[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Tja sowas macht man max. ein oder zweimal.
Erstmal eine der Lieblingskarten. FE oder Strix/Tuf zb. und kann man das nicht ertragen nimmt man eine Karte im Ref. Design mit den hohen Spulen.
Passt das einem auch nicht lässt man es halt bleiben. Die meisten die 10-20 Karten bestellen und retounieren machen das zum selektieren.
Ist keine schöne Sache , aber es ist wie es ist...
Naja dazwischen gibt es einen Mittelweg und Karten zu verkaufen statt sie zurück zu senden ...
@Topic
Schaut mal, Gerüchte über eine 4090ti gab es schon kurz nach Release der 4090:
So kann man eigentlich schon fast sagen, dass sich dieses Gerücht nicht bestätigt hat, oder Nvidia hat nicht genug bessere Chips zusammen sammeln können....
Man hat sich einfach entspannt zurückgelehnt als die AMD Karten raus kamen. Die wurden ja viel stärker erwartet. Zumindest das Topmodell.
Mal was interessantes, Gestern hat Krisfix einen Lifestream gemacht.
Fazit, Karte gut stützen bzw. vertikal einbauen. Nicht im PC versenden und möglichst Finger weg vom Kühler wenn man keinen Plan hat.(Schon durch leichte Biegekräfte können die Pads der Rams bzw. der Gpu beschädigt werden. Die meisten Karten stammen wohl von einem großen Versender der PC's mit den Karten im Rechner verschickt, das kann nur schief gehen ;)
ich halte deshalb auch die anti sag methode von jay für nicht gut. er drückt die karte an der slotseite "runter" damit sie am anderen ende oben bleibt. das ist genauso mist.
Auch wenn ich das auch nicht so gut finde und mir generell keine Sorgen wegen GPU Sag mache, gab es diese Methode schon bei Phanteks von Haus aus.
bei 5:15
auch das reicht meiner Meinung nach nicht wirklich. Im Idealfall hat meine eine Art Schublade oder Schlitten in der solche schweren Karten gerade gehalten werden können. Ich bin erhrlich gesagt ganz froh über den irrsinnigen Haltewinkel der 4090 Gaming OC. Auch wenn ich sonst kein Fan von GB bin. Aber die Kühlung der Speicherchips, der Winkel und die hohe Chance auf wenig bis gar nicht wahrnehmbares Spulenfiepen liesen mir keine ander Wahl.
Und Komplett-PC Versender müssen sich was überlegen. Vielleicht gibts Form Schaumstoffteile (oder andere, nachhaltigere Materialien) mit denen man die Lücken ausfüllen könnte. Bei den Brocken ist jedes unsanfte Abstellen schon schwierig. Bei einem Sturz kannst du das urbi et orbi sprechen (lassen).
Einfach das 1000W XOC VBIOS von Anus druff, dann wuppt das. :sneaky:
Sonst würde wohl kaum jeder zweite Hersteller eine mit AiO Kühler rausbringen und fast keiner eine mit Block.
Bei den AIO Karten ist die Obsoleszenz halt irgendwo eingebaut, außerdem koscht so ein Alu Radi und eine Asetek Style AIO in China halt auch vergleichsweise wenig.
Habe meine undervolted 4090 Gaming OC dauerhaft auf 60% Lüfter laufen und habe sogar noch einen 120er Lüfter an die freie Stelle mit den Finnen der Backplate drangetan per klebepads. Komme so gut wie nie an 60° C beim Gaming 😂👍
Gibt es da eine Datenbasis, die das bestätigt, dass die Hersteller bei ihren Aios minderwertige Komponenten verbauen und dem zu Folge die Pumpen rasch kaputt gehen?
Immerhin bieten Gigabyte bei der Waterforce 4 Jahre Garantie.
Die OEMs die AIOs herstellen sind halt teilweise nicht unbedingt ein Garant für Qualität, Probleme gibt es da genug, die mal früher oder mal später in Erscheinung treten.
Zum Thema Giagbyte Waterforce gibt es dann auch etwas eher unrühmliches zu sehen:
Immerhin gibbet ja eine neure Revision, die die Probleme nicht haben könnte. :sneaky:
Ich kann natürlich selber nur über die Rev.1.1 berichten und kann sagen, dass es dort keine Temperaturprobleme mit dem Speicher gibt.
hätte ne kleine Frage zu den 4090 Karten.
Habe gelesen, das manche (FE+Asus Strixx+KFA2+Gigabyte) 4090 Karten im Dual Monitor Betrieb mit zwei Monitoren mit jeweils 144Hz oder mehr angesteuert, nicht in den Zero Fan Modus (=Lüfter aus) schalten und die Lüfter immer mit ihrer minimum Drehzahl laufen.
Da ich mich für eine KFA2 4090 SG 1-Click OC interessiere (wegen Spulenfiepen), habe ich den KFA2 Support angeschrieben und folgendes erhalten:
>>> Scheint wohl für die KFA2 tatsächlich wahr zu sein :-(
Ist das wirklich bei manchen oder allen 4090 Karten so ? Wie ist das bei euch ?
Hatte gerade Gelegenheit das Video zu gucken...
Darin geht nicht hervor, welches BIOS ab Werk drauf ist
Kann mir aber nicht vorstellen, dass da das 1.000W-BIOS drauf ist. Bei dem es keinerlei Limits gibt
btw:
+600mV ist schon ein Wort
Bei insgesamt "nur" 1,22V @ Wasser bekomme ich schon Angst :d
Spannend wäre zu wissen, ob "Boost Master" auch auf normalen Strixen mit entsprechendem BIOS funktioniert
Dazu müsste man aber Zugang zu Beidem haben
btw:
Gerade nochmal nachgesehen...
Mit nur 1,13V fast 1.000W Input-Power
Gesamtleistung (CPU und RAM waren @ default - nicht mal XMP)
AiO mag zwar nicht Jeder, die Matrix (der "Kingpin-Ersatz") ist trotzdem interessanter, als eine Ti, falls die irgendwann kommen sollte
Und wieviel mehr Leistung haben diese selektierten GPUs?, vll 5%. Meist sind die selektierten GPUs für OC/Benchmarking aber im realen Szenario nur unwesentlich schneller.
Ich finde die Matrix interessant, die Frage stellt sich nur, wie gut ist deren AIO Lösung.
Die Frage ist auch was sie denn Kühlen will, so gut wie jede 0815 Karte der 4090er kühlt ausreichend.
Der Bauer hat ja nicht nur Kartoffeln sondern auch die 4090 mal übertaktet mit Voltmod.
Für den E-Penis sicher gut, aber es macht einfach keinen Sinn, überproportionaler Stromverbrauch bei x Prozent Leistungszuwachs.
Einfach nur eine weitere Idee den Leuten die Kohle aus der Tasche zu ziehen.
Naja, sollte deren AIO Kühllösung wirklich gut und leise sein, wäre sie durchaus interessant. Jedoch nicht, dass sie neue Spulen hat und vorselektiert ist. Dann kommt es auch auf den Preis an, da es bereits gute 4090er AIO Lösungen gibt. Sich im Herbst nochmal eine neue 4090 zu kaufen ist möglicherweise auch nicht sonderlich ratsam (wenn man schon eine 4090 hat). Denke nächstes Jahr wird sicher eine 4090Ti/Titan kommen!
Preis geht ja noch aber d.h., die Matrix wird sicher um die 2600€ kosten.
AIO ist bei vergleichbarer Leistung immer lauter als ne abgesetzte Pumpe im Kreislauf. Weil sich die AIO-Pumpe nicht entkoppeln lässt, denn sie sitzt ja idR starr auf der Leiterplatte(=ResonanzFläche).
Ähnliche Themen
