[Sammelthread] Raritäten - bis Jahr 2000 - Bilder und Kommentare
Titan Majesty TTC-M1AB
so ähnlich ;)
Habe heute mal meinen 486er wieder frisch gemacht:
Mainboard: FIC 486-VIP-IO
CPU: AMD AM486DX4 100
RAM: 64MB
GPU:Spea V7 VEGA PCI 1MB
Sound: Creative Labs CT2760 Sound Blaster AWE32 + RAM + Roland SCB55
NIC: 3com Etherlink III
HDD: Noname Slot Adapter + 512MB CF Card
ODD: Mitsumi FX0001DE
FDD: 1,44MB 3,5"
AMD486 2021_04 (1).JPG AMD486 2021_04 (2).JPG AMD486 2021_04 (3).JPG AMD486 2021_04 (4).JPG AMD486 2021_04 (5).JPG AMD486 2021_04 (6).JPG AMD486 2021_04 (7).JPG AMD486 2021_04 (8).JPG AMD486 2021_04 (9).JPG AMD486 2021_04 (10).jpg SpeedSYS.jpg
Würde gerne eine bessere GPU einbauen und das Soundkarten Set ist sinnfrei, also noch nicht fertig die Kiste ^^
Zerlegter A4000D der gerade aufbereitet wird mit Cybervision 64 + Cyberstorm MK2 mit 68060.
Anbei das BIOS für das Board mit K6-III+ Support, falls du es mal brauchst ;)
Tekram P5M3-A+ motherboard BIOS V1.04
with patch J.1 for AMD K6-2+ and K6-III+ support.
11/02/2001
by Jan Steunebrink
The latest, and probably final, BIOS upgrade from Tekram for the P5M3-A+
is the version 1.04.
This BIOS does not support the (mobile) K6-2+/III+ CPUs.
To overcome this problem, I have patched the P5M3A104 BIOS to include proper
recognition and handling of the K6-2+/III+.
I've made the following changes:
- Added detection of the K6-2+ and K6-III+ CPUs
- Expanded the CPU Type display routine for correct display of the
AMD-K6(tm)-2+ and AMD-K6(tm)-III+ strings
- Changed the K6 Write Allocation feature to work also on the K6-2+/K6-III+
- Expanded the K5/K6 busspeed/multiplier/CPU speed detection to work for the
K6-2+ and K6-III+ as well.
For all other functions, my patched BIOS is identical to the original V1.04,
so you don't have to clear the CMOS if you upgrade from a V1.04 BIOS.
The filename of the patched BIOS is P5M3A_J1.BIN and you can flash it with
the flash program you normally use to flash a P5M3-A+ BIOS upgrade.
Please take the usual precautions when flashing your BIOS.
Refer to Tekram's web-site at
for the proper flash procedure and the AWDFLASH program.
Note that, although this patched BIOS has been tested on different P5M3-A+
systems without any problems, it is provided "as is" and you use it
at your own risk.
I like to thank everybody who participated in testing this BIOS.
Jan.
Homepage: http://web.inter.nl.net/hcc/J.Steunebrink/
E-mail : J.Steunebrink@net.HCC.nl
// EDIT //
Handbuch noch beigefügt.
  • tekrambios.zip
  • p5m3aplus_100S.pdf
  • Tekram p5m3aplus_100H.pdf
Für 11,50 Euro inkl. kann man den mal mitnehmen:
Pentium 60 SX835
Und schönen guten Tag, wer ist denn da? :LOL:
Pentium 90 SX957
Ganz sauber ist er noch nicht...
Und ja sorry, ich konnte es nicht lassen... 🙈
Pentium 75 SX961
Ich lade gerade den Akku meiner Kamera, dann versuche ich mal ordentliche Makroaufnahmen...
Hachja, die gute alte Zeit als es noch ALi, ULi, ATi, VIA, SiS & Intel bei Chipsätzen gab, später dann noch AMD & nVidia und was ist heute übrig? AMD & Intel, der rest ist Konkurs, Aufgekauft oder nicht mehr von Bedeutung.
Naja, eher: Hat keine Lizenz um Chipsätze zu bauen.
Intel hat die ja nach und nach auslaufen lassen und dann nicht mehr verlängert.
Dürfen Monitore hier auch rein?
Habe vor ein paar Wochen einen 17" LG Flatron 795FT Plus gefunden. Wichtig war mir, dass Strom und VGA Kabel abnehmbar ist. Der zusätzliche USB Hub ist natürlich super.
Ich habe ihn schon angefangen zu putzen und nun habe ich gesehen, dass er viel Dreck und Staub auf der Elektronik innen liegen hat, Wie lange kann sich denn die Aufladung in der Röhre halten?
Bzw. wenn ich die Röhre erde, dürfte ja keine Gefahr mehr bestehen oder?:fresse2:
in meinem damals ersten PC den mir jemand schenkte war meine ich ein Pentium 3 drin, sone Aufsteckcpu Board Geschichte mit schwarzem Kühler in Plastik verkleidet, weis nur leider nicht mehr welcher es genau war und Bilder existieren nicht mehr bzw hat den auch niemand fotografiert.
Ich weis nur noch das nach dem später der neue PC da stand und Mutter sagte, den alten schmeißen wir weg.... ich dann meinen Tatendrang mit rumbasteln ausgelebt hab. Erst alles zerlegt, Netzteil usw weil ich als kleiner Bub wissen wollte wies drinnen so ausschaut(hab dsmals alles im Haus zerlegt und wieder zusammen gebaut)
Und dann alles wieder komplettiert und irgendwie kam ich dann vor der Entsorgung mit nem Kumpel drauf zu testen wie viele Bauteile man im laufenden Betrieb von der Mainboardplatine abreißen kann bis nix mehr geht :fresse2: 😂
Erstaunt waren wir das sich recht viele kleine Bauteile entfernen ließen und die Kiste noch immer ging. Irgendwann kamm dann halt Bauteil xyz und er ging aus 🙈
Makaber aber immerhin noch etwas Bastelspaß bevor Mutter ihn eh entsorgt hätte, überlebt hat bis heute hier nur die Matrox Millenium G400 Grafikkarte die ich schonmal zeigte aus dem Ding.
Wäre witzig wenn es den heute noch geben würde
Ich habe gestern angefangen, meinen ersten, selbstgekauften PC von 1996 nachzubauen.
Den MediaMarkt Katalog Feb.96 dazu hab ich noch und auch schon mal gescannt hier gepostet. Es geht um diesen Network Rechner:
2019 hab ich dann eher zufällig das Gehäuse bekommen:
Der Zustand ist nicht sooo toll, Gilb, Kratzer und Rost vorhanden. Mein Ziel ist aber auch nicht, hier eine neuwertige 1:1 Kopie aufzubauen, sondern ein used PC wie er damals hätte sein können.
Mittlerweile habe ich bis auf Netzteil und CD-Rom Laufwerk alle Teile zusammen, so soll er ungefähr werden:
Network Gehäuse. Wird nur gereinigt und bekommt ein bisschen retrobright. Rost wird entfernt, aber nicht neu lackiert.
Pentium 150@ 166 oder P166mmx. Aktuell steckt noch ein 233mmx drin.
Azza PT-5IV = Sockel 7 AT Mainboard mit Intel VX Chipsatz, 4x ISA and USB
32 oder 64MB FPM, EDO oder SDRAM. Da werde ich die Stabilität und Performance noch austesten
Matrox Mystique mit 2+2 RAM
Diamond Monster
AWE32 + RAM + Wavetable oder AWE64 Gold
Keine Festplatte, nur CF
Windows 95b
Gestern mal zusammen gesteckt:
Laufen tuts super, keine Probleme bei der Installation. Aktuell eine 4GB CF Karte drin. Zum testen habe ich Win98se genommen und vor dem installieren einfach die Installationsdaten auf die CF geschoben. Ging schnell und leise. 3D Benchmarks laufen über die 3dfx und die Mystique sauber durch.
Hatte auch schon nach einen besser passenden CD-Rom geschaut, aber mein 3fach Wechsler ist wohl hin und mein Creative LW ist proprietär. Alle anderen nicht verbauten sind zu neu. Ein 4- oder 6fach wäre super, da muss ich noch mal schauen......
Zum Geburtstag das Bundle von EKA letztens gegönnt ;)
Das kann ein 1999er PC werden wenn man ein Auge zudrückt. Muss mal sehen wann die KX133er Board rauskammen
P.S. ich war dreist und hab 5€ mehr angeboten als er eig. haben wollte ;)
Ach du hast es geschnappt? Viel Spaß damit, muss ich wohl noch etwas länger Slot A-Zeug suchen.
ich dachte es mir gerade fast selber.... aber hab die Abkürzung noch nie gehört😄
Die wollten doch den KX133 erst als KZ133 rausbringen und mussten den dann erstmal umlabeln, nachdem sich aufgrund des Kürzel ein "paar" Leute beschwert hatten.
