Und ausserdem
WeTek OS 1.1.6 for WeTek Play [25/11/2015]
Ich zitiere:
We are proud to announce that we start seeding OTA update of WeTek OS 1.1.6
If for some reason the OTA update fails, you can manually download the update files and follow this guide to do a manual update:
Download WeTek OS 1.1.6
Code:
https://mega.nz/#!jABx1ZoR!Joen3APJiu4JetTmYS_tfJVeJJVt-2e3UPolWSpDRno
Use Wipe data and Wipe media IF you want to make a clean installation
(This will delete all the settings on your WeTek)
Or
If you want to make a clean install or recover android on NAND
Code:
https://mega.nz/#!uVBXwJzB!SGvb9hsxYBdOXpRCi4dAPw0CgmAXrtgDjWrmyvxp blQ
Code:
Changelog of the new 1.1.6 version
Android:
- Fix bug with delete button:
- Use long press button "delete" to take a screenshot
- Add Hungarian language
WeUpdate:
- Improvements on Turkish translation
WeTek Theater:
- Fix DVB-T 7M Bandwidth issue
- Changes for LNB power off on exit(s)
- Switch off LNB before standby
- Update SAT and SRV table after merge
- Fixed crash ATSC tunner when start theater
- Mask ATSC subtitle
- Add Russian and Ukrainian translation
- Fix DVTplayer crashing (back to launcher black & need double exit)
- Disable MultipleFrequency function
- Improvements for Australian users
Launcher:
- Add TalkBack in Launcher's Main screen
Update Apps:
- New KODI 15.2
- GAPPS
- Aptoide
- others apps
On a Clean installation:
- YouTube for Google TV (discontinued version) Deleted
- Skype Deleted
- Box Deleted
- Chrome Deleted
- ES File Explorer Deleted
After this new installation finishes, please turn off your WeTek.
After turning on, please make a reboot, for the apps ti update properly
Thanks!
Best regards
Und wetek openelec ist gerade in black friday promo.
P.s : kein mitarbeiter
