[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Naja die MSI Grütze bietet ja überhaupt keinen Uninstaller an, aber gut beides scheiße... versteh ich nicht sowas.
Es geht mir hier garnicht darum das er sich Hardware leisten kann. Es geht mir hier darum das er sich angegriffen fühlt von einige User wegen seinem 8 Strix etc Posting. Und DANN so ein Bild posten und nochmal Benzin ins Feuer zu Gießen. Ich feier @TomCom205 in einer Art und Weise, aber so ein proll Raushängen lassen in der angespannten Situation finde ich falsch. Ich poste auch sehr gerne Bilder von meiner neuen Hardware
Mir ging es lediglich darum meine Erfahrungen mit der Thematik untermauern…nicht um zu Prollen aber natürlich wurde mal wieder missverstanden… will und wollte hier in Keinster weise jemanden Schaden sondern lediglich Erfahrungen austauschen …
So krass oder, wie man da gleich angegangen wird, wenn man mal fette Hardware hat.
Ist beim Crate genau das gleiche. Dafür braucht man auch Removal-Tools^^
Ansonsten hat man trotz deinstallierter Software noch 6 laufende Services.
Die hatte ich damals auch gebraucht und trotzdem liefen etliche Services im Background.
Versuchs mal restlos zu deinstallieren. Das Ding ist pures Aids.
Glaube ich dir/euch sofort, habe da schon etliche Horrorgeschichten zu gelesen.
Bin tatsächlich einfach froh, dass das Teil einfach läuft und mich absolut nicht ärgert 🙏
Hab nicht alles gelesen aber hatten wir schon geschmolzene Adapter hier im Forum? Bei mir (suprim x an dark power 12 pro) bisher keine Probleme. Neues kabel von bequiet hab ich trotzdem mal bestellt, kommt aber erst gegen ende November.
Hab den clip mit einem Schraubenzieher angehoben, vielleicht ist er so nun "eingelockt":
So, und jetzt leck mich am Arsch du dummer 12pin Anschluss.
Zum Thema Kabel kann ich zumindest sagen das Nvidia bei der FE explizit in dem genannten Problem Fall gefragt hat welches Kabel ich verwende … der Support dort wollte sogar das ich ein Bild schicke von dem montierten Nvidia Kabel … (Englischer Support vermute USA) … und ich wurde darum gebeten nur dieses Kabel zu verwenden. Man ist dort sehr vorsichtig glaube ich.
Wir hatten hier im Luxx zumindest 1 User der geschrieben hatte das bei ihm ein Adapter geschmolzen sei er hatte sich dazu dann aber nich weiter geäussert und auch keine Bilder gepostet
da er sich von einigen Usern hier bedrängt gefühlt hatte. ... diesen Fall muss man dann also ausklammern da er keine Beweise vorgelegt hat
Ansonsten hatten wir hier im Luxx noch einen User zu Gast der sich extra hier angemeldet hatte ( sofern ich mich grad noch recht erinner )
der aus den ersten 3 Fällen vom Anfang stammte ( 24-25 Oktober ) und auch von Nvidia angeschrieben wurde und auch weitere Bilder sowie ein Bild vom Nvidia Schriftverkehr hier gepostet hatte
Ingesamt haben wir nun bisher 24 bekannte Fälle : ( die letzten beiden in der oberen Liste sind Fälle wo ein Natives 16 Pin MSI Netzteil genutzt wurde ohne Adapter )
Ja das st
Hmm meine Karte legt immer 2520 Mhz an. Egal ob ein spiel läuft oder nicht. Normal?
Ja scheint nornal bei stock Einstellungen zu sein aber du kannst es mit dem MSI Afterburner sehr gut anpassen. Würde aber einfach das Powerlimit an ein Spiel anpassen, dann wird die dementsprechend nur so viel takten wie du ihr per Watt limit erlaubst. Die meisten Spiele laufen bei mir nur 60% Gesamtleistung bestens.
Habe extra ein zweites windows für armory crate. Die software ist eine seuche wie die sich ins system eingräbt.
Ja sind halt leider auch einige Services und Krams die da laufen … 2tes Windows dafür ist vermutlich ein kluger und sauberer Ansatz! (y)
Was haben eure 4090 für eine Temperatur im Idle? Also ich meine die Stock und nicht umgebaut.
34 bis 55°C, bei 55°C schalten sich die Lüfter ein bis die Temp auf 34°C dropt, dann schalten sie sich wieder aus. usw.
btw:
Welches Game zieht bei euch das Meiste über die GPU?
Diablo 2 Resseructed, DLDSR x2,25, gleich zu Spielstart auf der Startposition der Map mit 530W konstant. Ideal um den Adapter zu testen. (y)
Bei mir gehen 1850,höher hab ich mich noch nicht getraut weil ich nicht 100% weiß ob man sich damit dem RAM zerschiessen kann 😄
Nein, kann man nicht. Bei mir gehen auch +1800-2000MHz.
Habt ihr auch hin und wieder bei einigen Games Tearing obwohl ihr einen G-sync fähigen Monitor/TV habt und VRR?
Verstehe nicht warum ich bei meinem LG OLED C1 in manchen Games immer wieder Tearing habe und V-Sync einschalten muss... Jemand eine Idee?
@Slipknot
Habe mich bei der Gigabyte Gaming OC bei 60% Lüfterstärke eingependelt, finde ich genau richtig, GPU wird in Games keine 60° C und Lüfter sind nicht laut. Gefällt mir auch eher wenn ich sie etwas höre, dann weiß ich die 4090 ist gut gekühlt.
Na ganz einfach, weil deine Framerate über der Sync-Spanne liegt. Bei G-Sync immer V-Sync oder eine andere Framebegrenzung zu schalten!
Ja selbstverständlich habe ich das gemacht und zwar auf höchstens 120 FPS limitiert da ich ein 120Hz Panel habe. Bei 100 FPS habe ich kein Tearing bei knapp 120 sprich bei 116 oder 118 FPS habe ich dann wieder Tearing obwohl ich 120Hz eingeschaltet habe, habs geprüft.
Der Limiter sollte 2-3 FPS unter dem Maximum des Monitors eingestellt sein. Und V-Sync im Treiber ist eingeschaltet?
Ok. V-Sync im Treiber? meinst du bei der Nvidia Systemsteuerung? Im Spiel sollte es ja aus sein um zusätzliche Latenz zu vermeiden.
Da geht einfach nicht mehr:
Ich meine, ich merke beim reinstecken ja schon, dass da etwas greift und ich dann nochmal richtig ordentlich drücken muss, aber für die letzten 0,5 Millimeter reichts nicht. Das war aber beim NV-Adapter nichts anderes soweit ich mich erinnere.
Wie sauber sind die Pins im Stecker gearbeitet?
:d Wer die Beiträge von Thrawn kennt, muss bei der Geschichte doppelt lachen!
WAAAAAS? SPULENFIEPEN? HÖÖÖÖREEEE IIICH NIIIICHT :d
Mal ernst ich habe Tinnitus und kann trotzdem ganz gut hören, auch im höher Frequenten Bereich...mich kannste mit bestimmten Leuchtstoffröhren jagen gehen...
Aber Spulenfiepen hatte ich bisher nur bei 2 Karten, 3080FE und 3090FE. Die erste fiepte beim anschalten des PC aus dem kalten heraus und die andere hörte einfach nach einige Zeit einfach auf zu fiepen...
Aber beides ware auch nicht störend laut...da ich sowieso ein Headset trage.
Ich hoffe nur die 4090, die nächste Woche kommt, ist nicht zu laut. :d
Das Kabel von ModDIY kommt dann auch, das wartet aktuell bei DHL im Lager keine 10km entfernt... keine 10 Tage nach der Bestellung ist es da.
Ja, bei Verwendung G-Sync muss V-Sync muss im Control Panel aktiviert sein + FPS Limiter, damit du nicht aus der Range kommst.
weil hier niemand jemals seine superdollen "secrets" verraten will und so tut als haette er gold gefunden;
260/1400 nur. jemand dessen mem mehr takt macht, kann sich damit easy die #1 holen :)
So Secret is das eigentlich garnich .. das hatte JaysTwoCents 2021 auch mal in einem RTX 3000er OC Video gesagt und gezeigt als "Rip Jay" bzw "Rip Steve" damals gelaufen is
also das Spass OC Battle zwischen Jay und Steve ( Gamers Nexus ) nur das er in deinem Bild 1 noch unten direkt manuell auf Performance schaltete sofern ich mich da grad recht erinnere
Ähnliche Themen
