[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Habe gerade eine Suprim Liquid X da, die völlig anstandslos +2000 auf dem VRAM macht. Bisher nicht ein Bildfehler oder Absturz. Habe auf die schnelle keine Möglichkeit gefunden, das Limit im Afterburner in der .cfg zu erhöhen - oder ist das ohnehin eher Schwachsinn und ich sollte es bei +2000 belassen? Bisher skaliert es wunderbar bis +2000.
Chip ist leider eher eine Gurke, packt gerade so die 3Ghz. Endgeile Karte, sieht schon schick aus.
Die Karten skalieren besser mit dem Speicher. Das ist optimal fürs undervolting.
Ich würde 80% Powerlimit lassen und Speicher auf 1500 laufen lassen. Du wirst ca. 100W weniger Vebrauch haben aber kein Performanceverlust.
Blöde ist halt längerfristig ist AIO auf einer Karte doof , weil die gehen eher schonmal kaputt . Finde die aber auch ziemlich schick.
RDR2 hat 2.2.10. einige versionen zurück. ich teste mal :)
fu rockstar
das erkennt instant dass die datei nicht original ist und das spiel startet nicht ohne das ich auf aktualisierung drücke. er lädt dann die 2.2.10 :fresse:
selbst wenn du die exe ausm ordner startest macht er automatisch das update und und tauscht die datei wieder aus
Hahaha jop, das macht der Rockstar Social Club Launcher bei jedem Start.
Es gibt aber eine Loesung, ein simples batch Script, dass du bei Nexusmods findest, welches das Spiel startet, ein paar Sekunden wartet, bis die checksum durch ist und erst dann schnell die DLSSG DLL austauscht. DLSS 2.2 ist furchtbar bei RDR2 und vor allem Haare von Pferden sehen auch mit Quality Settings katastrophal aus und DLSS schaerft das Bild extrem, also lohnt es sich hier sehr die Zeit zu investieren.
"DLSS 2.5.1, the best version so far of DLSS for RDR2, in my opinion, and with the ugly sharpening filter finally removed."
Hier klicken ->
Dadurch startet das Spiel mit der neuen DLSS Version. Mit Ultra Settings und DLSS Quality auf 5120x1440 immer ueber 120FPS mit der 4090.
Fuer die meisten anderen Launcher empfehle ich die SWAPPER Version aus dem offiziellen GITHUB Projekt, im Gegensatz zur Windows Store Version hat die Version aus dem git Projekt bereits erweiterten Support fuer MS Store, Uplay, EA APP etc....
Hier klicken ->
Viel Spass
Das ist auch meine alternative Lösung. Aber generell scheint es, dass die Verfügbarkeit von RTX 4090 besser wird
Zurzeit scheint Gigabyte RTX 4090 Gaming OC gut verfügbar zu sein, die Testergebnisse sind aber nicht so überzeugend
Meine ist bis auf das schnelle random anlaufen der Lüfter absolut top aber das haben andere Karten wie die FE ja scheinbarauch. Kein fiepen, rasseln und sehr leise Lüfter/super temps + 600 Watt bios und 4 Jahre Garantie. Was soll denn nicht überzeugend sein?
Hab ich gestern auch gefunden. Aber bis es lief.... Die Anleitung von ihm ist fehlerhaft😅
Man muss nämlich beide Dateien im Ordner haben und nicht nur eine😅
haha ja stimmt xD und nicht vergessen auch regelmaessig zu checken vor jedem Start, ob die beiden Files nicht zufaellig wieder die gleiche Groesse haben, weil sie heimlich ueberschrieben wurde. Habe deshalb die aktuelle DLSS eine ebene hoeher und ersetze sie erst mal vor jedem Start. Es it dumm umstaendlich und viel einfacher unter Steam.
eventuell funktioniert es auch den Social Club Launcher im offline Modus zu starten, das muesste man mal testen.
Start your Rockstar Game launcher disable auto login. It means you will have to add everytime your password.
Disable Cloud Saves Play Offline
After this will start always offline mode and can play the story mode.
In case it still doesn't work log in with internet until it arrives to the Menu. ALT + TAB disable your internet.
Exit the Game then with disabled internet push play again in the launcher in offline mode.
Important keep cloud saves disabled and auto login.
IT will work offline mode everytime you close or open the launcher or the pc no need to repeat everytime.
Just remember if you want to update your cloud saves with internet to enable again, after updated just disable again for offline.
Ich bin mit meiner FE auch noch super zufrieden. Sieht toll aus.
Mal sehen ob sich das ändert, wenn ich sie irgendwann mal einbaue. :fresse:
passt sicher nicht mit dem 12pin und du musst, wie die meisten, die Seitenwand wegflexen :bigok:
Also tatsächlich ist die FE um einiges kompakter als alle anderen 4090 (luftgekühlt). Die passte problemlos in mein Mesh 205 (das ist die Breite). Die PNY hingegen nur ganz knapp mit ordentlichem Knick im Adapter und die Strix dann gar nicht mehr.
Die FE ist genau so groß wie eine 3080/Ti/3090/Ti TUF, falls das jemandem was sagt.
Bei 600W PT hätte ich mehr bei Overclocking erwartet:
Aber der Preis ist zurzeit schon verlockend
Ich hab mittlerweile meine 4090Fe auch einbaut ...das Cablemod Kabel ist nun auch nach 6 Wochen angekommen ...ist natürlich zu kurz...die Verarbeitung war aber top...also nochmal neu bestellt . Die Lüfter sind total ruhig ,ob es am vertikalen Einbau liegt?..Spulenfiepen hat Sie, aber deutlich weniger als meine 3090...ich finde es schade das NVidia die Position vom Stecker gegenüber der 3090Fe verändert hat..ich fand's bei der 3090 eigentlich perfekt...somit würden auch einige ihr Case wider zu bekommen...
Ich fände es echt schade. Meine Alternative KFA2 mit Alphacool Core wäre teurer und ohne Garantie.
"Yes, it does void the warranty (Umbau auf WaKü). However, if you put back in original state if you rma, you should be ok."
Das war die Antwort des EU Supports von heute.
Leider ein bunter Plastikbomber aber für unter 2k in Ordnung
Ja sieht aus wie die 3090 nur dicker ;)
Falls einer seine 40er FE auf Wakü umgebaut hat und den Kühler nicht mehr braucht kann gerne mal bei mir im Suchethread vorbeischauen. LINK
Bei Garantiefall könnt ihr ihn dann zurückkaufen 😁
Sieht echt super aus. Überlege im NZXT auch, den vertikalen Einbau auszuprobieren. Allerdings wäre die Karte dann relativ nah an der Scheibe. Und die Temps sollen insgesamt ja auch schlechter sein. Aber ich frage mich gerade wirklich, ob der zweite Lüfter (in Deinem Bild hinten rechts) dann weniger brummt. :unsure: Kann aber auf Grund der Art des Problems eigentlich nicht sein. Er ist ja zu nah an den Lamellen.
Wow, vielen Dank. Dann mache ich mir jetzt mal keine Sorgen mehr. Sollte die Frostbite storniert werden, wird es die KFA2.
600 Watt ist das geringste Problem beim oc. Eher Voltage und da bleibt auch bei der Konkurrenz nicht viel übrig. Memory +1800 und clock +170 bei mir was völlig in Ordnung ist.
Bunter Plastikbomber kann ich auch nicht stehen lassen, eher schwarzer Plastikbomber aber trotzdem noch angenehmer als manch anderes Design wobei das eh alles Geschmackssache ist :LOL:
Das nächste Problem: ich werden Kühlerwechsel wegen Wasserkühlung vornehme. In diesem Fall verliere ich die Garantie. Das ist der Grund, warum ich so zögere, sonst hätte ich längst zugeschlagen.
Selbe Antwort gabs auch von Zotac und bei anderen Herstellern (selbst angefragt).
Zotac Antwort von Donnerstag: "Hi there, Offiziell nein. Die Garantie erlischt. Inoffiziell handhaben wir das so, dass im fall eines defektes der Schaden nicht auf den umbau zurückzuführen werden darf. Die Karte müsste dann auch im originalen Zustand (mit dem originalen Kühler) an uns geschickt werden. "
Nachricht gelöscht
Falls jemand Interesse an einer 4090 Palit hat, die gibt es für 1899€ bei Mindfactory unter mindstar im Moment (grad eben auf Mydealz gesehen) - bei den Verfügbarkeitshinweisen ist die nicht aufgeführt.
Das Kühlerdesign ist aber auch speziell :d
Ihr nennt die immer Bananenkarte, aber wenn die leise und ohne Spulenfiepen ist, was spricht dann gegen die Palit? ^^
Woher kenne ich das nur.. High End Hardware und am Ende spielt man sowas wie Gothic xD
Das kenne ich gut. Bei League of Legends mit 5120x1440 und 240HZ schafft sie aber brav 230-240 FPS zu halten. Vermute, da limitiert aber eher noch die CPU.
Bei Witcher 3 NextGen hat sie - alle Regler oben - aber sehr gut zu tun.
Bei Diablo 2 (sowohl Remastered als auch Original) sieht die Sache natürlich wieder gelassener aus. :coffee2:
Weil die Karte krumm ist und die Backplate keine Wärme ab führt. Wenn du damit leben kannst ist die Karte vom Preis sehr attraktiv.
