CORSAIR Marcus
Corsair Support
Hallo zusammen!
Hier könnt ihr die aktuellen Release Notes von iCUE einsehen, inkl. einem Link zum download.
iCUE 5.9.105 Issues Resolved
Software Enhancements
- Resolved an issue that causes iCUE to crash on startup
- Resolved an issue with LS100 that causes iCUE to crash on device disconnect
- Resolved a conflict with iCUE with devices missing a manufacturer label in the USB string
- Improved the usability of vertical sliders when resizing the window
- Moving the window across monitor screens during an iCUE installation will no longer result in a black bar
- Resolved an issue with Launch Application that opens a folder instead of the application
- Users can now remove device modules even when iCUE is not connected to the internet
- Resolved an issue that causes other actions to be highlighted when assigning a modifier key
- Users will no longer be able to remove a module while it is updating
- Resolved various Dashboard bugs with adding and removing sensor widgets
- Nanoleaf in Canvas will no longer cause iCUE to crash after pairing multiple devices
- The LED ring will now properly rotate with the LCD on all LCD-based coolers
- Custom Fan Curves now properly work when used with various CPUID sensors
- Removing a Custom Cooling Fan Curve will no longer cause all fans to revert to the Balanced preset
- Hiding the graph for DIY devices will now properly work after an iCUE restart
- Resolved a conflict with data shown in Alerts when users switch between Fahrenheit and Celcius
- Voyager A1600 Cooler will no longer be shown as a Xeneon monitor
- Device Settings will no longer be missing features after a firmware update on H100i ELITE LCD coolers
- Custom Screen Preview will no longer show the wrong image with LINK LCD-based devices
- Resolved various minor bugs with the LCD screen and image customization
- DDR4 modules will no longer appear together with DDR5 modules (and vice versa)
- iCUE will no longer show Vengeance PRO DRAM as a name if it has been replaced with DOMINATOR DRAM
- Updated the hyperlink in the notification for DOLBY ATMOS
- The front LED and light edge LED on GLAIVE mice will no longer play incorrectly in iCUE
- M65 RGB PRO now properly saves hardware lighting to the device
- Resolved an issue with text overrun with various languages that prevented users from saving a Hardware Profile
- Resolved an issue that prevented “Disable Key if Lock Button is On” from functioning
- The lighting playback is now properly synchronized between iCUE and the device for the Control Wheel tab
- Resolved an issue with NEXUS when using Lighting Link
- ENVISION PRO will no longer show battery status as Unknown at near-empty battery levels
- Resolved an issue with audio devices crashing iCUE when switching from PlayStation to Multipoint Mode
