Grafikkarte.
Wus? Das Game soll eigentlich hübscher sein. RT war in MW 2019 nur Schatten RT. Hmm naja ich warte eh bissl ab. Will eigentlich eh nur die Kampagne einmal durchspielen.
RT GI ist 10x sinniger als reflections.
einmal den unterschied gesehn was GI ausmachen kann, dann sieht man jedem NICHT RT spiel die schwäche an :d
Joa da achtet jeder auf andere Details :-) finds ganz stimmig bis auf paar matschig Texturen.
Mit den 120 FPS gebe ich dir Recht, gerade Amsterdam war sehr heavy für die 3090. Würde mich sehr interessieren ob die 4090 200 FPS+ hält mit maximal Details.
@WilliWonka Danke für die Bilder! Schaut gut aus. Hast du vielleicht noch ein von der Rückseite des Kühlers bzw. den Kontaktflächen zum Chip gemacht? Ansonsten viel Spass beim Zusammenbau und halte uns auf dem Laufenden. Gerade auf die Ram Temperaturen bin ich sehr gespannt, die sind bei meiner TUF z.B. nicht so toll.
@ralle_h
Telegramm Benachrichtigung buggy für die Phantom von Alternate? Bei mir wirds sie ständig als nicht verfügbar angezeigt.
Wenn jetzt @Dampfkanes noch auf Wasser umbauen sollte und bestätigt das es sich um ein Ref Design handelt wäre die SG auch mein favorit
Die Karte ist zu 100% Ref, trifft bisher nur auf kfa2 und inno zu, die PNY ist etwas länger als Ref
Ähnliche Themen
