• Wir sind dabei, den Suchindex des Forums neu aufzubauen. Bis ca. 6 Uhr morgens kann die Qualität der Suchergebnisse variieren.
[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Danke euch, das hört sich ja mal sehr gut an.
Alles liegt bereit, nur Block fehlt noch.
Bin mal gespannt ob es nächste Woche endlich mal klappt.
... und der Nagellack ist genau für was? ^^
Flüssigmetallbremse ...
Oh ok, wieder was gelernt! Danke
Sei vorsichtig, damit du nicht so endest :fresse:
Bringt LM denn überhaupt was bei der 4090, die lässt sich doch eh schon sehr gut kühlen? Oder einfach habenwill?
@Tundor
Wäre nicht dass erste mal bei mir.
RIP 3090
Wieso machst du es dann nochmal, du hast doch bei der 4090 viel mehr zu verlieren als zu gewinnen? Ist natürlich deine Entscheidung, versuche es nur zu verstehen :d Selbst mit konventioneller Paste ist man mit nem guten Wakü Block ja noch Meilenweit vom Temp Limit entfernt.
Einfach habenwill :-)
Dann genehmigt 😅
Daumendrück 🙈
@Tundor
RIP 3090
Einfach nicht so rum sauen damit dann klappt das auch ohne Nagellack aber gut da geht man dann halt auf Nummer Sicher.
Hatte nun etliche Karten mit Liquid drauf .
Weniger ist meist mehr.
Nicht vergessen von beiden Seiten beschichten (einreiben) den DIE und Kühler.
Ich hab auch erstmal immer einen kleinen Abdruck mit Paste genommen also einmal kurz den Kühler auf das PCB gesetzt damit ich am Kühler sehe wo das Liquid drauf muss.
Dann mit einer Haarnadel die Eckpunkte auf dem Kühler leicht angerissen wo der Abdruck zu sehen ist vom Die so das das Liquid dann auch nur bis da Aufgetragen wird.
Da reicht ein klitzer kleiner Punkt es sollte hauch dünn aufgebracht werden da darf kein See zu sehen sein nur leicht feucht das reicht.
Viel Erfolg!
Ich nehme lieber dieses...
Günstiger und mehr drin
Bringt schon was, aber wirklich nötig ist es nur, wenn man hohe Scores haben will
Bei meinem delided 13900K war es absolut wichtig, weil dessen Energiedichte viel höher ist, als die der 4090
Also selbst mit der TG Kryonaut Extreme war es unmöglich, diese CPU über Direct-Die anständig zu kühlen
Meine 4090 suprim schafft bei cyberpunk gamestable 3060- 3075 mhz bei +220 +1000
Was haut ihr da so raus ?
Musst uns schon deine Settings mitteilen, wenn du eine vernünftige Antwort erwartest.
Die Preise gehen ja aktuell ganz gut runter Gaming Trio 4090 für 1798 € bei PC King. Die Suprim für 1900 mit Cash Back...
Werde es die Tage denke ich noch mal wagen....
Was für Cashback? Bei MSI direkt?
Sacht mal an die, die ihre 4090 mit Vapor Champer vertikal montiert haben, wie die MSi Suprim zb.
Hat das bei euch Einfluss auf die Kühlleistung der Karte?
Gab schonmal Situation wo dem so war bei älteren Grakas , dass die Heatpipes nicht richtig funktioniert haben je nach Position.
Hatte das Phänomen dass das Delta zwischen GPU und GPU Hotspot größer war als bei den anderen um paar Kelvin am Anfang .Dieses ist dann mit der Zeit geschrumpft . Warum und weshalb keine Ahnung .Karte anfangs vertikal ohne Case und dann normal horizontale Position im Case.
Also wenn ich sehe wie die ganzen Tech Tuber ihre Karten vertikal testen, sollte das wohl kein Problem (mehr?) darstellen.
Ist aber natürlich jetzt kein wissenschaftlicher Beleg. Wann immer ich das mal bei mir getestet habe, gab es aber einen maximalen Unterschied von ein bis zwei Grad. Also selbst wenn eher verschmerzbar.
Ähnliche Themen
