[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Ich hatte eigentlich drauf gehofft, dass die Netzteilhersteller passend zum Nvidia Event die Verfügbarkeit ihrer neuen ATX 3.0-Modelle ankündigen würden. Vielleicht passiert das heute noch. Konkret verfügbar in nächster Zeit scheinen nur diese Thermaltake-Netzteile zu sein. Leider noch nicht getestet o.ä. Die 1350W und 1650W Varianten sollen bei Alternate wohl in 2 Tagen lagernd sein.
1500W sollten jedoch eigentlich dicke reichen denke ich. Ich würds einfach drauf ankommen lassen und testen. Im schlimmsten Fall schaltet sich der PC bei extremen Spannungsspitzen ja nur aus.
Die Watt werden denke ich auch reichen aber die neuen Netzteile sollen z.B. mit den Leistungsspikes besser umgehen können und haben eben gleich den neuen Stecker, ohne, dass man 3 Kabel zu dem Adapter führen muss. Thermaltake werde ich nicht kaufen, habe da keinen guten Bezug zu der Marke.
Die Frage ist eher ob ich mit meinem bequiet DPP11 1000W ne 4090 (+ggf. AM5) sicher über die Bühne bekomme :fresse:
Sei doch froh
Mein 10er Dark Power 750Watt kommt dann definitiv an die Grenzen. Die 480Watt der Strix 3090 waren aber stabil.
Leider noch keine ATX3.0 Netzteile auf dem Markt außer Thermaltake. Hoffe auf ein neues Be Quiet dieses Jahr
Nur nochmal als Reminder falls jemand die neuen Karten mit 3x8Pin nutzen möchte. Augen auf bei der Adapterwahl. Falls sich das überhaupt vermeiden lässt.
Außerdem die Frage da ich bischen raus bin: Bringt eine aktive Backplate "einiges" oder eher vernachlässigbar? Danke
Sei doch froh
Ich such aktuell noch nach Adaptern auf den neuen Stromanschluss, die 3x8PIN auf Adapter sind aber erstens nur bis 450W statt 600W ausgelegt und 4x8 PIN oder gar 5x8 PIN gibt es leider meines Wissens nach nicht. Dazu hab ich letztens iwo nen Test gesehen, dass die Lastverteilung der 3x8 PIN wohl so bescheiden sein soll, dass die teils krass über deren Specs liegen. Gerade wenn man dann auch noch an OC denkt, bin ich da raus. Wird also evtl auch ein neues Netzteil werden müssen... Hatte eigentlich für RTX30XX gerade erst ein neues gekauft in Hoffnung auf Zukunftssicherheit.
Ah während des langsamen tippens hat er den erwähnten Test gefunden :fresse:
pcie 4.0 so so
Und leider den gleichen Takt wie die FE. Habe wieder das Gefühl, dass die FE die besseren OC Chips haben werden :)
Ich habe auch das Gefühl, wenn ich so durch alle möglichen Internationalen Foren schaue, dass das Interesse nicht sehr hoch ist für die 40er Reihe.
Bei dem 30xx Release war deutlich mehr los nach der Ankündigung.
Reicht denke auch sehr wahrscheinlich.
RTX 3090 @ PCI E 3.0 7-12% Bandbreitennutzung im Gaming.
PCI E 3.0 wird denke auch für die neuen Karten reichen .
Ich tendiere aktuell zur FE.
EVGA ist ja leider weg...
Live Stream ab 16 Uhr, MSI stellt eigene 4000er Karten vor:
Ich muss ehrlich sagen, dass ich im Moment auch more hyped auf die neuen Intel CPUs bin, da die hoffentlich nen besserem IMC haben und man da 7000Mhz Module problemlos betreiben kann. Eigentlich brauche ich die Mehrleistung der 4090 nicht, da ich mit der 3090Ti in meinen bevorzugten Games mehr als versorgt bin aber haben wollen ist halt oft stärker ausgeprägt als brauchen :d.
To all my Ampere friends, it is save to upgrade now. :d
Review NDAs fallen ja klassischerweise um 15 Uhr, also würde ich den 26.9 tippen.
Verkaufsstart ist der 12.10 dann auch in DE? Ist das schon offiziell?
Sehe ich auchso.
Irgendwie ist der Hype lange nicht so heftig wie noch zu RTX 3000 Zeiten. Da könnte man ja fast hoffen das Preissenkungen oder Preiskampf mit AMD kommen.. Ich warte erstmal ab.
Naja, der Karte ist es am Ende auch egal, ob der Strom über drei oder vier Leitungen in den Adapter geht. Aber psst, nicht den Elektrikern weitersagen :fresse:
MSI und aios....
da war doch was :fresse:
RECOMMENDED PSU
850W
Ez :d
Ähnliche Themen
