2014:06:23-12:35:21 Astaro audld[23150]: Starting Up2Date Package Downloader
2014:06:23-12:35:21 Astaro audld[23150]: patch up2date possible
2014:06:23-12:35:26 Astaro audld[23150]: id="3701" severity="info" sys="system" sub="up2date" name="Authentication successful"
2014:06:23-12:35:26 Astaro audld[23150]: id="3707" severity="info" sys="system" sub="up2date" name="Successfully synchronized fileset" status="success" action="download" package="avira3"
2014:06:23-12:35:27 Astaro auisys[23208]: Starting Up2Date Package Installer
2014:06:23-12:35:28 Astaro auisys[23208]: Searching for available up2date packages for type 'man9'
2014:06:23-12:35:28 Astaro auisys[23208]: id="371D" severity="info" sys="system" sub="up2date" name="No up2date packages available for installation" status="failed" action="preinst_check" package="man9"
2014:06:23-12:35:33 Astaro auisys[23208]: Searching for available up2date packages for type 'appctrl3'
2014:06:23-12:35:33 Astaro auisys[23208]: id="371D" severity="info" sys="system" sub="up2date" name="No up2date packages available for installation" status="failed" action="preinst_check" package="appctrl3"
2014:06:23-12:35:38 Astaro auisys[23208]: Searching for available up2date packages for type 'ohelp9'
2014:06:23-12:35:38 Astaro auisys[23208]: id="371D" severity="info" sys="system" sub="up2date" name="No up2date packages available for installation" status="failed" action="preinst_check" package="ohelp9"
2014:06:23-12:35:43 Astaro auisys[23208]: Searching for available up2date packages for type 'mpfc'
2014:06:23-12:35:43 Astaro auisys[23208]: id="371D" severity="info" sys="system" sub="up2date" name="No up2date packages available for installation" status="failed" action="preinst_check" package="mpfc"
2014:06:23-12:35:48 Astaro auisys[23208]: Searching for available up2date packages for type 'geoipxtipv6'
2014:06:23-12:35:48 Astaro auisys[23208]: id="371D" severity="info" sys="system" sub="up2date" name="No up2date packages available for installation" status="failed" action="preinst_check" package="geoipxtipv6"
2014:06:23-12:35:53 Astaro auisys[23208]: Searching for available up2date packages for type 'cadata'
2014:06:23-12:35:53 Astaro auisys[23208]: id="371D" severity="info" sys="system" sub="up2date" name="No up2date packages available for installation" status="failed" action="preinst_check" package="cadata"
2014:06:23-12:35:58 Astaro auisys[23208]: Searching for available up2date packages for type 'geoip'
2014:06:23-12:35:58 Astaro auisys[23208]: id="371D" severity="info" sys="system" sub="up2date" name="No up2date packages available for installation" status="failed" action="preinst_check" package="geoip"
2014:06:23-12:36:03 Astaro auisys[23208]: Searching for available up2date packages for type 'ipsbundle'
2014:06:23-12:36:03 Astaro auisys[23208]: id="371D" severity="info" sys="system" sub="up2date" name="No up2date packages available for installation" status="failed" action="preinst_check" package="ipsbundle"
2014:06:23-12:36:08 Astaro auisys[23208]: Searching for available up2date packages for type 'avira3'
2014:06:23-12:36:08 Astaro auisys[23208]: Installing up2date package file '/var/up2date//avira3/u2d-avira3-9.6861-6881.patch.tgz.gpg'
2014:06:23-12:36:08 Astaro auisys[23208]: Verifying up2date package signature
2014:06:23-12:36:09 Astaro auisys[23208]: Unpacking installation instructions
2014:06:23-12:36:09 Astaro auisys[23208]: Unpacking up2date package container
2014:06:23-12:36:09 Astaro auisys[23208]: Running pre-installation checks
2014:06:23-12:36:09 Astaro auisys[23208]: Starting up2date package installation
2014:06:23-12:36:26 Astaro auisys[23208]: id="371Z" severity="info" sys="system" sub="up2date" name="Successfully installed Up2Date package" status="success" action="install" package_version="9.6881" package="avira3"
2014:06:23-12:36:26 Astaro auisys[23208]: New Pattern Up2Dates installed
2014:06:23-12:36:31 Astaro auisys[23208]: Searching for available up2date packages for type 'savi'
2014:06:23-12:36:31 Astaro auisys[23208]: id="371D" severity="info" sys="system" sub="up2date" name="No up2date packages available for installation" status="failed" action="preinst_check" package="savi"
2014:06:23-12:36:37 Astaro auisys[23208]: id="3716" severity="info" sys="system" sub="up2date" name="Up2date Package Installer finished, exiting"
2014:06:23-12:41:37 Astaro auisys[23373]: Starting Up2Date Package Installer
2014:06:23-12:41:37 Astaro auisys[23373]: Searching for available up2date packages for type 'sys'
2014:06:23-12:41:37 Astaro auisys[23373]: Installing up2date package file '/var/up2date//sys/u2d-sys-9.195006-200011.tgz.gpg'
2014:06:23-12:41:38 Astaro auisys[23373]: Verifying up2date package signature
2014:06:23-12:41:43 Astaro auisys[23373]: Unpacking installation instructions
2014:06:23-12:41:45 Astaro auisys[23373]: New Firmware Up2Date is ready for installation
2014:06:23-12:41:45 Astaro auisys[23373]: Stopping package processing, unpack only selected
2014:06:23-12:41:45 Astaro auisys[23373]: Installing up2date package file '/var/up2date//sys/u2d-sys-9.200011-201023.tgz.gpg'
2014:06:23-12:41:45 Astaro auisys[23373]: Verifying up2date package signature
2014:06:23-12:41:50 Astaro auisys[23373]: Unpacking installation instructions
2014:06:23-12:41:52 Astaro auisys[23373]: New Firmware Up2Date is ready for installation
2014:06:23-12:41:52 Astaro auisys[23373]: Stopping package processing, unpack only selected
2014:06:23-12:41:52 Astaro auisys[23373]: Installing up2date package file '/var/up2date//sys/u2d-sys-9.202028-203003.tgz.gpg'
2014:06:23-12:41:52 Astaro auisys[23373]: Verifying up2date package signature
2014:06:23-12:41:55 Astaro auisys[23373]: Unpacking installation instructions
2014:06:23-12:41:56 Astaro auisys[23373]: New Firmware Up2Date is ready for installation
2014:06:23-12:41:56 Astaro auisys[23373]: Stopping package processing, unpack only selected
2014:06:23-12:41:57 Astaro auisys[23373]: id="3720" severity="info" sys="system" sub="up2date" name="Successfully triggered up2date sync" status="success" action="sync"
2014:06:23-12:42:02 Astaro auisys[23373]: id="3716" severity="info" sys="system" sub="up2date" name="Up2date Package Installer finished, exiting"
2014:06:23-12:42:32 Astaro auisys[23434]: Starting Up2Date Package Installer
2014:06:23-12:42:32 Astaro auisys[23434]: Searching for available up2date packages for type 'sys'
2014:06:23-12:42:32 Astaro auisys[23434]: id="371C" severity="info" sys="system" sub="up2date" name="up2date package is excluded by command line(version: 9203003 min_version: 0.000 max_version: 9.200011" status="failed" file="/var/up2date//sys/u2d-sys-9.113001-203003.tgz.gpg" action="preinst_check" package="sys"
2014:06:23-12:42:32 Astaro auisys[23434]: id="371C" severity="info" sys="system" sub="up2date" name="up2date package is excluded by command line(version: 9201023 min_version: 0.000 max_version: 9.200011" status="failed" file="/var/up2date//sys/u2d-sys-9.200011-201023.tgz.gpg" action="preinst_check" package="sys"
2014:06:23-12:42:32 Astaro auisys[23434]: id="371C" severity="info" sys="system" sub="up2date" name="up2date package is excluded by command line(version: 9203003 min_version: 0.000 max_version: 9.200011" status="failed" file="/var/up2date//sys/u2d-sys-9.202028-203003.tgz.gpg" action="preinst_check" package="sys"
2014:06:23-12:42:32 Astaro auisys[23434]: Installing up2date package file '/var/up2date//sys/u2d-sys-9.195006-200011.tgz.gpg'
2014:06:23-12:42:32 Astaro auisys[23434]: Verifying up2date package signature
2014:06:23-12:42:37 Astaro auisys[23434]: Unpacking installation instructions
2014:06:23-12:42:39 Astaro auisys[23434]: >=========================================================================
2014:06:23-12:42:39 Astaro auisys[23434]: id="371J" severity="error" sys="system" sub="up2date" name="Fatal: Version conflict: required version: 9.195006 <=> current version: 9.113001" status="failed" action="install" package="sys"
2014:06:23-12:42:39 Astaro auisys[23434]: 1. main::alf:70() auisys.pl
2014:06:23-12:42:39 Astaro auisys[23434]: 2. main:
erform_work:1078() auisys.pl
2014:06:23-12:42:39 Astaro auisys[23434]: 3. main::auisys_prepare_and_work:555() auisys.pl
2014:06:23-12:42:39 Astaro auisys[23434]: 4. main::top-level:32() auisys.pl
