[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Weiß jemand woran das liegt?
Ich habe meine 4090UV auf 900mv, 2695MHZ aber jedes mal wenn ich das Profil speicher, stellt er mir die Kurve so hin:
Stell mal -500MHz ein und geh dann in den Curve-editior. Dann müsste es funktionieren.
Hab jetzt nach ca. 5 Stunden wieder nen Blackscreen bekommen. Ich denke also wirklich dass die Grafikkarte nen defekt hat. Das DP Kabel kann es unmöglich sein, das funktionierte ja wie gesagt mit der 3080 noch einwandfrei.
Schicke die Karte jetzt wieder zurück...
Was für eine Karte hast du noch Mal ?
Ah steht Palit bei drin im System hätte da auch früher kucken können.
Klingt jetzt etwas komisch aber du hast nicht zufällig das neueste BIOS schon aufgespielt für dein Mainboard .
Für mein X570 Taichi gab extra ein BIOS wegen Kompatibilität zur 4090.
Vielleicht hilft dir das ja weiter hatte hier jemanden im Forum da lief die 4090 gar nicht ohne ein neues Mainboard BIOS.
Ansonsten drück ich dir die Daumen das alles schnell geht beim Einschicken der Karte!
Gerade beim Schreiben dieses Posts wieder nen Blackscreen :fresse:
Ist eine Palit NonOC.
Uh, ne, tatsächlich noch nicht.
Nein, problematik tritt sowohl mit OC als auch mit Stockvoltage und Taktraten auf.
Hast du einen HDMi Anschluss am Monitor um nur Mal zu testen .
Jap, mein Zweitmonitor ist per HDMI an der Karte angeschlossen, der ist von den Blackscreens verschont. Es wird immer nur der 4K Bildschirm, der via DP angeschlossen ist, schwarz.
Oder meinst du den 4K Bildschirm testweise mit HDMI betreiben? Das wäre ne Möglichkeit.
Den letzten Treiber hast du aber drauf?
Wie sieht es hiermit (GPU UEFI Firmware 1.2) aus:
Ja, da ist alles aktuell.
Bin auch langsam mit meinem Latein am Ende. Hab schon so ziemlich alles versucht.
- G Sync deaktiviert
- Alle DP Ports getestet
- Grafikkartentreiber neu installiert
- mit Stockvoltage und Taktraten laufen lassen
- Im Bios GEN3 forciert
- Duplikate im CRU entfernt
- Riserkabel rausgenommen und Karte regulär verbaut
- In den Bildschirmeinstellungen alle Syncmodi ausgeschaltet
- Ereignisanzeige analysiert (ohne Auffälligkeiten)
Übermorgen kommt das neue DP Kabel. Wenn das nicht funktioniert weiß ich auch nicht weiter. Letzte Möglichkeit wäre Windows neu zu installieren.
Interessant auch, dass wenn ich nen Screenshots während des Blackscreens mache, der Screenshot vorhanden ist. Die Karte scheint also weiterhin auch am 4K Bildschirm ein Bild auszugeben.
Ist halt save das Kabel. Sehr unwahrscheinlich das es die Karte ist!
Diese soll nicht fiepen und besser als von Amazon geht doch nicht? 2.246€
ZOTAC Gaming GeForce RTX 4090 AMP Extreme AIRO 24GB Gaming
Bei Arlt gibts noch eine 50€ günstiger.
Top Kurs habe im Oktober 2228,- bei MM gezahlt !
Oder hier seit gestern Mittag nochmal günstiger:
Ich warte aber noch, bis die unter 2000 € gehen ...
Noch geiler der Kurs!
Ich hoffs! Hab meine 3080 nämlich letzte Woche hier im Marktplatz verkloppt und hab kein Ersatz :d
Dagegen spricht halt, dass der Bildschirm und das Kabel auch nagelneu sind und vom 22.11-14.12 ohne einen einzigen Blackscreen an der 3080 geklemmt haben.
Und reproduzierbar sind die Blackscreens auch nicht. Manchmal kommen 2 stück innerhalb von 10 Minuten und manchmal halt 5-6 Stunden gar keiner.
Kannst ja ggf mal von 4K/120(144?) auf 60Hz oder HDMI testen. Falls das nicht hilft, es also nicht die unzureichende Qualität/Bandbreite der Strippe ist, hat die ggf nen Bruch oder Stecker sind Crap etc.
Ich traue mich Wetten, dass es die Strippe ist!
Bis auf die 8GB RAM ein fairer Ersatz (nahezu gleiche Perf) (y)
Geil wäre eine 4090 mit möglichst lautem Spulenfiepen, die Jingle Belts zirpen könnte :d
Moni-Kabel könnte es auch sein
Habe meine 2080 ti 430€ in der Bucht vertickt, P/L top..., deswegen auch die 30 Gen komplett übersprungen
Das wäre aber echt schwach von LG, wenn die so ein Schmutzkabel zu einem 4K@160Hz Bildschirm legen. Ich probier jetzt mal testweise 60Hz. Danke schonmal.
Wobei.. Die Blackscreens treten ja auch im Idle auf wenn ich nur hier im Forum unterwegs bin. Oder hat die Bandbreite nix mit der Last der Graka zu tun?
Ich hab keine Ahnung mehr was für eine Karte ich möchte: MSI hatte drei mal grausamstes Spulenfiepen, 2x Gainward mit Lüfterbrummen und 1x davon mit komischen rumpelnden Geräuschen zwischendurch. Die ASUS Karten haben anscheinend alle Spulenfiepen und die Zotacs, die wegen Garantie recht interessant sind, anscheinend auch die lauten Lüfter. PNY gefällt mir das Design nicht und Gigabyte muss ich nichts weiter zu schreiben. Hat jemand noch einen Tipp. Insb weil der Platz im Case eigentlich sehr limitiert ist (o11d razer)
Die kleinste Customkarte ist die Palit. Die passt sogar regulär eingebaut ins o11 rein wenn du dich traust das Kabel etwas zu knicken. Spulenfiepen nicht mehr wahrnehmbar beim Spielen und extrem leise.
Ich kann tatsächlich mit dem Lüfterbrummen der Gainward am Besten leben, da ich hauptsächlich mit dem Flightsimulator spiele und durch die Turnbinengeräusche der Flugzeuge das definitiv überlagert wird beim Spielen. Davor oder nach dem Spielen laufen die Lüfter durch das UV fast nie mehr an oder nur bei 30%, wo das unangenehme Brummen noch nicht ganz auftritt. Das Fiepen oder Rasseln hat irgendwie eine unangenehme Frequenz(wie Tinnitus) und hört man selbst beim Spielen raus. Es hat natürlich jeder ein anderes Empfinden oder eine Schwelle wo es störend wird.
Wenns der 27GN950 bzw. der Refresh ist... das Kabel was dabei war, ist gut. Habe es testen lassen. Kann gut sein dass du ein Montagsmodell erwischt hast, was aber auch echt peinlich für LG wäre..
Ne, es ist ein 32GQ950, also eigentlich noch schlimmer, da das Teil das doppelte kostet. Bislang läufts @60Hz wieder ohne Blackscreens seit 2 Stunden. Ich schöpfe wieder Hoffung :d
offtopic, aber für uns Zocker…
Bei Epic gibt es „Death Stranding Directors Cut“ kostenlos, bis morgen 17Uhr ;)
Aber mom. leider schwer erreichbar...
Die gainward hat ja noch so ein rumpelndes Zusatzgeräusch, das ist super nervig und einfach sehr laut. Ich habe eigentlich einen silent PC gebaut, der so eingestellt ist, dass du unter Vollast maximal ein minimales Surren der AIO hören kannst, wenn dein Ohr direkt am PC ist. Dementsprechend ist der Wunschtraum eine MSI Gaming Trio (wie ich finde eine der schönsten Karten) ohne Spulenfiepen. Hat die Palit nicht das Lüfterproblem? Wäre dann eine echte Alternative die ich einmal testen könnte. Ich hatte auch gesehen, dass man die Zotac reinquetschen kann. Aber so wie ich es verstanden habe hat die auch die Lüfter Brumm Problematik, richtig?
LG und frohe Weihnachten an euch Alle.
Nope, die Lüfter laufen alle 3 ganz normal. Die läuft regulär eingebaut mit 53-55°C bei 30% Fanspeed @ 1150rpm. Mit vertical Mount kit sind es so zwischen 58 und 60°C bei 30% Fanspeed.
Was is den bisher so euer Maximal Takt mit Max OC bei 3D Mark mit ner 4090 ? Hat schon einer die 3,2 ghz geknackt ?
Höher als das komm ich mit meiner 4090 Strix nich ( PT 450 Watt )
.. meist is aber bei 3150 mhz ende .. habs bisher erst 2 mal geschafft die 3165 mhz zu erreichen .. is bei mir noch mit Luft ( Lüfter auf 100 % ) der EK wakü block verspätet sich mal wieder
2950, Lüfterprofil @ Stock.
Ein schön hoher max. Takt (Peak) ist zwar nett. Viel entscheidender ist, wie lange dieser während dem ganzen Bench gehalten wird und was am Ende für ein durchschnittlicher Takt raus kommt.
Da kann jmd mit „nur“ 3.150MHz einen höheren Score haben, weil sein durchschnittlicher Takt sehr nah am Max. Takt ist (zb 3.120MHz). Während bei anderen Benches, der durchschnittliche Takt weiter vom Max. Takt entfernt ist. Mit Kühlung und/oder Spannung kann man das beeinflussen
Ein beliebiger Fire Strike Ultra Bench aus dem Netz und dein Takt
Seine GPU-Temp hat zwar auch 48°C, aber die könnte 55-60°C haben, um die gleiche Takt-Differenz von 75MHz, wie bei dir zu haben
Ähnliche Themen
Antworten
6K
Aufrufe
381K
