How much cpu performance do you need?
If you want to go for low power consumption a intel nuc (or similar platforms) might be the better choice with also more performance, but cheaper. It's based on mobile platforms. But however you can't connect many drives.
You can buy NUC with Celeron 5000 up to i7, depending on how much performance you need.
