• Wir sind dabei, den Suchindex des Forums neu aufzubauen. Bis ca. 6 Uhr morgens kann die Qualität der Suchergebnisse variieren.
[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Der "Energieverwaltungmodus" steht wie...?
Steht bei mir immer auf Normal. Denke aber nicht, dass es das Problem ist. Einfach ein Bug. Hab eben nen Rollback gemacht bis da entweder ein Hotfix oder neuer Treiber kommt. Kam eh nichts so wirklich für mich interessantes mit dem letzten.
Wenn man sieht wie Ada mit Shadern skaliert anhand der 4090 und 4080 bringen die 2K mehr Shader, die eine 4090Ti oder Titan hätte wohl nicht besonders viel. Mit leicht höherem Takt vllt. +10% im Vergleich zur 4090. Lohnen wird sich das kaum aber ich bin ehrlich: Wenn eine 4090 Ti kommt mit UVP leicht über 2K würde es schon wieder jucken bei mir :fresse: Zumindest wenn die bald erscheint und nicht wieder kurz vor der 50er Serie erst.
Aber grundsätzlich gibt es für Nvidia, finde ich, gerade keinen besseren Zeitpunkt um eine Titan zu releasen. Um die Leistungskrone muss Nvidia die nächsten 1,5 Jahre sowieso nicht kämpfen, jetzt könnte man einfach ein wahres Prestige Produkt raushauen. Und eine Titan für jenseits der 3K wäre dann doch eher uninteressant für mich. Aber mal sehen, aktuell sieht es ja eher nicht danach aus, als wenn Nvidia in naher Zukunft oberhalb der 4090 etwas platziert. Haben sie ja eig. auch nicht nötig. Besser unten rum endlich mal besser aufstellen, dann verkauft man vllt. auch wieder ein paar Grafikkarten.
Kurze Frage.
Wenn du lukü Karten 3 slot Abdeckungen haben und ich auf wakü umbaue, sind da dann die 2 slot Halter dabei oder wo bekomme ich welche her? Ins Silent Base 802 geht vertical nur 2 slot.
Mal ja, mal nein. Bei den Bykski Blöcken z.B. nicht, bei dem Granzon schon bauartbedingt ja.
Ergo: ist i.d.R. von den Blöcken abhängig ... evtl. gibt es auch die 3er als Ersatzteile für Deine Graka, dann kannste im worst case auch einen Slot absägen.
Kurze Frage.
nicht in jedem Fall, das musst Du beim Kühler selbst schauen.
Bei meinen ASUS sind extra nur Dual-Slot-Blenden dran, die kann ich problemlos behalten, aber Icke hatte einige Probleme für die AIRO ne neue Blende zu finden, ich weiß auch aktuell nicht wie da der Status ist.
Eine 4090 TI oder auch 5090 müsste für mich schon einen sehr großen Leistungszuwachs haben, um umzusteigen.
Für F@H sind die 4090er mit UV einfach ideal, bzw. um Klassen effizienter, als die im Verhältnis viel stromhungrigeren 3xxx oder gar die lahmen 2xxx ...
Beim Gaming kommt halt immer noch der Joker mit DLSS3 inkl. Frame Generation hinzu. Klar ist es ein optischer Kompromiss, ab ich habe keine Probleme damit auch nicht mit dem Input Lag. Getestet bei Witcher 3 und Hogwarts Legacy. Wie gesagt 4090 + DLSS3 bläst jede Karte aus dem Rennen. Gerade am oberen Ende im Bereich 4k/120fps.
Gibt es eigentlich ne Undervolting Tabelle irgendwo von der RTX 4090?
Hab bisher mal so 900mV bei 2700 takt probiert, das stürzt aber sofort ab bei meiner Karte. Würde gerne wissen, was man so erwarten kann bei welcher mV Zahl um mich dann daran zu hangeln bevor ich jetzt komplett durchtesten muss.
Servus zusammen!
Überlege gerade ob ich mir eine ASUS TUF 4090 non OC hole und mein Corsair AX850 Titanitum dafür ausreicht?
ASUS gibt auf ihrer Page ein 1000W Netzteil an bei einem Ryzen 9 | 5900X ... denke dir gehen auf Nummer sicher oder?
Wär toll wenn ihr mir ein paar Tips oder Erfahrungen mitteilen könntet. Danke
Servus zusammen!
Bei mir im Zweitsystem läuft die Combo 5900X / 4090 Strix mit einem Corsair RM850x ohne Probleme.
Wenn Du die Tuf nur mit den 450 Watt (oder sogar UV) betreibst und nicht auf die theoretisch möglichen 600 Watt gehst, reicht Deine PSU dicke mit der CPU.
Ok, das hört sich ja schon mal sehr gut an.
UV werde ich auf jeden Fall machen, das hat schon bei meiner 3080 gut was gebracht.
Jetzt mal noch schlau machen was diesen Adapter angeht. Ich meine recherchiert zu haben, das der von NVIDIA nicht so biegebereit ist.
Danke euch.
die Premium-Variante ist da nochmal etwas biegsamer, da die Adern einzeln liegen (aktuell 27,90 EUR)
sind auch oben beim Link vom @Youngtimer mit dabei, aber eben auch das Standard
Dito. Auch wenn die Strix auf 600w PL läuft reichen meine 850w, solange es ein Marken NT ist.
Fehlarlarm. War nie verfügbar.
Tses, so einfach verpasst man unnötig vielen Menschen einen Herzinfarkt. NBB sollte Ausgleichszahlungen an die Krankenkassen leisten. :fresse:
Servus zusammen!
Bei mir verbraucht das Komplettsystem (4090 FE mit UV, 5800X3D, 7 Lüfter, Aio Kühler und RGB) unter Vollast so um die 500W. Ohne UV kann es auch mal 600W sein, aber mehr auch nicht
Entweder das oder wieder ein "Wir-Verkaufen-Einfach-neu-versiegelte-Rückläufer-als-Neuware"-Drop mit nur sehr wenigen Karten.
Gabs überhaupt schon eine 4090 FE als B-Ware im NBB-Shop? Wenn, dann ist es sehr lange her.
Irgendwo müssen solche Karten ja hinkommen.
Hats jedenfalls beim letzten Drop so gegeben (20.02.2022).
Hier mit dem klassichen großen NBB-Karton anstelle des OVP-Versandkartons:
Die ursprünglichen Siegel von nVidia sind nicht mehr vorhanden gewesen:
Dafür hat NBB dann diesen hier angebracht:
Und 2 Hinterlassenschaften vom vorherigen Nutzer:
4090 FE 20230222 Gebraucht als Neu (6).JPG 4090 FE 20230222 Gebraucht als Neu (7).JPG
  • Danke
Reaktionen: SH
Anscheinend auch schon wieder weg. Wie war das mit der Nachfrage? ;)
Also ich bin bis zum Zahlvorgang gekommen. Hab dann aber nicht weiter gemacht, brauche ja keine.
Zum Thema Nachfrage, ich gehörte ja nie zu denen, die hier ständig behaupten die Karten würden in den Regalen versauern.
Ähnliche Themen
