[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Immer mehr User bekommen ihre ersten Karten. Ihr dürft nicht vergessen, dass die Verfügbarkeit in den USA um einiges schlechter ist als in Europa.
Daher kommen auch nun immer mehr Reports wegen dem Stecker. Ich kann mir gut vorstellen, dass wir noch einige Reports bis Ende nächster Woche sehen werden.
Nach diesem Wochenende ist NVIDIA gezwungen, ein offizielles Statement zu geben. Ich vermute auf Montag/Dienstag.
Nvidia wird sicher etwas machen, aber nicht so schnell wie viele erwarten. Ich gehe davon aus das es eine Tauschaktion geben wird für das Kabel. Aber das brauch einfach Zeit.
Nun ja zumindest könnten sie Mal ne Informationskampagne fahren....
Das ist eine ernstzunehmende Situation. Und nicht alle wissen darüber Bescheid.
Spiele die ganze Zeit normal, mit corsair kabel 12VHPWR habe da auch keine Angst
Was das Corsair Kabel angeht gibt es solche Fälle ja bisher nich bei den Fällen geht es rein um das von Nvidia beigelegte Apdater Kabel
wo Nvidia sich ja weiterhin weigert da offiziell Stellung zu zu nehmen und schadensbegrenzung zu betreiben bzw Offizielle Alternativen anzubieten.
Nvidia hat eben bei der Qualitätskontrolle beim Adapter Misst gebaut bzw wissentlich weggeschaut und nun müssen sie eben dafür Grade stehen aber noch tun sie das halt nich
aber zumindest haben sie sich ja schonmal dazu bekannt das zumindest mal zu untersuchen ... das is aber nur Schritt Nr. 1 von mehreren Schritten die sie nun eigentlich gehen müssen
Igors : ------------------------------------------------- Pauls Hardware :
Anhang anzeigen 809668--- Anhang anzeigen 809670--- Anhang anzeigen 809669
Genau da liegt das ja das Problem...Bei Igor sind die Litzen "scheiße" gelötet, aber dafür mehr Kontakt zu den Pads...
Genau diese Unterschiede entscheiden ob der Adapter in Rauch aufgeht oder nicht...Aber das sollte nicht sein.
Edit: Auch sehe ich nun mehr Deteils bei Pauls Hardware...die Pads sind keine Platine wie ein PCB (habe da Igor missverstanden), sondern ein Stück von der Pin-Büchse.
Bist du extrem ängstlich oder stark diszipliniert? 😀 wie kann man das teil nicht einbauen nachdem alle davon erstaunt sind?
Nun ja ich bin einfach nur vorsichtig und ja ich kann warten.
Wollte mir sowieso erst AMD's Vorstellung von deren RX 7900 XT/XTX Karten ansehen bevor ich mich komplett für die RTX 4090 entscheide und sie auspacke.
Ansonsten wird die nämlich wieder verkauft, was ich nicht hoffe.
Ich weiß, ich hab da so eine eigenartige Einstellung 😆 aber eigentlich war geplant bei AMD zu bleiben doch konnte ich es auch nicht mehr abwarten und der Reiz war zu groß eine zu bekommen, weil die nicht so einfach zu bekommen sind.
Und genau das wollte ich damit aufzeigen (y)
Es gibt unter den Nvidia Adapter eben Nieten und es kommt drauf an ob man so eine Niete erwischt oder glück hat ... Schlechte Qualitätskontrolle oder absichtliches übersehen seitens Nvidia.
Allerdings is der Adapter dennoch anfällig für seitliches biegen während er wohl hoch und runter biegen besser wegsteckt
Aber man sieht auch wie dünn die dieses Verbindungsstück is :
Es währe halt besser wenn jedes Kabel direkt in eine Buchse reingeht ( wie es all die Jahre zuvor ja auch war ) statt es so mit so einer "Verbindungsbrücke" zu lösen
da sie aber so dicke Kabelquerschnitte ( glaub 14 AWG wars ) genommen haben geht das da wohl nich anders .. aber ich bin auch kein Elektro Mensch und kann das nich
so direkt beurteilen aber meine bisherigen Kabel warn immer jeweils so aufgebaut : Ein Kabel = Eine Buchse ... nun haben wir aber eben 8 Kabel und 16 Buchsen bzw 12 oder sowas
Konnte denn Mittwochs außer @coldfingers sonst noch jemand eine Karte bestellen?
Ja @mawrat war neben mir einer der Glücklichen.
Konnte heute leider doch nicht anders als den Hermes Boten abzuwarten und zum Geburtstag meiner Schwägerin zu spät zu kommen. Zeitfensterangabe lautete 12:15 - 16:15 Uhr und er kam halt erst um 15:40 Uhr... naja Sie hat es mir verziehen auch wenn Sie keine Ahnung hat was da ankam :haha:
Also ich bin echt krass von der Foxconn (lila Aufkleber seitlich drauf) Umverpackung geflashed. Das geht mit dem bereits extrem wertig los und man muss ihn mit nem Aufziehband aufreißen. Seitlich wird der Karton dann aufgeklappt und die OVP ist noch in einer weißen edlen Folie wie ne Praline. Die OVP selbst hat auch auf beiden Seiten Siegel, sprich auch die ist nach dem ersten Eindruck nigelnagelneu! Hab noch nicht aufgemacht, da ich den 5800X3D, angekündigt für Montag, noch abwarte. Bei 359.- konnte ich leider nicht widerstehen, ja nen Tag später sogar um 10€ günstiger aber wurscht. Oh man schon lang nicht mehr so auf einen Einbau gefreut. Morgen muss ich erstmal mein Mainboard Bios updaten und den neuen AB saugen etc.
@webmi
Danke ;)
Und jetzt ein Bild für die ungläubigen Mobber :d
@dante`afk
die neue soll ja doppelt so schnell sein wie die alte :
Die wird in 4K Gaming sicher ähnlich sein zur 4090 vielleicht etwas dahinter ( was aber nich alzu schlimm währe ) die große unbekannte is halt Ray Performance und da wird sie glaub ich nich an die 4090 rankommen
sondern so in der mitte liegen zwischen 3000er und 4000 serie und dann is da halt noch AMDs FSR was auch noch verbessert werden muss und wo auch Nvidia Vorne liegt.
Auch wo die dann Preislich liegt wird interessant und AMD setzen ja auf die alten 8 Pin Stecker und die Verfügbarkeit is auch noch ein Punkt.
Jay meinte auch das manche Games vielleicht anfangs noch Probs haben könnten wegen dem Chiplet disign da eventuell die Games angepasst werden müssten
und dies etwas dauern könnte.
Es ist doch schon öfters geleaked worden, dass AMD mit der RAW Performance knapp an der 4090 ist, aber RayTracing um einiges schlechter sein wird.
Aber dafür wird wahrscheinlich der Preis um einiges besser bei AMD :)
@dante`afk
Schau dir mal FSR 2.1 an was Ghosting angeht Vorbildlich .
Und es würde mich nicht wundern wen AMD zu Framegeneration auch ein Gegenstück liefert!
Der nächste Fall.. Nummer 15...
3er Adapter übrigens, also NICHT der von NVIDIA beigelegte 4x 8Pin bei jeder Karte.
Wobei dieser Nutzer imho seinen Stecker nicht komplett eingesteckt hat:
Aus eigener Erfahrung weiß ich auch, das die letzten 1-2mm besonders streng gehen. Mir ists gestern selbst auch passiert, das ich ihn nicht vollständig aufgesteckt hatte.
Da frage ich mich: Wieviele der anderen Fälle fußen auch auf Anwenderfehlern?
Oder die Diskussion hier im Thread: Die Rastung würde kein Geräusch machen.
Meiner Erfahrung nach gibts sehrwohl ein "Klack". Wer das nicht gehört hat, sollte vielleicht mal prüfen, ob da nicht auch die letzten 1-2mm fehlen.
Jetzt kann man sich noch darüber streiten: Hätte nVidia /die Norm den Stecker so gestallten könnten, so das die beiden SENSE-Pins nur Kontakt haben, wenn der Stecker vollständig eingesteckt ist?
Würde dann ja wenigstens auf 450W limitieren.
  • Danke
Reaktionen: SH
Ich hatte ja jetzt schon paar 4090 eingebaut. Es gab immer ein Klack Geräusch. Ansonsten war der Stecker nie komplett drin.
Hier ist mal was neues:
Achtet mal in Paul's Video darauf, wenn er den hinteren Gummi Teil abschneidet, woher kommen die Fäden her?
Wenn der hintere Teil des Steckers unter Temperatur mit Gummi verpresst wird, drückt sich das flüssige Gummi teilweise bis in die Terminals rein und kann in seltenen Fällen eventuell die Innenseite des Terminals bis zum Ausgang mit Gummi verdecken. Deutet auf einen Produktionsfehler hin.
Wenn es ein Klack Geräusch gibt, dann muss der Stecker ja irgendwo einrasten. Wie bekommt man den denn dann wieder raus? Einfach rausziehen wird dann ja sicher nicht gehen, muss man da noch irgendwo drücken (den Stecker zusammendrücken vielleicht) um das wieder zu lösen? Wie sind denn da die Erfahrungen?
Ja man muss wie bei dem normalen PCIe Kabel Druck von unten ausüben, um es zu lösen.
Junge junge, hier geht's tatsächlich nur noch um diesen total blöden Adapter und es gibt einfach kein Thema mehr. Ich frage mich wirklich ob die 4090 Besitzer hier wirklich nichts anderes tun derzeit als mit ihrer 4090 im Netz nach Fällen von verschmorten Adaptern zu suchen oder nach Videos ob das nun klack machen muss beim einrasten des Steckers oder nicht. Echt übel wie sich dieses Thema entwickelt. Und eigentlich noch viel übler das es von Menschen befeuert wird, die nicht mal eine 4090 besitzen.
Bin echt mal gespannt wo wir hier heute Abend stehen. Ob es weitere 50 Seiten sind wo es um die Inkompetenz von Nvidia und um die dummen Adapter geht. Oder tatsächlich mal wieder über die 4090 gequatscht wird. Denn der Adapter hat eigentlich sogar einen eigenen Beitrag.
Wäre nett von dir beim Erhalt der Karte kurzes Feedback zu geben, ob es Neuware oder ein durchgenudelter Rückläufer ist.
So hier mal mein kurzes Feedback. Habe die Karte auch gestern bereits erhalten, ging echt schnell, Respekt!
Der Karton war auf beiden Seiten zugeklebt, gehe davon aus, dass es sich um sie originalen Aufkleber handelt. Die Karte selber ist auch sauber in der Folie eingepackt, auch hier wurde das Siegel noch nicht geöffnet. Auch der Vierzack ist noch original verpackt. Gehe davon aus, dass es sich hier definitiv um Neuware handelt. Für mehr hatte ich noch keine Zeit.
Mal von der Adapterthematik abgesehen, wenn ich die anderen Berichte zur KFA so lese, hab ich eigentlich schon keinen Bock mehr!
Warum genau hast du keinen Bock mehr?
Wundert mich das so wenige Leute darüber teilen wie ihre Karte läuft . Was die OC packt .
Kommen meistens nur paar wenige mit einer Perle um die Ecke .
Auch du @WilliWonka hast wenig Infos über deine Karte in Verbindung zu deinem Wasserblock gepostet .
Ne stattdessen heulen alle über Spulenfiepen rum . Habe Spulenfiepen seit der GTX 275 und bin seit GeForce 2 dabei . Also weiß garnicht warum das immer wieder thematisiert wird…
Was halt komplett falsch ist. Es gab 5 Beiträge mit Bildern, 3 Mit Feedback und dazwischen noch welche Mit Screenshots bzgl. Temperatur. Mehr gibt es dazu nicht zu sagen. Ich bin mit der Karte im Alltag angekommen.
Mich würde mal interessieren ob der Fan für die Backplate bei der KFA 4090 tatsächlich einen messbaren Effekt hat.
Ähnliche Themen
