[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Nein, Intel I9-10850K.
Ich habe das Bios Update nur gemacht, weil ich im Afterburner nur max 90% Power Limit hatte.
Jetzt habe ich danach 100%, aber ich kann nicht höher stellen und Benchmarks sind wie zuvor.
Das spricht dafür, dass er den vierten Anschluss nicht erkennt, dann wird auf 450W begrenzt. Hast du das Nvidia command Line Tool Mal befragt?
nvidia-smi.exe -q -d power
wie viele 8pin an der karte?
Der 90° Stecker von Cablemod wird das Schmorproblem auch nicht unbedingt lösen, aber zumindest verbessern...hoffe ich...Er wird aber definitiv Leuten helfen die wirklich wenig Platz bis zum Seitenpanel haben.
Dem Twitter-Kommentar nach zu urteilen (danke @KiLiK), soll das "Biegeradien-Problem" gar nicht so ausschlaggebend sein, sondern eher, wie der Stecker im Terminal sitzt. Macht ja auch Sinn, denn bislang waren ja immer (bis auf das eine Bild von PCI-SIG) Stecker angeschmort und nicht die (nur) Kabel.
Wie ich mir Leute vorstelle die grade ihre 4090 stresstesten:
Interessant was ist das genau und wo bekommt man es her?
Sollte jeder mit dem Treiber haben, irgendwo in System32 glaub ich (erinner mich Grad nicht an den genauen Pfad)
Ich habe seit gestern 4 8-Pin dran, aber laut dem cmd tool habe ich nur 450W.
Dann muss ich da jetzt nochmal ran.
450 reichen aber :)
Demnach ist also die "Halteklammer" zu lang? Naja sowas kenne ich von nachgebauten Patronen für Tintenstrahldrucker. Klammer zu lang = kein Kontakt zum Chip :d
Ich sage deshalb zu lang, weil man ja so meist so fest reinsteckt bis es klick macht... Beim "biegen" vom Kabel, während es schon montiert ist, könnte dieser bei einer zu langen Klammer ja auch wieder ein Stück rausrutschen.
Ich meinte mit meinem Kommentar ja nur, das der 90° Stecker von Cablemod nicht wirklich bei einem Biegeproblem hilft, dafür aber bei einem Platzproblem.
Die einzigen Kabel die ich derzeit als "Sicher" empfinde sind alle außer dem Nvidia Adapter :d
Könnt ihr mal schaun was ihr für Seriennummern habt. Ich hab meine gestern von Alternate bekommen und. Die Lüftergeräusche wie in dem Video oben sind schon heftig. Vom Ton her hört es sich bei mir genauso an aber bei mir wird es mit steigender Lüfterdrehzahl nicht lauter. Hab auch mal einzeln die Lüfter mit der Hand angehakten der Ton bleibt bei mir gleich. Auch im Leerlauf wenn man die Lüfter mit den Finger dreht keinerlei Geräusche.
Das bringt alles nichts. Einige User und ich haben schon am 15.10. über dieses Problem berichtet. Es gibt mehrere Threads dazu in Computerbase und bei Igors Lab und hier. Ein User hat hier auch ein Statement von Gainward eingestellt. Es sind aber nicht alle Karten betroffen aber doch recht viele.
Aber sollte ich damit beim Afterburner auch höher gehen können, als 100% ?
wenn die karte nen bios mit mehr al 450w hat ja, sofern du 4 kabel angeschlossen hast.
aber ich nutze auch nur 3 und dabei belasse ich es da ich die karte eh unter 80% pt betreibe und somit unter 400w
Und was bringt mir das wenn die Lüfter je nach Drehzahl ein noch viel unangenehmeres Geräusch machen als es die Spulen je könnten?
Mit deinen Ohren wärst du eigentlich echt ein Kandidat für eine ordentliche Wakü :d für die Gainward wurde aber m.W. noch kein Block angekündigt...
Am Ende liest der Afterburner auch nur das aus, was auch die nvidia-smi.exe meldet.
Aber die 450W reichen ja an sich auch, gut man hat vielleicht das Gefühl irgendwas funktioniert nicht richtig. Evtl limitiert die strix im quiet BIOS auf 450W? Die TUF lässt auch im quiet 600W zu
Es ist die Strix OC, also sollte sie ja mehr können.
Mein ganzes Problem ist nur das mir Leistung abgeht und da der Afterburner 90% angezeigt hatte, dachte ich das es da irgendein Problem gibt.
Ich habe beim Timespy zB für mein System Punkte, die ein gutes Stück unter dem vorletzten Platz ist.
Bei der Strix 3080 davor war ich im Mittelfeld.
Das Powerlimit nimmt er ja von den angeschlossenen Leitungen, oder?
Dann denkt er bei mir das nur 3 dran sind.
naja die karten im timespy sind alle massiv übertaktet.
aktuelles bios auf der karte und aufm board?
die karte zieht nur ab und zu in Regionen ab 550 Watt (meistens pegelt sie zwischen 300 und 400 Watt). an den FPS merkst du in vielen spielen keinen Unterschied. Aber ich kenne das, ich wollte auch erst die 600 Watt haben. DDU mal den Treiber weg installiere den NVidia treiber ganz neu und stecke die stecker fest rein, das sollte es tun. Ich nutze den MSI Afterburner. Am Netzteil Single Rail eingestellt?
ich habe heute Tarkov mit 30% power limit in 4k mit allen Details auf Ultra gespielt mit 40 - 50 fps ^^ Dank Gsync flüssig! 30% das ist 150 Watt quasi von früher ne starke Glühbirne.. 90% sind die 450 Watt damit bist du ja eh schon fast am limit. also kannst du erstmal in Ruhe zocken und die Tage mal schauen was es sein könnte.
@johnieboy
Echt krass, das tut mir leid für dich und auch Gainward aber scheinbar nehmen sie das Problem nicht ernst wie man in den E-Mails gesehen hat. Habe auch eine geschrieben und bis heute keine Antwort erhalten. Deshalb habe ich sie auch schon längst von meiner Auswahlliste gestrichen...
FFS Alternate :fresse:
gibts prolbem mit amd systemen und rtx 4090?
Ich nutze das 12VHPWR Kabel das beinem Seasonic PX-1600 beilag.
Hoffe das dieses sicherer ist.
Mein Netzteil hat anscheinend nur Single Rail.
Treiber habe ich gerade neu installiert, Kabel vorhin neu gesteckt.
Hab echt keinen Plan mehr.
was passiert wenn du von 4 einen abmachst?
Hast Du die Afterburner Beta drauf. Das muss doch bis 133% gehen bei Dir, unabhängig ob Du es nutzen möchtest. Ich würde auch den Afterburner nochmals komplett de - und installieren, sowie den Nvidia Treiber. Muss doch gehen normalerweise...und ich weiß das es einem keine Ruhe lässt, bis es funktioniert.
Genau deswegen habe ich das Video gemacht. Du hast eine Meinung und ich eine wissenschaftliche Analyse dazu.
Nach meiner wissenschaftlichen Analyse :unsure: komme ich zu dem Fazit das die Begrenzung des Power Limit mit gleichzeitiger Erhöhung der Spannung, GPU und Vram overclock die besten Ergebnisse erzielt.
9891 Speed Way, bei 75% PL bzw. maximal 338 Watt. https://www.3dmark.com/3dm/81150314?
Also fast 50 Watt weniger als bei deiner wissenschaftlichen Empfehlung und trotzdem noch mehr Score. Nur so meine Meinung ;)
Was ich etwas seltsam finde: Den neuen Connector gibt es schon seit der 3090 TI. Warum wird das jetzt gerade bei den neuen Karten zum Problem? Wir hätten zumindest schon seit April Meldungen hierzu hören müssen, oder?
Ähnliche Themen
