[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Jetzt mal ohne Spaß. Ich bin sehr froh dass jetzt wirklich interessante Titel mit aufwendiger Grafik kommen werden wie Dead Space Remake, The Callisto Protocol und Resi 4 Remake. Sonst wäre der Kauf meiner 4090 echt etwas sinnlos geworden.
Das sind die Spiele, die eigentlich die Graka nicht fordern werden. Das wird auch locker Ampere durchballern können.
Interessanter sind: Witcher 3 Rezastered. STALKER 2. Atomic heart. Cyberpunk 2077 nächster Patch. Portal RTX. Und wahrscheinlich noch 8 andere die uns gerade nicht einfallen.
Ich sage das. Du kannst ja das Gegenteil beweisen. Andere Käufer dürfen auch testen, das steht jedem frei. Man steht sich nur selbst im Weg rum. Das Übliche halt.
Ich wollte dich nicht Fronten. Es ist auch ok, wenn du damit leben kannst. Aber das Thema ist damit nicht durch.
Ich bin echt niemand, der irgendwas aufbauscht. Aber ich glaube nicht, dass mehr als die Spitze des Eisberges bekannt ist. Es wird sicher einen Austausch geben. Und derzeit wirkt es so, als sei das absolut notwendig.
die Gesamtdiskussion hier ist sicher übertrieben. Aber das viele User im Ergebnis das Powerlimit reduzieren und damit die Gefahr verringern, ist ein echter Mehrwert.
hoffen wir mal das witcher 3 wirklich ein Next gen ist.....Remastered sind einfach total lächerlich.....da muss man mit Lupe suchen.
Remakes sind natürlich klasse aber einfache Remastered vollkommen Sinnlos.
Ich erwarte schon mehr als nur Beleuchtung, Spiegelung und bissl Texturen.
EDIT: Es gibt also verschiedene Ausführungen der Adapter.
Man kann rausfinden, welchen man selbst hat, wenn man vorsichtig die Ummantlung unterhalb des Steckers entfernt und den Sleeve bei einem Kabel vorsichtig etwas runterzieht.
Bei Igor stand 150V auf dem Kabel, GN hat nur welche mit 300V, bei denen die Probleme nicht auftreten, weil sie besser verarbeitet sind (bei min 25:40)
Ob da jetzt 150 V oder 300 V steht ... das Vertrauen in diesen Adapter ist hinüber.
Habe da jetzt keinen Unterschied gemacht zwischen Rezastered, next gen usw... Ist für mich irgendwie alles das Selbe. Im Endeffekt zählt ja das, was da reinkommt ins Spiel und das wird bei Witcher 3 sicher ziemlich dick werden mit raytracing. Portal RTX genauso. Steinzeit engine, aber einfach 1 extra bounce pro pixel einfügen und schon haben wir 4fps auf der 4090. (y)
Wenn ihr eure 4090 mal so richtig knechten wollt :banana:
Ohne DLSS natürlich ;)
Can it run Doom RTX ... Yes die 4090 kann das sogar ziemlich gut
Installation ist ganz einfach, falls ihr Doom habt, einfach die doom.wad in den entpackten Ordner einfügen und starten
nochmals für die jüngeren
iddqd und idkfa im Spiel eingeben --> frohes Testen
Frostbite Review…
400w sind als Max PT einfach zu wenig.
Das gleiche war meine ich aber auch bei der 3090.
Was mache ich denn dann mit meinem XFX Netzteil? Bis da ein speziell angepasstes Kabel kommt, kann ich wohl lange warten. Einen Ersatz für das Adapterkabel, das netzteilunabhängig ist, gibt es wohl nicht?
Frostbite Review…
Delta von 20K zwischen Wasser und GPU ist jetzt nicht wirklich so pralle.
Dass man schon 'ne Karte mit vorinstalliertem Block aufsetzt und dann das PL auf 450W beschränkt ist auch völlig Banane. Egal, wie viele da jetzt mehr brauchen oder nicht.
Ich habe die Erkenntnisse von Igor und Gamers Nexus auch noch einmal verarbeitet (5. Update): https://www.hardwareluxx.de/index.p...nge-biegeradien-sollten-vermieden-werden.html
In den vergangenen Tagen gab es eine gewisse Weiterentwicklung bei diesem Thema. Einerseits hat NVIDIA damit begonnen die defekten Karten einzusammeln. Dazu werden die Boardpartner gebeten sich mit den Kunden in Verbindung zu setzen, damit die Karten in das Headquarter von NVIDIA in die USA geschickt werden können. Dort sollen weitere Untersuchungen stattfinden.
Igor's Lab hat sich mit dem Stecker selbst und dessen Ausführung beschäftigt. Das Zubehör-Kabel scheint in der Ausführung fehlerhaft zu sein. Ein schlechtes Verlöten und zu dünne Folie, die Kontakt über die Pins herstellen soll, sind demnach der Grund für die späteren Schäden am Stecker. In der besagten Form liegt das Kabel als 3x 8-Pin- und 4x 8-Pin-Adapter den Karten bei. Kabel von den Netzteilherstellern sind somit zunächst einmal nicht mehr direkt unter Verdacht. Zwar gab es auch hier Qualitätsmängel, diese sind aber nicht direkt mit geschmolzenen 12VHPWR-Steckern in Verbindung zu bringen.
Igors Analyse scheint aber auch nicht allumfassend zu sein bzw. den Kern zu treffen. Gamers Nexus hat sich den Adapter ebenfalls genauer angeschaut und kommt zu leichten Differenzen in der Analyse.
So hat Igor die Masse-Seite des Steckers betrachtet, laut der Fotos häufig betroffen sind aber die Pins auf der 12-V-Seite des Steckers. Masse und 12 V Bereich des Steckers dürften aber gleich ausgeführt sein. Eine weitere Differenz in der Betrachtung zeigt sich am Adapter selbst. Die zuführenden Kabel des Adapters bei Igor sind jeweils für 150 V und 105 °C (14AWG-Leitungen) ausgelegt. Die von Gamers Nexus betrachteten Adapter haben Leitungen, die für 300 V (16AWG-Leitungen) ausgelegt sind. Uns liegen insgesamt fünf Adapter vor, allesamt mit 16AWG-Leitungen.
Es gibt hier also schon einmal größere Unterschiede im Adapter. Dies betrifft auch die Lötpads bzw. die Art und Weise, sie die Kabel und die Pins im Stecker miteinander verbunden werden. Während es beim von Igor analysierten Adapter sechs Pads für sechs Pins gab, die miteinander verbunden werden sollten, sind es bei den Adaptern mit 16AWG-Leitungen zwei Pads, die jeweils drei Pins versorgen und die vier Zuleitungen teilen sich zu jeweils zwei Leitungen auf ein Pad auf. Diese Konstruktion wirkt deutlich stabiler und besser verarbeitet.
Die Frage ist nun, wie sich die Verteilung der unterschiedlichen Adapter darstellt. Die Adapter mit den 300 V (16AWG-Leitungen) scheinen deutlich stabiler zu sein. Hier war es Gamers Nexus auch nicht möglich diesen durch zu enge Biegeradien zu beschädigen. Probleme mit zu hohen Temperaturen konnte Gamers Nexus ebenfalls nicht feststellen, selbst wenn die beiden äußeren der sechs Kontakte abgetrennt wurden und die Versorgung über nur noch vier Pins erfolgen musste.
Zum aktuellen Stand kann man also folgendes festhalten: Ohne ein komplettes Bild der bisher defekten Adapter zu haben, lassen sich kaum Rückschlüsse ziehen. Einen funktionierenden Adapter auseinandersägen und daraus eine Analyse zu erstellen, scheint kaum sinnvoll zu sein. Zunächst einmal scheint es sinnvoll zu sein möglichst viele defekte Adapter zu sammeln und sich anzuschauen, an welchen Punkten diese ausgefallen sind bzw. wo es hier zu den Beschädigungen gekommen ist. NVIDIA sammelt die defekten Karten bzw. Adapter und wird diese analysieren. Gamers Nexus will ebenfalls entsprechende Daten sammeln: Welche Adapter sind im Umlauf (150 V / 14AWG-Leitungen und 300 V / 16AWG-Leitungen)? Defekte Adapter müssen untersucht werden und nicht ausschließlich solche, die noch voll funktionsfähig waren. Natürlich können auch Analysen auf Basis funktionsfähiger Adapter gemacht werden, daraus aber finale Rückschlüsse zu ziehen scheint nur schwer möglich zu sein.
Womöglich wird es in den kommenden Tagen neue Erkenntnisse von offizieller Seite geben. Diese bleibt es abzuwarten.
Zur Frostbite . Delta 20 kelvin finde ich nicht gerade wenig . Karte scheint nicht so restriktiv, aber durchfließt nicht alle Bereiche sauber . Vram Temps hätte Roman mal gerade mit HWINFO auslesen können.
Igor wird da sicher auch einen Test machen.
Der wird sicher aufschlussreicher .
@WilliWonka : Welche Vram Temps hattest du max. bei welcher Wassertemperatur?
Finde rein optisch ist der Block von ALC garnicht so verkehrt . Ein acetal Terminal mit klassischen Stopfen hätten auch gut gepasst meiner Meinung nach , aber das ist Geschmacksache.
Ja vor allem freue ich mich damit mal Cyberpunk 2077 ordentlich spielen zu können. Bisher hab ich es gelassen trotz einer RX 6900 XT LC.
Ach ja und ich wollte mal endlich X2 Foundations anfangen. Mit der RX 6900 XT bei hohen 4k settings war das nicht so berauschend. Bin auf die 4090 gespannt.
Wenn man risikofreudig ist, könnte man versuchen, das KFA2/Galax 510W Bios auf die Inno zu flashen. Die sind vom PCB so ähnlich, dass es wahrscheinlich sogar klappt.
Kriege voraussichtlich die Woche eine Inno X3, vielleicht versuche ich es.
Aber am Ende macht es wohl keinen großen Unterschied.
Ach stimmt, da war ja was!
Dann sollte Serious Sam RTX jetzt ja auch ganz vernünftig laufen mit der 4090 - gab es auch mal einen Artikel auf PCGH zu:
mal ausprobieren die Tage :)
Warum die Frostbite 20K zwischen Wasser und GPU haben sol, verstehe ich nicht. Wenn ich mir die Inno3d X3 OC mit dem gleichen Block zusammenbaue sind das 9 bis 10 Grad weniger. Wieso ? Das liegt sicher nicht an der WLP. Irgendwas stimmt da nicht.
Bin auch gespannt was die Karte kosten wird. Wenn die über 2249€ liegt ist es fast günstiger die selbst zusammenzubasteln.
cabelmod wird aber auch dauern bis da was kommt , bei mir steht We are currently processing your order. The current estimated shipping date is November 17th, 2022.
ich habe bei meiner Suprim X das Problem, dass sich das Power Limit auf 93,8% stellt, obwohl als Default 100% stehen sollten. Das Maximum ist auch weiterhin bei 108,3% und ich kann den Wert mit Afterburner etc. anpassen.
Ich habe bereits Windows mal neu installiert und das Problem besteht leider weiterhin.
Außerdem habe ich geprüft, dass auch alle Kabel richtig sitzen, in dem ich nacheinander alle 4 Kabel mal einzeln abgeklemmt habe - in dem Fall blieb das Power Limit bei 93,8%, aber das Maximum wanderte auch von 108,3% auf 93,8%. Scheint also auch in Ordnung zu sein.
Hat jemand eine Idee, was das noch sein könnte?
und 15€ Versandkosten stehen bei mir. Kostet einfach mal nen knappen 50er :d Dann doch lieber morgen das Amazon Kabel für 20€
@gjn
Im Gaming BIOS hat die Suprim X 480W default. Deine 93,8% entsprechen also 450W ;)
Max sind es 520W bei 108,3%
Ah okay danke für die Info.
Leider finde ich dazu auf deren Homepage noch nichts. Weißt du zufällig wie man da rankommt? :d
Sehr cool. Hatte mit der 2080Ti vorher 30fps (mit OC), jetzt mit der 4090 sind es 70fps (ohne OC). (y)
der link für dich
msi-bios-update und suchmaschine nutzen
Ähnliche Themen
