[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
So da WoW ja nicht allzu fordernd ist, habe ich mal AC Valhalla gezockt. Die Auslastung war bei 95-98% und die Leistung der 4090 ist ja disgusting (im positiven Sinne). Alles auf max. bei meiner Auflösung (kein upscaling) und man hat zwischen 120-200fps. Die Karte bleibt trozt der hohen Auslastung bei 52° GPU und 59° VRAM und 60° Hotspot. Die Backplate ist lauwarm, das Stromkabel kalt. Wie hat Nvidia dieses Meisterstück hinbekommen?
Bezüglich Spulenfiepen: Also man hört die Karte unter Last aber es ist kein Fiepen wie bei der Suprim, sondern eher hört man Strom "fließen" aber sehr gedämpft und man muss schon wirklich mit dem Ohr ran (wenn das Gehäuse offen ist). Selbst im Menü mit ca. 500fps wird dieses Geräusch nicht mehr.
Wenn das nur in diesem Game ist und in allen anderen nicht dann kann es ja nur ein Gamespezifischer Bug sein. Es müsste ja ähnlich oder mehr sein mit DLSS...
@Brandur
Die konnten das schon immer, wollten nur nicht (könnte man vermuten). Aber da sie mit der letzten Generation gesehen haben, dass die dummen User auch problemlos 2k für ein Monsterkühler hinlegen. Haben sie es endlich mal gemacht^^
Die Frage war (Bilder anschauen) kostet DLSS CPU-Zeit, und kann es sein, das es 40% CPU-Zeit-Kostet.
Ich habe im absoluten CPU-Limit mit DLLS 100 FPS, schalte ich DLLS aus, erwarte ich, dass die FPS gleich bleiben (wenn das Abschalten von DLLS das CPU-Limit nicht ändert, denn die CPU kann ja nicht mehr) oder weniger werden (wenn ich ins GPU-Limit rutsche).
Das ich plötzlich 40% MEHR FPS habe ohne DLLS habe, hat mich stutzig gemacht. Das habe ich nicht erwartet.
Mir ist klar was DLLS macht. Die Frage war: Wie kann es sein, das hier das Gegenteil davon passiert, was ich (wir) erwarten?
Die FPS bleiben nicht gleich oder weden weniger wenn ich im CPU-Limit DLLS abschalte. Es werden mehr. Gute 40%. Das kann eigentlich gar nicht sein. Verstehst? Deshalb die Frage.
Habe deswegen nochmal den Beitrag editiert. :d
Welche Version von DLSS nutzt denn deine Metro Version? Die Basis Version nutzte ja 1.0 oder so und die Enhanced auch "nur" 2.0.
Tritt der Fehler auch auf, wenn du die neuste DLSS version reinkopierst?
Metro hatte schon öfters komische Bugs bei mir...
Schaltet sich vielleicht V-Sync oder so mit DLSS an?
Mehr müssten es nur sein, wenn ich im Graka-Limit starte. Aber ich starte ja im CPU-Limit.
Es ist völliger Unsinn im CPU-Limit zu starten, aber so war nun mal die Ausgangslage im Heul-Thread vom User, der sich nicht mit der Funktion von DLSS beschäftigt hat.
Tatsächlich hab ich nix hineinkopiert. Also die Version die Epic mit Exodus ausliefert.
Und die Bilder sind von mir. Also nicht aus 3. Hand. Ich hab die gemacht und deshalb auch den Überblick darüber was das System macht und wo ich an den Schaltern gedreht habe.
Und Du bist genau so stutzig wie ich gerade. Das macht gar keinen Sinn^^
V-Sync liegt bei 120hz (LG C2). Also ist auch das ausgeschlossen.
Deswegen finde ich es ja interessant...es sollte ja rein theoretisch nicht so sein...gutes Beispiel von Theorie und Praxis😂
tombraider ist DLSS bei mir ausgeraut. kanns daher adhoc nicht testen
Jemand hier Doom Eternal am spielen?
Stürzt bei mir aktuell sporadisch immer wieder ab, Hotfix ist drauf und den älteren Treiber hab ich auch probiert...
CP2077, Witcher3,Hell Let Loose, Fall Guys und Zero Dawn gehen ohne Probleme...
Beim Test von DF in 4k Spiderman gab DLSS2 nur 1-10% und war manchmal sogar unter den FPS von Native. Nur DLSS3 brachte viele FPS, weil DLSS3 die CPU nicht belastet.
Bei A Plague Tale: Requiem hatte ich mit DLSS3 so einige Szenen, wo auf einmal die GPU-Last runterging. Das konnte ich mir nicht erklären.
Leaked 4080FE
Source: Videocardz.com
Nutzt ihr jetzt aktuell die mitgelieferten Stromkabel für eure 4090er oder habt ihr euch andere besorgt?
Gleich zu Release 2x beQuiet Kabel gekauft. Den Adapter habe ich aber 6 Monate mit meiner 3090Ti ohne Probleme genutzt.
Aktuell dieses Adaptermodell, bis Corsair bzw. CableMod liefern können. Ist aber durchaus gute Qualität (besser als der 4x150V Adapter...).
Weil du dann ins cpu limit läufst. Deshalb spiele ich es mit dlss3 auf 100hz. Da bleibt die framerate stabil. Habe dazu auch ein video auf meinem kanal.
GTA V in dx11 immer wieder eine technische meisterleistung. :LOL:
da kannste reinstopfen was du willst. die cpu macht immer schlapp :d
1 regler. 25% leistungsverlust auf der cpu. da nützt dir die dickste karte nichts.
Hi, habe meine 4090 auf 875mv, 2560mhz UV. Wisst ihr wie ich dort zum Sweetspot komme oder ist das so OK? Kenne mich überhaupt damit nicht aus und habe nur mal ein bisschen rumprobiert oder im Internet mal rumgeschaut, was andere für UV Werte hatten.
4090 Suprim X exakt auf den gleichen Wert eingestellt. Langt mir vollkommen.
Ich habe 900mv @ 2650 Mhz. Kannst ja mal versuchen 50 Mhz mehr zu nehmen. Oder in 25er Schritten.
Also wenn ich theoretisch die 0,15mv noch dazugebe (wie bei dir). Würde das mehr Leitung bringen oder wie regelt das?
Und außerdem, macht es ein unterschied wie weit man die kurve bei MSI Afterburner am Anfang runterzieht?
Hätte ich noch erwähnen sollen: Ich habe das Spiel mit DL-DSR in 5760*3240 (so wie jedes Spiel bis jetzt) gespielt. Da sollte man normalerweise dauerhaft im GPU-limit hängen.
@EleCtricStream
UV und PL verhalten sich anders je nach Spiel.
Raytracing scheint bei der 4090 auch nochmal einiges an Strom zu verbrauchen. Da könnte man theoretisch mehr mit PL einsparen als mit UV.
TESTEN kann ich es erst, wenn meine Karte in 1-2 Tagen ankommt...Wenn sie nicht in einem DHL Lager verschimmelt.
Also ChernobylLite hat schon viel RT..
PL wie gesagt, ich weiiiissss nicht..
Du kannst die mv erhöhen und gleichzeitig kannst du etwas auf den Takt drauf geben. Du könntest jetzt erstmal versuchen deine 875mv zu lassen und den takt um 15 zu heben. Wenn das klappt wieder um 15. Solange bis es eben Crashes oder co gibt. Oder du gehst direkt um 15mv hoch und kannst auch direkt mehr Takt geben. Viel Unterschied macht das nicht am Ende. Am ehsten kannst du dann schauen wie hoch der Unterschied beim Stromverbrauch wäre.
Deine Einstellung passt auch wie sie ist.
Eine auflösungangabe würde zu den fps sinn machen. 😀
So, die GPU taktet im Desktop nicht mehr runter. Hängt ständig auf 2520MHz fest, VRAM auf 10500MHZ, 60W. Kein OC, alles default.
Noistart des PCs bringt nichts.
Energiesparshice immer auf "Minimum Leistung", in Windows und auch im Treiber.
Im BIOS nichts verändert.
Kann das mit keinem speziellern Ereignis in Verbindung bringen. Aufeinmal fiel es mir auf.
Was can man dagegen machen?
Treiber neu installieren
Ähnliche Themen
Antworten
6K
Aufrufe
381K
