[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Gibt es einen Beweis das NVidia da Kulanzunfreudiger reagiert oder ist deine Aussage nur Blabla?
nvidia verweigert explizit die Garantie bei Kühlerdemontage. Ich hatte nach knapp 2 Jahren nun 3 defekte 3090FE die auf Wasser umgebaut waren und in einem Server liefen. Bei 2 wurde die Garantie verweigert, 1 ist durchgegangen. Eine gute Quote sieht anders aus.
Haben die Karten ein siegel? Ich frag deswegen weil ich noch nie ein FE hatte.
@cHio
Und Du hast alle 3 Karten "sauber", so das man den Umbau nicht mehr gesehen hat, zurückgebaut?
Die Karten haben kein Siegel.
@cHio
Selbstverständlich. Aber wenn jemand ganz genau guckt, sieht man das der Kühler runter war. Spätestens wenn ein Support Mitarbeiter selbst dann den Kühler zur Prüfung entfernt und etwas Ahnung hat. Kann man nicht vermeiden.
@cHio
Genau deswegen habe ich nach einem Siegel gefragt
Ich weiß zwar NICHT wie die Gesetzlage ist, aber wenn kein Siegel auf der Karte ist was nach dem Umbau defekt ist. Würde ich gegen NVIDIA klagen, da sie mir erstmal beweisen müssen das ich die umgebaut habe.
Da die Karten aus 2020 stammen müssen die nach 6 Monaten (Beweislastumkehr) garnix mehr beweisen. Nur weil keine Siegel da sind, kann ein Hersteller die Garantie bzw. Demontage trotzdem ablehnen/verbieten.
Trozdem müssen sie dir einen Grund angegeben haben wieso sie die Garantie verweigert haben. Und da spricht entweder schlampiges wiederzusammenbauen auf uhrzustand hin oder wasser rückstände etc. Weil ein Hersteller auch Nvidia sagt nicht einfach NÖ machen wir nicht.
Grund = Kühler war runter. Damit ist die Garantie erloschen. Nicht so schwer zu verstehen oder? Und nein, die Karten waren einwandfrei zurückgebaut.
Du musst hier ned unverschämt werden. Mit deiner aussage "nicht so schwer zu verstehen oder"
Ist für mich kein Grund. Aber egal scheinst ja geld zu haben wenn du 3 3090 schrotten kannst und dir das gefallen lässt.
Du hast ernsthaft 70 Euro inkl Versand für diesen adapter abgedrückt?
Ich hab ein offenes Gehäuse das direkt auf meinem Schreibtisch steht. Ein schwarzes kabel würde die Optik zu nichte machen. Ein neues Netzteil kommt nicht in Frage da das aktuelle 1300w liefert und erst ein Jahr alt ist.
Bei Chio weiß man doch dass er Geld hat :)
Ist zwar nicht der Händler meines Vertrauens, aber sei's drum :)
Ja nimm den Link wieder raus ^^
Wer von euch denkt auch das wenn er keine FE bekommt, auch zur Supreme greift? :wink:
Finde die Karte nach der FE mitunter die wertigste und schönste im Design, Leistung und Göße passen auch..
Ich werde nicht unverschämt, sondern habe jetzt eigentlich mehrfach unmissverständlich klar gemacht, dass der alleinige Grund der Kühlerdemontage zur Verweigerung der Garantie geführt hat. Du interpretierst in deine Unwissenheit jedoch Dinge hinein, die einfach nicht da sind. Auch das Gesetz schützt dich dort als Verbraucher nicht nach den besagten 6 Monaten (Heute 12).
Ich hab deutlich mehr als 3 3090FE. Daher bin ich auch in der Lage eine gewisse Erfahrung wiederzugeben, dass so ein Fall eben durchaus eintreten kann. Was ist also verkehrt daran, Leute zu warnen bevor bei einer 2k€ Karte das Geheule später dann groß ist. Dem Risiko sollte man sich bewusst sein.
P.S. Du kannst den Kühler noch so gut und sauber wieder montieren, es wird dir nie so gut gelingen wie das vorher industriell aufgebracht aussah. Es wird immer nachweisbar sein das der Kühler runter war.
Hier auch nochmal ein älterer Artikel, der sich damit befasst: https://www.computerbase.de/2016-09...er im Rahmen,auf jeden Fall aufgehoben werden.
Danke für den Hinweis. Zusammen mit der frickeligen Kühlerdemontage und dem abgesägten PCB sind die FEs echt keine tollen Wakü Karten :(
Nachricht gelöscht
Ist den jetzt zur Frosbite was bekannt wegen 600W ....hat die ein Dual Bios?
Mein Corsair Kabel geht gerade in den Versand ich interpretiere nun hinein das eine höhere Macht möchte das ich zum release eine Karte kaufen soll .
Jetzt gehen die Selbstgespräche wieder los. 🤪ja nein ja nein
Also wenn die frostbite 600w bekommt, fress ich nen Besen 😛
man muss die hersteller aber auch verstehen wenn Sie keinen bock haben kaputtgemoddete gpus auf eigene kosten auszutauschen.
gibt nen haufen dullies da draußen die einfach nicht das händchen dafür haben.
mir ist das selbst auch schon 1 mal passiert. 1x 8800gts 512 ging nach dem umbau nicht mehr. bild war interessant. Ging auf meine Kappe und gut ist. 350€ in die tonne
Natürlich blöd wenn das bei ner 2k euro gpu passiert. ich kann mir eine 4090 zwar leisten aber nicht mehrere und deshalb verzichte ich auf den umbau auf eigene faust.
Ähnliche Themen
