[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Karte rennt wieder, max 50° 😁
Hier sind paar Bilder als ich die Karte auseinander genommen habe.
ist der EK Block für eine Zotac, korrekt? Meiner kam heute an....was war der Fehler?
Zu dicke Pads😄
Jetzt läuft alles, max. Temp. 50° bis jetzt👍
Jetzt brauche ich nur noch jemand wo mir beim aufräumen hilft.
Endlich wieder ruhe im Kasten.
Habe meine Strix eben eingebaut und in Betrieb genommen, alles läuft hier mit stock Bios,
aber die Karte taktet den Speicher im Idle nicht runter, woran könnte das liegen??
Zu dicke Pads😄
hast du die beigelegten hergenommen oder andere?
Welcher Trenner nutzt ihr intern? Sind die QD3s da immer noch das Maß der Dinge? Überlege auch mir für die Graka mal noch welche einzubauen, leider ist halt der Platz / Schlauchweg da auch begrenzt da es von GPU zur CPU ja echt nur wenige cm sind, das ist dann ja ziemliches gefummel.
Ich benutze die hier, war immer zufrieden.
LM und die 1mm Pads von Gelid gehen immer am besten bei mir.
Die beigelegten Pads kannst auch benutzen, da machst auch nicht falsch.
Anleitung hast nehm ich mal an.
Falsche Link vorhin, habs korrigiert.
Ich nutze für Hauptkomponenten QD3...
Was ich nicht so toll finde, ist entkuppeln an der 4090
Die Feder in QD3 ist so stark, dass es beim Entkuppeln an der GPU einen heftigen Ruck am Block gibt, während das PCB fix gehalten wird
btw:
Der Gesamt-Flow mit vielen QD3 im Loop ist aber besser als vermutet - 300L/h :d
sollte er mal checken wie krumm sein Die ist.
sobald es zu krumm ist, ist LM eher suboptimal, dadurch das WLP nicht ganz so dünnflüssig ist, kann sie diese Spalten besser überbrücken.
Was wäre in deinen Augen "zu krumm"?
Stell mal am Messschieber 0,1mm ein und schaue durch den Spalt ;)
LM hat eine recht hohe Oberflächenspannung und wird auch bei mehr als 0,1mm Unebenheit des Die durch die Kapillarwirkung zw. Die und Block "gehalten"
btw:
Das ist "krumm" (durch die Spiegelung wirkt es auf dem Bild extrem) :fresse:
Delided 13900K - das CPU-PCB war 1:1 genauso stark gebogen, wie der CPU-Die. Da bin ich leider nicht der Einzige. Dagegen ist der GPU-Die meiner TUF regelrecht "plan" :d
Hab die das Problem gefunden, man darf auf dem Desktop keine 240hz haben, ab 120hz geht der Speicher wieder normal runter im Idle.
Anleitungen schreiben kann EK aber, muss man ihnen lassen. Das ist Bykskis größte Schwachstelle aus meiner Sicht.
Danke fürs Verlinken, die nehme ich zum Auseinanderschrauben meiner Zotac später :)
Gibt es keinen europäischen Distributor?
Ach komm, das gänzliche Fehlen einer Anleitung gehört zum Erlebnis dazu! Unvergessen der Moment, wenn der PC gestartet wird und man dann erst erfährt, ob man es richtig oder falsch gemacht hat...
CableMod Variant B passt auch bei der msi 4090 suprim x
dass das kabel nach unten geht
[Bild]
Bekommst du den Stecker auch wieder raus?
Weil die Haltenase ja nun vom Stecker verdeckt wird.
ja mit einem kleinen Schraubendreher von der Seite bekommt man die Nase gedrückt
Naja, beim Alphacoolkühler bei der SuprimX geht es mit dem normalen Kabel auch schon nur mit einem kleinen Schraubendreher. Aber ob man dann mit dem Adapter noch ran kommt, könnte ich mir schwer vorstellen.
ich hab auch dutzende Pärchen QD3, aber wie durch Zauberhand hängen jetzt auf einmal mehrere, trotz oder vielleicht auch weil ich die so oft löse :heul:
Bis vor kurzem hatte ich die Probleme überhaupt nicht, nur mal bei 1 oder 2 schwarzen
Dass die schwarzen (zumindest die früheren Versionen) Probleme machen ist ja bekannt. Meine silbernen laufen eigentlich gut bis jetzt die sind halt relativ groß für im Gehäuse aber möglich ist es natürlich.
korrekt, auch weil sich die Beschichtung löst
bis jetzt waren meine auch gut, aber jetzt sind mind. 2 weibliche mit >80% Wahrscheinlichkeit nicht dicht. Die schließen nicht mehr, wenn man sie trennt. Am Anfang ging das noch mit neu verbinden und nochmal trennen, jetzt auch nicht mehr so wirklich.
Ich hab aber ca. 10 Paar oder so verbaut und bisher ist es mir bei den beiden jeweils am Mora aufgefallen
Hab jetzt extra ne Verlängerung dran gemacht, damit ich nicht jedes Mal über der Strix trennen muss, ist mir aktuell zu heikel ;)
In der Regel am Treiber oder an DEN Monitoren. Bzw. der Refreshrate/Auflösungs-Kombination.
Treiber-Reinstall haste sicher gemacht.
Ist mehr als ein Monitor drann? Dann mal den 2. vom Kabel abziehen?
Eventuell den Desktop mal auf 120hz runterschrauben. Du hast den Treiber ja so eingestellt das er in Games die Graka voll ausfährt und am Desktop "nur" 120hz tut nicht weh.
Ah, erst später gesehen. Sorry.
Ähnliche Themen
