[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Plague Tale 2
Was Cyberpunk 2077 und MSFS angeht, denke ich wollen die noch die UI Bugs mit DLSS 3.0 beheben..
MSFS kann man ja auch schon DLSS3 in der Beta benutzten, funktioniert meiner Meinung nach phenomenal und natürlich der bisher einschneidenste Verwendungszweck für DLSS3
Von 85FPS einfach mal 140FPS ist ne nummer, und man fühlt es auch. Bei MSFS muss ich aber vsync über das control panel forcieren empfehlen, auch wenn die Latenz dabei verdoppelt wird
Flight Simulator kann DLSS 3.0 ebenfalls. War für mich sogar eines der besten Beispiele, da hier die CPU limitiert. War überrascht wie viel besser das Spielgefühl ist trotz der Tatsache, dass die CPU in detaillierten Städten nur ca 45 fps liefern konnte. Ein weiteres Spiel ist Bright Memory: Infinite. Das läuft jedoch mit DLSS 2.0 bereits mit 4k120 locked, von daher nicht so interessant. :d Vermutlich ist da DLSS 3.0 ganz gut für Leute mit 240hz Monitor.
Flight Simulator ist ein sehr interessantes Beispiel. Lt. nVidia gibt es hier zwischen der 4080 und 4090 kaum Unterschiede im Gegensatz zu den anderen Spielen:
Im Vergleich dazu wirken sämtliche RTX 3000 Karten wie von Vorgestern :fresse:
Nachdem ich das mit der Trio bei Reddit gesehen hatte, habe ich es mit der Suprim versucht.
Sie geht und war auch soweit drin aber ohne mit Dremel/Flex den Ausschnitt vorne am NR200P zu bearbeiten bekommst das Gehäuse nicht mehr zu.
Wie meinste nicht mehr zu? Hast du die Front abgeschraubt?
Oder nur das PCI-E Kabel... das problem ist mir klar :d
CPU Limit mit 12900k...
Ja mehr oder weniger.
Du musst es so machen wir der Kollege mit seiner Trio, die Verbindungsleisten von vorne nach hinten raus machen.
Dann kannst du die Karte einbauen aber Aufgrund der Länge von 336mm sowie der Stärke von 78mm stößt sie an der Front an.
Hab ich dir mal an dem Bild markiert:
Irgendwie lustig, wie man mit einer Produkteinführung so viele Unannehmlichkeiten schaffen kann :d
Als würden plötzlich Autos nur noch 1m breiter als bisher produziert werden und alle Menschen müssen eine Seite ihrer Garage einreißen...
Also es gibt durchaus die Situationen das bestimmte Autos nichtmehr in altertümliche Garagen passen. Auch wenn der Vergleich etwas hinkt. Denn das Problem ist ja nicht die Karte an sich, sondern der einfach nur Krasse Luftkühler der draufklebt. MIt Waküblock oder anderer Lösung ist das Thema direkt kein Thema mehr.
Najaaa das ist eine Trio und jemand anderes hat die auch ohne Mods einbauen können...
Bei der Dicke muss man vielleicht die Plastikclips für den Boden rausnehmen...aber sonst?
Aber auch deswegen will ich ja eher die FE haben :(
Haben andere auch nicht, aber finden immer eine Lösung. Adapterkabel knicken usw :d
Nene die TUF ist länger als der PC... :d
Ändert doch nichts an der Tatsache, dass die Karten, so wie sie released sind, offensichtlich für einigen "Stress" sorgen. Nicht jeder möchte Kühler abmontieren und die Karte umbauen, die man gerade für 2,5K EUR gekauft hat :)
Das PCB ändert sich doch nicht mit WaKüblock,sprich die Breite incl. Steckerproblematik bleibt.
Das weiß ich leider nicht wie der die Trio ohne Mod da rein bekommen hat. Von den Abmessungen her sind die Trio und die Suprim laut GH recht ähnlich.
Also die Plastikclips hatten jetzt eigentlich nicht gestört.
Bei mir lang und drückte die Karte die Front nach außen weg, die Verbindungsleisten konnte ich nicht mehr zusammenschrauben.
Edit: Wenn ich mir das Bild von der Trio im NR200P anschaue, scheint die Trio an der markierten Stelle kürzer zu sein:
falsch, man kann das Kabel ganz anders legen und muss weniger biegen. Ich habe meine Karte unter Wasser.
Ist ja schön das deine Karte unter Wasser ist,ändert aber nichts am Anschluss oder Biegeradius
Für alle, die keine 4090 bekommen haben und *echte* RT-Leistung bevorzugen: (und ganz ohne Brandgefahr)
DLSS 3 , da wird doch die Anzahl an FPS durch gerenderte Bilder zwischen 2 Frames gepush.
Schau mal ob du das ganze auch noch al Variante ohne DLSS3 findest, wenn es um die pure Leistung geht.
Das ist erst ab dem 31.10.2022 gelistet. Aktuell läuft beim Kabel der Timer runter.
Das ist leider nicht richtig. Nur der Adapter hat release date an diesem Datum. Das Kabel gibt es schon lange.
Welche CPU?
Verstehst nicht was ich meine, egal. Du hast recht.
Achso,erst liege ich falsch und dann hab ich recht....jungejunge
Das PCB endet mit dem Kühlerblock,wie bei jeder anderen GPU.Und damit bleibt der Seitenabstand und Biegeradius gleich.
