[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
was n hier los...alle schon am pennen, cable gate schon vorbei?
Moin!
Hat jemand ne Idee wie ich den Bereich meiner Suprim X abdecken könnte? Hab etwas Bauchschmerzen direkt über dem CPU Block^^
Einfach Panzertape.
Eigentlich macht man bei einer Wakü eine Dichtigkeitsprüfung bevor man den Stromstecker ansetzt und zieht alle Schraubtülle richtig an und kontrolliert beim überziehen ob der Schlauch vollstänständig auf der Tülle sitzt.
Ansonsten nimmt man besser einen Luftkühlker. Außerdem wenn was nicht passt geht es meistens gleich beim Einbau beim Erststart in die Hose. Ich habe beim neuen System, nach etlichen Einbauten, mal nicht richtig geschaut und gleich mal das 200 Euro Netzeil unter Wasser gesetzt. Hat zusätzlich 5h Mehrarbeit bis um 5 Uhr morgens gekostet. Netzteil komplett auseinanderbauen und mit Alkohol reinigen und trocken wischen. Einen Stromschlag vom Netzteil gab es beim zusammenbauen auch noch gratis dazu (geladene Kondensatoren, feuchte Hände)
Jetzt ist zwar die Garantie vom Netzteil dahin, habe ich aber noch nie bennötigt. Hauptsache der 13900K mit samt der 4090 läuft.
Man ist immer gut beraten gleich beim ersten mal sorgfälltig vorgehen und es gleich richtig machen, sonst hat man meistens ein vielfaches an Mehrarbeit.
Gab doch bei CB einen Test zu Anfang.
Ne PCI E 3.0 16x reicht vollkommen.
2-3% Leistungsverlust max.
Habe selber auch noch PCI E 3.0.
Die Bandbreite hat sich teilweise gegenüber 3090 je nach Game schon verdoppelt .
Habe die Nutzung der PCI E Bandbreite bei mir im Overlay mit drinne .
Steve GN hat erst heute dazu ein Video gemacht.
Habt ihr eine Idee wie viel brutto Marge die Versender an so ner Karte haben? Natürlich bezogen auf den UVP.
Wenn dieser z. B. 2000,-€ ist, sind es dann eher 5%, 10% oder gar 20%?. Ich spreche nicht vom Gewinn.
Wird eher bei 5% liegen. Am meisten kassiert Lederjacke up. Da sollten 600-700EUR Marge je Karte drin sein.
Auf meine ASUS TUF werde ich wohl 1-2 Wochen verzichten müssen.
Ich habe die Bestätigung das meine TUF am Alphacool Send it in and get one cooler for free Programm teilnimmt. Die geht also morgen in den Versand nach Braunschweig, wird dort vermessen und auf dem 3D Abdruck meiner Karte wird eine Wasserkühler-Line für alle ASUS 4090 TUF und Strix produziert.
Klar habe ich jetzt etwas Aufwand mit Verzicht der Grafikkarte, aber dafür die ungewöhnliche Chance einen wirklich perfekt passenden Kühler für meine ASUS Karte zu bekommen.
Mein Nachbar arbeitet dort. (In Braunschweig) Nur ich bin voll mit Luftkühlung zufrieden (obwohl Pumpe und Wärmetauscher ist immer noch in Computer eingebaut sind. (Ich hatte mal 1080Ti SLI mit Wasserkühlung) Mein TUF schafft 225 /1400.
Ja das passt auch etwa dazu was ich selber sehe.
Auf jedenfall zb. CP 2077 waren bei 3090 7-15% Bandbreitennutzung von 3.0 16X
Bei der 4090 ging das auch mal bis 30% .
Bei PUBG ist die Bandbreitennutzung sehr gering bei beiden Karten.
Auf jedenfall geht bei der 4090 mehr Daten durch als es bei der 3090 der fall war .
Warhammer spiele ich selber nicht und zocke auch in 4k und nicht in 1080P.
Durch die bank weg kann ich sagen UHD bis 144 HZ kommt meine aktuelle Plattform mit 10900K und 4000er Ram gut klar in DX 12 games.
In DX 11 Games kommt die CPU noch sehr super zurrecht und der Verbrauch ist deutlich geringer.
Bei CP 2077 oder BF 2042 geht da auch mal die CPU mit der neuen Karte auch mal bis 150 Watt Verbrauch.
Aktuell sehe ich daher so , dass ich nicht wechseln muss.
AM5 fande ich anfangs recht interessant , aber bei den Temp Problemen und den mangel an X3d Version + paar Bugs bei den Boards ist das Interesse geschwunden.
Sockel 1700 ist nicht absolut verkehrt , aber überzeugt mich nicht 100%
Ich möchte daher auf Meteorlake warten und da einen Plattformwechsel machen höchstwahrscheinlich .
Direkt Storage sollte dann bis dahin auch mehr und mehr ein Thema werden , aber aktuell sehe ich da kein muss.
:bigok:
Ich hab an der 4090 meinen LG Monitor und LG CX65 und manchmal bugged etwas, wenn ich auf den TV will. Mit dem 2. Treiber war es katastrophal und ich musste neustarten, wenn ich zurück zum Monitor wollte. Zusätzlich lief MW2 mit flickering.
Dummerweise kotzen sich einige in den Steam-Wertungen mit einem negativem Review über dieses flickering aus. Dabei ist es ein Treiber-Fehler, den Nvidia bereits eingeräumt hat :fresse:
Besten Dank für die Erläuterungen!
Ich hab auch ein Problem mit meinem CX77, ich hab per cru 4L12 freigeschaltet. Mit der 3090 keine Probleme, mit der 4090 Bild Aussetzer.
Ich warte immer noch auf den Hotfix Treiber :hmm:
Normalerweise ist Nvidia schneller, was das angeht.
Bin froh, dass ich vorher noch von den Problemen gehört hatte bevor ich den Treiber aktualisiert habe. Paar Homies haben im CoD MP auch nur Probleme gehabt mit dem aktuellen Treiber. Ansonsten halt deinstallieren und vorherigen druff, bis der Hotfix für's Wurstbrot net da is.
Ich habe das Problem das im Windowsdesktop manchmal der PC einfriert, sich aber dann wieder fängt. Könnte natürlich alle mögliche sein. Aber gleichzeitig verliert der Monitor kurz das Signal und bereits geöffnete Fenster werden, nach dem nach wenigen Sekunden das Signal wieder kommt, nicht mehr richtig dargestellt. Darum vermute ich mal liegt es an der Grafikkarte und es sieht so aus als ob der Grafikkartentreiber abgestürzt wäre. Das System wurde neu aufgesetzt und ist somit noch relativ "Bug Frei"
Hat jemand ähnliche Probleme?
Ich nehme an, ohne Graka-oc?
Hatten wir Tech-Jesus schon? Mit PCIe 3-4-5 scaling mit der 4090?
Der Freak erst 😂
Müsste das hier sein. Entweder den Takt auf -105 im Desktop AB Profil einstellen; oder Höchstleistung im NV CP oder auf Treiberfix warten. Ich fahre die -105 im Desktop und hab seitdem weit!!! weniger Fehler.
Klingt nach dem Treiberproblem. Stell mal auf max. Performance bevorzugen.
*seufz*
Also keiner von euch hätte so eine Karte mit Spulenfiepen verdient deswegen habe ich sie ja auch als Defekt zurück geschickt. Schlimm ist wenn diese getestet werden und andere sagen die Karte ist okay…
Das Spulenfiepen kein technischer Defekt ist ist dir aber klar oder? Und wer bist du dass du die beste Karte von allen brauchst? Techjesus? So ein Kaufverhalten macht den Markt kaputt und führt dazu dass Händler die Preise anziehen müssen. Weißt du was für einen Schaden die Händler davon haben? Stell dir vor du kaufst 10 Karten beim selben Händler jeweils im Wert von über 2k und schickst die alle zurück. Der Händler verliert nicht nur seine Marge sondern muss die dann auch noch mit Minus geöffnet abdrücken an den nächsten. Und was eine Karte für über 2k können muss oder nicht ist rein subjektiv. Wenn du Probleme mit Spulenfiepen hast kauf dir eine KFA2 oder Inno oder Zotac, aber nicht 100 vom selben Modell wo von Anfang an klar ist das die Spulenfiepen haben. Das ist nicht nur wirtschaftlich verwerflich sondern einfach Dumm. Wie sagt man so schön: Dumm ist der, der immer wieder den selben Fehler macht und sich ein anderes Ergebnis erwartet
Also ich denke auch dass Coil Whine nicht als technischer Defekt im eigentlichen Sinne durchgeht. Der Hersteller wird nichts machen und der Händler wird auch nicht sagen "B-Ware wegen Coil Whine".
Ja, eine gewisse Erkenntnis erlangt man, wenn einer 7 Strix hatte und alle sind am whinen, aber naja... es hat ein Gschmackerl. Aber was willst machen? Man hat die Möglichkeit, also kann man das tun.
Moralischer Gruppendruck? Bitte nicht schon wieder ^^
Ich hab kein Problem damit wenn jemand seine Karte zurückschicken sollte die unerträglich fiepen. Aber im Vorfeld mehrere Karten zu bestellen damit man lein Leerlauf hat sollte die erste nicht passen halte ich für bisschen egoistisch. Denn wie andi sagt. Das ist ein Schaden für die Händler und für uns alle.
Das muss nicht sein, auch wenn derjenige in geld schwimmt. Andere tun das nicht und sind froh überhaupt eine Karte bei Release zu bekommen.
Oc Binning ja, aber erst wenn die Nachfrage gedeckt ist und nicht bei Release.
Vielen Dank für die geöffneten Karten.
Also solche Methoden sind ja nun bei Gott nicht neu. Sowas gibt es doch schon immer und überall in den Hardwareforen. Meines Erachtens sollte man da Thema einfach klüger angehen und von dem "Ich lass mich mal dafür feiern das ich 20 Karten kaufe und 19 zurücksende" Trip wegkommen. Dann ist das Thema direkt geklärt.
Wenn man sowas schon macht, auch wenn es Mist ist, dann sollte man es halt nicht unbedingt kommunizieren. Denn was keiner weiß, bringt keinen auf Puls.
Noch etwas zum eigentlichen Thema Hardware:
Wir wissen ja vermutlich alle das Spulenfiepen kein Defekt ist und auch Aussagen wie "dann bauen die hoffentlich bessere Karten" für den Eimer sind bei diesem Thema.
Klar hat man die Möglichkeit, aber dann muss man a) das hier nicht so breittreten und b) gibt es auch die Möglichkeit das so wie ein @SH zu machen, der dann die Karten zum EK im Marktplatz verkauft, so ist kein Händler geschädigt und ein User freut sich. Aber alleine das Argument kein User verdient sich Spulenfiepen. Jeder weiß dass gewisse Hersteller Spulenfiepen haben, wenn ich das nicht möchte meide ich den Kauf dieser Hersteller. Punkt. Und wenn es einer nach 8 Strixen immer noch nicht verstanden hat dass die 9te, 10te und 11te Karte dass auch haben werden, dann muss man einfach feststellen dass der Kollege nicht die hellste Kerze auf der Torte ist. Sorry
Ähnliche Themen
