[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Cablemod kriegt es doch auch hin und das ist im vergleich zu nvidia ein Furz im Wind.
Das sollte für nvidia kein kunstück sein da innerhalb von wenigen Tagen Abhilfe zu schaffen wenn sie denn wollen.
Nvidia könnte mit cm in Kontakt treten und jedem 1 Kabel for free schicken der eins bestellt.
Das wäre die Ad hoc Lösung. Dazu müsste nvidia halt hergeben und die Eier haben und sich entschuldigen für den bockmist aber dass passiert sicher nicht 😆
Kunststück nicht, wenn denn die Lieferketten mitspielen. CM kann ja z.B. jetzt schon kaum liefern... Corsair verkauft 50 Adapter und ist dann wochenlang blank.
Ich glaube ehrlich gesagt nichtmal das Nvidia da viel macht. Klar haben die jetzt gesagt das ist Chefsache, aber das müssen Sie ja auch sagen. Die werden jetzt einfach einen Aufkleber auf die Verpackung der GPU oder vom Kabel machen das auf richtige Anwendung zu achten ist. Und eventuell auf Webseiten eine Info hinterlassen.
Das erinnert mich immer an den Fall mit der MSI Twin Frozr von der ich glaube Serie 900. Da haben manche den Aufkelber auf dem Lüfter so fest abgerissen das der Lüfter abgegangen ist. Da war am Ende auch nur eine Info auf der Packung das man bitte vorsichtig die Aufkleber abzieht.
Reicht ein 750W Netzteil (Be Quiet Dark Power Pro 11) erstmal für die 4090 mit einem i9 9900k? Steht eh bald ein Wechsel auf einen 7950X an, dann gibts auch ein neues NT, aber hab mich gefragt ob das wohl auch noch mit dem alten NT gehen würde
Klar, kein Problem. Mein System zieht komplett geradeeinmal 450-550 Watt (5900X, Asus TUF 4090) in 1440p in Cyberpunk (ULTRA/RT ON)
Ja, ist REF, aber es wird nicht alles abgedeckt. Der ALC Block ist also zu 100% nur für Inno3D
Siehe hier:
#28
Danke für den Link.
Hatte zwischenzeitlich im ALC-Forum etwas gestöbert, dabei hab ich den Beitrag von @X Cellence gefunden.
Vielleicht kann er dann etwas mehr dazu sagen.
Flight Simulator kann DLSS 3.0 ebenfalls. War für mich sogar eines der besten Beispiele, da hier die CPU limitiert. War überrascht wie viel besser das Spielgefühl ist trotz der Tatsache, dass die CPU in detaillierten Städten nur ca 45 fps liefern konnte. Ein weiteres Spiel ist Bright Memory: Infinite. Das läuft jedoch mit DLSS 2.0 bereits mit 4k120 locked, von daher nicht so interessant. :d Vermutlich ist da DLSS 3.0 ganz gut für Leute mit 240hz Monitor.
Meine Vermutung: Man wird auf ATX 3.0 Netzteile setzen für die neuen Karten, denn warum sollte man weiter mit einem Adapter rum fackeln, wenn die Netzteile verfügbar sind.
Ganz sicher nicht. Alle die jetzt eine 4090 haben betreiben diese mit einem ATX 2.X Netzteil und der allerkleinste Anteil wird sich ein ATX3 NT kaufen wenn das aktuelle NT ausreicht. Dasselbe gilt für die kommende 4080. Wir reden hier ja von mindestens 270-300€ für ein 1000W ATX3 NT! Die 4080 werden auch ganz sicher diesen Adapter beiliegen haben.
Soweit ich das gelesen habe, hat MSFS noch nicht das DLSS 3.0 Update.
Das soll doch erst im November kommen.
Evtl haben es manche im Beta Programm schon.
Hast du die SU11 Beta installiert? Wie sieht es mit den Instrumenten aus? Sind diese bei aktivierten DLSS ohne Schlieren ablesbar? Denn genau das ist ein brutal hässlicher Nebeneffekt vom aktuellen DLSS!!
Bei Cyberpunk haben auch manche schon das Update zum testen bekommen, aber eben noch nicht offiziell erschienen.
Genau, über den Xbox Insider Hub kann man das Update bereits testen.
Ja, habe ich installiert. Die Instrumente habe ich leider nicht genau beachtet und bin momentan auch ohne Karte also kann ich gerade nicht schauen.
Hast du nicht eine Clubkarte? Steht da nicht ne Nummer drauf?
Doch schon, aber diese Nummer steht nirgendwo auf der Rechnung, also bringt die ja Gigabyte auch nichts :unsure:
Vor allem hat sich die Club Nummer Dank des neuen myMediaMarkt Dings auch geändert gegenüber meiner letzten Bestellung:ROFLMAO:
Man muss aber schon etwas realistisch an das ganze rangehen, auch wenn es einfach ist das ganze auf den Adapter zu schieben. Es macht denke ich schon einen Unterschied wie man mit den Kabeln umgeht und was man mit der karte macht. Es ist schon ein Unterschied ob ich zwischen Karte und gehäusewand 10 CM habe oder nur 5 CM und auch ob ich die Karte auf Standard laufen lasse oder übertakten muss bis zum geht nicht mehr. Das sind schon auch alles Faktoren.
Man sieht ja sehr gut an den bisher unter 10 Fällen das keiner sagte was mit der Karte gemacht wurde. Man kann das schon etwas beeinflussen.
Ich hab meine FPS eh auf 60 Begrenzt
Mehr gibt mein Oled nicht her und meine aktuellen Games ziehen nicht mal annähernd 400 Watt
Ich hab den Adapter überprüft und bisher sind da keine Anzeichen für allerdings hat mein Kabel dennoch eine seitliche Biegung
Schau mir das Kabel nach der Arbeit nochmal an und überprüfe es
Solange werde ich das Glasfenster offen lassen bis mal Seasonic Vertex veröffentlicht
Habe gerade bei mir in den Bestellungen mal geschaut. Ich finde auch keine Kundennummer. Frag mal Gigabyte ob nicht ein Kaufbeleg oder sowas auch reicht, weil du dort einfach keine Kundennummer hast...
Irgendwas hat MM heute gegen mich. Jetzt komm ich immer bis zum letzten Schritt und dann darf ich nicht bezahlen :fresse:
Vielleicht von Interesse:
Hab ich mal zwei Bilder gepostet, von den beiden Netzteilen bzw. deren Steckern, die ich gerade da habe.
Hat jemand schon so ein Kabel von cablemod bekommen und kann da mal bitte ein Bild posten?
Meine 4090 FE von gestern ist jetzt gerade angekommen. Jetzt bleibt nur die Frage FE oder doch noch auf ein Custom Modell hoffen :(
Die Kabel sollten gut sein. Also sicherlich nichts verlötet was dann unter Zugspannung abbröckelt. Ich würde sie jetzt knicken und dann geknickt einbauen...
Das ist erst ab dem 31.10.2022 gelistet. Aktuell läuft beim Kabel der Timer runter.
Diese Frage kann dir keiner abnehmen. Das wirst du bei einer Investition von 2000€ auch selbst entscheiden müssen. Die karten machen allesamt einen ordentlichen Job. Kannst es ja von fiepen oder Lüfterlautstärke abhängig machen.
Also für mich wäre die FE die allererste Wahl. Nur leider werde ich da wirklich keine bekommen wenn ich sie nicht auf dem Sekundärmarkt für überhöhte Preise erwerbe. Also stünde FÜR MICH da gar keine Frage
Plague Tale 2
Was Cyberpunk 2077 und MSFS angeht, denke ich wollen die noch die UI Bugs mit DLSS 3.0 beheben..
Derzeit plane ich neben der FE irgendwie noch eine suprim oder so unterbringen zu können....wird knapp beim NR200P...da wird das untere Drittel nur GPU sein...
Alternativ vielleicht eine Gigabyte oder so...
Die sollen alle rein passen:
Btw kann einer sagen was für VRM/Powerlimit die KFA2 hat?
Ich hab ne FE und bin sehr zufrieden. Kann 600 Watt PT 133% ist von der Kühlleistung "OK" (andere haben halt mehr Volumen und halt 3 Lüfter, dadurch leiser). Ansonsten Overclock geht auch ganz gut. Sind oben mit dabei.
Schau halt ob sie Dir zu laut ist.. oder zu viel Spulenfiept. Verkauft bekommst die aktuell auf alle Fälle. Ich behalte meine, wie meine 3090FE .. die sind einfach echt Wertig gebaut und das Design gefällt mir.. was für den Adapter halt nicht gilt. :)
Bei der Auspackerlebnis, haben sie auf alle Fälle zur 3090FE zugelegt. :) Aber das sollte kein Grund sein 1949€ auf den Tisch zu legen. :d
Nachdem ich das mit der Trio bei Reddit gesehen hatte, habe ich es mit der Suprim versucht.
Sie geht und war auch soweit drin aber ohne mit Dremel/Flex den Ausschnitt vorne am NR200P zu bearbeiten bekommst das Gehäuse nicht mehr zu.
Ähnliche Themen
Antworten
6K
Aufrufe
392K
