BobbyD
Experte
- Laptop
- https://psref.lenovo.com/Detail/Legion/Legion_5_17ACH6H?M=82JY005RGE
@Supaman Ja, schon beides probiert.
Edit:
Edit:
Sep 01 00:00:45 prox1 systemd[1]: Starting dpkg-db-backup.service - Daily dpkg database backup service...
Sep 01 00:00:45 prox1 systemd[1]: Starting logrotate.service - Rotate log files...
Sep 01 00:00:45 prox1 systemd[1]: dpkg-db-backup.service: Deactivated successfully.
Sep 01 00:00:45 prox1 systemd[1]: Finished dpkg-db-backup.service - Daily dpkg database backup service.
Sep 01 00:00:45 prox1 systemd[1]: Reloading pveproxy.service - PVE API Proxy Server...
Sep 01 00:00:47 prox1 pveproxy[438048]: send HUP to 1761
Sep 01 00:00:47 prox1 pveproxy[1761]: received signal HUP
Sep 01 00:00:47 prox1 pveproxy[1761]: server closing
Sep 01 00:00:47 prox1 pveproxy[1761]: server shutdown (restart)
Sep 01 00:00:47 prox1 systemd[1]: Reloaded pveproxy.service - PVE API Proxy Server.
Sep 01 00:00:47 prox1 systemd[1]: Reloading spiceproxy.service - PVE SPICE Proxy Server...
Sep 01 00:00:48 prox1 spiceproxy[438068]: send HUP to 1768
Sep 01 00:00:48 prox1 spiceproxy[1768]: received signal HUP
Sep 01 00:00:48 prox1 spiceproxy[1768]: server closing
Sep 01 00:00:48 prox1 spiceproxy[1768]: server shutdown (restart)
Sep 01 00:00:48 prox1 systemd[1]: Reloaded spiceproxy.service - PVE SPICE Proxy Server.
Sep 01 00:00:48 prox1 systemd[1]: Stopping pvefw-logger.service - Proxmox VE firewall logger...
Sep 01 00:00:48 prox1 pvefw-logger[1753]: received terminate request (signal)
Sep 01 00:00:48 prox1 pvefw-logger[1753]: stopping pvefw logger
Sep 01 00:00:48 prox1 systemd[1]: pvefw-logger.service: Deactivated successfully.
Sep 01 00:00:48 prox1 systemd[1]: Stopped pvefw-logger.service - Proxmox VE firewall logger.
Sep 01 00:00:48 prox1 systemd[1]: pvefw-logger.service: Consumed 11.029s CPU time.
Sep 01 00:00:48 prox1 systemd[1]: Starting pvefw-logger.service - Proxmox VE firewall logger...
Sep 01 00:00:48 prox1 pvefw-logger[438081]: starting pvefw logger
Sep 01 00:00:48 prox1 systemd[1]: Started pvefw-logger.service - Proxmox VE firewall logger.
Sep 01 00:00:48 prox1 systemd[1]: logrotate.service: Deactivated successfully.
Sep 01 00:00:48 prox1 systemd[1]: Finished logrotate.service - Rotate log files.
Sep 01 00:00:50 prox1 spiceproxy[1768]: restarting server
Sep 01 00:00:50 prox1 spiceproxy[1768]: starting 1 worker(s)
Sep 01 00:00:50 prox1 spiceproxy[1768]: worker 438086 started
Sep 01 00:00:50 prox1 kernel: pveproxy invoked oom-killer: gfp_mask=0x140cca(GFP_HIGHUSER_MOVABLE|__GFP_COMP), order=0, oom_score_adj=0
Sep 01 00:00:51 prox1 kernel: CPU: 0 PID: 1761 Comm: pveproxy Tainted: P O 6.2.16-10-pve #1
Sep 01 00:00:51 prox1 kernel: Hardware name: Virtuozzo KVM, BIOS 1.11.0-2.vz7.4 04/01/2014
Sep 01 00:00:51 prox1 kernel: Call Trace:
Sep 01 00:00:51 prox1 kernel: <TASK>
Sep 01 00:00:51 prox1 kernel: dump_stack_lvl+0x48/0x70
Sep 01 00:00:51 prox1 kernel: dump_stack+0x10/0x20
Sep 01 00:00:51 prox1 kernel: dump_header+0x50/0x290
Sep 01 00:00:51 prox1 kernel: oom_kill_process+0x10d/0x1c0
Sep 01 00:00:51 prox1 kernel: out_of_memory+0x23c/0x570
Sep 01 00:00:51 prox1 kernel: __alloc_pages+0x1180/0x13a0
Sep 01 00:00:51 prox1 kernel: alloc_pages+0x90/0x1a0
Sep 01 00:00:51 prox1 kernel: folio_alloc+0x1d/0x60
Sep 01 00:00:51 prox1 kernel: filemap_alloc_folio+0xfd/0x110
Sep 01 00:00:51 prox1 kernel: __filemap_get_folio+0x1d4/0x3c0
Sep 01 00:00:51 prox1 kernel: filemap_fault+0x14a/0x940
Sep 01 00:00:51 prox1 kernel: ? _raw_spin_unlock+0xe/0x40
Sep 01 00:00:51 prox1 kernel: ? filemap_map_pages+0x14b/0x6f0
Sep 01 00:00:51 prox1 kernel: __do_fault+0x39/0x150
Sep 01 00:00:51 prox1 kernel: do_fault+0x1c7/0x430
Sep 01 00:00:51 prox1 kernel: __handle_mm_fault+0x6d9/0x1070
Sep 01 00:00:51 prox1 kernel: handle_mm_fault+0x119/0x330
Sep 01 00:00:51 prox1 kernel: ? lock_mm_and_find_vma+0x43/0x230
Sep 01 00:00:51 prox1 kernel: do_user_addr_fault+0x194/0x620
Sep 01 00:00:51 prox1 kernel: exc_page_fault+0x80/0x1b0
Sep 01 00:00:51 prox1 kernel: asm_exc_page_fault+0x27/0x30
Sep 01 00:00:51 prox1 kernel: RIP: 0033:0x7f4ddeff3d70
Sep 01 00:00:51 prox1 kernel: Code: Unable to access opcode bytes at 0x7f4ddeff3d46.
Sep 01 00:00:51 prox1 kernel: RSP: 002b:00007ffedf617288 EFLAGS: 00010246
Sep 01 00:00:51 prox1 kernel: RAX: 00007f4ddd71295b RBX: 00007f4ddd716e08 RCX: 0000000000000000
Sep 01 00:00:51 prox1 kernel: RDX: 00007ffedf617380 RSI: 00007f4ddf170250 RDI: 00007ffedf617360
Sep 01 00:00:51 prox1 kernel: RBP: 00007ffedf6177f0 R08: 00007f4dd91da270 R09: 0000000000000024
Sep 01 00:00:51 prox1 kernel: R10: 0000000000000035 R11: 0000000000000246 R12: 0000000000000000
Sep 01 00:00:51 prox1 kernel: R13: 0000000000000000 R14: 000055f84a0f5f90 R15: 00007f4ddd71295b
Sep 01 00:00:51 prox1 kernel: </TASK>
Sep 01 00:00:51 prox1 kernel: Mem-Info:
Sep 01 00:00:51 prox1 kernel: active_anon:10065 inactive_anon:1847495 isolated_anon:0 active_file:25 inactive_file:18 isolated_file:0 unevictable:0 dirty:0 writeback:29 slab_reclaimable:4955 slab_unreclaimable:55066 mapped:11748 shmem:11902 pagetables:5963 sec_pagetables:0 bounce:0 kernel_misc_reclaimable:0 free:26405 free_pcp:118 free_cma:0
Sep 01 00:00:51 prox1 kernel: Node 0 active_anon:40260kB inactive_anon:7389980kB active_file:100kB inactive_file:72kB unevictable:0kB isolated(anon):0kB isolated(file):0kB mapped:46992kB dirty:0kB writeback:116kB shmem:47608kB shmem_thp: 0kB shmem_pmdmapped: 0kB anon_thp: 1165312kB writeback_tmp:0kB kernel_stack:3952kB pagetables:23852kB sec_pagetables:0kB all_unreclaimable? no
Sep 01 00:00:51 prox1 kernel: Node 0 DMA free:14336kB boost:0kB min:128kB low:160kB high:192kB reserved_highatomic:0KB active_anon:0kB inactive_anon:0kB active_file:0kB inactive_file:0kB unevictable:0kB writepending:0kB present:15992kB managed:15360kB mlocked:0kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:0kB
Sep 01 00:00:51 prox1 kernel: lowmem_reserve[]: 0 2872 7850 7850 7850
Sep 01 00:00:51 prox1 kernel: Node 0 DMA32 free:46748kB boost:2048kB min:26728kB low:32896kB high:39064kB reserved_highatomic:0KB active_anon:18652kB inactive_anon:2813160kB active_file:152kB inactive_file:72kB unevictable:0kB writepending:116kB present:3129200kB managed:3010796kB mlocked:0kB bounce:0kB free_pcp:460kB local_pcp:0kB free_cma:0kB
Sep 01 00:00:51 prox1 kernel: lowmem_reserve[]: 0 0 4978 4978 4978
Sep 01 00:00:51 prox1 kernel: Node 0 Normal free:44536kB boost:0kB min:42772kB low:53464kB high:64156kB reserved_highatomic:2048KB active_anon:21608kB inactive_anon:4576820kB active_file:0kB inactive_file:0kB unevictable:0kB writepending:0kB present:5242880kB managed:5097500kB mlocked:0kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:0kB
Sep 01 00:00:51 prox1 kernel: lowmem_reserve[]: 0 0 0 0 0
Sep 01 00:00:51 prox1 kernel: Node 0 DMA: 0*4kB 0*8kB 0*16kB 0*32kB 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 1*2048kB (M) 3*4096kB (M) = 14336kB
Sep 01 00:00:51 prox1 kernel: Node 0 DMA32: 180*4kB (UME) 890*8kB (UME) 362*16kB (UME) 761*32kB (UME) 106*64kB (UME) 13*128kB (UM) 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 46432kB
Sep 01 00:00:51 prox1 kernel: Node 0 Normal: 388*4kB (UME) 107*8kB (UME) 703*16kB (UME) 709*32kB (UMEH) 116*64kB (UM) 4*128kB (M) 1*256kB (M) 0*512kB 0*1024kB 0*2048kB 0*4096kB = 44536kB
Sep 01 00:00:51 prox1 kernel: Node 0 hugepages_total=0 hugepages_free=0 hugepages_surp=0 hugepages_size=1048576kB
Sep 01 00:00:51 prox1 kernel: Node 0 hugepages_total=0 hugepages_free=0 hugepages_surp=0 hugepages_size=2048kB
Sep 01 00:00:51 prox1 kernel: 12015 total pagecache pages
Sep 01 00:00:51 prox1 kernel: 0 pages in swap cache
Sep 01 00:00:51 prox1 kernel: Free swap = 0kB
Sep 01 00:00:51 prox1 kernel: Total swap = 0kB
Sep 01 00:00:51 prox1 kernel: 2097018 pages RAM
Sep 01 00:00:51 prox1 kernel: 0 pages HighMem/MovableOnly
Sep 01 00:00:51 prox1 kernel: 66104 pages reserved
Sep 01 00:00:51 prox1 kernel: 0 pages hwpoisoned
Sep 01 00:00:51 prox1 kernel: Tasks state (memory values in pages):
Sep 01 00:00:51 prox1 kernel: [ pid ] uid tgid total_vm rss pgtables_bytes swapents oom_score_adj name
Sep 01 00:00:51 prox1 kernel: [ 735] 0 735 8280 224 98304 0 -250 systemd-journal
Sep 01 00:00:51 prox1 kernel: [ 777] 0 777 6585 320 69632 0 -1000 systemd-udevd
Sep 01 00:00:51 prox1 kernel: [ 1059] 103 1059 1969 128 53248 0 0 rpcbind
Sep 01 00:00:51 prox1 kernel: [ 1125] 101 1125 2304 192 53248 0 -900 dbus-daemon
Sep 01 00:00:51 prox1 kernel: [ 1130] 0 1130 38187 128 61440 0 -1000 lxcfs
Sep 01 00:00:51 prox1 kernel: [ 1131] 0 1131 69539 128 86016 0 0 pve-lxc-syscall
Sep 01 00:00:51 prox1 kernel: [ 1136] 0 1136 4159 256 61440 0 0 systemd-logind
Sep 01 00:00:51 prox1 kernel: [ 1137] 0 1137 583 32 40960 0 -1000 watchdog-mux
Sep 01 00:00:51 prox1 kernel: [ 1138] 0 1138 1327 96 45056 0 0 qmeventd
Sep 01 00:00:51 prox1 kernel: [ 1140] 0 1140 60164 256 86016 0 0 zed
Sep 01 00:00:51 prox1 kernel: [ 1159] 0 1159 1766 115 49152 0 0 ksmtuned
Sep 01 00:00:51 prox1 kernel: [ 1356] 0 1356 615 32 45056 0 0 bpfilter_umh
Sep 01 00:00:51 prox1 kernel: [ 1401] 0 1401 1256 96 45056 0 0 lxc-monitord
Sep 01 00:00:51 prox1 kernel: [ 1420] 0 1420 1468 64 45056 0 0 agetty
Sep 01 00:00:51 prox1 kernel: [ 1428] 0 1428 3851 384 69632 0 -1000 sshd
Sep 01 00:00:51 prox1 kernel: [ 1443] 100 1443 4715 202 57344 0 0 chronyd
Sep 01 00:00:51 prox1 kernel: [ 1456] 100 1456 2633 210 57344 0 0 chronyd
Sep 01 00:00:51 prox1 kernel: [ 1517] 0 1517 181841 307 176128 0 0 rrdcached
Sep 01 00:00:51 prox1 kernel: [ 1534] 0 1534 281223 14654 458752 0 0 pmxcfs
Sep 01 00:00:51 prox1 kernel: [ 1627] 0 1627 10664 166 73728 0 0 master
Sep 01 00:00:51 prox1 kernel: [ 1629] 104 1629 10774 224 73728 0 0 qmgr
Sep 01 00:00:51 prox1 kernel: [ 1634] 0 1634 1652 96 45056 0 0 cron
Sep 01 00:00:51 prox1 kernel: [ 1654] 0 1654 37828 22753 294912 0 0 pve-firewall
Sep 01 00:00:51 prox1 kernel: [ 1655] 0 1655 36446 21408 290816 0 0 pvestatd
Sep 01 00:00:51 prox1 kernel: [ 1742] 0 1742 56157 31595 393216 0 0 pvedaemon
Sep 01 00:00:51 prox1 kernel: [ 1743] 0 1743 58462 32268 442368 0 0 pvedaemon worke
Sep 01 00:00:51 prox1 kernel: [ 1744] 0 1744 58536 32204 442368 0 0 pvedaemon worke
Sep 01 00:00:51 prox1 kernel: [ 1758] 0 1758 53186 25932 352256 0 0 pve-ha-crm
Sep 01 00:00:51 prox1 kernel: [ 1761] 33 1761 54564 29981 425984 0 0 pveproxy
Sep 01 00:00:51 prox1 kernel: [ 1768] 33 1768 19973 12448 196608 0 0 spiceproxy
Sep 01 00:00:51 prox1 kernel: [ 1769] 33 1769 20033 12581 188416 0 0 spiceproxy work
Sep 01 00:00:51 prox1 kernel: [ 1771] 0 1771 53066 25749 352256 0 0 pve-ha-lrm
Sep 01 00:00:51 prox1 kernel: [ 1801] 0 1801 1099721 651464 6082560 0 0 kvm
Sep 01 00:00:51 prox1 kernel: [ 1984] 0 1984 563288 246747 2654208 0 0 kvm
Sep 01 00:00:51 prox1 kernel: [ 17767] 0 17767 51969 26251 348160 0 0 pvescheduler
Sep 01 00:00:51 prox1 kernel: [ 220616] 0 220616 58370 32012 413696 0 0 pvedaemon worke
Sep 01 00:00:51 prox1 kernel: [ 223908] 0 223908 1099892 951662 8372224 0 0 kvm
Sep 01 00:00:51 prox1 kernel: [ 233042] 33 233042 60642 34468 442368 0 0 pveproxy worker
Sep 01 00:00:51 prox1 kernel: [ 242072] 33 242072 61096 34629 450560 0 0 pveproxy worker
Sep 01 00:00:51 prox1 kernel: [ 282591] 33 282591 60026 33657 430080 0 0 pveproxy worker
Sep 01 00:00:51 prox1 kernel: [ 426172] 104 426172 10764 160 73728 0 0 pickup
Sep 01 00:00:51 prox1 kernel: [ 437881] 0 437881 1366 32 49152 0 0 sleep
Sep 01 00:00:51 prox1 kernel: [ 438081] 0 438081 19796 64 49152 0 0 pvefw-logger
Sep 01 00:00:51 prox1 kernel: [ 438086] 33 438086 20029 12602 184320 0 0 spiceproxy work
Sep 01 00:00:51 prox1 kernel: oom-kill:constraint=CONSTRAINT_NONE,nodemask=(null),cpuset=pveproxy.service,mems_allowed=0,global_oom,task_memcg=/qemu.slice/102.scope,task=kvm,pid=223908,uid=0
Sep 01 00:00:51 prox1 kernel: Out of memory: Killed process 223908 (kvm) total-vm:4399568kB, anon-rss:3806264kB, file-rss:384kB, shmem-rss:0kB, UID:0 pgtables:8176kB oom_score_adj:0
Sep 01 00:00:51 prox1 kernel: vmbr2: port 3(tap102i0) entered disabled state
Sep 01 00:00:51 prox1 kernel: zd0: p1 p2 p3
Sep 01 00:00:51 prox1 systemd[1]: 102.scope: A process of this unit has been killed by the OOM killer.
Sep 01 00:00:51 prox1 systemd[1]: 102.scope: Failed with result 'oom-kill'.
Sep 01 00:00:51 prox1 systemd[1]: 102.scope: Consumed 5h 7min 58.655s CPU time.
Sep 01 00:00:51 prox1 pveproxy[1761]: restarting server
Sep 01 00:00:51 prox1 pveproxy[1761]: starting 3 worker(s)
Sep 01 00:00:51 prox1 pveproxy[1761]: worker 438273 started
Sep 01 00:00:51 prox1 pveproxy[1761]: worker 438274 started
Sep 01 00:00:51 prox1 pveproxy[1761]: worker 438275 started
Sep 01 00:00:52 prox1 qmeventd[438238]: Starting cleanup for 102
Sep 01 00:00:52 prox1 qmeventd[438238]: Finished cleanup for 102
Sep 01 00:00:55 prox1 spiceproxy[1769]: worker exit
Sep 01 00:00:55 prox1 spiceproxy[1768]: worker 1769 finished
Sep 01 00:00:56 prox1 pveproxy[233042]: worker exit
Sep 01 00:00:56 prox1 pveproxy[242072]: worker exit
Sep 01 00:00:56 prox1 pveproxy[282591]: worker exit
Sep 01 00:00:56 prox1 pveproxy[1761]: worker 233042 finished
Sep 01 00:00:56 prox1 pveproxy[1761]: worker 282591 finished
Sep 01 00:00:56 prox1 pveproxy[1761]: worker 242072 finished
