[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
In über 10 Jahren hat das nie geklappt. Ist und bleibt echt ein Mythos ^^.
Wüsste auch nicht, was elektrotechnisch sich bei den Netzteilen untescheiden sollen ... außer vill. die Restwelligkeit.
Mach mal nen 300 Watt Netzteil da fiept dann nix mehr sondern der Rechner geht direkt aus vor dem fiepen 😂😂
Bei Ebay Kleinanzeigen verscalpt tatsächlich ein gewerblicher ne FE. Jemand Lust das Ding zwei Wochen zu testen und dann zu widerrufen? :P
Wir können ja reihum jeder hier mal testen und kurz vor Ende der 14 Tage jeweils zurückschicken :fresse2:
könnte mir vorstellen das caseking das bald mit aufnimmt
hab mir aber erstmal ein 3x8 auf 12 geordert (450w sind ja mehr als ausreichend) um den adapter loszuwerden.
nebenbei noch ein custom coiled keyboard cable
da ich das keyboard cable komplett konfiguriert habe gehe ich von mitte november aus
Dachte ich mir auch. Oder immer bestellen, 7 Tage bei DHL liegen lassen und dann zurück gehen lassen. Kostet uns nichts und der Scalper hat seine Freude :)
dachte 150W pro Kabel?
Nur mal ne Frage zum besseren Verständnis, wir reden immer nur von bis zu 150 Watt oder bei den neuen NT von bis zu 300 Watt je Leitung oder? hab das neue ROG Thor mit 1200 Watt liegen, das beiliegende 16 Pin geht nur auf 2 PCIex, dürfte also 300 Watt je Kanal drücken. Cablemod bietet nur 3 oder 4 Pin an, sollte kein Problem sein oder grille ich damit die Karte?
Auch die jetzigen NT liefern sogar meistens über 300W pro 8-pin buchse nur das Kabel muss das halt aushalten. Daher geht theoretisch alles 2x 8 pin, 3x 8 pin und 4x 8pin adapter.
Hallo zusammen,
heute kam meine am Freitag bei Saturn bestellte Gigabyte 4090 Gaming OC 24G. Meine Erfahrung bezüglich des Geräuschpegels deckt sich mit den anderen Berichten: Kein bis minimales Coilwhine. Für mich überhaupt nur wahrnehmbar vielleicht bis 30cm Abstand bei offenem Gehäuse bei den üblichen Kandidaten wie z.B. Firestrike. Bei Furmark nur mit Ohr an der Karte. Überhaupt kein Vergleich zur TUF OC. Die war z.B. bei Furmark in 2 Metern Abstand durch das geschlossene Gehäuse wahrnehmbar.
Ich hab ein Problem mit dem Adapter. Das habe ich irgendwo bei Willi Wonka gelesen. Auf einmal flackert das Bild und mein Dell AW3418DW schaltet auf 85 Hz um. Wenn ich den Adapter etwas biege dann gehts wieder...aber hilft auch nicht immer. Betrifft nur Displayport 1. Im triple screen für Simracing geht's wieder...komische Sache.
Kann natürlich auch ein Displayport Problem sein. Trat erst auf als ich den 34 Zöller grade dran hing. Hm...
Probier mal den von deiner anderen Karte, wie verhält es sich dann?
Das meinte ich. Muss ich mal schauen. Die andere hab ich hübsch eingepackt. Die anderen Displayport funktionieren ohne Probleme. Der erste jetzt auch wieder...hm mal beobachten das ganze...
macht bitte alle hier mit:
Can man irgendwie im MSI Afterburner moar als +2000MHz auf den VRAM ballern? Ich schaffe keine Bildfehler/Abstürze bei +2000MHz. ^^
Hm? Es sind ja +2000MHz applied. Ich würde aber lieber noch moar einstellen, zB +2250?
Steigt den die Leistung beim Benchen weiter also more Points bei 2000?
+ 2000 wäre aber abartig viel so was gab es hier noch gar nicht oder ?
Nein, die Leistung steig ab 2000 nicht weiter an. Wenn ich in Afterburner zB 2250 eingebe und Enter drücke, m8 das Teil sofort wieder 2000 draus. Auch wird dann korrekt 25000MHz in den Programmen angezeigt.
ECC ist tatsächlich off.
Dafür scheint die GPU eine oc-Krücke zu sein. :cautious:
Beim anderen Kabel das gleiche. Ein bisschen wackeln am Displayport hat es vorerst behoben. Toll ist das nicht. Naja mal beobachten ob es weiterhin auftritt. Da könnte man schon wieder ausrasten...
