[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Ich bin da sehr optimistisch. Montag kurzer Anruf bei Alternate und gut ist. Die Lüfterdrehzahlen kommen ja ohne Eingriff vom VBios. Es kann gut sein das die unterschiedlich drehen um Turbulenzen Bzw. Geräusche zu vermindern.
Beste Grüße
Alles Quark was du erzählst. Bei Auslandssendungen kommt es immer wieder zu Verzögerungen und Tagen, an denen sich das Paket nicht bewegt. Einfach mal locker bleiben. Kann man außerdem den Medien entnehmen, dass es aktuell zu Verzögerungen aufgrund des hohen Krankenstandes kommen kann.
Nope, nie Probleme gehabt und ich bestelle regelmäßig in DE, auc zu Coronazeiten. Ist das erste mal mit einer Verzögerung. (y)
Hoffentlich wird es schnell abgewickelt. Da drücke ich die Daumen.
Bei der Gigabyte Gaming OC drehen die Lüfter unterschiedlich von Haus aus oder...der eine mit 67% und der andere mit 70%. Dachte das wäre immer gleich im Afterburner @stock (es sei denn man hat ne eigene Lüfterkurve).
Ne. Die beiden Linken haben einen Controller und der Rechte seinen eigenen. Der ist auch ca. 100RPM langsamer.
gut er braucht die karte beruflich somit sind die aufpreise der händler weniger das problem denke ich
Beruflich brauchen ist etwas übertrieben. Ist ein guter zuverdienst. Im Geschäft haben wir A6000er Karten. Die kann ich Notfalls auch mal laufen lassen wenn keiner hin schaut :d. Und ich bin schon Schwabe das ich nicht unnötig drauf zahle :d
Bin aber froh nicht auf den letzten Euro achten zu müssen.
Beste Grüße
Ich konnt mich mal wieder nicht beherrschen ;) 2300 € über EKA.
ist doch halbwegs fair. billiger kriegt man ne suprim im handel auch nicht mehr aktuell :fresse:
bin auch sehr zufrieden. diese power als reserve zu haben ist super. karte bleibt leise, kühl und verbraucht die hälfte als die 3080ti
Nee, fand ich auch. Der Kollege hat mir sogar die Original Rechnung gegeben von MF über 2250 €.
Absolut okay der Preis. Ich werde wenn kein Austausch möglich wieder nach ner 1949er ausschau halten. Muss sich ja schnell bezahlt machen :d
Beste Grüße
Sorry war aufm falschen Dampfer. Ich würde eine Alphacol Eisbär nehmen :) Bei deiner Auswahl wohl am ehesten die Fractal Celsius.
@cHio Flasht du auf die kfa2 ein 600 Watt Bios oder glaubst das klappt nicht weil Referenz PCB?
Jetzt ist die Shice dann tatsächlich doch noch hoite gekommen. (y)
So groß ist die Karte gar nicht wie alle sagen, passt doch locker ins Gehäuse. :o
Die Verarbeitung der FE ist schon ziemlich edel. (y)
Die GPU selbst scheint aber eine Krücke zu sein, +150 und speedway kackt sofort ab. Erst +100 schafft nen run, dazwischen nicht getestet, stable wird wohl aber näher bei +100 liegen als bei +150. (Oder ich mache was falsch?)
3GHz wohl wahrscheinlich nicht mal mit Wakü möglich. (y)
VRAM bisher nur +1500, scheint stable zu sein. Mehr habe ich noch ned getestet.
Spulenfappen scheinbar unhörbar, auch dann nicht wenn ich mit dem Ohr an die Graka move. Muss aber noch mehr testen (=ein lästiges Game-Menü finden). Lüfter sind in Ordnung, kein Rattern oder was da auch immer beschrieben wurde?
Leistung ist natürlich abartig, kann nur den Kopf schütteln und facepalmen. DLDSR 2,25x (+DLSS wenn verfügbar) bei 3440x1440 als Grundlage überhaupt kein Thema für die GPU. Das ist ne kranke Shice, komme aber auch von einer 2080Ti.
richtige oldschool wakü aus 2008 :d
how much watt?
Meine Karte wird irgendwie ganz schön warm. GPU 79 Grad, Hotspot noch mehr :unsure:
Verbrauch? OC-Bios/Silent-BIOS? Lüfterdrehzahlen?
Nicht so geizen mit den Infos. ;) Dass der Hotspot höher liegt, ist normal. Das ist aber alles weit von kritischen Temperaturen entfernt.
Radi in der Front, Radi in der Seite. Sieht nach Brutzelhölle aus :bigok:
AIDA Stresstest ca 420 W Verbrauch. Beim daddeln aber auch über 70..Gaming Bios.... Glaube vorne am 420er Radi kommt zu wenig rein...Da musste ich umbauen..
Den Radi an der Seite musste ich rausnehmen, ist mit der Karte kollidiert^^ Jetzt only CPU Wakü...
Hier mal noch ein Foto wo die kleine "werkelt". Hab die GPU mal mit einem Pfel markiert :d
p.s. die Suppe ist nicht braun, sieht nur braun aus aufm Foto. Und ich hatte keine Lust zu entstauben. Das mache ich morgen vielleicht.
Mal eine Frage... Ist die Anzahl der Phasen wichtig für den Stock-Betrieb oder mit 60% PL oder UV? Bin in der Sache Laie...
fiepfrei ziehe ich 10x vor jedem oc. wenn die karte still ist sei froh. glaube jeder würde ne fiepfreie karte mit handkuss nehmen
jedes modell hat genug phasen. wenn du eh kein OC planst, ist es nochmal wurschter. bei gesenkten PT nochmal mehr. je weniger die karte nuckelt desto stressfreier für die versorgung.
würd ich mal schätzen
habs mit 1000€ + versucht, zahlt keiner für ne 3080ti.
unter welchen bedingungen hast du die getestet bzw beurteilt?
vollast denke ich mal auch bei 80fps?
die aufpreise sind ja bei der strix nicht zu sehen
das sind diese alibikarten damit man auf dem papier was zur uvp anbieten kann. anders kann ich mir diesen move nicht erklären
ja hab auch geschaut. Selbst die 3090 bekommst nimmer für 900€ weg
Würde das nicht verschreien, muss natürlich noch mehr Szenarien testen.
Ähnliche Themen
