[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Also ich habe die FE jetzt mal mit Standoffs gemodded, laut Artikelbeschreibung 3.5 und 4mm höhe.. bei beiden ist auch bei 30% Fanspeed noch ein Brummen zu vernehmen, ich hab jetzt sogar mal beide aufeinander verbaut :d, brummt immer noch leicht, ist vielleicht etwas besser geworden, kann ich mir aber auch einbilden, aber wie gesagt leider nicht ganz weg, verlangsame ich den Lüfter mit dem Finger verschwindet es ganz.
Die Karte darf aber bleiben.
Wie ist es bei den Zotac Trinitys? Die sehen zwar billig aus, haben aber laut Spulenfiepenthread anscheinend gute Spulen. Brummen da die Lüfter genau so wie bei der AMP oder nicht. Letztere hatte auch ein sehr kurzes Gastspiel in meinem PC…
Spulenfiepen nur bei 150+ FPS, Lüfterrattern aber schon ab 30% also vom Start weg.
Hab mir gestern Abend ein spezielles Afterburnerprofil für mein Hauptgame - Hunt: Showdown erstellt.
700MHz bei 0,9v und Speicher auf -500MHz. PT auf 33%. Erreiche auf Low @4K permanent 130-140FPS mit den Settings und hab nen Stromverbrauch von 120-150W. Lüfter aus. Sehr geil.
genau das ist das geile an so nem vieh. gerade wenn man mal etwas zockt was nicht so anspruchsvoll ist kann man das ding fast passiv betreiben :d
diablo 4
Hoffe so sehr, dass D4 gut wird.
Woher kenne ich das nur.. High End Hardware und am Ende spielt man sowas wie Gothic xD
Meine 4090 strampelt sich hauptsächlich auch mit Civ 5 ab. Verbraucht dabei so ca 52W. :d
In League of Legends taktet die Karte mit 210MHz, aber das würde selbst mein Handy flüssig wiedergeben können :d
AOE2DE gurkt die Karte tatsächlich bei 30% Auslastung bei 700Mhz rum :d
Ich bin immer so der mitleser hier, und dabei ist mir vor allem am Anfang aufgefallen, dass viele den Metro Benchmark benutzen. Also hab ich u.a. den mal her genommen, um meine UV zu testen.
Als ich meine 4090 ichill X3 zurückschicken musste, habe ich mir gedachte die Ergebnisse der Karte behalte ich mal da um später mit der neuen Karte vergleichen zu können. Als am Donnerstag nun meine 4090 AMP extreme ankam, wurde direkt der gleiche Undervolt wie bei der ichill im Metro Bench getestet, und das Ergebnis hat mich definitiv überrascht bzw. verwundert.
Bei beiden Karten ist quasi alles gleich.
Spannung: 950mV, Takt: 2790mhz, Verbauch: bei der krassesten Szene liegt bei etwas über 400W, Temp: 63°- 65° und zu guter letzt die Einstellungen, aber trotzdem kommt die AMP konstant auf 4 FPS weniger.
Das sind doch keine Messtoleranzen mehr oder doch? Kenne mich mit dem Benchmark leider nicht aus, und war jetzt allgemein etwas überfragt, daher dachte ich frag mal hier nach, wo die ganzen Hobby Bencher unterwegs sind :haha:
Gezeigt wird jeweils das beste Ergebnis, der Benchmark lief insgesamt 10 mal am Stück pro Karte. Der Unterschied pro Durchlauf lag bei max 0,17FPS, daher nicht weiter erwähnenswert, würde ich sagen.
Haha, stecke in genau derselben Situation. Die Kohle wäre mir wirklich egal in diesem Fall, selbst wenn die Teurere von beidem verschont bliebe. Aber die FE brummt, die Strix zirpt. Beides irgendwie nicht so pralle.
Ist wirklich ein wenig nervig. Ich beneide jeden, der den Jackpot geknackt hat. Also eine 4090 mit Luftkühlung, die weder fiept, rasselt oder brummt. :)
Mit der gaming oc geht das meistens
Ja die Tage auch mal dead by daylight gespielt . Karte genehmigt sich in 4K Ultra 119 Watt ^^ . Ja man zockt halt was man zockt . Wichtig ist einfach das es läuft .
Bei mir ist es Monster Hunter Rise :ROFLMAO: Braucht auch kaum Leistung in 4K und lief eigentlich mit der 3090 schon perfekt mit 4K120Hz...Aber bald kommen ja die dicken Titel. Freue mich auf Wild Hearts, Resi 4 und Star Wars Jedi Survivor
Hat sich jemand zufällig die 4090 frostbite gegönnt von euch ?
hab da nämlich ne frage an die/den jenigen die sich eine geholt haben und
nutzen :)
nutzen :)
besitze im Moment die 4080 Frostbite und hab die 4090 Frostbite bestellt
Gibt es eigentlich für eine Gainward Phantom ein angepasstes BIOS mit > 450W?
Ich frag für n Freund :d
Von Gainward nicht aber ich denke man kann da wie auf jeder 4090 was anderes drauf flashen. Z.B. Galax 666W oder Strix 600W. Ich würde es aber bei der Phantom nicht machen. Die hat eher ein Budget PCB Layout und verträgt so viel Power vermutlich eher weniger gut. Ich würde bis max 500W gehen, da dies das maximal mögliche ist mit der Phantom GS.
Mit dem Galax Bios nimmt er das höhere PL nicht an. Jedenfalls sah es nicht nach 500w+ aus.
Woran machst du das fest? Es ist ja normal, dass die Karte die 600W+ selbst unter Vollast nicht zieht in vielen Szenarien weil die Spannung limitiert. Die 4090 skaliert halt generell sehr schlecht mit einem höheren PL als 450W. Manche würden sagen, die Karte skaliert ab 300W schon eher schlecht.
Finde es auch krass, dass man als Hersteller lieber 1/3 mehr Verbrauch konfiguriert (450 statt 300W), statt auf etwas Leistung zu verzichten (eh kein Konkurrent da) und ein wirklich gutes Gesamtpaket anzubieten. Wirkt aus der Zeit gefallen. Aber zum Glück kann man nachhelfen.
Blöde Frage warum bauen eigentlich viele ihre GPU Vertikal ein...ich hab das mal mit einer Zotac Amp 4090 angetestet...Vertikal sind die Lüfter
anscheinend viel zu nah an der Glasscheibe und die Temps sind bei mir um 10 Grad höher als horizontal....
Schätze mal die Leistung die AMD bringen wird war vorher nicht klar. Da gab es ja (mal wieder) haarsträubende Gerüchte vorab. Man dachte halt, man muss in die Vollen gehen, weil die Leistungskrone wird man bei Nvidia wohl unter keinen Umständen abgeben wollen nach etlichen Jahren. Mal sehen ob jetzt überhaupt noch eine 4090 Ti kommt. Eigentlich ja total unnötig. Vermute die wird eher als Titan kommen, wenn überhaupt. Da kann man nochmal einen richtigen unverschämten Aufschlag drauf packen :ROFLMAO:
Weils besser aussieht und in meinem Fall auch nicht anders passt. Regulär eingebaut ist die 4090 einfach zu groß.
Temperaturen sind bei mir vertikal aber nur 3-5 Grad höher, nicht 10.
