[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
@Ronin513
ist wievielen RPM laufen die Lüfter?
Ich hab vor alle Lüfter im Case (und ich hab nur die Hälfte) noch einen 7V Widerstand gesteckt, weil das sonst nicht zu ertragen ist :-)
Die Regelung im Bios ist ja meistens fürn Arsch, weil man das gar nicht weit genug runter bekommt.
Jetzt schön ne 4090 bei NBB holen dann bis zum 31 Januar damit zocken und zurückschicken, durch die verlängerte Rückgabe aktuell :d
Also ich hatte von letztem Freitag die Strix OC im Test hier. Direkt weiterverkauft. Spulen lauter als die Allianzarena gestern und Chip war auch nix besondres…
Zu Igors neusten Power Adapter Video :
Auf den Untertitel achten :
Das Video brachte wieder mal neue Erkenntnisse was da so alles schief gelaufen ist .. ich bin eigentlich nich so ein Igor Fan aber er gräbt da wirklich gut nach bei dem Thema.
OK also V2 des Nvidia Power Adapters wird dann also tiefer sitzende Sense Pins haben sodass die Karte dann nur noch anspringt wenn auch der Stecker wirklich zu 100 % drinn steckt
das is also die Änderung die PCI-Sig am 6.12 macht ... wird dann natürlich dann nochmal einige Wochen dauern bis die Version 2 des Power Adapters dann mal bei uns in Deutschland landet.
Astron wird den Adapter für die 4070 Ti wohl nicht liefern laut Igor .. also Nvidia scheint da schon intern Astron auf die Finger gehauen zu haben weil deren Adapter nich so gut is wie der von NTK
Zitat aus seinem Artikel : ( spricht er aber auch im Video an )
". Eine interessante Fußnote dabei ist allerdings, dass die kommende GeForce RTX 4070 Ti mit einem x2 Adapter ausgeliefert werden soll, der diesmal nicht von Astron stammen dürfte"
Zitat aus dem Artikel von Igor zu den neuen Erkenntnissen was ja auch im Video behandelt wird :
"Da Astron als Hersteller des Adapters (x4 und x3) federführend ist, habe ich mir als als Einführung einmal die Konstruktionspläne für diesen Adapter besorgt. Die wichtige schematische Übersicht stelle ich hier exemplarisch voran, denn sie zeigt auch, dass einige der bisher festgestellten Mängel so hätten gar nicht auftreten dürfen."
"Ich hatte ja über den aufgeschnittenen Stecker berichtet, dessen Lötstellen auf den Pads recht kritikwürdig ausfielen, zumal auch die Lötqualität allen Normen widersprach (Bild unten). Dazu kommt, dass die Zuordnung der Kabel zu den Lötpads der Kontakte der Vorgabe aus der Zeichnung (Bild oben) widerspricht. Ein diesem (und einigen weiteren) Fällen muss man von einem Produktionsfehler ausgehen, der sich letztendlich wohl auf einen einzigen Herstellenden reduzieren lässt, der die Zuführungen aus Unkenntnis falsch positioniert hat. Das erklärt dann auch die Seltenheit dieses Fehlers, der aber durch eine ordentliche Schulung und die obligatorische Qualitätskontrolle vermeidbar gewesen wäre."
Und das bei einem eigentlichen Serien Produkt 2 unterschiedliche Firmen rangezogen werden die dann auch noch unterschiedlich Fertigen mit unterschiedlicher Qualitätskontrolle is schon n starkes Ding find ich.
Hast hoffentlich mitgeteilt wie laut die gpu war :)
Das durfte sich der Käufer vor Ort selbst anhören, aber ich bin Fan deiner passiv-aggressiven Zwischen-den-Zeilen-Unterstellung, ich hätte es nicht gemacht:d
@Ronin513
Am besten einen Aquaero an die Lüfter klemmen .
Bei mir werden so 16 Lüfter intern gesteuert.
Im idle bei 350RPM unter Last bis knapp 600RPM.
Auch auf Reddit im 16 Pin Megathread gibt es nochmal eine zusammenfassung von Igors neusten Erkenntnissen :
Währenddessen rutscht die Strix weiter runter im Preis :
mein EKWB Asus block wurde gerade verschickt, fehlt nur immer noch das Seasonic Kabel..
Wer will schon eine fiepende Strix, wenn es auch leisere Karten gibt, die taugt nur zum Benchen imo.
Hallo Gemeinde,
eigentlich hatte ich mir zum Release-Tag der RTX 4090 geschworen, keine Karte zu kaufen, weil ich zum einen die Preispolitik von Nvidia nicht unterstützen wollte und ich zum anderen schlicht und ergreifend keinen wirklichen Bedarf gesehen habe, mir ein GPU-Flaggschiff anzuschaffen. Mit meiner ASUS Strix 3080 OC war ich eigentlich sehr zufrieden. Aber wie so oft im Leben (und je länger man hier in diesem Thread mitgelesen hat) kam ich an den Punkt, an dem die anfängliche Vernunft vom Gefühl des „Habenwollens“ verdrängt wurde.
Seit letzter Woche bin ich nun stolzer Besitzer einer Gigabyte RTX 4090 Windforce 24G. Und was soll ich sagen: ich bin von der Karte mehr als begeistert!
Klar ist sie nicht die Stärkste 4090 (siehe Benchmark-Ergebnis). Aber für mich und meine Zwecke ist sie mehr als ausreichend. Und da ich mir erst Anfang letzten Jahres ein neues System (AM4-Sockel) zusammengestellt hatte, wollte ich nicht schon wieder auf eine neuere Plattform setzen, um das Potenzial einer 4090 vollends entfachen zu können. Etwaige Flaschenhälse nehme ich also in Kauf. Ich habe mir aufgrund der Empfehlungen hier im Forum lediglich eine etwas stärkere CPU (Wechsel von AMD Ryzen 5800X auf einen 5800X3D) sowie ein stärkeres Netzteil (750W --> 1.000W) geholt.
Hier mal ein paar Eindrücke von der Karte:
Die Karte hat unter Last (10 Minuten FurMark, Time Spy, Cyberpunk 2077, Battlefield 2042) nach meinem Empfinden kein wahrnehmbares Spulenfiepen und ist an sich wirklich leise. Jedenfalls kann ich die Karte nicht aus meinem System heraushören. Gerade im Hinblick auf die Temperaturen und im Vergleich zu meiner alten Strix 3080 OC bleibt die Karte angenehm kühl, was ich auch an der Raumtemperatur nach einer halben Stunde BF2042 gemerkt habe. Die Temperatur des GPU Hot Spots lag lt. Logfile von GPU-Z nach ca. 30 Minuten BF2042 auf Ultra-Settings bei maximal 74,9 Grad.
Idle:Last (BF2042, Ultra-Einstellungen):
Bezüglich der Adapter-Problematik kann ich nur sagen, dass der mitgelieferte Adapter ohne Probleme hörbar eingerastet ist. Vom Biegeradius sollte es in meinem Gehäuse (Define 7) auch passen. Mit dem Glasseitenteil, welches ich auch besitze, ist minimal mehr Platz vorhanden als mit dem Seitenteil aus Metall plus Dämmmatte. Ich werde allerdings noch das Adapterkabel von be quiet! (12VHPWR) verbauen, sofern es denn jemals geliefert wird.
Was mir optisch an der Karte gut gefällt, ist, dass sie ohne viel Bling-Bling auskommt und relativ nüchtern ist - auch wenn ein Metallgehäuse á la ASUS TUF einen bestimmt noch wertigeren Eindruck vermittelt hätte. Ich denke, dass ich die Gigabyte Windforce behalten werde und mit ihr erst einmal eine Zeit lang alles flüssig spielen kann. Und wie gesagt ist die Karte angenehm leise und auch preislich (UVP) eine Empfehlung wert, sofern man denn eine bekommt.
Ich habe zwar noch eine ungeöffnete ASUS TUF 4090 OC hier bei mir liegen, aber die wenigen Prozent an Mehrleistung benötige ich nicht. Oder doch? Und schon fange ich wieder an zu grübeln… :haha:
Ich glaub die können alle fiepen.
Selbst die Suprime mit ihren speziellen Teilen fiept .
Meine erste Gigabyte Master 4090 hat auch gefiept !
Vorhin auch die normale Tuf verpasst im Asus Shop für 1950 € damit könnte ich mich auch anfreunden da sehr günstig mit Top Kühler die OC dann ehr nicht weil preislich halt schon an der Strix dran und der Kühler ist für mich echt Hammer.
Wenn ich knapp 2300 hinlege dann für das schmuckstück .
Die ganzen anderen Plastik Gehäuse gefallen mir gar nicht!
Da die Tuf und Strix bei gerade Mal 1000RPM rum laufen im Silent BIOS einfach Top!
Bei mir lief die Master mit lauten 1500Rpm nach Zero Fan an das war richtig nervig!
Da ich dieses Mal sehr zögerlich bin wegen Umbau auf Wakü achte ich um so mehr auf die Luftkühlung da ich die Karte wohl das erste Mal nicht umbauen möchte!
Ich kenne bislang niemanden mit funktionierendem Gehör, der mit der Strix glücklich ist. Finde sie auch sehr schick, aber damit geht kaum ein Standardgehäuse noch zu und sie ist so unnormal laut...
Ist ja auch Okay bei meinem 1000D ist Platz und die Karre steht 3m weg .
+ Undervolting
Spulenfiepen bei der GTX 280 war damals der Grund, warum ich mir gesagt habe, dass ein PC unter und nicht auf dem Tisch gehört.
Die Aussage verstehe ich ja für andere fiepende Modelle, aber extra Geld ausgeben, um ihre einzigen Stärken gegenüber anderen karten links liegen zu lassen geht mir nicht in den Schädel
Ist das fiepen der Strix um soviel schlimmer als bei den anderen Karten ?
Ich mein die Kochen alle nur mit Wasser.
Und selbst wenn da 0.99€ bringt ja nix wenn die Karten nicht verfügbar sind. :(
Jo nur nicht zu kaufen das Pracht Exemplar :mad:
Selbst wenn da 1900 stehen würde hilft es einem ja leider nicht!
Ich seh die Sache aus einem anderen Blickwinkel ... die eigentliche UVP dieser Karte ist nun 2273 Euro statt wie anfangs 2350 Euro oder gar 2500 Euro und wer weiss um wieviel die in den nächsten Wochen
noch fällt ... alles was drüber is über 2273 Euro ist Shop Scalper Aufschlag somit gilt es sein eigenes Limit was man für diese Karte bereit ist zu zahlen aufgrund der nun niedrigeren UVP neu zu berechnen
und wir nähern uns dem normalen Abstand von 100 - 200 Euro Aufschlag für eine Costum Karte im Vergleich zur FE mit der Strix an.
Ich bin nun auch nich mehr bereit für die Strix 2500 Euro hinzulegen da deren UVP 2273 Euro is oder vielleicht sogar noch geringer und hab mein Limit was ich max bezahlen will aufgrund der UVP nun geändert
Für mich kommt damit aktuell nur noch der Asus Shop in Frage wo ich dann meine Bestellung tätige
sollte ich mal das Glück haben zur richtigen Zeit am Richtigen Ort zu sein und die Verfügbare Menge stimmen sollte sodas man länger als 30 Sekunden Zeit hat zum bestellen da mir nun der Scalper Aufschlag
der Scalper Shops die die Strix immernoch für 2500 Euro führen nun zu hoch is bei einer eigentlichen UVP von 2273 Euro für diese Karte
Ich glaube meine 7 x 140mm Lüfter die beim Zocken gern mal auf 1200 umdrehungen und mehr hoch gehen ( weil von mir so eingestellt ) dürften da lauter sein.
Und meine D5 Next Pumpe fiept auch schon seit über 3 Jahren is nich schlimm für mich.
Klar die Silent Leute machen nen bogen um solche Karten aber mir is das Wumpe ... daher is das mit dem Fiepen immer Subjektiv zu betrachten
Jupp ... also ich hab in den Jahren die Erfahrung bisher gemacht das meine Karten wenn dann gefiept haben dies erst ab so 200 FPS und mehr beginnt und soviele FPS hab ich nich weil 120hz OLED
Bei meiner 3080 Strix fängt das fiepen etwas früher manchmal an so bei 150 FPS oder so ... im Bereich von 90 Hz/FPS hat bei mir bisher noch nich eine Karte gefiept
Denke also mal das die Leute die die Strix fiepen höhren eher im hohen FPS Bereich zocken 144 hz / FPS und mehr .. ich hab nen 120hz OLED also is da bei mir bei 117 FPS ende ( Gsync FPS Cap )
und da hat bisher bei mir noch nich eine Karte gefiept in den letzten 10 Jahren wenn dann wars dann nur mal im Hauptmenu oder beim Laden von einem Level oder bei 3D Mark
Also die Sache mit dem Fiepen is meiner Meinung nach eher Subjektiv von Mensch zu Mensch zu betrachten ( eigenes Empfinden ) als auch mit wieviel FPS dieser Mensch zockt bzw wieviel Hz sein Monitor hat
gehen die FPS hoch in den 200 FPS + Bereich oder zb nur im 60 - 100 FPS Bereich .. und bei einigen dürften dann auch die PC Lüfter lauter sein als das Fiepen ... aber ich vermute hier nur aber das sind bisher so meine Erfahrungen der letzten Jahre mit meinen GPUs die ich so über die Jahre hatte
Gibts hier eigentlich jemanden der so mutig war eine 4090 FE in ein Meshlicious einzubauen? Mich würde vor allem interessieren wie es mit dem Stromanschluss aussieht. Theoretisch sollte sie reinpassen, die 3090FE ging auch rein aber die Geschichte mit dem berüchtigiten Adapter zur Seite macht mir da Sorgen.
Gibt es ein Spiel und/oder Benchmark wo ich die FPS am besten per Tastendruck regulieren kann?
Ich habe hier bei meiner Strix leichtes/leises Spulenfiepen, aber ich möchte gerne herausfinden ab welcher FPS Zahl dieses hier genau beginnt.
Ähnliche Themen
