[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Welche Programme hast bisher versucht? Welches Mainboard haste?
Asus Brett mit Armory Crate geht es natürlich nicht dem MSI Tool natürlich auch nicht, open RGB hatte ich nur kurz überflogen ....
Was für ne Karte ist das genau?
Konntest denn vorher mit Armory Crate alles einstellen und nach dem Galax Bios Flash ging der Regenbogen los?
Ist eine WaKü für eine 4090 überhaupt nötig? Meine Tuf bewegt sich eh schon im 50er Bereich und allzu laut ist sie auch nicht. Wenn jemand Spaß am umbauen hat ist es ja ok aber gibt es außer Optik technische Vorteile?
Ja wenn man schon vorher alles unter Wasser hat und dazu ein absolut leises System haben möchte.
Nö, diese monströsen Kühler sind bei ner undervolteten 4090 ein Hochgenuss. Wenn du die FPS auf 90-100 begrenzt, bleibt die Karte teilweise unter 50°C und die Lüfter drehen gar nicht erst.
Ist eine MSI SupX mit Galax Bios mit dem Werks MSI Bios konnte man das RGB auch nur per MSI Software steuern,
Armory Crate kann glaube ich auch nur Asus Produkte.
Danke schau ich mir an, dass tool scheitert aber wohl schon bei der Installation ....
Bin wahrscheinlich eh zu ungeschickt und ungeduldig für diese Präzisionsarbeit. Aber die Optik ist schon geil. Ok an die Größe habe ich gar nicht gedacht aber mein Define XL hat genügend Platz.
Hast du dein Glück schonmal mit iCUE versucht? Damit konnte man zumindest Asus Karten steuern.
Erst kein Glück und dann kaum auch noch Pech dazu :fresse:
Von Icue mit ich geheilt, da lass ich die Finger von ....
Vielleicht überlege ich es mir noch mal .Sind bestimmt genug Modder hier die helfen könnten. Wie sieht es denn preislich aus?
eine custom wakü? nen lilanen wirst du locker hinlegen müssen
200-300 block.
100er 360er radiator. eventuell auch 2x
pumpe + agb 100er +
cpu block 60-100
fittings, schlauch, wasser und lüfter
das läppert sich rücki zucki
Lach. Für ne 4090 hat es ja gereicht :-). Habe auch keine Vorstellung wieviel Zeit man als ungeübter braucht.
für was zusammebau der wakü? gpu block stunde, wenn case und komponenten gut gewählt nochmal 1-2 stunden. gerade als beginner. aber in der regel ist das doch der spaßigste teil imho sofern alles passt :ROFLMAO:
Okay verstehe.
Zurückflashen auf MSI BIOS, RGB einstellen und wieder auf Galax flashen ist wahrscheinlich zu nasty...
Bei dem Xtreme Tuner von KFA²/Galax wurde Dir nicht mal ne Karte angezeigt,oder?
RGB Fusion von Gigabyte könntest noch versuchen, dass Prog zeigt meine 4090FE zwar als SLI Brücke an, aber lässt sich steuern.
Werde es mir mal durch meine Geldbörse gehen lassen.
Das Aufrüsten ist halt gleich mal deutlich teurer, wenn man ne WaKü im System hat :d
Neue Graka? Pah, erstmal nen Block kaufen.. Neue CPU?.... usw.
Doch wurde angezeigt alle Funktionen gingen auch bis auf das RGB, naja RGB ist halt wilder Westen ich schau mal weiter ....
Ähnliche Themen
