• Wir sind dabei, den Suchindex des Forums neu aufzubauen. Bis ca. 6 Uhr morgens kann die Qualität der Suchergebnisse variieren.
[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Weißes Kabel, schwarzer Stecker... tzzzz :d
Hab ich mir erst auch gedacht, allerdings ist die Seite auf der Karte auch schwarz, das passt sehr gut. Der Stecker ist auch etwas nach unten versenkt bei der Strix, daher wird das gut aussehen. Hab ja aktuell das Fasgear dran (nur da ist auch das Kabel schwarz weiß :rolleyes:), da ist es auch so und passt sehr gut.
Lian Li Uni Fans V2 140mm sind auch unterwegs, freu mich drauf. :cool:
Das Fasgear Kabel gab es aber auch ganz in weiß :P aber wenn der Anschluss an der Karte auch schwarz ist passt das ja :d
Hab ich nirgends gefunden, nur eben dieses schwarz weiße. Also "nirgends" im Sinne von mal kurz bei Amazon geschaut und dann eins bestellt. Wollte es eh durch das Seasonic ersetzen nur haben die das Release immer wieder verschoben.
Vielleicht kam das ganz weiße auch erst später dazu (seh grad is auch ein wenig Silber im Spiel), aber wenn du es sowieso ersetzen wolltest (durch das Seasonic) dann passt das ja :d
schau an, 20% sind ja leider vorbei, aber der Preis ist auch nicht schlecht :d, ist in meinem Warenkorb, kann sie in die Freiheit entlassen, eventuell ist es ja die Karte von dem User hier der doch lieber was mit RGB wollte? :d
@hwk, genau, das ist nämlich eigentlich silber, wenn Du das meinst. Das Seasonic ist wirklich weiß. ;)
Hier mal zwei Ergebnisse mit dem, was auf der Graka und CPU @ stock voltage so geht. Habe gehört dass einige hier auch 3.100MHz @ stock schaffen, oder irre ich mich da?
  • Danke
Reaktionen: hwk
Naja 2 Pin auf 12VHPWR gegenüber 3 oder 4 Pin von Cablemod und günstiger
Hab die von Cablemod auch unbenutzt hier und ich mag die irgendwie nicht aufgrund der Anschlüsse. War damals ne Spontanbestellung nach dem Theater mit den verschmorten Steckern. Werd die wohl in den Marktplatz stellen.
Wow das währe aber extrem .... meine Asus 4090 Strix @ Stock geht auf 2865 mhz aber 3.100 mhz @ Stock währe schon sehr seltsam .. mit OC bei Stock Watt und Volt ok aber richtig Stock währe das mehr als Sportlich
Meisten Karten liegen zwischen 2700-2800MHZ .
Viele Karten machen keine 3,1GHZ @ 1,1V .
Da glaube ich Stock schonmal garnicht .
Eher nicht die ist nämlich angeblich immer noch nicht da 😡 zwar zugestellt seit 5 Tagen aber steht immer noch Warten auf Rücksendung mir eh egal Weiße strix jetzt nicht mehr lieferbar wie ich es gesagt habe.
Also OC auf stock Spannung meinte ich, nicht den Boost.
ah okay ... also Spannung auf Stock aber Watt dann nich .. ja da sollte es eigentlich kein Problem sein die 3100 zu erreichen ..
sofern ich mich erinnere hab ich bei meiner auch die 3100 mhz mit Stock Volt und auch Stock Watt schonmal gesehen .. glaub das war auch bei Cyberpunk als ich noch mit dem Vierzack bzw Dreizack gearbeitet hab
und eh nich höher als 450 Watt kamm kann aber auch sein das ich das grad mit 3000 mhz verwechsel is schon ne weile her
Meine Asus 4090 Strix schafft 3060 mhz mit Stock Watt und Volt bei mir höher komm ich nich .. bei 3075 mhz crasht er dann mit Stock Watt und Volt
Ist ja schon mal nicht schlecht. Die Strix hier ist dann wirklich schlecht gebinned für den Preis, wenn überhaupt. Ab 3015MHz Crash. Ist für mich aber ok. Die Temps bleiben immer unter 55/65/62, das finde ich schon krass gut. Dabei bleibt die absolut lautlos.
Ähm, also die Lüfter bleiben lautlos. :d
Es gibt kein Binning bei Grafikkarten...
Na klar gibt's das. Habe doch ca 400€ mehr gezahlt weil bei Asus einer die Karte handverlesen getestet und eingepackt hat. Ich glaub der Chef war's persönlich. :d
Btw... die "Stocks" sind alle. @Stagefire hat "Stock" Verbot für den Rest des Tages.
Hab eine 4090 von Gigabyte (Gaming OC).
Ist das normal, dass die Karte ohne Belastung am Desktop ca. 50 Grad (Hotspot 58) hat mit GPU Clock 210?
Bei den Bechmarks und Spielen geht sie auf 68-70 Grad und Hotspot 78-80° hoch (Lüfter bei 1300rpm).
Finde ich schon sehr hoch.
Joah klingt schon eher warm. Meine FE ist bei 21-22 Grad Raumtemperatur immer so bei 35 Grad im Idle. Ohne UV kriege ich die in Games und Benchmarks aber auch auf 65-70. mit UV eher 60. Also Idle sieht mir etwas hoch aus, aber die Temps in Games und Benchmarks sind schon realistisch wenn man die Stock betreibt. Hab jetzt aber auch keinen direkten Vergleich zu einer anderen Gaming OC. Tendenziell sind die Customs ja eigentlich etwas besser mit der Kühlung als die FE.
50 wahrscheinlich weil fan stop aktiv ist und du nen Brutkasten Rechner hast der Wärme speichert.
Und nein 80 Hotspot bei 1300 sind nicht viel, auch nicht 68-70 beim gamen. Kommt immer auf die Last, Lüftergeschwindigkeit etc an
Hat Mal jemand von euch in letzter Zeit was nach Alternate gesendet. Vor über 1 Woche was als Widerruf zurück geschickt. Am 15.02.23 4:58 laut DHL Sendebericht
Die Sendung wurde direkt ab Paketzentrum dem Geschäftskunden zugestellt.
seit dem Null keine Mail von Alternate das die Retoure eingegangen ist noch sonst was. Das es Mal 2 Tage Dauern kann ist mir bewusst aber das ist jetzt schon einiges Länger.
Laut Hotline ne noch net bei uns, wenn bekommen sie eine Mail mh ja toll.
Sammeln die Retouren erst 1-2 Wochen oder was machen die ?
evt kann ja jemand Licht ins Dunkel bringen.
@Miles2009
Eine Retoure an Alternate ist in der Weihnachtswoche 2022 innerhalb einer Woche bearbeitet gewesen (Rückversand + Bearbeitung bei Alternate).
So schnell ging es bei Alternate sonst nie. Und das noch dazu in der Weihnachtswoche.
Da geht sonst üblicherweise leicht eine weitere Woche ins Land zwischen der Übergabe ab Paketzentrum und der Bearbeitung der Retoure bei Alternate.
Das ist aber bei NBB ähnlich.
Nachricht gelöscht
:d
Steht dein PC offen in Sibirien? :ROFLMAO:
Bei welchem Bench war das?
Warum sollte die Verfügbarkeitsanzeige nicht stimmen?
Ähnliche Themen
