Wie installiert man "Qubes OS 4.x" auf seinem Notebook?
Milioo
Experte
mein Notebook heißt:
HP Pavilion dv7-1155ez
dv7-1155ez
Product Number
FV812EA
Microprocessor
2.3 GHz AMD Turion X2 Ultra Dual-Core Mobile Processor ZM-84
Microprocessor Cache
3 MB Level 2 cache
Memory
4096 (2 x 2048 MB)
Memory Max
Up to 8 GB
Video Graphics
ATI Radeon HD 3450
Video Memory
Up to 2303 MB (512 MB dedicated)
Hard Drive
250 GB
Multimedia Drive
Blu-Ray ROM with SuperMulti DVD±R/RW Double Layer
Display
17" WXGA+ High Definition BrightView Widescreen (1440 x 900)
Network Card
Integrated 10/100/1000 Gigabit Ethernet LAN
Wireless Connectivity
802.11 b/g WLAN
Bluetooth
Sound
Altec Lansing speakers
3D Sound Blaster Pro compatible sound 16 bit integrated
Keyboard
101 key compatible
Pointing Device
Touch Pad with On/Off button and dedicated vertical Scroll Up/Down pad, volume control, mute buttons, 2 Quick Launch Buttons
PC Card Slots
One ExpressCard/54 slot (also supports ExpressCard/34)
External Ports
5-in-1 integrated Digital Media Reader for Secure Digital cards, MultiMedia cards, Memory Stick, Memory Stick Pro, or xD
Picture cards
4 USB 2.0
1 VGA port
1 HDMI connector
1 eSata connector
1 RJ45 ethernet connector
2 headphones-out
1 mic-in
1 IEEE 1394
remote control infrared port
cable docking connector
Dimensions
39.6 cm (W) x 28.5 cm (D) x 4.5 cm (H)
Security
Integrated Fingerprint reader
Weight
3.46kg
Power
90 W AC Power Adapter
8-cell Lithium-Ion (Li-Ion) battery
What's In The Box
TV Tuner
HP Mobile Remote Control
HP Pavilion WebCam with Integrated Microphone
Software
Operating Sys
Jetzt möchte ich sehr gerne ein Betriebsystem installieren und weiß nicht wie?
Das sollen die Vorraussetzungen sein!
Minimum requirements for Qubes OS 4.x
Here are the minimum requirements for Qubes OS 4.x:
64-Bit-Intel oder AMD-Prozessor (x86_64 aka x64 aka AMD64)
Intel VT-x with EPT or AMD-V with RVI
Intel VT-d oder AMD-Vi
4 GB RAM
32 GB Speicherplatz
Es wird diese Fehlermeldung angezeigt!
error: no such partition.
Entering rescue mode...
grub rescue>
Frage, wie behebt man diesen Fehler, ich kenne mich in diesem Betriebssystem überhaupt nicht aus!
- - - Updated - - -
Ich habe diese Festplatte eingegraben:
Samsung 850 EVO, 500 GB
Of course, to be compatible with Qubes OS, the BIOS must properly expose all the VT-x, VT-d, and SLAT functionality that the underlying hardware offers (and which we require). Among other things, this implies proper DMAR ACPI table construction.
Updated requirements for Qubes-certified hardware | Qubes OS
Second Level Address Translation – Wikipedia
AMD processors with Rapid Virtualization Indexing required to run Hyper-V in Windows® 8
Auf deiner wirklich uralten und sehr lahmen Kiste kannst du Qubes definitiv knicken und der ZM-84 unterstützt AFAIK nicht so wirklich SLAT = AMD-V with RVI (eher bis absolut sicher das Bios deiner uralten absoluten Consumerschleuder tut das nicht und das kommt dann aufs gleiche raus!), viel zu lahm ist er absolut immer!
Allgemein nimmt man da übrigens immer besser einen ziemlich neuen Desktop PC mit 4 Kern CPU und definitiv kein NB von 2009...
PassMark - AMD Turion X2 Ultra Dual-Core Mobile ZM-84 - Price performance comparison
Die Werte sind für Qubes nur ne Lachnummer und sonst nix.
Frage: Kann man auf das Notebook das Betriebssystem ubuntu installieren?
Okay, wie startet man das Ganze?
Ich möchte die SSD Festplatte vorher formatieren
- Da brauchte ich so ein Befehlszeile Text, dass ein von Hand eingeben sollte
Wie kommt man in das Bios rein?
- Wegen DVD Startumstellung (F2 oder F10) oder ist das was anderes?
Was ist noch alles zu beachten?
Ich bin jetzt im BIOS darin, nur springt es mir immer durch, Anfang bis zum Ende, usw. wie kann man da das neue BIOS installieren?
HP Software- und Treiber-Downloads für HP Drucker, Laptops, Desktops und mehr | HP® Kundensupport
Da muß aber definitiv Windows auf der Kiste drauf sein!
RTC battery:
http://h10032.www1.hp.com/ctg/Manual/c01918142
CMOS-Reset - Wie lscht man das CMOS? (BIOS-Einstellungen resetten) | biosflash.com
Bei solchen Probs entfernt man definitiv die RTC battery und macht per 10-Cent-Stück einen CMOS-Clear.
Da dürfte aber das Mainboard defekt sein und dann hilft nur backen oder föhnen desselben und meißt auch nicht lange...
Verstehe ich dich richtig:
- Wenn ich Linux daraufmachen möchte, benötige ich kein BIOS Update?
Nein, das Bios hat mit dem installiertem OS nix zu tun, das Update des Bios aber sehr wohl und ist da nur unter Windows möglich!
BIOS – Wikipedia
Sollte man da schon lesen und verstehen!
Wenn du keine Ahnung von BIOS-Updates hast, solltest du dir jemanden suchen, der das hat.
Ansonsten verabschiede dich von deinem Laptop.
