#!/bin/bash
echo standby 0 | cec-client.exe -s
starting cec-client, and type this, followed by enter:
tx 10 44 6c
Mediacenter:~ # cec-client
No device type given. Using 'recording device'
CEC Parser created - libCEC version 2.1.3
no serial port given. trying autodetect:
path: /sys/devices/pci0000:00/0000:00:12.0/usb3/3-4
com port: /dev/ttyACM0
opening a connection to the CEC adapter...
DEBUG: [ 28] unregistering all CEC clients
DEBUG: [ 28] Broadcast (F): osd name set to 'Broadcast'
ERROR: [ 3533] error opening serial port '/dev/ttyACM0': Couldn't lock the serial port
ERROR: [ 3533] could not open a connection (try 1)
ERROR: [ 6368] error opening serial port '/dev/ttyACM0': Couldn't lock the serial port
ERROR: [ 6368] could not open a connection (try 2)
ERROR: [ 8258] error opening serial port '/dev/ttyACM0': Couldn't lock the serial port
ERROR: [ 8258] could not open a connection (try 3)
ERROR: [ 9518] error opening serial port '/dev/ttyACM0': Couldn't lock the serial port
ERROR: [ 9518] could not open a connection (try 4)
NOTICE: [ 10523] connection opened
ERROR: [ 10523] could not start CEC communications
unable to open the device on port /dev/ttyACM0
Mediacenter:~ # cec-client -l
ERROR: [ 3532] error opening serial port '/dev/ttyACM0': Couldn't lock the serial port
ERROR: [ 3532] could not open a connection (try 1)
ERROR: [ 6367] error opening serial port '/dev/ttyACM0': Couldn't lock the serial port
ERROR: [ 6367] could not open a connection (try 2)
ERROR: [ 8257] error opening serial port '/dev/ttyACM0': Couldn't lock the serial port
ERROR: [ 8257] could not open a connection (try 3)
ERROR: [ 9517] error opening serial port '/dev/ttyACM0': Couldn't lock the serial port
ERROR: [ 9517] could not open a connection (try 4)
Found devices: 1
device: 1
vendor id: 2548
product id: 1002
firmware version: 65535
