[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Ja die Tuf ist etwas teuer aber waren auch paar bessere Angebote dabei finde ich.
Sogar ne Aorus Master die sieht man ja sonst nie ....
Ich bräuchte aber die Werte zur Strix, die Werte von Suprim und TUF hab ich schon.
Ich hatte alle 3 davon. Ohne professionelles Equipment ist da nicht viel Unterschied festzustellen. Wenn ich ein subjektives Ranking machen müsste bezüglich Lüfter/Lautstärke wäre es 1. Strix=Suprim, 2. TUF.
Erstere Beiden hatten aber soviel Spulenfiepen, dass der leise Lüfter eigentlich nebensächlich wurde. Overall würde ich jederzeit die günstige aller 3 empfehlen d.h. die TUF.
Echt komisch wie einige hier reagieren, nur weil Updates zu einem nun mal vorhandenen Problem gepostet werden. Es scheint selten zu sein aber ich hätte gar kein Bock auf eine abrauchende Karte wo man dann ggf. um die Garantie bangen muss. Benutze derzeit das Asus Kabel was beim Thor Platinum II dabei ist aber so richtig sicher fühle ich mich damit nicht. Die 4090 war für mich schon eine sehr teure Investition für die ich einige Monate Geld bei Seite gelegt habe.
Und um was gehts in dem Video?
das video hab ich nach paar minuten abgebrochen zuviel rein spekulative hätte sollte könnte , war schwer zu ertragen viel rumgeeiere und video strecken , nvidia hält sich da auch wage und keine devinitive aussage das andere stecker/adapter die garantie verwirken , da es sich dann auch nur um die fe hadelt und nicht scheinbar nicht drauf eingegangen wird was asus und co in der richtung machen , kann mir schlecht vorstellen das nvidia in der richtung auch für die anderen spricht ,
verständlich, aber warum dann:
Damit hast du direkt das Problem das du um die Garantie bangen musst. Da du wenn etwas abschmiert keinen Adapter mitschicken kannst der ebenfalls abgeschmiert ist.
Kann ich vollkommen nachvollziehen. Daher werde ich im Zweifelsfall lieber doch den beigelegten Adapter von Nvidia weiter nutzen. Hätte bei 2k echt kein Bock mich nachher mit denen rumschlagen zu müssen, weil ich nicht deren Adapter genutzt habe. Davon abgesehen mache ich mir da jetzt aber ehrlich gesagt keinen Kopf. Ich genieße die Power der Karte jetzt einfach und wenn wirklich was passieren sollte, dann müssen sie die Verantwortung dafür tragen. Punkt.
Hat schon jemand den Kühler von Strix mit Suprim oder TUF vergleichen können?
Strix ist die beste luftgekühlte 4090 was Temps/Lautstärke betrifft.
Strix & TUF: https://quasarzone.com/bbs/qc_qsz?_...larity=&kind=subject&keyword=&sort=num,+reply (Google translate nötig).
TUF & Suprim X: https://www.guru3d.com/articles-categories/videocards.html
Strix & Suprim X: https://www.techpowerup.com/review/?category=Graphics+Cards&manufacturer=&pp=25&order=date
Die meisten anderen Review-Seiten sind entweder schlecht oder testen nur wenige Karten.
Bei allen 3 sollte man aber das Silent-BIOS verwenden (oder eher: bei allen 4090), außer du willst ein paar mehr MHz für eine wesentlich höhere Lautstärke.
Nun, aufgrund der aktuellen Datenlage erscheint mir das Risiko überhaupt ein Problem zu haben DEUTLICH höher zu sein, wenn ich den Adapter nutze, da ich meinen PC oft auch unbeaufsichtigt laufen lassen muss. Das Asus Kabel scheint mir solide verarbeitet zu sein und ich habe damit seit Wochen auch keine Probleme. Ist halt mein Risiko aber das ändert nichts daran, dass ich gerne über das Thema informiert sein möchte (an dieser Stelle Danke an @Stagefire ). Gerne auch in diesem Thread, da ich den am aktivsten verfolge.
Das ist das einzig richtige. Zu viele Gedanken machen dich kaputt. Es gibt so viele Menschen da draußen die nichts über dieses Thema wissen. Heute erst einen Kollegen gefragt wie es seiner 4090 Strix geht. Er wusste nicht was ich meine. ist nicht im Netz unterwegs. Er sagt er hat die Karte um damit nach Feierabend zu zocken und nicht im Netz nach Problemen zu suchen. Womit er auch recht hat.
Dagegen spricht ja nichts, meine Frage war lediglich wieso du wenn du Angst hast trotzdem nicht den Adapter nutzt. Was du ja insoweit beantwortet hast. Informiert sein kannst du ja wenn du das willst. Auch wenn es dafür eigentlich einen eigenen Beitrag gibt der leider nicht genutzt wird. Was eigentlich viel sinnvoller wäre, weil dort nur die Leute sind die das Thema eben auch so brennend interessiert.
Mal etwas anderes und ob das mal der eine oder andere netterweise gegenchecken kann und ob das bei ihm auch so ist.
Im Idle auf dem Desktop habe ich mit der 4090 zwischen 8 -11 Watt, also wenn nichts groß läuft, Browser zu und nur das Explorer Fenster auf ist und der Mauspfeil im weißen Bereich des Explorer Fensters steht, also ohne die Maus zu bewegen - die Watt schwanken dann eben. Wenn ich den Mauspfeil jetzt vom Explorer Fenster auf den Desktop bewege, also aus dem Explorer Fenster raus, erhöhen sich die Watt um so ca. 5 - 6, nur weil der Mauspfeil nicht mehr im Fenster steht - kann das jemand bestätigen? Siehe Bilder unter Board Power Draw bei GPU-Z als exemplarisches Beispiel - der Mauspfeil wird leider nicht mit gespeichert - Windows 11 22H2.
^^Ich habe zwei an der 4090 bzw. drei, einen 144Hz WQHD und einen 60HZ UHD. Ich meine im Einzelbildschirmbetrieb, es ist dann egal ob WQHD oder UHD Auflösung, die Watt sind bei mir gleich, nur wenn beide an sind es natürlich mehr, so um die 18 - 22 Watt. Dann steckt noch ein 55 Zoll LG Oled C9 über HDMI dran, auch hier der gleiche Verbrauch, wenn alleine.
@Trill kann dein Verhalten auch so in etwa bestätigen an einem 144Hz WQHD Monitor. Komplett idle so zwischen 7.x und 11.x W hin und her springerei. Sobald ich die Maus bewege steigt auch der Verbrauch. Ich denke das ist völlig normal.
Danke, der Verbrauch steigt ja aber auch dann, wenn der Mauszeiger auf dem Desktop anstatt im Fenster still steht, kann mir das nur mit der GPU Hardwarebeschleunigung von Windows erklären.
irgendsowas vermutlich. Die 4090 erscheint mir sehr viel reaktiver beim Anpassen des Taktes und der Verbrauchswerte als es meine 3080 war
Lag meiner Inno3d X3 OC bei. Ist eine Referenzkarte! Kann leider keine Bilder machen vom Stecker selbst, da das Handy schlecht ist. Stecker ist aber intakt nach 3 Wochen Nutzung.
nur fürs Protokoll und weil ich als das gepostet wurde unterwegs war: auf dem Adapter meiner GB Gaming OC ist auch das Nvidia Logo auf dem Stecker drauf. Also haben wir hier im Forum schon zwei Boardpartner Karten auf deren Adapter das Logo drauf ist - was auch immer das heißen mag oder nicht. Ich persönlich glaube nämlich dass das garnix aussagt. Warum auch?
Was soll das bringen?
Ist doch offensichtlich: er will Stimmung gegen Nvidia machen. Alleine die Tatsache, dass er Anfangs unseren Troll mitzählte, spricht Bände. Er hat sogar die unbestätigten Fälle mitgezählt, welche auf Reddit extra gelistet wurden.
wer wollte noch gleich spiele die die karte fordern?
endlich kann man skyrim zocken. wurde auch zeit :bigok:
sexy.
mittlerweile spiele ich nix mehr, installiere nur das neuste vom neuesten, ultra texturen, alles auf anschlag und gucken wie es laeuft
lmao
Mein Kumpel wirft mir dauernt vor das ich ein Nvidia Fanboy bin und du das ich gegen Nvidia Stimmung machen will andere sagen ich würde Power Adapter Panik verbreiten :ROFLMAO:
Ich berichte einfach nur hier über die Fälle und Diskutiere darüber der Rest passiert in euren Köpfen ausserdem will ich jja selbst ne 4090 Strix ( eine neue zu einem normalen Preis aus nem Shop )
die meine 3080 Strix ablösen soll
Leben und Leben lassen .. weiss nich was diese dauernden Anfeindunngen von immer den selben Leuten nun schon über Tage hinweg sollen das bringt doch niemanden weiter sondern sorgt nur für Schlechte Stimmug
.. Also so langsam sollte das dann auch mal gut sein oder ?
Ähnliche Themen
