[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Ok, dann werden Sie für die anderen Karten wohl nachschieben und die Referenz und Founder`s Edition geben nur den Startschuss.
Ich schwanke auch noch zwischen dem Core Wasserblock oder dem Watercool für die FE. Mal schauen welcher zu erst da ist, habe die Karte zumindest heute erstmal so eingebaut.
Zumindest für die weit verbreiteten GPUs wie Strix/TUF oder Suprim wird es auch keine Core Version geben. Für die TUF hätte es wohl aber noch bis Februar/März gedauert und das war mir zu lange.
Watercool würde mich auch sehr interessieren, aber da wurde noch kein Block für Die Gaming OC angekündigt.
aber der schwarze Karton war nicht im typischen Pappkarton eingepackt, sondern kam in einer Notebooksbilliger-Umverpackung.
Jetzt hab ich wahrscheinlich eine Retoure 😩
Dann wärs aber eine Retoure, die nicht verwendet worden ist. Oder der braune Karton hatte nen Transportschaden und man hat ihn bei nbb geöffnet um zu prüfen, ob die OVP in Ordnung ist.
Leute, 4090 FE oder Zotac 4090 OC ? beide neu und versiegelt für 2000.- , was auch meine Grenze ist.
Kommt in ein LianLi EVO invertiert u hochkannt. zZ ist eine Strix 3080ti so verbaut. Was meint ihr ?
Zotac hat nach Registrierung 5 Jahre Garantie.
Die FE gibts auch für 1859.
Ansonsten das was Gurkengraber sagt:
Und eben der Beweis (oder ein Beweis) dafür, dass auch bei der 4090 in 4K die CPU absolut entscheidend ist.
Also ich kann nicht verstehen, wie hier einige mit dem Lüfterbrummen der FE zurecht kommen. Und ja, das haben alle, das ist keine Lotterie wie beim Fiepen. :) Wenn Du also auch zu diesen Leuten gehörst, würde ich die FE nehmen, die ist meiner Meinung nach allen Vendorkarten überlegen. Nicht in jedem einzelnen Punkt jeder einzelnen Karte, aber im Gesamtkonzept
600W PT
warme Luft z.T. direkt aus dem Gehäuse
beste Haptik
kleinster Formfaktor
niedrigster idle Stromverbrauch
Zero Fan Mode
wertigstes Design
niedrigster Preis (mit Abstand)
Edit: Ansonsten noch ein Bild von den 4090ern in diesem Thread machen:
was habt ihr so für eine Bandbreite im 3DMark PCIe Bandwidth Test
Bandwidth 24.04 GB/s
So, ich werde mir auch was neues zum spielen anschaffen.. keine Lust mehr auf AMD. Der 5950x hat einige Monate Spaß gebracht, es ist Zeit für Intel.. again. Bringt DDR5 mittlerweile in Games endlich mal einen entscheidenden Vorteil? Sonst klatsch ich nen 13900k einfach auf nen DDR4 Brett.
da kann man so einiges 'rauslesen bzgl. ddr4 vs ddr5 (y)
Falls jemand eine günstige 4070 Ti Strix direkt von Asus haben will ...:ROFLMAO:
Immerhin haben sie ein paar zu dem Vorzugspreis auf Lager 😅
Spricht was gegen die INNO3D GeForce RTX 4090 ICHILL X3? Scheint die einzige zu sein die aktuell für unter 2k zu haben ist und wird eh auf Wasser umgebaut. Mal abgesehen vom scheinbar schlechten Support, das hab ich schon gelesen.
Da kannst auch ne Zotac nehmen .
Hast scheinbar die zwei Jahre Garantie bei Kühlerwechsel immerhin und beim Hersteller kann man ggf. auch ne RMA abwickeln . Daher eher die Überlegung Zotac statt Inno3d
Das steht bei Geizhals bei der Trinity .
fünf Jahre nach Registrierung (innerhalb von 28 Tagen nach Kauf, Standard: drei Jahre, Abwicklung über Händler oder Hersteller, nach zweitem Jahr verfällt Garantieanspruch bei Kühlerwechsel)
@Tundor Die Auswahl an Wasserblöcken für die Referenz PCB ist ganz ordentlich. Kann man machen. Seriöser Händler?
@Tundor
INNO3D erlaubt auch keine Kühlerdemontage.
Danke, dann keine Inno, ich schau mir mal die Trinity an. Bin eh am überlegen ob ich jetzt bestelle, Verfügbarkeit scheint ja langsam deutlich besser zu werden, vlt. werden bald auch mal die Preise etwas günstiger. Aber das ist ja seit 3 Jahren Wunschdenken in dem Markt :d
Die Inno geht auf Alphacool umzubauen. Da gibts auch die originale Frostbite, welche aber teurer und sehr selten ist.
Die Zotac ist ein Custom-Design. Es geht nur Byski und Granzon.
Ich würde nach bevorzugtem Wasserkühler entscheiden.
Wenn du unter 2k willst würde ich die empfehlen:
Kfa2 erlaubt den Kühlerwechsel und die ist Ref
Sieht ausreichend aus für mich, hab ich bestellt (y) Wie schnell und mit was liefert LDLC? Scheint ja dann aus FR zu kommen?
*edit*
Gerade erst gecheckt, die ist ja gar nicht verfügbar. Das wurde etwas seltsam von Chrome übersetzt.
Herpes hat die FE geliefert. Ich hab sie direkt ausgepackt. Leider ist beim Stromadapter keine Halterung angebracht. Die scheint irgendwo in der Produktion gebrochen zu sein. Zudem frage ich mich, ob an dem pcie Anschluss, oder wie das Ding auch immer heist, etwas fehlt…
das am pcb ist normal! da fehlt kein teil vom kontakt
das haben alle mal durchgemacht :d
das mit dem adapter ist natürlich blöd.
tendenziell sogar ein problem.
Ähnliche Themen
