ColinMacLaren
- Ort
- Chemnitz
- Desktop System
- Hartz4 Build wegen AMD GPU
- AMD Ryzen 7 9800X3D
- Gigabyte X870 Gaming X Wifi 7
- ARCTIC Liquid Freezer II 280
- 32GB Corsair VENGEANCE DDR5 6000MHz CL30
- Gigabyte 7900XTX Gaming OC
- LG OLED 32GS95UE-B
- 2x1TB WD SN550@Raid0, 1x2TB Kingston NV3
- Soundkarte
- Sound Blaster AE-9 Plus
- Fractal Design North White Mesh
- Corsair RM850 850W
- Keyboard
- Wooting 60HE
- Mouse
- Finalmouse Ultralight X @Wallhack SP-004 Faith Yume
- Windows 11 Ghostspectre 24H2
- Webbrowser
- Opera
- Sonstiges
- Beyerdynamic Xelento, Beyerdynamic T5P, Audeze Penrose
- Internet
- ▼250 MBit ▲50 MBit
Sorry für das Englisch, möchte jetzt nicht noch einmal alles übersetzen.
I just found out that the software package provided for the Recon 3D USB also includes drivers for every Creative USB product (down to the Audigy 2NX). These drivers are of a newer build (1.03.01.04) than the ones available on the support page of every card (which are always 1.02.x or older). It also includes updated Alchemy and Host OpenAL packages.
Then I had a look at the X-Fi MB2 Mod Pack for Realtek-Chips that is floating around the net. It includes a separate THX-Console as well as newer versions of the Audio Control Panel and Host OpenAL.
So I mixed it all together and uploaded it to my server. Drivers and in the case your card supports it, Dolby Digital Live, need to be installed manually, because I'm tpo lazy modifying the setup.
Creative USB Audio Drivers: 1.03.01.04
Creative ALchemy: 1.43.13
Creative Console Launcher: 2.61.53
Creative Audio Control Panel: 3.00.62
Creative Dolby Digital Live Pack: 3.01.00
Creative EAX Gadget: 1.00.04
Creative Volume Panel: 2.60.03
Host OpenAL: 2.02.56
THX TruStudio Pro Settings: 1.04.03
Should definitively work with the X-Fi HD USB and the X-Fi Surround Pro 5.1, likely with the X-Fi USB Go! Pro. For older cards without TruStudio-Support there is at least an updated driver, the utilities may work or may not.
If Alchemy doesn't recognize your card use 1.43.06 from the Pax-Master-Suite 2.05. The provided works with my X-Fi HD USB though.
Click!
Kein Support, das Ding war nur für mich gedacht und ist einfach nur aus öffentlich verfügbaren Teilen zusammenkopiert.
Click!
