[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Hehe sehr gut :). Mir hat das 7000d besser gefallen, da weniger Glas = weniger Staub wischen und mehr Luftdurchzug. Verbaue ausschließlich Noctua Industrials, daher ist mir das RGB nicht so wichtig :). Will reine Kühlleistung, wobei die 4090 (ähnlich wie die 3090 Ti) sowieso nicht so warm wird, wie meine 3090 davor. Ich weiß nur noch nicht, wie ich das GPU Stromkabel im 7000d verlegen soll. Denke ich lege es von der Rückwand durch den Schacht, welcher für eine SSD am Gehäuseboden gedacht ist, zur GPU. So sollte es am wenigsten knicken. Das Evolv X hat dafür eine Aussparung unter dem GPU Stromanschluss, was sehr praktisch ist.
Die Einsätze (Airflow / Glas) kann man ja auch separat kaufen.
Ich meine das war ein Video von GamerNexus, da hat er die verschiedenen Einsätze verglichen. Die besten Temps gabs mit Airflow in der Front und Glas aufm Deckel. Denke aber alles ist besser, als mein aktuelles Intertech 701. :ROFLMAO:
Kann es sein das die 4090 Strix Karten diesmal alle aus der Hölle kommen? Hab jetzt schon die 3e zurückgeschickt, die Geräuschentwicklung ist ja nicht zu ertragen... grauenvoll.
Was fürn Display hast du drin?
Habe schon paar mal überlegt so eins reinzuzimmern, allerdings sind (gefühlt) 90% der angebotenen Displays feinstes Chinesium (HW+ SW) und somit uninteressant.:o
Ist allerdings feinstes "Chinesium" aber in dem Shop nicht mehr verfügbar.
Ein Mechdiy 12.6 inch Aida64 Sensorpanel mit einer Auflösung von 1920x480 angeschlossen über Mini-HDMI und USB.
Das passende Template dazu habe ich mir selbst zusammengezimmert.
Da sieht man mal was fürn fetter Klopper die Karten sind. Die wenigsten haben so ein großes Case
Das stimmt. Wiegt auch so einiges. Mein darin verbautes System kommt auf ein Gesamtgewicht von 31,2 Kilogramm.
War bei 3090 auch schon so...
Mit Abstand die schlechteste Karte die ich da hatte
Tja ich hätte auch nie gedacht, dass ich eher eine Palit behalte als eine MSI. Aber das Fiepen bei der MSI war echt nicht mehr ertragbar. Und Geld gespart habe ich auch :ROFLMAO:
@jack3ss Meine 3090 Strix ist mit dem EK Kühler unhörbar...hatte wohl Glück.
Das "no performance loss" ist bissle ein clickbait, denn noch ganz interessant die Benchmarks
Sehr amüsant wie sich alle neue Kabel, neue Gehäuse kaufen müssen nur damit die häßligen neuen Ziegelsteine reinpassen 😂
Bei der nächsten Generation könnt ihr schonmal für nen Anbau am Haus sparen
Corsair 7000D aber das Kabel liegt leicht an der Geschlossenen Glastür an.
Bin aber Top zufrieden !
@ralle_h
Vielleicht kannst Du die beiden Links mit aufnehmen? Heute früh gab es wieder kurzzeitig Karten :-). Ich baue mir meine Frostbite selbst.
Ich werds mir mal anschauen. Viele Karten scheint der Shop aber nicht zu haben?
Hab Coolblue für alle 4090 hinzugefügt, nicht nur die zwei Karten. Keine Ahnung ob da noch mehr reinkommen oder nicht - kannst du ja vllt. besser sagen, wenn du den Shop schon länger beobachtest.
Hatte den gleichen Fehler mit meiner Suprim :)
RGB-Beleuchtung-Einstellung funktionierte nicht, stellenweise fuhr Windows nicht ordentlich runter oder ich hatte Start-Schwierigkeiten.
Hier die Lösung, ins Bios gehen und den TPM Chip aktiveren.
Am besten in Verbindung mit einem neuem Bios Update, würde es aber erst mal so versuchen (sofern das neuste, Windows 11 kompatible TPM-Setting vorhanden ist) Ansonsten wie erwähnt Bios Update
Alles aktuell und hat in meinem Fall nicht geholfen. Anscheinend geht das Controll Center nicht...hab ja nur ne Graka von Gigabyte. Was funktioniert unter Gigabyte Utility die Aorus Engine runterladen und darüber kann ich dann mit RGB Fusion(was wieder in der Software geupdatet werden muss) die Lampen an der Graka einstellen usw. Mit dem normalen Tool geht halt wie immer FW Update usw ähnlich dem Afterburner.
Kabel von Corsair oder Adapter ?
Mein Beileid übrigens . Was fürn scheiss..,
Da Bahnt sich nun also Fall Nr 4 an ( gibt sicher auch schon mehr nich jeder schreibt dazu ja gleich was ins Internet ) ... mal schauen wie es dann in weiteren 2 Wochen aussieht.
Ich gehe jetzt erstmal schlafen, bin bedient. Morgen schaue ich das Drama im Detail bei Tageslicht an.
Ohh man, echt bitter.. Tut mir echt Leid für dich. Am besten machst du auch gleich ein paar Fotos. Sonst heißt es immer noch, dass es "nur" 2-3 Einzelfälle sind. Der Stecker/ Adapter ist ein absoluter Fail und ein Sicherheitsrisiko, machen wir uns nichts vor. Wenigstens haben die Netzteile verschiedene Schutzmechanismen.
Hoffentlich ist der Schaden nicht zu groß. Echt bitter. Auf jeden Fall alles gut dokumentieren.
Vermutlich hat es nur den ollen Adapter und die Karte getroffen… dennoch scheiße.
Schmutz Teil!! Ich dachte der Rotz wurde bereits bei der 3090 TI verwendet oder vielmehr getestet, gab es da keine ähnlichen Probleme?
Wo gekauft?
Modell: ASUS TUF
Händler reagiert wie und braucht wie lange?
Sofortaustausch?
Bilder
Bitte echt einen eigenen Thread eröffnen, damit man das besser verfolgen kann.
Ja, bin vollkommen deiner Meinung !!
Ähnliche Themen
