[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Als Beispiel kannst du hier sogar die 3090 Ti nehmen. Gleiches Kabel aber keine Probleme. Warum? Weil einfach weniger Strom benötigt wurde.
Interessant wäre, ob es wirklich das gleiche Kabel ist oder ob es doch qualitative Unterschiede gibt, z.B. Rohstoffmangel, höhere Preise, Gewinnmaximierung etc. geschuldet oder was auch immer (identischer Hersteller?). Man müsste mal ein 3090ti Kabel (am besten aus der Releasezeit der 3090ti) aufschneiden und vergleichen.
Oder hast du das schon gemacht?
Klar kommt auch mehr Strom dazu, 3090ti scheint es nur mit Dreizack zu geben (keine Ahnung, ich hab selbst nur ne 3090) und die Karten die hier abgefackelt sind, hatten alle augenscheinlich den Vierzack.
Laut Video von Igor ist aber u.a. auch die miserabele Verlötung - warum der Hersteller sich auch immer dafür entschieden hat - dafür verantwortlich, dass die Stecker / Karten abfackeln.
Dazu dann Anwenderfehler durch knicken und biegen.
So kommt eines zum Anderen.
Fazit für mich persönlich, der Adapter ist scheiße, sowohl optisch, als auch praktisch und ich hoffe dass die eine befriedigende Lösung für alle Be(nach)teiligten finden.
Jetzt mal ehrlich: die die hier irgendwie schon 7,8.9 Karten durchgetestet haben müssen doch checkout Bots benutzen. Gefühlt geht das ohne nicht mehr. Ausser natürlich bei den Händlern die eh schon extreme Preise aufrufen.
Ich hätte um 6 Uhr locker eine Strix kaufen können....aber 1. 2599€ ist überm meinem Budget das ich mir festgelegt habe und 2. die passt nicht in den PC...
Ich brauche meine FEEEEEEEEEEEEE
Und jetzt versuch das mal bei einer Karte bei MM oder Saturn. Es ist derzeit meiner Meinung nach unmöglich.
Habe heute bei einer 4090 FE quasi im Affekt zugeschlagen. Eigentlich wollte ich eine Asus TUF oder Strix haben. Meint ihr, dass die Custom Karten besser sind und sich es lohnen würde erstmal noch zu warten die FE auszupacken? Theoretisch kann man die ja noch 2 Wochen lang zurückschicken, falls man noch eine andere Karte ergattern kann.
Wenn du die nicht verscalpen möchtest und lieber ne Custom suchst, wirst du hier einige im Thread finden die ne FE dringend suchen.
Buildzoid hat eine kleines Video gemacht in dem er darüber spricht.
Die 3090Ti hatte eine andere Stromverteilung. Dort war der Stromfluss auf 3x150W getrennt, während die 4090 600W als ganzes nimmt.
Auch sollten die abgerissenen Pads nicht die Pin-Buchsen zum schmelzen bringen. Wenn ein Kabel abreißt erhöht sich die Stromstärke in den anderen Kabeln, aber die max 600W bleiben ja in den Pins gleich.
Ja wenn die Pads AUßEN abreißen, müsste ja mehr Strom durch die MITTE fließen und nicht die äußeren Pins abfackeln...
Es müsste also der Stecker an einer anderen Stelle schmelzen, da ja dann eher die Kabel heißer werden und nicht die Pins...
Gleichzeitig nutzt der Nvidia Adapter aber andere Buchsen wie üblich. Normal sind Buchsen die wie ein U dessen Enden umgekrimpt sind. Nvidia nutzt aber welche die wie 2 Cs nebeneinander sind.
Möglicherweise verbiegen die Buchsen vom Nvidia Adapter viel leichter als sonst und dadurch kommt es zu Kontaktschwierigkeiten, ergo erhöhte Temperatur bei den Buchsen/Pins.
Also genau das was die PCI-SIG Warnung gemeint hat....
Der Rat das Kabel in der Hand zu biegen und nicht wenn der angeschlossen ist, ändert sich dabei nicht. :d Der Rat wird sogar wichtiger...
Am Ende sind alles logische Schlussfolgerungen. Dennoch sollte man sowas einem Experten überlassen und keinen Youtuber oder mir... :d
Kann man eigentlich irgendwie noch unter die 700 mV gehen? Nur mit negativem Offset – aber dann bekomme ich ja nur den auf den originalen Boost Steps basierenden Takt, richtig?
Wie kommst Du überhaupt auf 700mV? Ich kann meine nicht unter 865mV undervolten. Mach ich was falsch? Neue MSI AB Version? Oder womit arbeitest Du?
Das möchte ich auch mal wissen. Meine Suprim geht nur bis 870mV, was sehr schade ist. Bei der 3090 Suprim habe ich die minimale Spanung von 718mV regelmäßig genutzt.
ja, mehr Strom war vermutlich auch nicht nötig. Meiner Karte lag auch nur ein Dreizack bei.
Kurze verständnisfrage. Wie ist das gemeint? Das die Karte unter 870mv nicht mehr läuft oder das du die Kurve in AB nicht auf 700 setzen könntest ? Denn ich könnte das tun bei mir, allerdings ist 700 das niedrigste was geht.
Same here. Telegram eingerichtet, Handy wird sofort bei Benachrichtigung gezückt. Bei MM uns Saturn Dauerangemeldet. Bringt alles nichts. Spätestens beim Checkout ist Schluss.
Kann mir das nicht anders vorstellen, als das bei dem Shop scalp-bots am Werk sind. Bei der 3080 damals hatte man ziemlich sicher eine Karte, wenn man es bis zum Checkout geschafft hat.
Nö, der Merkzettel-Trick sollte da eigentlich ziemlich hilfreich sein.
@WilliWonka
Wenn man die Kurve auf unter 870mV stellt gibt der Treiber der GPU trotzdem 870mV. Das hatte ich so auch in irgendeinem Video mal aufgeschnappt.
Der Merkzettel "Trick" funktionierte auch letzte Woche noch. Mittlerweile kannst du nicht mehr zum Bezahlen klicken. Selbst wenn der Button aktiv ist wirst du zurückgesetzt. Das Spiel geht so 3-4x und dann haben die Bots den Bestand weggekauft.
Ich habe sowohl Saturn als auch Media Markt schon angeschrieben mit der Bitte endlich mal ihren Shop zu härten. Es ist eine Zumutung.
Ich selbst halt mich im Moment zurück. Ich baue jetzt Case, Wakü und ggfs. auch noch CPU um. Und dann kauf ich evtl. im nächsten Jahr.
Ich hätte sogar schon Karten im Warenkorb, die dann wieder eingestellt wurden. Musste also nicht al den Schritt gehen und diese in den Warenkorb legen und könnte quasi direkt auf bezahlen drücken. Hat trotzdem nichts gebracht.
Bei der 3090 hatte ich damit eigentlich keine Probleme.
Ich werde mir kein No-Name Kabel von Amazon an meine 2000€ teure Karte stecken :fresse2:
also ich habe das Kabel von Moddiy für RTX 4090FE läuft einwandfrei...auch no Name...dennoch besser als das NVIDIA KABEL;)
Und den Moddiy Kabel hatte ich schon davor bei meiner RTX 3090FE und 3080 Ti FE.....KEINE PROBLEME
Moin, ich habe mal eine frage. Hatte vor zwei Tagen bei Gforce Ex. einen Exklusiv Zugang für eine Rtx4090 FE bekommen, natürlich bestellt. Netzteil habe ich ein BeQuiet Straight Power 11 (850W).
Aber da wie es scheint, die NVIDIA adapter der 4090 müll sind ist jetzt die Frage, ob es für das Netzteil ein Custom Adapter gibt.
Ja von beQuiet selber:
Ist aber Ausverkauft...
Man bin ich froh das bisher alle die ein Foto gemacht haben eine Karte wie Suprim, Strrix oder Tuf hatten. Alle haben den Vierzack Adapter. Gut das ich nur einen Dreizack bei meiner Karte habe. :banana:
In beiden Varianten ziehen die Karten @stock bis zu 450W. Das geht auch mit dem Dreizack.
Ja, bei Mediamarkt und Saturn gibt es absolut keine Chance. Und alle anderen Shops scalpen ja mittlerweile mehr oder weniger
Ist mir klar, aber es sind trotzdem keine Dreizack Kabel. Aber bei mir hilft diese Panikmache sowieso nicht. Ich mache mir da null sorgen. Da wird weder die Karte geschrottet noch brennt die Bude ab. Alles gut.
Hier scheinen ja manche einen Bot eingerichtet zu haben das direkt die Infos kommen wenn wieder einer ein Bild eines verschmorten Kabels postet. Jeder wie er mag.
Wäre sogar logisch, weil die 240 Watt nicht zu 700mv passen. Ich nutze 900mv und 2655 Mhz und brauche zwischen 220 und 270 Watt unter Last.
Ihr habt natürlich Recht, nur weil man etwas einstellen kann, heißt das nicht, dass es auch tatsächlich anliegt...
Dass der Verbrauch mit 2610 MHz in jedem Fall höher ist als mit 2280 MHz ist ja logisch – aber warum sollte bei 900 mV 2610 MHz stabil laufen und bei 870 mV nur noch 2280 MHz? Das wäre auch etwas krass.
Die 320 Watt bei 900 mV kriege ich auch nur, wenn ich Benchmarks mit Raytracing ordentlich aufdrehe. In normalen Games oder 1440p komme ich auch ohne Framelimiter nicht da ran.
Modern Warfare 2019 nuckelt in nativ 4K dann z.B. die 220-250 Watt...
Ähnliche Themen
