2016:10:10-16:40:30 tsfw01 epsecd[28411]: I id="4210" severity="info" sys="System" sub="epsecd" name="Sleeping for 300 seconds"
2016:10:10-16:46:30 tsfw01 epsecd[28411]: I id="4232" severity="info" sys="System" sub="epsecd" name="Not syncing web policy resources as web control is disabled"
2016:10:10-16:46:33 tsfw01 epsecd[28411]: I id="4231" severity="info" sys="System" sub="epsecd" name="Syncing SWC with web control global status "
2016:10:10-16:56:37 tsfw01 epsecd[28411]: W id="4202" severity="warn" sys="System" sub="epsecd" name="Quit recieved from Sophos LiveConnect"
2016:10:10-16:56:37 tsfw01 epsecd[28411]: I id="4223" severity="info" sys="System" sub="epsecd" name="Closing socket to Sophos LiveConnect"
2016:10:10-16:56:37 tsfw01 epsecd[28411]: I id="4210" severity="info" sys="System" sub="epsecd" name="Sleeping for 300 seconds"
2016:10:10-17:02:07 tsfw01 epsecd[28411]: W id="424200" severity="warn" sys="System" sub="epsecd" name="Timeout starting SSL session."
2016:10:10-17:02:07 tsfw01 epsecd[28411]: >=========================================================================
2016:10:10-17:02:07 tsfw01 epsecd[28411]: E id="4281" severity="crit" sys="System" sub="epsecd" name="Unexpected error: Timeout starting SSL session. at /</usr/local/bin/epp_client.plx>Epsec/Logic/Client.pm line 184." effect="Can't talk to Sophos LiveConnect"
2016:10:10-17:02:07 tsfw01 epsecd[28411]: 1. Epsec::Utils::Logging::_log:59() /</usr/local/bin/epp_client.plx>Epsec/Utils/Logging.pm
2016:10:10-17:02:07 tsfw01 epsecd[28411]: 2. Epsec::Logic::Client:
n_error:1461() /</usr/local/bin/epp_client.plx>Epsec/Logic/Client.pm
2016:10:10-17:02:07 tsfw01 epsecd[28411]: 3. Epsec::Logic::Base::run:60() /</usr/local/bin/epp_client.plx>Epsec/Logic/Base.pm
2016:10:10-17:02:07 tsfw01 epsecd[28411]: 4. main::top-level:63() client.pl
2016:10:10-17:02:07 tsfw01 epsecd[28411]: <=========================================================================
2016:10:10-17:02:07 tsfw01 epsecd[28411]: I id="4210" severity="info" sys="System" sub="epsecd" name="Sleeping for 180 seconds"
2016:10:10-17:05:30 tsfw01 epsecd[28411]: I id="4232" severity="info" sys="System" sub="epsecd" name="Not syncing web policy resources as web control is disabled"
2016:10:10-17:05:33 tsfw01 epsecd[28411]: I id="4231" severity="info" sys="System" sub="epsecd" name="Syncing SWC with web control global status "
2016:10:10-17:15:47 tsfw01 epsecd[28411]: W id="4202" severity="warn" sys="System" sub="epsecd" name="Quit recieved from Sophos LiveConnect"
2016:10:10-17:15:47 tsfw01 epsecd[28411]: I id="4223" severity="info" sys="System" sub="epsecd" name="Closing socket to Sophos LiveConnect"
2016:10:10-17:15:47 tsfw01 epsecd[28411]: I id="4210" severity="info" sys="System" sub="epsecd" name="Sleeping for 300 seconds"
2016:10:10-17:21:06 tsfw01 epsecd[28411]: I id="4232" severity="info" sys="System" sub="epsecd" name="Not syncing web policy resources as web control is disabled"
2016:10:10-17:21:09 tsfw01 epsecd[28411]: I id="4231" severity="info" sys="System" sub="epsecd" name="Syncing SWC with web control global status "
2016:10:10-17:21:27 tsfw01 epsecd[28411]: I id="4213" severity="info" sys="System" sub="epsecd" name="User triggered changes in webadmin"
2016:10:10-17:31:39 tsfw01 epsecd[28411]: W id="4202" severity="warn" sys="System" sub="epsecd" name="Quit recieved from Sophos LiveConnect"
2016:10:10-17:31:39 tsfw01 epsecd[28411]: I id="4223" severity="info" sys="System" sub="epsecd" name="Closing socket to Sophos LiveConnect"
2016:10:10-17:31:39 tsfw01 epsecd[28411]: I id="4210" severity="info" sys="System" sub="epsecd" name="Sleeping for 300 seconds"
2016:10:10-17:37:09 tsfw01 epsecd[28411]: W id="424200" severity="warn" sys="System" sub="epsecd" name="Timeout starting SSL session."
2016:10:10-17:37:09 tsfw01 epsecd[28411]: >=========================================================================
2016:10:10-17:37:09 tsfw01 epsecd[28411]: E id="4281" severity="crit" sys="System" sub="epsecd" name="Unexpected error: Timeout starting SSL session. at /</usr/local/bin/epp_client.plx>Epsec/Logic/Client.pm line 184." effect="Can't talk to Sophos LiveConnect"
2016:10:10-17:37:09 tsfw01 epsecd[28411]: 1. Epsec::Utils::Logging::_log:59() /</usr/local/bin/epp_client.plx>Epsec/Utils/Logging.pm
2016:10:10-17:37:09 tsfw01 epsecd[28411]: 2. Epsec::Logic::Client:
2016:10:10-17:37:09 tsfw01 epsecd[28411]: 3. Epsec::Logic::Base::run:60() /</usr/local/bin/epp_client.plx>Epsec/Logic/Base.pm
2016:10:10-17:37:09 tsfw01 epsecd[28411]: 4. main::top-level:63() client.pl
2016:10:10-17:37:09 tsfw01 epsecd[28411]: <=========================================================================
2016:10:10-17:37:09 tsfw01 epsecd[28411]: I id="4210" severity="info" sys="System" sub="epsecd" name="Sleeping for 300 seconds"
