Up2Date 9.305004 package description:
Remarks:
System will be rebooted
Configuration will be upgraded
News:
Maintenance Update
Bugfixes:
Fix [31855]: Application control Rule created but is invisible in Webadmin
Fix [32082]: Issue with clipboard in html5vpn connection and chinese characters
Fix [32769]: Connection to TS Remote Desktop doesn't work correctly over HTML5VPN using windows server 2012 or windows 8
Fix [33580]: [9.3] vpn-reporter.pl segfaults, error 4 in libc-2.11.3.so
Fix [33735]: Authorization fails for openvpn if group "Active Directory Users" is used
Fix [33836]: IPSec packages are not routed correctly on a Cluster
Fix [34015]: SMC integration with UTM is not able to push Android\iOS wireless profile
Fix [34035]: [9.3] Dashboard does not show Antivirus active protocols for HTTP/S
Fix [34036]: [9.3] Using @ in hostname results in corrupt /etc/syslog-ng.conf
Fix [34037]: [9.3] aua does not work with facility http while installing basic guard license
Fix [34039]: [9.3] vpn-reporter.pl segfault in get_amazonvpc
RPM packages contained:
libsaviglue-9.30-2.g45706d0.rb1.i686.rpm
perf-tools-3.12.30-32.ge449d1b.rb2.i686.rpm
ep-reporting-c-9.30-11.gf9711cc.rb1.i686.rpm
ep-aua-9.30-11.g8177cbb.rb1.i686.rpm
ep-confd-9.30-194.gc2706d2.rb1.i686.rpm
ep-confd-tools-9.30-189.g3c71d4c.rb1.i686.rpm
ep-cssd-9.30-1.g115ca2c.rb1.i686.rpm
ep-localization-afg-9.30-25.g9a37992.rb1.i686.rpm
ep-localization-ang-9.30-25.g9a37992.rb1.i686.rpm
ep-localization-asg-9.30-25.g9a37992.rb1.i686.rpm
ep-localization-atg-9.30-25.g9a37992.rb1.i686.rpm
ep-localization-aug-9.30-25.g9a37992.rb1.i686.rpm
ep-mdw-9.30-139.g1da5b7f.rb5.i686.rpm
ep-screenmgr-9.30-3.g67fe26d.rb1.i686.rpm
ep-webadmin-9.30-114.gc18b2c7.rb1.i686.rpm
ep-webadmin-contentmanager-9.30-14.g84e423d.rb2.i686.rpm
chroot-smtp-9.30-3.ga2731ec.rb1.i686.rpm
kernel-smp-3.12.30-32.ge449d1b.rb2.i686.rpm
kernel-smp64-3.12.30-32.ge449d1b.rb2.x86_64.rpm
ep-release-9.305-4.noarch.rpm
