• Wir sind dabei, den Suchindex des Forums neu aufzubauen. Bis ca. 6 Uhr morgens kann die Qualität der Suchergebnisse variieren.
[Sammelthread] OnePlus 7/7Pro - Thread
Jimmi
Jena
OnePlus 7Pro
Grunddaten:
Abmessungen
162.6×75.9×8.8mm
Gewicht
206g
Back Material
3D Corning® Gorilla® Glass
Farben
Mirror Gray/Nebula Blue/Almond
CPU
Qualcomm® Snapdragon™855 (Octa-core, 7nm, up to 2.84 GHz), with Qualcomm AI Engine
GPU
Adreno 640
RAM
6GB/8GB/12GB LPDDR4X
Speicher
128GB/256GB UFS 3.0 2-LANE
Sensoren
In-display Fingerprint Sensor, Accelerometer, Electronic Compass, Gyroscope, Ambient Light Sensor, Proximity Sensor, Sensor Core, Laser Sensor
Ports
USB 3.1 GEN1, Type-C, Support standard Type-C earphone
Dual nano-SIM slot
Akku
4000 mAh (non-removable) Warp Charge 30 Fast Charging (5V/6A)
Vibration
Haptic Vibration
Tasten
Gesten- und Bildschirmnavigationsunterstützung
Alert Slider
Audio
Duale Stereo-Lautsprecher
Geräuschunterdrückung
Dolby Atmos®
Entsperroptionen
Face Unlock
Konnektivität
LTE
4×4 MIMO, LTE Cat. 18, DL 5CA, UL CA, Supports up to DL Cat18 /UL Cat13 (1.2Gbps /150Mbps), depending on carrier support
Frequenzbänder
FDD LTE: B1,2,3,4,5,7,8,12,13,17,18,19,20,25,26,28,29,32,66
TDD-LTE: B34,38,39,40,41
TDS: B34,39
UMTS: B1,2,4,5,8,9,19
CDMA: BC0,BC1
GSM: B2,3,5,8
Wi-Fi
2x2 MIMO, Wi-Fi 802.11 a/b/g/n/ac, 2.4G/5G
Bluetooth
Bluetooth 5.0, support aptX & aptX HD & LDAC & AAC
NFC
NFC-fähig
Positionsbestimmung
GPS (L1+L5 Dual Band), GLONASS, Galileo (E1+E5a Dual Band), Beidou, SBAS, A-GPS
Display Format
6.67 inches(The corners of the screen are within a standard rectangle. Measured diagonally, the screen size is 6.67 inches in the full rectangle and 6.46 inches accounting for the rounded corners.)
Auflösung
3120 x 1440 pixels 516ppi
Seitenverhältnis
19.5:9
Typ
Fluid AMOLED
Glasabdeckung
Features
Support sRGB, Display P3
Video Enhancer
Lesemodus
Nachtmodus
Rear camera
Kamera hinten - Haupt
Sensor: Sony IMX586
Megapixels: 48
Pixel Size: 0.8 µm/48M; 1.6 µm (4 in 1)/12M
Lens Quantity: 7P
OIS: Yes
EIS: Yes
Aperture: f/1.6
Telephoto Lens
Megapixels: 8
Pixel Size: 1.0µm
OIS: Yes
Aperture: f/2.4
Ultra Wide Angle Lens
Megapixels: 16
Aperture: f/2.2
Field of View: 117°
Flash
Doppelter LED-Blitz
Video
4K video at 30/60 fps
1080P video at 30/60 fps
Super Slow Motion: 1080p video at 240 fps, 720p video at 480 fps
Time-Lapse
Video Editor
Features
UltraShot, Nightscape, Studio Lighting, Portrait, Pro Mode, Panorama, HDR, AI Scene Detection, RAW Image
Frontkamera
Sensor: Sony IMX471
Megapixels: 16
Pixel Size: 1.0 µm
EIS: Yes
Autofocus: Fixed Focus
Aperture: f/2.0
Video
1080P video at 30fps
Zeitraffer
Features
Face Unlock, HDR, Screen Flash, Face Retouching
Test's:
OnePlus 7 Pro im Hands-on: Premium-Dreiklang aus Performance, Display und Kamera
OnePlus 7
Grunddaten:
Abmessungen
157.7×74.8×8.2 mm
Gewicht
182g
Back Material
3D Glass, Corning® Gorilla® Glass
Farben
Mirror Gray / Red(CHINA&INDIA only)
CPU
Qualcomm® Snapdragon™ 855 (Octa-core, 7nm, up to 2.84 GHz) , with Qualcomm AI Engine
GPU
Adreno 640
Vibration
linear motor
RAM
6/8GB LPDDR4X
Speicher
128/256GB UFS3.0 2-LANE
Sensoren
Ports
Dual nano-SIM slot
Akku
3700 mAh (non-removable) Fast Charging (5V 4A)
Tasten
Gestures and on-screen navigation support
Left: Volume Key; Right: Power Key, Alert Slide
Audio
Dolby Atmos®
Entsperroptionen
Face Unlock
Konnektivität
LTE/LTE-A
4×4 MIMO, LTE Cat.16, DL 5CA, UL CA, Supports up to DL Cat.16/ UL Cat.13 (1Gbps/150 Mbps), depending on carrier support
Bands CHINA & INDIA & EU
FDD LTE: Band 1/2/3/4/5/7/8/12/13/17/18/ 19/20/25/26/28/29/30/32/66/71
TDD LTE: Band 34/38/39 / 40 / 41 / 46
TD - SCDMA: Band 34/39
UMTS(WCDMA): Band 1/2/4 / 5 / 8 / 9 / 19
CDMA: BC0/ BC1
GSM: 850 / 900 / 1800 / 1900 MHz
Auf die schnelle erstellt, wird erweitert.
(Verbesserung, Anregungen ... bitte PM)
Mein erster Eindruck ist ambivalent. Kurz zu mir, iOS User aus Überzeugung, allerdings immer mal im Android Lager unterwegs (z.B OnePlus 3, 3T und 5), letztendlich aber immer wieder zurück zu Apple. Direktes Vergleichsgerät ist mein XS Max.
Was soll ich sagen, das 7 Pro ist ein solides, gutes Smartphone. Bisher (nutze es seit dem heutigen Mittag) aber nicht mehr. Es kann Vieles gut, aber nichts so richtig einzigartig gut dass es mich komplett abholt. Klar, das Display ist eine Klasse für sich und derzeit einfach Klassenbester. Aber sonst?!?
Die Software zeigt kleine Macken, Doppel Tap to Wake funktioniert nicht (mehr), die blauen Streifen bei Benachrichtigungen habe ich bisher überhaupt nicht zu Gesicht bekommen. Sicherlich Kleinigkeiten, die per Update behoben werden können.
Meine Tendenz geht bisher eher zur Retoure, aber über das Wochenende bekommt das 7 Pro noch seine faire Chance
Mir geht es ähnlich wie Matze,
komme aktuell vom iPhone X. Das X ist mir nach 1,5 Jahren etwas langweilig geworden, was neues musste her. Das OnePlus 7 Pro hat mich sofort überzeugt, also direkt bestellt. Nutze das Gerät nun seit 2 Tagen. Bisher sehr zufrieden, es ist unfassbar schnell. Das X im direkten Vergleich kommt mir sehr langsam vor. Vieles hat sich getan bei Android, war auch die meiste Zeit iOS Nutzer. Nun kann ich kaum noch Kritikpunkte finden. iOS macht ein paar Sachen einfacher, dafür kann Android deutlich mehr. Die Einstellungsvielfalt ist enorm bei Android, dazu ist es super flüssig. Was ich etwas schade finde, die Apps sehen nach wie vor schöner aus für iOS und sind meiner Meinung nach besser programmiert. Werde das OnePlus denke ich behalten, was es zum für mich perfekten Smartphone machen würde, eine noch deutlich bessere Kamera. Diese sehe ich gerade Mal auf iPhone X Niveau, welches bald 2 Jahre alt wird. Der Rest ist absolut auf Highend Niveau, teils sogar drüber, da es neue Maßstäbe setzt. Lags oder der gleichen gibt es bei mir nicht. Alles läuft, wie es soll.
Hast du den Fingerabdruck in einem dunklen Raum eingerichtet?
So sollte man es zumindest bei dem 6T machen. Wird hier ja nicht anders sein,
da es ebenfalls ein optischer Sensor ist.
Das kann dann noch etwas helfen.
Puh, ist schon ein geiles Gerät, hätte ich so nicht erwartet.
Paar Bugs müssen noch behoben werden, aber ansonsten erst mal geil.
Ans Gewicht habe ich mich im Laufe des Tages schon gewöhnt.
Aber wenn du voll und ganz zufrieden bist, geht es dir doch gar nicht wie Matze :d
- - - Updated - - -
Mal zu was anderem: Warum hat niemand von euch über das normale 7er nachgedacht? Das hat ja im Grunde alles, was das Pro hat, außer den High-End Bildschirm und die dritte (unnötige?) Kamera.
... Mal zu was anderem: Warum hat niemand von euch über das normale 7er nachgedacht? Das hat ja im Grunde alles, was das Pro hat, außer den High-End Bildschirm und die dritte (unnötige?) Kamera.
Ganz einfach, ich wollte keine Kerbe im Display, für eine (für mich) unnötige Kamera.
Das Display ist schon richtig genial, auch wenn die Edges für mich echt gar keinen Vorteil bieten, ganz im Gegenteil.
Das Gewicht stört beim längeren Zocken oder Surfen schon ein bisschen.
Kamera ist wie bereits überall geschrieben gut, aber nicht der Knaller.
Was bei mir trotz mehrfachen Neueinrichten echt nicht gut funktioniert ist der Fingerprint, nervt richtig.
Habe es im Dunkeln eingerichtet und im Hellen auch, trotzdem funktioniert er oft erst beim dritten Anlauf.
Kaum schreib ich es, funktioniert er perfekt, wtf.
Momentan bin ich echt nicht sicher, ob ich es behalte, mal gucken.
Moin,
jetzt halte ich es auch in den Händen seit heute morgen. Der erste Eindruck ist folgender: Verarbeitung top, aussehen Top (obwohl ich ausversehen doch das schwarze bestellt habe), Software super flüssig wie beim Pixel 3 xl., Bildschirm ist top, aber das vom Note 9 ist ebenbürtig. Fingerprint Sensor ist so mittelmäßig bis jetzt.Mal sehen wie ich das verbessern kann. Volte und WiFi call habe ich auch aktiviert mit meiner Vodafone Karte .
Jemand schon Mal die GCam app getestet? Bei mir stürzt die aktuelle Beta immer ab. Falls jemand was brauchbares hat, bitte her damit.
Schon nicht so geil, je nach Licht und App die man gerade nutzt sind sie störend bis gar nicht störend. Bin hin und her gerissen.
Bei Spielen zb sind sie gut und stören null.
Sobald aber Text in den Edges ist, nervt es mich.
Allerdings bin ich heute irgendwie von dem Gerät mehr angetan als gestern noch. Ist echt schwer zu beschreiben :d
Gegen die Qualität der Kamera kann ich überhaupt nichts sagen, erst recht nicht, wenn ich den gcam Mod nutze, aber da hatte ich auch noch nie hohe Ansprüche.
Bin mir unsicher wie lange nicht. Ich habe halt schiss das ich jetzt auslasse und mich das P4 auch nicht überzeugt.
Und mein 2er muss eigentlich zur Reparatur.
Das Edge Thema wirst du nur klären können, wenn du das Gerät mindestens zwei Tage hast und benutzt. Ich mache sowas sonst nie, aber notfalls schickst du es zurück. Auch im Laden begrabbeln würde hier nichts bringen, man muss es wirklich nutzen.
Seitdem hat sich aber einiges getan vor allem bei Samsung
Edge stört kaum noch
Ohne wäre es trotzdem deutlich geiler.
Neues Update ist da, mal gucken ob es was für die Kamera bringt.
Kamera wird nachher Mal gestetet. Leider ist die Benachrichtigungs LED (anzeige) nicht besser. Ist einer der Funktion die ich echt vermisse. Kann man nicht wenigstens eine paar Pixel für eine Benachrichtigung LED missbrauchen?
In den Foren wird Pulse Beat empfohlen, funktioniert bei mir aber auch nicht zuverlässig. Kannst es ja mal testen.
So nach zwei Tagen habe ich meinen Frieden mit dem 7 Pro geschlossen und werde es behalten :d Es war keine Liebe auf den ersten Blick, aber wir haben uns zusammen gerauft. Mein XS MAX ist bereits verkauft (hätte gar nicht gedacht dass es so eine große Nachfrage gibt).
Ich bin nun doch abgesprungen. Edge, Durchschnittliche Kamera, Schlechte Benachrichtigungen und kein AOD waren doch zu viel.
Ich geh dann mal all in aufs P4 XL.
Wird vermutlich das richtige sein für dich. Wenn man vorher schon so viele Zweifel hat, macht es wenig Sinn.
Es ärgert mich eigentlich, da ich das Display und die Ausfahrbare Kamera wirklich mega geil finde.
Aber es sind eben oft die kleinlichkeiten die einen zufrieden stellen, und da bin ich manche Dinge vom pixel gewöhnt die ich nicht aufgeben will.
