sudo dmesg
[ 0.087212] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.087243] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.087441] mce: CPU0: Thermal monitoring enabled (TM1)
[ 0.087457] process: using mwait in idle threads
[ 0.087459] Last level iTLB entries: 4KB 64, 2MB 8, 4MB 8
[ 0.087461] Last level dTLB entries: 4KB 64, 2MB 0, 4MB 0, 1GB 4
[ 0.087464] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[ 0.087466] Spectre V2 : Mitigation: Retpolines
[ 0.087467] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[ 0.087469] Spectre V2 : Enabling Restricted Speculation for firmware calls
[ 0.087470] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[ 0.087472] Spectre V2 : User space: Mitigation: STIBP via seccomp and prctl
[ 0.087474] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl and seccomp
[ 0.087478] MDS: Mitigation: Clear CPU buffers
[ 0.087479] MMIO Stale Data: Mitigation: Clear CPU buffers
[ 0.087482] SRBDS: Mitigation: Microcode
[ 0.087587] Freeing SMP alternatives memory: 32K
[ 0.089046] smpboot: CPU0: Intel(R) Pentium(R) Gold G5400 CPU @ 3.70GHz (family: 0x6, model: 0x9e, stepping: 0xa)
[ 0.089130] Performance Events: PEBS fmt3+, Skylake events, 32-deep LBR, full-width counters, Intel PMU driver.
[ 0.089139] ... version: 4
[ 0.089140] ... bit width: 48
[ 0.089141] ... generic registers: 4
[ 0.089142] ... value mask: 0000ffffffffffff
[ 0.089143] ... max period: 00007fffffffffff
[ 0.089144] ... fixed-purpose events: 3
[ 0.089145] ... event mask: 000000070000000f
[ 0.089216] rcu: Hierarchical SRCU implementation.
[ 0.089633] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[ 0.089668] smp: Bringing up secondary CPUs ...
[ 0.089720] x86: Booting SMP configuration:
[ 0.089722] .... node #0, CPUs: #1 #2
[ 0.091799] MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
[ 0.091799] MMIO Stale Data CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/processor_mmio_stale_data.html for more details.
[ 0.091799] #3
[ 0.091799] smp: Brought up 1 node, 4 CPUs
[ 0.091799] smpboot: Max logical packages: 1
[ 0.091799] smpboot: Total of 4 processors activated (29598.80 BogoMIPS)
[ 0.132413] node 0 deferred pages initialised in 40ms
[ 0.132673] devtmpfs: initialized
[ 0.132673] x86/mm: Memory block size: 128MB
[ 0.133121] PM: Registering ACPI NVS region [mem 0x7cbc6000-0x7cbc6fff] (4096 bytes)
[ 0.133121] PM: Registering ACPI NVS region [mem 0x8488d000-0x8992cfff] (84541440 bytes)
[ 0.133121] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.133121] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.133703] pinctrl core: initialized pinctrl subsystem
[ 0.133832] NET: Registered protocol family 16
[ 0.133908] audit: initializing netlink subsys (disabled)
[ 0.136362] audit: type=2000 audit(1663688461.076:1): state=initialized audit_enabled=0 res=1
[ 0.136412] thermal_sys: Registered thermal governor 'fair_share'
[ 0.136412] thermal_sys: Registered thermal governor 'bang_bang'
[ 0.136414] thermal_sys: Registered thermal governor 'step_wise'
[ 0.136416] thermal_sys: Registered thermal governor 'user_space'
[ 0.136417] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.136427] cpuidle: using governor ladder
[ 0.136427] cpuidle: using governor menu
[ 0.136427] ACPI: bus type PCI registered
[ 0.136427] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.136441] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[ 0.136444] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in E820
[ 0.136455] PCI: Using configuration type 1 for base access
[ 0.136651] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[ 0.136807] Kprobes globally optimized
[ 0.136811] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.136811] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.228523] ACPI: Added _OSI(Module Device)
[ 0.228523] ACPI: Added _OSI(Processor Device)
[ 0.228523] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.228523] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.228523] ACPI: Added _OSI(Linux-Dell-Video)
[ 0.228523] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[ 0.228523] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[ 0.251344] ACPI: 9 ACPI AML tables successfully acquired and loaded
[ 0.255568] ACPI: Dynamic OEM Table Load:
[ 0.255574] ACPI: SSDT 0xFFFF8DDF0094C600 0000F4 (v02 PmRef Cpu0Psd 00003000 INTL 20160527)
[ 0.256220] ACPI: \_SB_.PR00: _OSC native thermal LVT Acked
[ 0.256786] ACPI: Dynamic OEM Table Load:
[ 0.256790] ACPI: SSDT 0xFFFF8DDF009B6400 000400 (v02 PmRef Cpu0Cst 00003001 INTL 20160527)
[ 0.257516] ACPI: Dynamic OEM Table Load:
[ 0.257520] ACPI: SSDT 0xFFFF8DDF00CCB000 0006CB (v02 PmRef Cpu0Ist 00003000 INTL 20160527)
[ 0.258301] ACPI: Dynamic OEM Table Load:
[ 0.258304] ACPI: SSDT 0xFFFF8DDF009BB000 00011B (v02 PmRef Cpu0Hwp 00003000 INTL 20160527)
[ 0.258960] ACPI: Dynamic OEM Table Load:
[ 0.258965] ACPI: SSDT 0xFFFF8DDF00CCA000 000724 (v02 PmRef HwpLvt 00003000 INTL 20160527)
[ 0.259787] ACPI: Dynamic OEM Table Load:
[ 0.259792] ACPI: SSDT 0xFFFF8DDF00CCC000 0005FC (v02 PmRef ApIst 00003000 INTL 20160527)
[ 0.260537] ACPI: Dynamic OEM Table Load:
[ 0.260541] ACPI: SSDT 0xFFFF8DDF009B4400 000317 (v02 PmRef ApHwp 00003000 INTL 20160527)
[ 0.261304] ACPI: Dynamic OEM Table Load:
[ 0.261308] ACPI: SSDT 0xFFFF8DDF0072D000 000AB0 (v02 PmRef ApPsd 00003000 INTL 20160527)
[ 0.262383] ACPI: Dynamic OEM Table Load:
[ 0.262387] ACPI: SSDT 0xFFFF8DDF009B6000 00030A (v02 PmRef ApCst 00003000 INTL 20160527)
[ 0.264052] ACPI: Interpreter enabled
[ 0.264083] ACPI: (supports S0 S3 S4 S5)
[ 0.264084] ACPI: Using IOAPIC for interrupt routing
[ 0.264113] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.264462] ACPI: Enabled 8 GPEs in block 00 to 7F
[ 0.269633] ACPI: Power Resource [USBC] (on)
[ 0.271974] ACPI: Power Resource [V0PR] (on)
[ 0.272254] ACPI: Power Resource [V1PR] (on)
[ 0.272530] ACPI: Power Resource [V2PR] (on)
[ 0.276377] ACPI: Power Resource [WRST] (on)
[ 0.277848] ACPI: Power Resource [PIN] (off)
[ 0.278113] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-fe])
[ 0.278119] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI HPX-Type3]
[ 0.278865] acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug SHPCHotplug PME AER PCIeCapability LTR]
[ 0.279311] PCI host bridge to bus 0000:00
[ 0.279313] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7 window]
[ 0.279315] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
[ 0.279317] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[ 0.279318] pci_bus 0000:00: root bus resource [mem 0x000c0000-0x000c3fff window]
[ 0.279320] pci_bus 0000:00: root bus resource [mem 0x000c4000-0x000c7fff window]
[ 0.279321] pci_bus 0000:00: root bus resource [mem 0x000c8000-0x000cbfff window]
[ 0.279323] pci_bus 0000:00: root bus resource [mem 0x000cc000-0x000cffff window]
[ 0.279325] pci_bus 0000:00: root bus resource [mem 0x000d0000-0x000d3fff window]
[ 0.279326] pci_bus 0000:00: root bus resource [mem 0x000d4000-0x000d7fff window]
[ 0.279328] pci_bus 0000:00: root bus resource [mem 0x000d8000-0x000dbfff window]
[ 0.279329] pci_bus 0000:00: root bus resource [mem 0x000dc000-0x000dffff window]
[ 0.279331] pci_bus 0000:00: root bus resource [mem 0x000e0000-0x000e3fff window]
[ 0.279332] pci_bus 0000:00: root bus resource [mem 0x000e4000-0x000e7fff window]
[ 0.279334] pci_bus 0000:00: root bus resource [mem 0x000e8000-0x000ebfff window]
[ 0.279335] pci_bus 0000:00: root bus resource [mem 0x000ec000-0x000effff window]
[ 0.279337] pci_bus 0000:00: root bus resource [mem 0x000f0000-0x000fffff window]
[ 0.279339] pci_bus 0000:00: root bus resource [mem 0x8f800000-0xdfffffff window]
[ 0.279340] pci_bus 0000:00: root bus resource [mem 0x4000000000-0x7fffffffff window]
[ 0.279342] pci_bus 0000:00: root bus resource [mem 0xfc800000-0xfe7fffff window]
[ 0.279344] pci_bus 0000:00: root bus resource [bus 00-fe]
[ 0.279359] pci 0000:00:00.0: [8086:3e0f] type 00 class 0x060000
[ 0.279431] pci 0000:00:02.0: [8086:3e90] type 00 class 0x030000
[ 0.279438] pci 0000:00:02.0: reg 0x10: [mem 0x6000000000-0x6000ffffff 64bit]
[ 0.279443] pci 0000:00:02.0: reg 0x18: [mem 0x4000000000-0x400fffffff 64bit pref]
[ 0.279447] pci 0000:00:02.0: reg 0x20: [io 0x3000-0x303f]
[ 0.279458] pci 0000:00:02.0: BAR 2: assigned to efifb
[ 0.279653] pci 0000:00:12.0: [8086:a379] type 00 class 0x118000
[ 0.279679] pci 0000:00:12.0: reg 0x10: [mem 0x6001005000-0x6001005fff 64bit]
[ 0.279874] pci 0000:00:14.0: [8086:a36d] type 00 class 0x0c0330
[ 0.279901] pci 0000:00:14.0: reg 0x10: [mem 0x8f920000-0x8f92ffff 64bit]
[ 0.279986] pci 0000:00:14.0: PME# supported from D3hot D3cold
[ 0.280279] pci 0000:00:14.2: [8086:a36f] type 00 class 0x050000
[ 0.280300] pci 0000:00:14.2: reg 0x10: [mem 0x6001000000-0x6001001fff 64bit]
[ 0.280311] pci 0000:00:14.2: reg 0x18: [mem 0x6001004000-0x6001004fff 64bit]
[ 0.280457] pci 0000:00:16.0: [8086:a360] type 00 class 0x078000
[ 0.280481] pci 0000:00:16.0: reg 0x10: [mem 0x6001003000-0x6001003fff 64bit]
[ 0.280556] pci 0000:00:16.0: PME# supported from D3hot
[ 0.280759] pci 0000:00:17.0: [8086:a352] type 00 class 0x010601
[ 0.280770] pci 0000:00:17.0: reg 0x10: [mem 0x8f930000-0x8f931fff]
[ 0.280782] pci 0000:00:17.0: reg 0x14: [mem 0x8f933000-0x8f9330ff]
[ 0.280793] pci 0000:00:17.0: reg 0x18: [io 0x3090-0x3097]
[ 0.280799] pci 0000:00:17.0: reg 0x1c: [io 0x3080-0x3083]
[ 0.280805] pci 0000:00:17.0: reg 0x20: [io 0x3060-0x307f]
[ 0.280816] pci 0000:00:17.0: reg 0x24: [mem 0x8f932000-0x8f9327ff]
[ 0.280869] pci 0000:00:17.0: PME# supported from D3hot
[ 0.281001] pci 0000:00:1b.0: [8086:a340] type 01 class 0x060400
[ 0.281105] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[ 0.281211] pci 0000:00:1b.4: [8086:a32c] type 01 class 0x060400
[ 0.281327] pci 0000:00:1b.4: PME# supported from D0 D3hot D3cold
[ 0.281361] pci 0000:00:1b.4: PTM enabled (root), 4ns granularity
[ 0.281540] pci 0000:00:1f.0: [8086:a309] type 00 class 0x060100
[ 0.281854] pci 0000:00:1f.4: [8086:a323] type 00 class 0x0c0500
[ 0.281907] pci 0000:00:1f.4: reg 0x10: [mem 0x6001002000-0x60010020ff 64bit]
[ 0.281984] pci 0000:00:1f.4: reg 0x20: [io 0xefa0-0xefbf]
[ 0.282164] pci 0000:00:1f.5: [8086:a324] type 00 class 0x0c8000
[ 0.282184] pci 0000:00:1f.5: reg 0x10: [mem 0xfe010000-0xfe010fff]
[ 0.282327] pci 0000:00:1f.6: [8086:15bb] type 00 class 0x020000
[ 0.282372] pci 0000:00:1f.6: reg 0x10: [mem 0x8f900000-0x8f91ffff]
[ 0.282584] pci 0000:00:1f.6: PME# supported from D0 D3hot D3cold
[ 0.282710] pci 0000:00:1b.0: PCI bridge to [bus 01]
[ 0.282829] pci 0000:02:00.0: [2646:2263] type 00 class 0x010802
[ 0.282853] pci 0000:02:00.0: reg 0x10: [mem 0x8f800000-0x8f803fff 64bit]
[ 0.283130] pci 0000:00:1b.4: PCI bridge to [bus 02]
[ 0.283137] pci 0000:00:1b.4: bridge window [mem 0x8f800000-0x8f8fffff]
[ 0.283986] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 10 11 12 14 15) *0
[ 0.284045] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 10 11 12 14 15) *1
[ 0.284102] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 10 11 12 14 15) *0
[ 0.284159] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 10 11 12 14 15) *0
[ 0.284216] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 10 11 12 14 15) *0
[ 0.284272] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 10 11 12 14 15) *0
[ 0.284328] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 10 11 12 14 15) *0
[ 0.284387] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 10 11 12 14 15) *0
[ 0.284635] iommu: Default domain type: Passthrough (set via kernel command line)
[ 0.284645] pci 0000:00:02.0: vgaarb: setting as boot VGA device
[ 0.284645] pci 0000:00:02.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[ 0.284645] pci 0000:00:02.0: vgaarb: bridge control possible
[ 0.284645] vgaarb: loaded
[ 0.284645] EDAC MC: Ver: 3.0.0
[ 0.284645] Registered efivars operations
[ 0.284645] NetLabel: Initializing
[ 0.284645] NetLabel: domain hash size = 128
[ 0.284645] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.284645] NetLabel: unlabeled traffic allowed by default
[ 0.284645] PCI: Using ACPI for IRQ routing
[ 0.365121] PCI: pci_cache_line_size set to 64 bytes
[ 0.365207] e820: reserve RAM buffer [mem 0x0009f000-0x0009ffff]
[ 0.365208] e820: reserve RAM buffer [mem 0x7cbc6000-0x7fffffff]
[ 0.365209] e820: reserve RAM buffer [mem 0x7cc97000-0x7fffffff]
[ 0.365210] e820: reserve RAM buffer [mem 0x7f8bd000-0x7fffffff]
[ 0.365210] e820: reserve RAM buffer [mem 0x7fa7d000-0x7fffffff]
[ 0.365211] e820: reserve RAM buffer [mem 0x7ff7c000-0x7fffffff]
[ 0.365211] e820: reserve RAM buffer [mem 0x83a40000-0x83ffffff]
[ 0.365212] e820: reserve RAM buffer [mem 0x8a000000-0x8bffffff]
[ 0.365213] e820: reserve RAM buffer [mem 0x46e800000-0x46fffffff]
[ 0.365977] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
[ 0.365982] hpet0: 8 comparators, 64-bit 24.000000 MHz counter
[ 0.368411] clocksource: Switched to clocksource tsc-early
[ 0.374719] VFS: Disk quotas dquot_6.6.0
[ 0.374730] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.374806] AppArmor: AppArmor Filesystem Enabled
[ 0.374819] pnp: PnP ACPI init
[ 0.374901] system 00:00: [mem 0x40000000-0x403fffff] has been reserved
[ 0.374906] system 00:00: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.375088] system 00:01: [io 0x0a00-0x0a0f] has been reserved
[ 0.375090] system 00:01: [io 0x0a10-0x0a1f] has been reserved
[ 0.375091] system 00:01: [io 0x0a20-0x0a2f] has been reserved
[ 0.375093] system 00:01: [io 0x0a30-0x0a3f] has been reserved
[ 0.375096] system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.375323] system 00:02: [io 0x0680-0x069f] has been reserved
[ 0.375325] system 00:02: [io 0x164e-0x164f] has been reserved
[ 0.375328] system 00:02: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.375359] pnp 00:03: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.375416] system 00:04: [io 0x1854-0x1857] has been reserved
[ 0.375420] system 00:04: Plug and Play ACPI device, IDs INT3f0d PNP0c02 (active)
[ 0.375508] system 00:05: [mem 0xfed10000-0xfed17fff] has been reserved
[ 0.375510] system 00:05: [mem 0xfed18000-0xfed18fff] has been reserved
[ 0.375512] system 00:05: [mem 0xfed19000-0xfed19fff] has been reserved
[ 0.375513] system 00:05: [mem 0xe0000000-0xefffffff] has been reserved
[ 0.375515] system 00:05: [mem 0xfed20000-0xfed3ffff] has been reserved
[ 0.375517] system 00:05: [mem 0xfed90000-0xfed93fff] could not be reserved
[ 0.375518] system 00:05: [mem 0xfed45000-0xfed8ffff] has been reserved
[ 0.375520] system 00:05: [mem 0xfee00000-0xfeefffff] could not be reserved
[ 0.375523] system 00:05: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.375667] system 00:06: [io 0x1800-0x18fe] could not be reserved
[ 0.375669] system 00:06: [mem 0xfd000000-0xfd69ffff] has been reserved
[ 0.375671] system 00:06: [mem 0xfd6c0000-0xfd6cffff] has been reserved
[ 0.375673] system 00:06: [mem 0xfd6f0000-0xfdffffff] has been reserved
[ 0.375674] system 00:06: [mem 0xfe000000-0xfe01ffff] could not be reserved
[ 0.375676] system 00:06: [mem 0xfe200000-0xfe7fffff] has been reserved
[ 0.375677] system 00:06: [mem 0xff000000-0xffffffff] has been reserved
[ 0.375680] system 00:06: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.375876] system 00:07: [io 0x2000-0x20fe] has been reserved
[ 0.375879] system 00:07: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.376648] system 00:08: [mem 0xfd6e0000-0xfd6effff] has been reserved
[ 0.376651] system 00:08: [mem 0xfd6d0000-0xfd6dffff] has been reserved
[ 0.376652] system 00:08: [mem 0xfd6b0000-0xfd6bffff] has been reserved
[ 0.376654] system 00:08: [mem 0xfd6a0000-0xfd6affff] has been reserved
[ 0.376657] system 00:08: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.377098] system 00:09: [io 0x0200] has been reserved
[ 0.377101] system 00:09: Plug and Play ACPI device, IDs FXY0815 PNP0c02 (active)
[ 0.377140] pnp: PnP ACPI: found 10 devices
[ 0.382404] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ 0.382442] NET: Registered protocol family 2
[ 0.382557] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.383920] tcp_listen_portaddr_hash hash table entries: 8192 (order: 5, 131072 bytes, linear)
[ 0.384005] TCP established hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.384138] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[ 0.384195] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.384233] UDP hash table entries: 8192 (order: 6, 262144 bytes, linear)
[ 0.384267] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes, linear)
[ 0.384310] NET: Registered protocol family 1
[ 0.384315] NET: Registered protocol family 44
[ 0.384326] pci 0000:00:1b.0: PCI bridge to [bus 01]
[ 0.384340] pci 0000:00:1b.4: PCI bridge to [bus 02]
[ 0.384344] pci 0000:00:1b.4: bridge window [mem 0x8f800000-0x8f8fffff]
[ 0.384353] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7 window]
[ 0.384364] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff window]
[ 0.384365] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[ 0.384367] pci_bus 0000:00: resource 7 [mem 0x000c0000-0x000c3fff window]
[ 0.384369] pci_bus 0000:00: resource 8 [mem 0x000c4000-0x000c7fff window]
[ 0.384370] pci_bus 0000:00: resource 9 [mem 0x000c8000-0x000cbfff window]
[ 0.384372] pci_bus 0000:00: resource 10 [mem 0x000cc000-0x000cffff window]
[ 0.384373] pci_bus 0000:00: resource 11 [mem 0x000d0000-0x000d3fff window]
[ 0.384374] pci_bus 0000:00: resource 12 [mem 0x000d4000-0x000d7fff window]
[ 0.384376] pci_bus 0000:00: resource 13 [mem 0x000d8000-0x000dbfff window]
[ 0.384377] pci_bus 0000:00: resource 14 [mem 0x000dc000-0x000dffff window]
[ 0.384379] pci_bus 0000:00: resource 15 [mem 0x000e0000-0x000e3fff window]
[ 0.384380] pci_bus 0000:00: resource 16 [mem 0x000e4000-0x000e7fff window]
[ 0.384382] pci_bus 0000:00: resource 17 [mem 0x000e8000-0x000ebfff window]
[ 0.384383] pci_bus 0000:00: resource 18 [mem 0x000ec000-0x000effff window]
[ 0.384385] pci_bus 0000:00: resource 19 [mem 0x000f0000-0x000fffff window]
[ 0.384386] pci_bus 0000:00: resource 20 [mem 0x8f800000-0xdfffffff window]
[ 0.384388] pci_bus 0000:00: resource 21 [mem 0x4000000000-0x7fffffffff window]
[ 0.384389] pci_bus 0000:00: resource 22 [mem 0xfc800000-0xfe7fffff window]
[ 0.384391] pci_bus 0000:02: resource 1 [mem 0x8f800000-0x8f8fffff]
[ 0.384475] pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[ 0.384738] PCI: CLS 64 bytes, default 64
[ 0.384769] Trying to unpack rootfs image as initramfs...
[ 1.039666] Freeing initrd memory: 65320K
[ 1.039696] DMAR: No ATSR found
[ 1.039718] DMAR: dmar0: Using Queued invalidation
[ 1.039721] DMAR: dmar1: Using Queued invalidation
[ 1.039981] pci 0000:00:00.0: Adding to iommu group 0
[ 1.039987] pci 0000:00:02.0: Adding to iommu group 1
[ 1.039995] pci 0000:00:12.0: Adding to iommu group 2
[ 1.040004] pci 0000:00:14.0: Adding to iommu group 3
[ 1.040009] pci 0000:00:14.2: Adding to iommu group 3
[ 1.040016] pci 0000:00:16.0: Adding to iommu group 4
[ 1.040022] pci 0000:00:17.0: Adding to iommu group 5
[ 1.040041] pci 0000:00:1b.0: Adding to iommu group 6
[ 1.040048] pci 0000:00:1b.4: Adding to iommu group 7
[ 1.040060] pci 0000:00:1f.0: Adding to iommu group 8
[ 1.040066] pci 0000:00:1f.4: Adding to iommu group 8
[ 1.040072] pci 0000:00:1f.5: Adding to iommu group 8
[ 1.040077] pci 0000:00:1f.6: Adding to iommu group 8
[ 1.040093] pci 0000:02:00.0: Adding to iommu group 9
[ 1.040111] DMAR: Intel(R) Virtualization Technology for Directed I/O
[ 1.040113] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ 1.040115] software IO TLB: mapped [mem 0x0000000077484000-0x000000007b484000] (64MB)
[ 1.040492] Initialise system trusted keyrings
[ 1.040499] Key type blacklist registered
[ 1.040550] workingset: timestamp_bits=36 max_order=22 bucket_order=0
[ 1.041262] zbud: loaded
[ 1.041368] integrity: Platform Keyring initialized
[ 1.041371] Key type asymmetric registered
[ 1.041372] Asymmetric key parser 'x509' registered
[ 1.041377] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
[ 1.041404] io scheduler mq-deadline registered
[ 1.041811] pcieport 0000:00:1b.0: PME: Signaling with IRQ 122
[ 1.041996] pcieport 0000:00:1b.4: can't derive routing for PCI INT A
[ 1.041998] pcieport 0000:00:1b.4: PCI INT A: not connected
[ 1.042092] pcieport 0000:00:1b.4: PME: Signaling with IRQ 123
[ 1.042150] pcieport 0000:00:1b.4: AER: enabled with IRQ 123
[ 1.042189] pcieport 0000:00:1b.4: DPC: enabled with IRQ 123
[ 1.042191] pcieport 0000:00:1b.4: DPC: error containment capabilities: Int Msg #0, RPExt+ PoisonedTLP+ SwTrigger+ RP PIO Log 4, DL_ActiveErr+
[ 1.042296] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 1.042305] efifb: probing for efifb
[ 1.042314] efifb: framebuffer at 0x4000000000, using 1920k, total 1920k
[ 1.042316] efifb: mode is 800x600x32, linelength=3200, pages=1
[ 1.042317] efifb: scrolling: redraw
[ 1.042318] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[ 1.043162] Console: switching to colour frame buffer device 100x37
[ 1.043966] fb0: EFI VGA frame buffer device
[ 1.043983] intel_idle: MWAIT substates: 0x11142120
[ 1.043984] intel_idle: v0.5.1 model 0x9E
[ 1.044135] intel_idle: Local APIC timer is reliable in all C-states
[ 1.044762] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 1.045378] Linux agpgart interface v0.103
[ 1.045410] AMD-Vi: AMD IOMMUv2 functionality not available on this system - This is not a bug.
[ 1.045559] i8042: PNP: No PS/2 controller found.
[ 1.045608] mousedev: PS/2 mouse device common for all mice
[ 1.045654] rtc_cmos 00:03: RTC can wake from S4
[ 1.046746] rtc_cmos 00:03: registered as rtc0
[ 1.047025] rtc_cmos 00:03: setting system clock to 2022-09-20T15:41:02 UTC (1663688462)
[ 1.047057] rtc_cmos 00:03: alarms up to one month, y3k, 242 bytes nvram, hpet irqs
[ 1.047082] intel_pstate: Intel P-state driver initializing
[ 1.047261] intel_pstate: Disabling energy efficiency optimization
[ 1.047681] intel_pstate: HWP enabled
[ 1.048115] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.048743] NET: Registered protocol family 10
[ 1.054060] Segment Routing with IPv6
[ 1.054493] mip6: Mobile IPv6
[ 1.054900] NET: Registered protocol family 17
[ 1.055360] mpls_gso: MPLS GSO support
[ 1.056032] microcode: sig=0x906ea, pf=0x2, revision=0xea
[ 1.056448] microcode: Microcode Update Driver: v2.2.
[ 1.056451] IPI shorthand broadcast: enabled
[ 1.057257] sched_clock: Marking stable (1051789403, 4566164)->(1060162566, -3806999)
[ 1.057746] registered taskstats version 1
[ 1.058158] Loading compiled-in X.509 certificates
[ 1.079857] Loaded X.509 cert 'Debian Secure Boot CA: 6ccece7e4c6c0d1f6149f3dd27dfcc5cbb419ea1'
[ 1.080304] Loaded X.509 cert 'Debian Secure Boot Signer 2020: 00b55eb3b9'
[ 1.080788] zswap: loaded using pool lzo/zbud
[ 1.081385] Key type ._fscrypt registered
[ 1.081819] Key type .fscrypt registered
[ 1.082242] Key type fscrypt-provisioning registered
[ 1.082681] AppArmor: AppArmor sha1 policy hashing enabled
[ 1.084108] integrity: Loading X.509 certificate: UEFI:db
[ 1.084556] integrity: Loaded X.509 cert 'SUSE Linux Enterprise Secure Boot Signkey: 3fb077b6cebc6ff2522e1c148c57c777c788e3e7'
[ 1.085412] integrity: Loading X.509 certificate: UEFI:db
[ 1.085982] integrity: Loaded X.509 cert 'Fujitsu Technology Solutions GmbH: DB: 9d8e0a4aa809435e7318cc863546eacfa37403e6'
[ 1.086868] integrity: Loading X.509 certificate: UEFI:db
[ 1.087436] integrity: Loaded X.509 cert 'Fujitsu BIOS DB Certificate: 2ebf8cd9b3324e874ef4e790ea6d1585'
[ 1.088322] integrity: Loading X.509 certificate: UEFI:db
[ 1.088791] integrity: Loaded X.509 cert 'Microsoft Corporation UEFI CA 2011: 13adbf4309bd82709c8cd54f316ed522988a1bd4'
[ 1.089713] integrity: Loading X.509 certificate: UEFI:db
[ 1.090192] integrity: Loaded X.509 cert 'Microsoft Windows Production PCA 2011: a92902398e16c49778cd90f99e4f9ae17c55af53'
[ 1.093008] integrity: Loading X.509 certificate: UEFI:MokListRT (MOKvar table)
[ 1.093632] integrity: Loaded X.509 cert 'Debian Secure Boot CA: 6ccece7e4c6c0d1f6149f3dd27dfcc5cbb419ea1'
[ 1.095878] Freeing unused kernel image (initmem) memory: 2428K
[ 1.128683] Write protecting the kernel read-only data: 22528k
[ 1.129683] Freeing unused kernel image (text/rodata gap) memory: 2040K
[ 1.130448] Freeing unused kernel image (rodata/data gap) memory: 616K
[ 1.178763] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 1.179285] x86/mm: Checking user space page tables
[ 1.218833] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 1.219359] Run /init as init process
[ 1.219873] with arguments:
[ 1.219874] /init
[ 1.219874] with environment:
[ 1.219875] HOME=/
[ 1.219875] TERM=linux
[ 1.219876] BOOT_IMAGE=/ROOT/22.02.3@/boot/vmlinuz-5.10.131+truenas
[ 1.219876] intel_iommu=on
[ 1.219876] zfsforce=1
[ 1.317987] fjes: module verification failed: signature and/or required key missing - tainting kernel
[ 1.337226] ACPI: bus type USB registered
[ 1.337956] usbcore: registered new interface driver usbfs
[ 1.337978] pps_core: LinuxPPS API ver. 1 registered
[ 1.338659] usbcore: registered new interface driver hub
[ 1.339348] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 1.341755] usbcore: registered new device driver usb
[ 1.342678] SCSI subsystem initialized
[ 1.343550] PTP clock support registered
[ 1.345295] cryptd: max_cpu_qlen set to 1000
[ 1.347163] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 1.347930] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 1
[ 1.348664] SSE version of gcm_enc/dec engaged.
[ 1.349722] xhci_hcd 0000:00:14.0: hcc params 0x200077c1 hci version 0x110 quirks 0x0000000000009810
[ 1.351601] xhci_hcd 0000:00:14.0: cache line size of 64 is not supported
[ 1.352749] i801_smbus 0000:00:1f.4: SPD Write Disable is set
[ 1.352794] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 1.353670] i801_smbus 0000:00:1f.4: SMBus using PCI interrupt
[ 1.354177] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.354179] usb usb1: Product: xHCI Host Controller
[ 1.356704] usb usb1: Manufacturer: Linux 5.10.131+truenas xhci-hcd
[ 1.357609] usb usb1: SerialNumber: 0000:00:14.0
[ 1.358015] i2c i2c-0: 1/4 memory slots populated (from DMI)
[ 1.358480] hub 1-0:1.0: USB hub found
[ 1.359695] hub 1-0:1.0: 16 ports detected
[ 1.359915] i2c i2c-0: Successfully instantiated SPD at 0x51
[ 1.361090] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 1.361779] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
[ 1.362453] xhci_hcd 0000:00:14.0: Host supports USB 3.1 Enhanced SuperSpeed
[ 1.363177] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[ 1.363893] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.364571] usb usb2: Product: xHCI Host Controller
[ 1.365277] usb usb2: Manufacturer: Linux 5.10.131+truenas xhci-hcd
[ 1.365999] usb usb2: SerialNumber: 0000:00:14.0
[ 1.366778] hub 2-0:1.0: USB hub found
[ 1.369009] hub 2-0:1.0: 10 ports detected
[ 1.400841] e1000e: Intel(R) PRO/1000 Network Driver
[ 1.401455] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 1.402345] e1000e 0000:00:1f.6: Interrupt Throttling Rate (ints/sec) set to dynamic conservative mode
[ 1.404392] libata version 3.00 loaded.
[ 1.406147] ahci 0000:00:17.0: version 3.0
[ 1.406365] ahci 0000:00:17.0: SSS flag set, parallel bus scan disabled
[ 1.407726] nvme nvme0: pci function 0000:02:00.0
[ 1.412613] nvme nvme0: missing or invalid SUBNQN field.
[ 1.416679] nvme nvme0: 4/0/0 default/read/poll queues
[ 1.417131] ahci 0000:00:17.0: AHCI 0001.0301 32 slots 6 ports 6 Gbps 0x3f impl SATA mode
[ 1.417652] ahci 0000:00:17.0: flags: 64bit ncq sntf stag pm clo only pio slum part ems sxs deso sadm sds apst
[ 1.418119] nvme0n1: p1 p2 p3 p4
[ 1.473086] scsi host0: ahci
[ 1.473850] scsi host1: ahci
[ 1.474512] scsi host2: ahci
[ 1.475157] scsi host3: ahci
[ 1.475786] scsi host4: ahci
[ 1.476396] scsi host5: ahci
[ 1.476945] ata1: SATA max UDMA/133 abar m2048@0x8f932000 port 0x8f932100 irq 126
[ 1.477415] ata2: SATA max UDMA/133 abar m2048@0x8f932000 port 0x8f932180 irq 126
[ 1.477872] ata3: SATA max UDMA/133 abar m2048@0x8f932000 port 0x8f932200 irq 126
[ 1.478313] ata4: SATA max UDMA/133 abar m2048@0x8f932000 port 0x8f932280 irq 126
[ 1.478755] ata5: SATA max UDMA/133 abar m2048@0x8f932000 port 0x8f932300 irq 126
[ 1.479182] ata6: SATA max UDMA/133 abar m2048@0x8f932000 port 0x8f932380 irq 126
[ 1.479671] scsi host6: ahciem
[ 1.480219] scsi 6:0:0:0: Enclosure AHCI SGPIO Enclosure 2.00 PQ: 0 ANSI: 7
[ 1.484234] e1000e 0000:00:1f.6 0000:00:1f.6 (uninitialized): registered PHC clock
[ 1.552692] e1000e 0000:00:1f.6 eth0: (PCI Express:2.5GT/s:Width x1) 4c:52:62:bc:97:97
[ 1.553746] e1000e 0000:00:1f.6 eth0: Intel(R) PRO/1000 Network Connection
[ 1.554940] e1000e 0000:00:1f.6 eth0: MAC: 13, PHY: 12, PBA No: FFFFFF-0FF
[ 1.796148] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 1.846554] ata1.00: ATA-11: ST18000NM000J-2TV103, SN02, max UDMA/133
[ 1.847672] ata1.00: 35156656128 sectors, multi 16: LBA48 NCQ (depth 32), AA
[ 1.888148] ata1.00: configured for UDMA/133
[ 1.889573] scsi 0:0:0:0: Direct-Access ATA ST18000NM000J-2T SN02 PQ: 0 ANSI: 5
[ 2.040415] tsc: Refined TSC clocksource calibration: 3695.979 MHz
[ 2.041619] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x6a8cfe7c4bf, max_idle_ns: 881590703071 ns
[ 2.044108] clocksource: Switched to clocksource tsc
[ 2.205124] ata2: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 2.212874] ata2.00: ATA-9: WDC WD120EMAZ-11BLFA0, 81.00A81, max UDMA/133
[ 2.214071] ata2.00: 23437770752 sectors, multi 16: LBA48 NCQ (depth 32), AA
[ 2.227810] ata2.00: configured for UDMA/133
[ 2.229292] scsi 1:0:0:0: Direct-Access ATA WDC WD120EMAZ-11 0A81 PQ: 0 ANSI: 5
[ 2.548252] ata3: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 2.599672] ata3.00: ATA-11: ST18000NM000J-2TV103, SN02, max UDMA/133
[ 2.600904] ata3.00: 35156656128 sectors, multi 16: LBA48 NCQ (depth 32), AA
[ 2.641598] ata3.00: configured for UDMA/133
[ 2.643093] scsi 2:0:0:0: Direct-Access ATA ST18000NM000J-2T SN02 PQ: 0 ANSI: 5
[ 2.960052] ata4: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 2.967812] ata4.00: ATA-9: WDC WD120EMAZ-11BLFA0, 81.00A81, max UDMA/133
[ 2.969148] ata4.00: 23437770752 sectors, multi 16: LBA48 NCQ (depth 32), AA
[ 2.982904] ata4.00: configured for UDMA/133
[ 2.984568] scsi 3:0:0:0: Direct-Access ATA WDC WD120EMAZ-11 0A81 PQ: 0 ANSI: 5
[ 3.300094] ata5: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 3.302655] ata5.00: ATA-11: WDC WDS250G2B0A-00SM50, 401020WD, max UDMA/133
[ 3.304162] ata5.00: 488397168 sectors, multi 1: LBA48 NCQ (depth 32), AA
[ 3.307854] ata5.00: configured for UDMA/133
[ 3.309710] scsi 4:0:0:0: Direct-Access ATA WDC WDS250G2B0A 20WD PQ: 0 ANSI: 5
[ 3.628630] ata6: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 3.631429] ata6.00: ATA-11: WDC WDS250G2B0A-00SM50, 401020WD, max UDMA/133
[ 3.633069] ata6.00: 488397168 sectors, multi 1: LBA48 NCQ (depth 32), AA
[ 3.636929] ata6.00: configured for UDMA/133
[ 3.638826] scsi 5:0:0:0: Direct-Access ATA WDC WDS250G2B0A 20WD PQ: 0 ANSI: 5
[ 3.645607] e1000e 0000:00:1f.6 eno1: renamed from eth0
[ 3.647814] ses 6:0:0:0: Attached Enclosure device
[ 3.650019] sd 0:0:0:0: [sda] 35156656128 512-byte logical blocks: (18.0 TB/16.4 TiB)
[ 3.650099] sd 5:0:0:0: [sdf] 488397168 512-byte logical blocks: (250 GB/233 GiB)
[ 3.650123] sd 2:0:0:0: [sdc] 35156656128 512-byte logical blocks: (18.0 TB/16.4 TiB)
[ 3.650124] sd 2:0:0:0: [sdc] 4096-byte physical blocks
[ 3.650140] sd 4:0:0:0: [sde] 488397168 512-byte logical blocks: (250 GB/233 GiB)
[ 3.650154] sd 4:0:0:0: [sde] Write Protect is off
[ 3.650156] sd 4:0:0:0: [sde] Mode Sense: 00 3a 00 00
[ 3.650165] sd 2:0:0:0: [sdc] Write Protect is off
[ 3.650166] sd 2:0:0:0: [sdc] Mode Sense: 00 3a 00 00
[ 3.650190] sd 4:0:0:0: [sde] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 3.650197] sd 1:0:0:0: [sdb] 23437770752 512-byte logical blocks: (12.0 TB/10.9 TiB)
[ 3.650198] sd 1:0:0:0: [sdb] 4096-byte physical blocks
[ 3.650207] sd 2:0:0:0: [sdc] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 3.650222] sd 1:0:0:0: [sdb] Write Protect is off
[ 3.650223] sd 1:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[ 3.650253] sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 3.650767] sd 0:0:0:0: [sda] 4096-byte physical blocks
[ 3.651488] sd 5:0:0:0: [sdf] Write Protect is off
[ 3.651505] sd 3:0:0:0: [sdd] 23437770752 512-byte logical blocks: (12.0 TB/10.9 TiB)
[ 3.651507] sd 3:0:0:0: [sdd] 4096-byte physical blocks
[ 3.651512] sd 3:0:0:0: [sdd] Write Protect is off
[ 3.651513] sd 3:0:0:0: [sdd] Mode Sense: 00 3a 00 00
[ 3.651523] sd 3:0:0:0: [sdd] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 3.652065] sd 0:0:0:0: [sda] Write Protect is off
[ 3.652600] sd 5:0:0:0: [sdf] Mode Sense: 00 3a 00 00
[ 3.653129] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 3.653664] sd 5:0:0:0: [sdf] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 3.654159] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 3.682576] sdf: sdf1 sdf2
[ 3.682804] sde: sde1 sde2
[ 3.708551] sd 4:0:0:0: [sde] Attached SCSI removable disk
[ 3.716552] sd 5:0:0:0: [sdf] Attached SCSI removable disk
[ 3.716958] sdc: sdc1 sdc2
[ 3.724036] sda: sda1 sda2
[ 3.725977] sdd: sdd1 sdd2
[ 3.728212] sdb: sdb1 sdb2
[ 3.732594] sd 2:0:0:0: [sdc] Attached SCSI removable disk
[ 3.740604] sd 3:0:0:0: [sdd] Attached SCSI removable disk
[ 3.740620] sd 0:0:0:0: [sda] Attached SCSI removable disk
[ 3.749261] sd 1:0:0:0: [sdb] Attached SCSI removable disk
[ 4.060392] raid6: sse2x4 gen() 18791 MB/s
[ 4.128389] raid6: sse2x4 xor() 11489 MB/s
[ 4.196388] raid6: sse2x2 gen() 20810 MB/s
[ 4.264388] raid6: sse2x2 xor() 12833 MB/s
[ 4.332388] raid6: sse2x1 gen() 16834 MB/s
[ 4.400388] raid6: sse2x1 xor() 9705 MB/s
[ 4.400755] raid6: using algorithm sse2x2 gen() 20810 MB/s
[ 4.401123] raid6: .... xor() 12833 MB/s, rmw enabled
[ 4.401484] raid6: using ssse3x2 recovery algorithm
[ 4.402032] xor: measuring software checksum speed
[ 4.402818] prefetch64-sse : 22760 MB/sec
[ 4.403619] generic_sse : 21452 MB/sec
[ 4.403949] xor: using function: prefetch64-sse (22760 MB/sec)
[ 4.404417] async_tx: api initialized (async)
[ 4.442149] spl: loading out-of-tree module taints kernel.
[ 4.443935] znvpair: module license 'CDDL' taints kernel.
[ 4.444290] Disabling lock debugging due to kernel taint
[ 4.544610] ZFS: Loaded module v2.1.5-1, ZFS pool version 5000, ZFS filesystem version 5
[ 5.386469] Not activating Mandatory Access Control as /sbin/tomoyo-init does not exist.
[ 5.430903] systemd[1]: Inserted module 'autofs4'
[ 5.491611] systemd[1]: systemd 247.3-6 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=unified)
[ 5.512762] systemd[1]: Detected architecture x86-64.
[ 5.544123] systemd[1]: Set hostname to <truenas>.
[ 5.690380] systemd[1]: Queued start job for default target TrueNAS Target.
[ 5.698102] systemd[1]: Created slice system-modprobe.slice.
[ 5.699250] systemd[1]: Created slice User and Session Slice.
[ 5.700249] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 5.701290] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 5.702441] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 5.704019] systemd[1]: Reached target Local Encrypted Volumes.
[ 5.705177] systemd[1]: Reached target Host and Network Name Lookups.
[ 5.706292] systemd[1]: Reached target Paths.
[ 5.707405] systemd[1]: Reached target Slices.
[ 5.708480] systemd[1]: Reached target Swap.
[ 5.709674] systemd[1]: Listening on D-Bus System Message Bus Socket.
[ 5.710800] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 5.711992] systemd[1]: Listening on LVM2 poll daemon socket.
[ 5.715706] systemd[1]: Listening on RPCbind Server Activation Socket.
[ 5.717815] systemd[1]: Listening on Process Core Dump Socket.
[ 5.718950] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 5.720183] systemd[1]: Listening on Journal Audit Socket.
[ 5.721469] systemd[1]: Listening on Journal Socket (/dev/log).
[ 5.722693] systemd[1]: Listening on Journal Socket.
[ 5.724072] systemd[1]: Listening on udev Control Socket.
[ 5.725266] systemd[1]: Listening on udev Kernel Socket.
[ 5.727133] systemd[1]: Mounting Huge Pages File System...
[ 5.728820] systemd[1]: Mounting POSIX Message Queue File System...
[ 5.730581] systemd[1]: Mounting NFSD configuration filesystem...
[ 5.732228] systemd[1]: Mounting RPC Pipe File System...
[ 5.734823] systemd[1]: Mounting Kernel Debug File System...
[ 5.737583] systemd[1]: Mounting Kernel Trace File System...
[ 5.738771] systemd[1]: tmp.mount: Directory /tmp to mount over is not empty, mounting anyway.
[ 5.739969] systemd[1]: Mounting Temporary Directory (/tmp)...
[ 5.741935] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
[ 5.743148] systemd[1]: Finished Availability of block devices.
[ 5.745421] systemd[1]: Started D-Bus System Message Bus.
[ 5.748338] systemd[1]: Condition check resulted in Reboot to TrueNAS core being skipped.
[ 5.749385] RPC: Registered named UNIX socket transport module.
[ 5.749705] systemd[1]: Starting TrueNAS Update...
[ 5.750379] RPC: Registered udp transport module.
[ 5.751775] RPC: Registered tcp transport module.
[ 5.751775] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 5.754956] systemd[1]: Starting Set the console keyboard layout...
[ 5.757643] systemd[1]: Starting Create list of static device nodes for the current kernel...
[ 5.760187] systemd[1]: Starting Load Kernel Module configfs...
[ 5.762328] systemd[1]: Starting Load Kernel Module drm...
[ 5.765211] systemd[1]: Starting Load Kernel Module fuse...
[ 5.767512] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 5.770408] systemd[1]: Starting Journal Service...
[ 5.772197] fuse: init (API version 7.32)
[ 5.772588] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 5.775160] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 5.777745] systemd[1]: Starting Coldplug All udev Devices...
[ 5.781466] systemd[1]: Mounted Huge Pages File System.
[ 5.783820] systemd[1]: Mounted POSIX Message Queue File System.
[ 5.785750] systemd[1]: Mounted NFSD configuration filesystem.
[ 5.787623] systemd[1]: Mounted RPC Pipe File System.
[ 5.789506] systemd[1]: Mounted Kernel Debug File System.
[ 5.791363] systemd[1]: Mounted Kernel Trace File System.
[ 5.793196] systemd[1]: Mounted Temporary Directory (/tmp).
[ 5.795337] systemd[1]: Finished TrueNAS Update.
[ 5.797632] systemd[1]: Finished Set the console keyboard layout.
[ 5.800036] systemd[1]: Finished Create list of static device nodes for the current kernel.
[ 5.801808] systemd[1]: modprobe@configfs.service: Succeeded.
[ 5.802583] systemd[1]: Finished Load Kernel Module configfs.
[ 5.803911] systemd[1]: modprobe@drm.service: Succeeded.
[ 5.804687] systemd[1]: Finished Load Kernel Module drm.
[ 5.805870] systemd[1]: modprobe@fuse.service: Succeeded.
[ 5.806578] systemd[1]: Finished Load Kernel Module fuse.
[ 5.807873] systemd[1]: Finished Remount Root and Kernel File Systems.
[ 5.810465] systemd[1]: Mounting FUSE Control File System...
[ 5.813503] systemd[1]: Mounting Kernel Configuration File System...
[ 5.816603] systemd[1]: Starting Extract /conf/base...
[ 5.819673] systemd[1]: Starting pNFS block layout mapping daemon...
[ 5.822521] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[ 5.823666] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
[ 5.826996] systemd[1]: Starting Load/Save Random Seed...
[ 5.830199] systemd[1]: Starting Create System Users...
[ 5.832910] systemd[1]: Mounted FUSE Control File System.
[ 5.835203] systemd[1]: Mounted Kernel Configuration File System.
[ 5.838175] systemd[1]: Started pNFS block layout mapping daemon.
[ 5.842621] systemd[1]: Finished Create System Users.
[ 5.845650] systemd[1]: Started Journal Service.
[ 5.861493] systemd-journald[897]: Received client request to flush runtime journal.
[ 5.940434] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input0
[ 5.945062] ACPI: Sleep Button [SLPB]
[ 5.946165] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1
[ 5.947217] ACPI: Power Button [PWRB]
[ 5.948285] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
[ 5.964446] ACPI: Power Button [PWRF]
[ 6.225813] EDAC MC0: Giving out device to module ie31200_edac controller IE31200: DEV 0000:00:00.0 (POLLED)
[ 6.230379] mei_me 0000:00:16.0: enabling device (0000 -> 0002)
[ 6.231547] ses 6:0:0:0: Attached scsi generic sg0 type 13
[ 6.233086] sd 0:0:0:0: Attached scsi generic sg1 type 0
[ 6.234029] sd 1:0:0:0: Attached scsi generic sg2 type 0
[ 6.235249] sd 2:0:0:0: Attached scsi generic sg3 type 0
[ 6.236158] sd 3:0:0:0: Attached scsi generic sg4 type 0
[ 6.237879] sd 4:0:0:0: Attached scsi generic sg5 type 0
[ 6.238744] sd 5:0:0:0: Attached scsi generic sg6 type 0
[ 6.442022] ee1004 0-0051: 512 byte EE1004-compliant SPD EEPROM, read-only
[ 6.450860] iTCO_vendor_support: vendor-support=0
[ 6.456198] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.11
[ 6.457772] iTCO_wdt: Found a Intel PCH TCO device (Version=6, TCOBASE=0x0400)
[ 6.467052] pstore: Using crash dump compression: deflate
[ 6.467213] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[ 6.467958] pstore: Registered efi as persistent store backend
[ 6.528882] input: PC Speaker as /devices/platform/pcspkr/input/input3
[ 6.564352] Error: Driver 'pcspkr' is already registered, aborting...
[ 6.595034] i915 0000:00:02.0: [drm] VT-d active for gfx access
[ 6.595984] checking generic (4000000000 1e0000) vs hw (6000000000 1000000)
[ 6.595986] checking generic (4000000000 1e0000) vs hw (4000000000 10000000)
[ 6.595987] fb0: switching to inteldrmfb from EFI VGA
[ 6.597465] Console: switching to colour dummy device 80x25
[ 6.597507] i915 0000:00:02.0: vgaarb: deactivate vga console
[ 6.601623] i915 0000:00:02.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=io+mem:owns=io+mem
[ 6.603578] i915 0000:00:02.0: [drm] Finished loading DMC firmware i915/kbl_dmc_ver1_04.bin (v1.4)
[ 6.712849] RAPL PMU: API unit is 2^-32 Joules, 4 fixed counters, 655360 ms ovfl timer
[ 6.712855] RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
[ 6.712857] RAPL PMU: hw unit of domain package 2^-14 Joules
[ 6.712859] RAPL PMU: hw unit of domain dram 2^-14 Joules
[ 6.712860] RAPL PMU: hw unit of domain pp1-gpu 2^-14 Joules
[ 6.813965] mei_hdcp 0000:00:16.0-b638ab7e-94e2-4ea2-a552-d1c54b627f04: bound 0000:00:02.0 (ops i915_hdcp_component_ops [i915])
[ 6.921131] i915 0000:00:02.0: [drm] failed to retrieve link info, disabling eDP
[ 6.923035] intel_pmc_core intel_pmc_core.0: initialized
[ 6.925101] intel_rapl_common: Found RAPL domain package
[ 6.925107] intel_rapl_common: Found RAPL domain core
[ 6.925109] intel_rapl_common: Found RAPL domain uncore
[ 6.925111] intel_rapl_common: Found RAPL domain dram
[ 6.953971] [drm] Initialized i915 1.6.0 20200917 for 0000:00:02.0 on minor 0
[ 6.956057] ACPI: Video Device [GFX0] (multi-head: yes rom: no post: no)
[ 6.956293] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input4
[ 6.988404] i915 0000:00:02.0: [drm] Cannot find any crtc or sizes
[ 7.039737] i915 0000:00:02.0: [drm] Cannot find any crtc or sizes
[ 7.074796] i915 0000:00:02.0: [drm] Cannot find any crtc or sizes
[ 13.427036] device-mapper: uevent: version 1.0.3
[ 13.427113] device-mapper: ioctl: 4.43.0-ioctl (2020-10-01) initialised: dm-devel@redhat.com
[ 13.640390] Adding 16777212k swap on /dev/mapper/nvme0n1p4. Priority:-2 extents:1 across:16777212k SSFS
[ 15.870546] dca service started, version 1.12.1
[ 15.871490] ioatdma: Intel(R) QuickData Technology Driver 5.00
[ 15.873117] NTB Resource Split driver, version 1
[ 15.874028] Software Queue-Pair Transport over NTB, version 4
[ 15.880727] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[ 20.107405] e1000e 0000:00:1f.6 eno1: NIC Link is Up 1000 Mbps Full Duplex, Flow Control: Rx/Tx
[ 20.107535] IPv6: ADDRCONF(NETDEV_CHANGE): eno1: link becomes ready
[ 28.888494] md/raid1:md127: not clean -- starting background reconstruction
[ 28.888501] md/raid1:md127: active with 2 out of 2 mirrors
[ 28.888524] md127: detected capacity change from 0 to 2147418624
[ 28.942848] md/raid1:md126: not clean -- starting background reconstruction
[ 28.942854] md/raid1:md126: active with 2 out of 2 mirrors
[ 28.942875] md126: detected capacity change from 0 to 2147483648
[ 29.099041] md/raid1:md125: not clean -- starting background reconstruction
[ 29.099047] md/raid1:md125: active with 2 out of 2 mirrors
[ 29.099068] md125: detected capacity change from 0 to 2147483648
[ 29.229046] md: resync of RAID array md127
[ 29.344486] Adding 2097084k swap on /dev/mapper/md127. Priority:-3 extents:1 across:2097084k FS
[ 29.432429] md: resync of RAID array md126
[ 29.484411] Adding 2097148k swap on /dev/mapper/md126. Priority:-4 extents:1 across:2097148k FS
[ 29.608879] md: resync of RAID array md125
[ 29.660545] Adding 2097148k swap on /dev/mapper/md125. Priority:-5 extents:1 across:2097148k SSFS
[ 29.825521] md: md125: resync interrupted.
[ 29.833872] md125: detected capacity change from 2147483648 to 0
[ 29.833885] md: md125 stopped.
[ 30.255804] md: md126: resync interrupted.
[ 30.263419] md126: detected capacity change from 2147483648 to 0
[ 30.263432] md: md126 stopped.
[ 30.488381] md: md127: resync interrupted.
[ 30.488749] md127: detected capacity change from 2147418624 to 0
[ 30.488762] md: md127 stopped.
[ 31.178951] md/raid1:md127: not clean -- starting background reconstruction
[ 31.178958] md/raid1:md127: active with 2 out of 2 mirrors
[ 31.178976] md127: detected capacity change from 0 to 2147418624
[ 31.252398] md/raid1:md126: not clean -- starting background reconstruction
[ 31.252406] md/raid1:md126: active with 2 out of 2 mirrors
[ 31.252439] md126: detected capacity change from 0 to 2147483648
[ 31.328394] md/raid1:md125: not clean -- starting background reconstruction
[ 31.328401] md/raid1:md125: active with 2 out of 2 mirrors
[ 31.328420] md125: detected capacity change from 0 to 2147483648
[ 31.452390] md: resync of RAID array md127
[ 31.524390] Adding 2097084k swap on /dev/mapper/md127. Priority:-2 extents:1 across:2097084k FS
[ 31.599348] md: resync of RAID array md126
[ 31.696393] Adding 2097148k swap on /dev/mapper/md126. Priority:-3 extents:1 across:2097148k FS
[ 31.786442] md: resync of RAID array md125
[ 31.824552] Adding 2097148k swap on /dev/mapper/md125. Priority:-4 extents:1 across:2097148k SSFS
[ 33.975635] systemd-journald[897]: Received client request to relinquish /var/log/journal/af021ae749c6486cb5ceaa403cd9a288 access.
[ 33.976781] systemd-journald[897]: Received SIGTERM from PID 1 (systemd).
[ 33.976874] systemd[1]: Stopping Journal Service...
[ 33.977358] systemd[1]: systemd-journald.service: Succeeded.
[ 33.977619] systemd[1]: Stopped Journal Service.
[ 33.979130] systemd[1]: Starting Journal Service...
[ 34.001240] systemd[1]: Started Journal Service.
[ 34.008384] systemd-journald[4367]: Received client request to flush runtime journal.
[ 34.603815] systemd-journald[4367]: Received client request to relinquish /var/log/journal/af021ae749c6486cb5ceaa403cd9a288 access.
[ 34.604994] systemd-journald[4367]: Received SIGTERM from PID 1 (systemd).
[ 34.605087] systemd[1]: Stopping Journal Service...
[ 34.605664] systemd[1]: systemd-journald.service: Succeeded.
[ 34.605937] systemd[1]: Stopped Journal Service.
[ 34.607572] systemd[1]: Starting Journal Service...
[ 34.630115] systemd[1]: Started Journal Service.
[ 34.637422] systemd-journald[4699]: Received client request to flush runtime journal.
[ 35.054326] audit: type=1400 audit(1663688496.505:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/bin/man" pid=4838 comm="apparmor_parser"
[ 35.054337] audit: type=1400 audit(1663688496.505:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_filter" pid=4838 comm="apparmor_parser"
[ 35.054342] audit: type=1400 audit(1663688496.505:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_groff" pid=4838 comm="apparmor_parser"
[ 35.054414] audit: type=1400 audit(1663688496.505:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=4839 comm="apparmor_parser"
[ 35.054420] audit: type=1400 audit(1663688496.505:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=4839 comm="apparmor_parser"
[ 35.057103] audit: type=1400 audit(1663688496.509:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="virt-aa-helper" pid=4841 comm="apparmor_parser"
[ 35.058525] audit: type=1400 audit(1663688496.509:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lsb_release" pid=4842 comm="apparmor_parser"
[ 35.062323] audit: type=1400 audit(1663688496.513:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/ntpd" pid=4844 comm="apparmor_parser"
[ 35.065940] audit: type=1400 audit(1663688496.517:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="tcpdump" pid=4843 comm="apparmor_parser"
[ 35.069843] audit: type=1400 audit(1663688496.521:11): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libvirtd" pid=4840 comm="apparmor_parser"
[ 36.515924] NFSD: Using UMH upcall client tracking operations.
[ 36.515938] NFSD: starting 90-second grace period (net f00000a8)
[ 36.556695] IPMI message handler: version 39.2
[ 36.557337] ipmi device interface
[ 36.565857] ipmi_si: IPMI System Interface driver
[ 36.565909] ipmi_si: Unable to find any System Interface(s)
[ 41.832778] md: md127: resync done.
[ 43.298650] md: md126: resync done.
[ 45.387629] md: md125: resync done.
[ 47.291404] alg: No test for fips(ansi_cprng) (fips_ansi_cprng)
[ 47.322365] Bluetooth: Core ver 2.22
[ 47.322390] NET: Registered protocol family 31
[ 47.322393] Bluetooth: HCI device and connection manager initialized
[ 47.322397] Bluetooth: HCI socket layer initialized
[ 47.322400] Bluetooth: L2CAP socket layer initialized
[ 47.322403] Bluetooth: SCO socket layer initialized
[ 49.383370] ahci 0000:00:17.0: port does not support device sleep
[ 49.383932] ahci 0000:00:17.0: port does not support device sleep
[ [ 241.443814] i2c /dev entries driver
[ [ 325.389990] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 325.390684] Bridge firewalling registered
[ 325.526600] Initializing XFRM netlink socket
[ 331.890048] cgroup: cgroup: disabling cgroup2 socket matching due to net_prio or net_cls activation
[ 800.022250] ata3.00: exception Emask 0x10 SAct 0x40800 SErr 0x4050000 action 0xe frozen
[ 800.022263] ata3.00: irq_stat 0x00000040, connection status changed
[ 800.022269] ata3: SError: { PHYRdyChg CommWake DevExch }
[ 800.022276] ata3.00: failed command: WRITE FPDMA QUEUED
[ 800.022287] ata3.00: cmd 61/08:58:b0:34:40/00:00:bc:03:00/40 tag 11 ncq dma 4096 out
res 40/00:a8:28:dd:91/00:00:17:01:00/40 Emask 0x10 (ATA bus error)
[ 800.022296] ata3.00: status: { DRDY }
[ 800.022301] ata3.00: failed command: WRITE FPDMA QUEUED
[ 800.022310] ata3.00: cmd 61/08:90:88:59:40/00:00:ba:03:00/40 tag 18 ncq dma 4096 out
[ 800.022318] ata3.00: status: { DRDY }
[ 800.022326] ata3: hard resetting link
[ 800.734116] ata3: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 800.824497] ata3.00: configured for UDMA/133
[ 800.868670] sd 2:0:0:0: [sdc] tag#11 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
[ 800.868687] sd 2:0:0:0: [sdc] tag#11 Sense Key : Illegal Request [current]
[ 800.868696] sd 2:0:0:0: [sdc] tag#11 Add. Sense: Unaligned write command
[ 800.868704] sd 2:0:0:0: [sdc] tag#11 CDB: Write(16) 8a 00 00 00 00 03 bc 40 34 b0 00 00 00 08 00 00
[ 800.868714] blk_update_request: I/O error, dev sdc, sector 16043226288 op 0x1:(WRITE) flags 0x700 phys_seg 1 prio class 0
[ 800.868729] zio pool=HDDPool vdev=/dev/disk/by-partuuid/b5aa7dfb-4bcd-4206-803f-0162340c1d92 error=5 type=2 offset=8211984310272 size=4096 flags=180880
[ 800.868767] sd 2:0:0:0: [sdc] tag#18 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
[ 800.868779] sd 2:0:0:0: [sdc] tag#18 Sense Key : Illegal Request [current]
[ 800.868789] sd 2:0:0:0: [sdc] tag#18 Add. Sense: Unaligned write command
[ 800.868799] sd 2:0:0:0: [sdc] tag#18 CDB: Write(16) 8a 00 00 00 00 03 ba 40 59 88 00 00 00 08 00 00
[ 800.868812] blk_update_request: I/O error, dev sdc, sector 16009681288 op 0x1:(WRITE) flags 0x700 phys_seg 1 prio class 0
[ 800.868826] zio pool=HDDPool vdev=/dev/disk/by-partuuid/b5aa7dfb-4bcd-4206-803f-0162340c1d92 error=5 type=2 offset=8194809270272 size=4096 flags=180880
[ 800.868849] ata3: EH complete
[ 1028.861855] ata3.00: exception Emask 0x10 SAct 0x3c0000 SErr 0x4040000 action 0xe frozen
[ 1028.861868] ata3.00: irq_stat 0x00000040, connection status changed
[ 1028.861876] ata3: SError: { CommWake DevExch }
[ 1028.861882] ata3.00: failed command: WRITE FPDMA QUEUED
[ 1028.861895] ata3.00: cmd 61/08:90:b0:01:40/00:00:00:00:00/40 tag 18 ncq dma 4096 out
res 50/00:00:00:00:00/00:00:00:00:00/a0 Emask 0x10 (ATA bus error)
[ 1028.861905] ata3.00: status: { DRDY }
[ 1028.861910] ata3.00: failed command: WRITE FPDMA QUEUED
[ 1028.861920] ata3.00: cmd 61/08:98:b0:03:40/00:00:00:00:00/40 tag 19 ncq dma 4096 out
[ 1028.861930] ata3.00: status: { DRDY }
[ 1028.861934] ata3.00: failed command: WRITE FPDMA QUEUED
[ 1028.861944] ata3.00: cmd 61/08:a0:b0:fb:7f/00:00:2f:08:00/40 tag 20 ncq dma 4096 out
[ 1028.861953] ata3.00: status: { DRDY }
[ 1028.861958] ata3.00: failed command: WRITE FPDMA QUEUED
[ 1028.861967] ata3.00: cmd 61/08:a8:b0:fd:7f/00:00:2f:08:00/40 tag 21 ncq dma 4096 out
[ 1028.861976] ata3.00: status: { DRDY }
[ 1028.861984] ata3: hard resetting link
[ 1029.573852] ata3: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 1029.662149] ata3.00: configured for UDMA/133
[ 1029.714703] sd 2:0:0:0: [sdc] tag#18 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
[ 1029.714720] sd 2:0:0:0: [sdc] tag#18 Sense Key : Illegal Request [current]
[ 1029.714728] sd 2:0:0:0: [sdc] tag#18 Add. Sense: Unaligned write command
[ 1029.714736] sd 2:0:0:0: [sdc] tag#18 CDB: Write(16) 8a 00 00 00 00 00 00 40 01 b0 00 00 00 08 00 00
[ 1029.714747] blk_update_request: I/O error, dev sdc, sector 4194736 op 0x1:(WRITE) flags 0x700 phys_seg 1 prio class 0
[ 1029.714762] zio pool=HDDPool vdev=/dev/disk/by-partuuid/b5aa7dfb-4bcd-4206-803f-0162340c1d92 error=5 type=2 offset=155648 size=4096 flags=180ac0
[ 1029.714801] sd 2:0:0:0: [sdc] tag#19 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
[ 1029.714814] sd 2:0:0:0: [sdc] tag#19 Sense Key : Illegal Request [current]
[ 1029.714825] sd 2:0:0:0: [sdc] tag#19 Add. Sense: Unaligned write command
[ 1029.714836] sd 2:0:0:0: [sdc] tag#19 CDB: Write(16) 8a 00 00 00 00 00 00 40 03 b0 00 00 00 08 00 00
[ 1029.714848] blk_update_request: I/O error, dev sdc, sector 4195248 op 0x1:(WRITE) flags 0x700 phys_seg 1 prio class 0
[ 1029.714857] zio pool=HDDPool vdev=/dev/disk/by-partuuid/b5aa7dfb-4bcd-4206-803f-0162340c1d92 error=5 type=2 offset=417792 size=4096 flags=180ac0
[ 1029.714872] sd 2:0:0:0: [sdc] tag#20 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
[ 1029.714879] sd 2:0:0:0: [sdc] tag#20 Sense Key : Illegal Request [current]
[ 1029.714886] sd 2:0:0:0: [sdc] tag#20 Add. Sense: Unaligned write command
[ 1029.714893] sd 2:0:0:0: [sdc] tag#20 CDB: Write(16) 8a 00 00 00 00 08 2f 7f fb b0 00 00 00 08 00 00
[ 1029.714900] blk_update_request: I/O error, dev sdc, sector 35156655024 op 0x1:(WRITE) flags 0x700 phys_seg 1 prio class 0
[ 1029.714909] zio pool=HDDPool vdev=/dev/disk/by-partuuid/b5aa7dfb-4bcd-4206-803f-0162340c1d92 error=5 type=2 offset=17998059823104 size=4096 flags=180ac0
[ 1029.714922] sd 2:0:0:0: [sdc] tag#21 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
[ 1029.714930] sd 2:0:0:0: [sdc] tag#21 Sense Key : Illegal Request [current]
[ 1029.714936] sd 2:0:0:0: [sdc] tag#21 Add. Sense: Unaligned write command
[ 1029.714943] sd 2:0:0:0: [sdc] tag#21 CDB: Write(16) 8a 00 00 00 00 08 2f 7f fd b0 00 00 00 08 00 00
[ 1029.714950] blk_update_request: I/O error, dev sdc, sector 35156655536 op 0x1:(WRITE) flags 0x700 phys_seg 1 prio class 0
[ 1029.714958] zio pool=HDDPool vdev=/dev/disk/by-partuuid/b5aa7dfb-4bcd-4206-803f-0162340c1d92 error=5 type=2 offset=17998060085248 size=4096 flags=180ac0
[ 1029.714968] ata3: EH complete
[[ 1786.767531] ata3.00: exception Emask 0x10 SAct 0x780000 SErr 0x4050000 action 0xe frozen
[ 1786.767545] ata3.00: irq_stat 0x00000040, connection status changed
[ 1786.767553] ata3: SError: { PHYRdyChg CommWake DevExch }
[ 1786.767560] ata3.00: failed command: WRITE FPDMA QUEUED
[ 1786.767572] ata3.00: cmd 61/08:98:48:02:40/00:00:00:00:00/40 tag 19 ncq dma 4096 out
[ 1786.767582] ata3.00: status: { DRDY }
[ 1786.767588] ata3.00: failed command: WRITE FPDMA QUEUED
[ 1786.767598] ata3.00: cmd 61/08:a0:48:04:40/00:00:00:00:00/40 tag 20 ncq dma 4096 out
[ 1786.767607] ata3.00: status: { DRDY }
[ 1786.767612] ata3.00: failed command: WRITE FPDMA QUEUED
[ 1786.767621] ata3.00: cmd 61/08:a8:48:fc:7f/00:00:2f:08:00/40 tag 21 ncq dma 4096 out
[ 1786.767630] ata3.00: status: { DRDY }
[ 1786.767635] ata3.00: failed command: WRITE FPDMA QUEUED
[ 1786.767645] ata3.00: cmd 61/08:b0:48:fe:7f/00:00:2f:08:00/40 tag 22 ncq dma 4096 out
[ 1786.767653] ata3.00: status: { DRDY }
[ 1786.767661] ata3: hard resetting link
[ 1787.495281] ata3: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 1787.583869] ata3.00: configured for UDMA/133
[ 1787.628348] sd 2:0:0:0: [sdc] tag#19 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
[ 1787.628353] sd 2:0:0:0: [sdc] tag#19 Sense Key : Illegal Request [current]
[ 1787.628355] sd 2:0:0:0: [sdc] tag#19 Add. Sense: Unaligned write command
[ 1787.628357] sd 2:0:0:0: [sdc] tag#19 CDB: Write(16) 8a 00 00 00 00 00 00 40 02 48 00 00 00 08 00 00
[ 1787.628360] blk_update_request: I/O error, dev sdc, sector 4194888 op 0x1:(WRITE) flags 0x700 phys_seg 1 prio class 0
[ 1787.628364] zio pool=HDDPool vdev=/dev/disk/by-partuuid/b5aa7dfb-4bcd-4206-803f-0162340c1d92 error=5 type=2 offset=233472 size=4096 flags=180ac0
[ 1787.628377] sd 2:0:0:0: [sdc] tag#20 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
[ 1787.628380] sd 2:0:0:0: [sdc] tag#20 Sense Key : Illegal Request [current]
[ 1787.628381] sd 2:0:0:0: [sdc] tag#20 Add. Sense: Unaligned write command
[ 1787.628383] sd 2:0:0:0: [sdc] tag#20 CDB: Write(16) 8a 00 00 00 00 00 00 40 04 48 00 00 00 08 00 00
[ 1787.628385] blk_update_request: I/O error, dev sdc, sector 4195400 op 0x1:(WRITE) flags 0x700 phys_seg 1 prio class 0
[ 1787.628387] zio pool=HDDPool vdev=/dev/disk/by-partuuid/b5aa7dfb-4bcd-4206-803f-0162340c1d92 error=5 type=2 offset=495616 size=4096 flags=180ac0
[ 1787.628390] sd 2:0:0:0: [sdc] tag#21 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
[ 1787.628392] sd 2:0:0:0: [sdc] tag#21 Sense Key : Illegal Request [current]
[ 1787.628394] sd 2:0:0:0: [sdc] tag#21 Add. Sense: Unaligned write command
[ 1787.628396] sd 2:0:0:0: [sdc] tag#21 CDB: Write(16) 8a 00 00 00 00 08 2f 7f fc 48 00 00 00 08 00 00
[ 1787.628398] blk_update_request: I/O error, dev sdc, sector 35156655176 op 0x1:(WRITE) flags 0x700 phys_seg 1 prio class 0
[ 1787.628400] zio pool=HDDPool vdev=/dev/disk/by-partuuid/b5aa7dfb-4bcd-4206-803f-0162340c1d92 error=5 type=2 offset=17998059900928 size=4096 flags=180ac0
[ 1787.628403] sd 2:0:0:0: [sdc] tag#22 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
[ 1787.628404] sd 2:0:0:0: [sdc] tag#22 Sense Key : Illegal Request [current]
[ 1787.628406] sd 2:0:0:0: [sdc] tag#22 Add. Sense: Unaligned write command
[ 1787.628408] sd 2:0:0:0: [sdc] tag#22 CDB: Write(16) 8a 00 00 00 00 08 2f 7f fe 48 00 00 00 08 00 00
[ 1787.628410] blk_update_request: I/O error, dev sdc, sector 35156655688 op 0x1:(WRITE) flags 0x700 phys_seg 1 prio class 0
[ 1787.628412] zio pool=HDDPool vdev=/dev/disk/by-partuuid/b5aa7dfb-4bcd-4206-803f-0162340c1d92 error=5 type=2 offset=17998060163072 size=4096 flags=180ac0
[ 1787.628414] ata3: EH complete
[[ 2354.845362] ata3: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 2354.930695] ata3.00: configured for UDMA/133
[ 2870.516638] ata3: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 2870.602763] ata3.00: configured for UDMA/133
[[ 3261.524649] ata3.00: exception Emask 0x10 SAct 0x38000 SErr 0x4050000 action 0xe frozen
[ 3261.524684] ata3.00: irq_stat 0x00000040, connection status changed
[ 3261.524690] ata3: SError: { PHYRdyChg CommWake DevExch }
[ 3261.524696] ata3.00: failed command: READ FPDMA QUEUED
[ 3261.524706] ata3.00: cmd 60/00:78:90:1e:f4/01:00:75:01:00/40 tag 15 ncq dma 131072 in
res 40/00:20:90:1d:f4/00:00:75:01:00/40 Emask 0x10 (ATA bus error)
[ 3261.524714] ata3.00: status: { DRDY }
[ 3261.524719] ata3.00: failed command: READ FPDMA QUEUED
[ 3261.524727] ata3.00: cmd 60/00:80:90:1f:f4/01:00:75:01:00/40 tag 16 ncq dma 131072 in
[ 3261.524735] ata3.00: status: { DRDY }
[ 3261.524739] ata3.00: failed command: READ FPDMA QUEUED
[ 3261.524747] ata3.00: cmd 60/00:88:90:20:f4/01:00:75:01:00/40 tag 17 ncq dma 131072 in
[ 3261.524754] ata3.00: status: { DRDY }
[ 3261.524761] ata3: hard resetting link
[ 3262.244707] ata3: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 3262.334429] ata3.00: configured for UDMA/133
[ 3262.412142] sd 2:0:0:0: [sdc] tag#15 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
[ 3262.412164] sd 2:0:0:0: [sdc] tag#15 Sense Key : Illegal Request [current]
[ 3262.412177] sd 2:0:0:0: [sdc] tag#15 Add. Sense: Unaligned write command
[ 3262.412188] sd 2:0:0:0: [sdc] tag#15 CDB: Read(16) 88 00 00 00 00 01 75 f4 1e 90 00 00 01 00 00 00
[ 3262.412203] blk_update_request: I/O error, dev sdc, sector 6273900176 op 0x0:(READ) flags 0x700 phys_seg 2 prio class 0
[ 3262.412223] zio pool=HDDPool vdev=/dev/disk/by-partuuid/b5aa7dfb-4bcd-4206-803f-0162340c1d92 error=5 type=1 offset=3210089340928 size=131072 flags=1808b0
[ 3262.412262] sd 2:0:0:0: [sdc] tag#16 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
[ 3262.412274] sd 2:0:0:0: [sdc] tag#16 Sense Key : Illegal Request [current]
[ 3262.412285] sd 2:0:0:0: [sdc] tag#16 Add. Sense: Unaligned write command
[ 3262.412297] sd 2:0:0:0: [sdc] tag#16 CDB: Read(16) 88 00 00 00 00 01 75 f4 1f 90 00 00 01 00 00 00
[ 3262.412309] blk_update_request: I/O error, dev sdc, sector 6273900432 op 0x0:(READ) flags 0x700 phys_seg 2 prio class 0
[ 3262.412324] zio pool=HDDPool vdev=/dev/disk/by-partuuid/b5aa7dfb-4bcd-4206-803f-0162340c1d92 error=5 type=1 offset=3210089472000 size=131072 flags=1808b0
[ 3262.412353] sd 2:0:0:0: [sdc] tag#17 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
[ 3262.412365] sd 2:0:0:0: [sdc] tag#17 Sense Key : Illegal Request [current]
[ 3262.412377] sd 2:0:0:0: [sdc] tag#17 Add. Sense: Unaligned write command
[ 3262.412387] sd 2:0:0:0: [sdc] tag#17 CDB: Read(16) 88 00 00 00 00 01 75 f4 20 90 00 00 01 00 00 00
[ 3262.412399] blk_update_request: I/O error, dev sdc, sector 6273900688 op 0x0:(READ) flags 0x700 phys_seg 2 prio class 0
[ 3262.412412] zio pool=HDDPool vdev=/dev/disk/by-partuuid/b5aa7dfb-4bcd-4206-803f-0162340c1d92 error=5 type=1 offset=3210089603072 size=131072 flags=1808b0
[ 3262.412438] ata3: EH complete
[[[[[[[[16211.786291] ata3.00: exception Emask 0x10 SAct 0x1800 SErr 0x4050000 action 0xe frozen
[16211.786303] ata3.00: irq_stat 0x00000040, connection status changed
[16211.786310] ata3: SError: { PHYRdyChg CommWake DevExch }
[16211.786315] ata3.00: failed command: WRITE FPDMA QUEUED
[16211.786325] ata3.00: cmd 61/08:58:40:a5:40/00:00:c0:03:00/40 tag 11 ncq dma 4096 out
res 40/00:a8:d8:4b:42/00:00:b8:03:00/40 Emask 0x10 (ATA bus error)
[16211.786334] ata3.00: status: { DRDY }
[16211.786338] ata3.00: failed command: WRITE FPDMA QUEUED
[16211.786347] ata3.00: cmd 61/08:60:40:a5:40/00:00:c2:03:00/40 tag 12 ncq dma 4096 out
[16211.786354] ata3.00: status: { DRDY }
[16211.786361] ata3: hard resetting link
[16212.506266] ata3: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[16212.586852] ata3.00: configured for UDMA/133
[16212.639307] sd 2:0:0:0: [sdc] tag#11 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
[16212.639323] sd 2:0:0:0: [sdc] tag#11 Sense Key : Illegal Request [current]
[16212.639332] sd 2:0:0:0: [sdc] tag#11 Add. Sense: Unaligned write command
[16212.639340] sd 2:0:0:0: [sdc] tag#11 CDB: Write(16) 8a 00 00 00 00 03 c0 40 a5 40 00 00 00 08 00 00
[16212.639350] blk_update_request: I/O error, dev sdc, sector 16110363968 op 0x1:(WRITE) flags 0x700 phys_seg 1 prio class 0
[16212.639366] zio pool=HDDPool vdev=/dev/disk/by-partuuid/b5aa7dfb-4bcd-4206-803f-0162340c1d92 error=5 type=2 offset=8246358802432 size=4096 flags=180880
[16212.639401] sd 2:0:0:0: [sdc] tag#12 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
[16212.639409] sd 2:0:0:0: [sdc] tag#12 Sense Key : Illegal Request [current]
[16212.639416] sd 2:0:0:0: [sdc] tag#12 Add. Sense: Unaligned write command
[16212.639423] sd 2:0:0:0: [sdc] tag#12 CDB: Write(16) 8a 00 00 00 00 03 c2 40 a5 40 00 00 00 08 00 00
[16212.639431] blk_update_request: I/O error, dev sdc, sector 16143918400 op 0x1:(WRITE) flags 0x700 phys_seg 1 prio class 0
[16212.639440] zio pool=HDDPool vdev=/dev/disk/by-partuuid/b5aa7dfb-4bcd-4206-803f-0162340c1d92 error=5 type=2 offset=8263538671616 size=4096 flags=180880
[16212.639455] ata3: EH complete
[25579.347729] ata3: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[25579.434323] ata3.00: configured for UDMA/133
[38838.280436] ata3: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[38838.363004] ata3.00: configured for UDMA/133
[53507.402989] ata3.00: exception Emask 0x10 SAct 0x600000 SErr 0x4050000 action 0xe frozen
[53507.403000] ata3.00: irq_stat 0x00000040, connection status changed
[53507.403006] ata3: SError: { PHYRdyChg CommWake DevExch }
[53507.403012] ata3.00: failed command: WRITE FPDMA QUEUED
[53507.403022] ata3.00: cmd 61/08:a8:20:39:40/00:00:a6:03:00/40 tag 21 ncq dma 4096 out
res 40/00:68:40:5d:40/00:00:d8:03:00/40 Emask 0x10 (ATA bus error)
[53507.403030] ata3.00: status: { DRDY }
[53507.403034] ata3.00: failed command: WRITE FPDMA QUEUED
[53507.403043] ata3.00: cmd 61/08:b0:20:39:40/00:00:a8:03:00/40 tag 22 ncq dma 4096 out
[53507.403051] ata3.00: status: { DRDY }
[53507.403057] ata3: hard resetting link
[53508.115138] ata3: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[53508.202540] ata3.00: configured for UDMA/133
[53508.263469] sd 2:0:0:0: [sdc] tag#21 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
[53508.263486] sd 2:0:0:0: [sdc] tag#21 Sense Key : Illegal Request [current]
[53508.263495] sd 2:0:0:0: [sdc] tag#21 Add. Sense: Unaligned write command
[53508.263503] sd 2:0:0:0: [sdc] tag#21 CDB: Write(16) 8a 00 00 00 00 03 a6 40 39 20 00 00 00 08 00 00
[53508.263513] blk_update_request: I/O error, dev sdc, sector 15674128672 op 0x1:(WRITE) flags 0x700 phys_seg 1 prio class 0
[53508.263529] zio pool=HDDPool vdev=/dev/disk/by-partuuid/b5aa7dfb-4bcd-4206-803f-0162340c1d92 error=5 type=2 offset=8023006330880 size=4096 flags=180880
[53508.263560] sd 2:0:0:0: [sdc] tag#22 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
[53508.263569] sd 2:0:0:0: [sdc] tag#22 Sense Key : Illegal Request [current]
[53508.263576] sd 2:0:0:0: [sdc] tag#22 Add. Sense: Unaligned write command
[53508.263582] sd 2:0:0:0: [sdc] tag#22 CDB: Write(16) 8a 00 00 00 00 03 a8 40 39 20 00 00 00 08 00 00
[53508.263591] blk_update_request: I/O error, dev sdc, sector 15707683104 op 0x1:(WRITE) flags 0x700 phys_seg 1 prio class 0
[53508.263600] zio pool=HDDPool vdev=/dev/disk/by-partuuid/b5aa7dfb-4bcd-4206-803f-0162340c1d92 error=5 type=2 offset=8040186200064 size=4096 flags=180880
[53508.263618] ata3: EH complete
[53836.672029] ata3.00: exception Emask 0x10 SAct 0x3800 SErr 0x4040000 action 0xe frozen
[53836.672047] ata3.00: irq_stat 0x00000040, connection status changed
[53836.672057] ata3: SError: { CommWake DevExch }
[53836.672066] ata3.00: failed command: READ FPDMA QUEUED
[53836.672084] ata3.00: cmd 60/00:58:00:60:ea/01:00:66:03:00/40 tag 11 ncq dma 131072 in
res 40/00:60:00:5f:ea/00:00:66:03:00/40 Emask 0x10 (ATA bus error)
[53836.672100] ata3.00: status: { DRDY }
[53836.672108] ata3.00: failed command: READ FPDMA QUEUED
[53836.672126] ata3.00: cmd 60/00:60:00:61:ea/01:00:66:03:00/40 tag 12 ncq dma 131072 in
[53836.672141] ata3.00: status: { DRDY }
[53836.672149] ata3.00: failed command: READ FPDMA QUEUED
[53836.672164] ata3.00: cmd 60/00:68:00:62:ea/01:00:66:03:00/40 tag 13 ncq dma 131072 in
[53836.672179] ata3.00: status: { DRDY }
[53836.672190] ata3: hard resetting link
[53837.383896] ata3: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[53837.472436] ata3.00: configured for UDMA/133
[53837.533253] sd 2:0:0:0: [sdc] tag#11 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
[53837.533270] sd 2:0:0:0: [sdc] tag#11 Sense Key : Illegal Request [current]
[53837.533279] sd 2:0:0:0: [sdc] tag#11 Add. Sense: Unaligned write command
[53837.533287] sd 2:0:0:0: [sdc] tag#11 CDB: Read(16) 88 00 00 00 00 03 66 ea 60 00 00 00 01 00 00 00
[53837.533297] blk_update_request: I/O error, dev sdc, sector 14611537920 op 0x0:(READ) flags 0x700 phys_seg 2 prio class 0
[53837.533313] zio pool=HDDPool vdev=/dev/disk/by-partuuid/b5aa7dfb-4bcd-4206-803f-0162340c1d92 error=5 type=1 offset=7478959865856 size=131072 flags=1808b0
[53837.533345] sd 2:0:0:0: [sdc] tag#12 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
[53837.533353] sd 2:0:0:0: [sdc] tag#12 Sense Key : Illegal Request [current]
[53837.533360] sd 2:0:0:0: [sdc] tag#12 Add. Sense: Unaligned write command
[53837.533367] sd 2:0:0:0: [sdc] tag#12 CDB: Read(16) 88 00 00 00 00 03 66 ea 61 00 00 00 01 00 00 00
[53837.533376] blk_update_request: I/O error, dev sdc, sector 14611538176 op 0x0:(READ) flags 0x700 phys_seg 2 prio class 0
[53837.533385] zio pool=HDDPool vdev=/dev/disk/by-partuuid/b5aa7dfb-4bcd-4206-803f-0162340c1d92 error=5 type=1 offset=7478959996928 size=131072 flags=1808b0
[53837.533407] sd 2:0:0:0: [sdc] tag#13 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
[53837.533419] sd 2:0:0:0: [sdc] tag#13 Sense Key : Illegal Request [current]
[53837.533430] sd 2:0:0:0: [sdc] tag#13 Add. Sense: Unaligned write command
[53837.533441] sd 2:0:0:0: [sdc] tag#13 CDB: Read(16) 88 00 00 00 00 03 66 ea 62 00 00 00 01 00 00 00
[53837.533453] blk_update_request: I/O error, dev sdc, sector 14611538432 op 0x0:(READ) flags 0x700 phys_seg 2 prio class 0
[53837.533468] zio pool=HDDPool vdev=/dev/disk/by-partuuid/b5aa7dfb-4bcd-4206-803f-0162340c1d92 error=5 type=1 offset=7478960128000 size=131072 flags=1808b0
[53837.533492] ata3: EH complete
[56746.552626] ata3.00: exception Emask 0x10 SAct 0x40000003 SErr 0x4050000 action 0xe frozen
[56746.552638] ata3.00: irq_stat 0x00000040, connection status changed
[56746.552644] ata3: SError: { PHYRdyChg CommWake DevExch }
[56746.552651] ata3.00: failed command: READ FPDMA QUEUED
[56746.552661] ata3.00: cmd 60/00:00:c0:fd:4a/01:00:d3:01:00/40 tag 0 ncq dma 131072 in
res 40/00:b8:c0:fb:4a/00:00:d3:01:00/40 Emask 0x10 (ATA bus error)
[56746.552670] ata3.00: status: { DRDY }
[56746.552675] ata3.00: failed command: READ FPDMA QUEUED
[56746.552684] ata3.00: cmd 60/00:08:c0:fe:4a/01:00:d3:01:00/40 tag 1 ncq dma 131072 in
[56746.552693] ata3.00: status: { DRDY }
[56746.552698] ata3.00: failed command: READ FPDMA QUEUED
[56746.552707] ata3.00: cmd 60/00:f0:c0:fc:4a/01:00:d3:01:00/40 tag 30 ncq dma 131072 in
[56746.552715] ata3.00: status: { DRDY }
[56746.552722] ata3: hard resetting link
[56747.268603] ata3: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[56747.351833] ata3.00: configured for UDMA/133
[56747.404457] sd 2:0:0:0: [sdc] tag#0 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
[56747.404474] sd 2:0:0:0: [sdc] tag#0 Sense Key : Illegal Request [current]
[56747.404483] sd 2:0:0:0: [sdc] tag#0 Add. Sense: Unaligned write command
[56747.404491] sd 2:0:0:0: [sdc] tag#0 CDB: Read(16) 88 00 00 00 00 01 d3 4a fd c0 00 00 01 00 00 00
[56747.404502] blk_update_request: I/O error, dev sdc, sector 7839874496 op 0x0:(READ) flags 0x700 phys_seg 2 prio class 0
[56747.404564] zio pool=HDDPool vdev=/dev/disk/by-partuuid/b5aa7dfb-4bcd-4206-803f-0162340c1d92 error=5 type=1 offset=4011868192768 size=131072 flags=1808b0
[56747.404610] sd 2:0:0:0: [sdc] tag#1 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
[56747.404622] sd 2:0:0:0: [sdc] tag#1 Sense Key : Illegal Request [current]
[56747.404632] sd 2:0:0:0: [sdc] tag#1 Add. Sense: Unaligned write command
[56747.404643] sd 2:0:0:0: [sdc] tag#1 CDB: Read(16) 88 00 00 00 00 01 d3 4a fe c0 00 00 01 00 00 00
[56747.404656] blk_update_request: I/O error, dev sdc, sector 7839874752 op 0x0:(READ) flags 0x700 phys_seg 2 prio class 0
[56747.404672] zio pool=HDDPool vdev=/dev/disk/by-partuuid/b5aa7dfb-4bcd-4206-803f-0162340c1d92 error=5 type=1 offset=4011868323840 size=131072 flags=1808b0
[56747.404712] sd 2:0:0:0: [sdc] tag#30 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
[56747.404725] sd 2:0:0:0: [sdc] tag#30 Sense Key : Illegal Request [current]
[56747.404735] sd 2:0:0:0: [sdc] tag#30 Add. Sense: Unaligned write command
[56747.404747] sd 2:0:0:0: [sdc] tag#30 CDB: Read(16) 88 00 00 00 00 01 d3 4a fc c0 00 00 01 00 00 00
[56747.404762] blk_update_request: I/O error, dev sdc, sector 7839874240 op 0x0:(READ) flags 0x700 phys_seg 2 prio class 0
[56747.404778] zio pool=HDDPool vdev=/dev/disk/by-partuuid/b5aa7dfb-4bcd-4206-803f-0162340c1d92 error=5 type=1 offset=4011868061696 size=131072 flags=1808b0
[56747.404799] ata3: EH complete
[57623.379351] ata3.00: exception Emask 0x10 SAct 0x7 SErr 0x4040000 action 0xe frozen
[57623.379365] ata3.00: irq_stat 0x00000040, connection status changed
[57623.379372] ata3: SError: { CommWake DevExch }
[57623.379379] ata3.00: failed command: READ FPDMA QUEUED
[57623.379392] ata3.00: cmd 60/00:00:30:20:45/01:00:54:00:00/40 tag 0 ncq dma 131072 in
res 40/00:f8:30:1e:45/00:00:54:00:00/40 Emask 0x10 (ATA bus error)
[57623.379402] ata3.00: status: { DRDY }
[57623.379407] ata3.00: failed command: READ FPDMA QUEUED
[57623.379417] ata3.00: cmd 60/00:08:30:21:45/01:00:54:00:00/40 tag 1 ncq dma 131072 in
[57623.379427] ata3.00: status: { DRDY }
[57623.379432] ata3.00: failed command: READ FPDMA QUEUED
[57623.379441] ata3.00: cmd 60/00:10:30:22:45/01:00:54:00:00/40 tag 2 ncq dma 131072 in
[57623.379450] ata3.00: status: { DRDY }
[57623.379458] ata3: hard resetting link
[57624.091292] ata3: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[57624.174310] ata3.00: configured for UDMA/133
[57624.218634] sd 2:0:0:0: [sdc] tag#0 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
[57624.218652] sd 2:0:0:0: [sdc] tag#0 Sense Key : Illegal Request [current]
[57624.218660] sd 2:0:0:0: [sdc] tag#0 Add. Sense: Unaligned write command
[57624.218668] sd 2:0:0:0: [sdc] tag#0 CDB: Read(16) 88 00 00 00 00 00 54 45 20 30 00 00 01 00 00 00
[57624.218678] blk_update_request: I/O error, dev sdc, sector 1413816368 op 0x0:(READ) flags 0x700 phys_seg 2 prio class 0
[57624.218694] zio pool=HDDPool vdev=/dev/disk/by-partuuid/b5aa7dfb-4bcd-4206-803f-0162340c1d92 error=5 type=1 offset=721726431232 size=131072 flags=1808b0
[57624.218723] sd 2:0:0:0: [sdc] tag#1 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
[57624.218731] sd 2:0:0:0: [sdc] tag#1 Sense Key : Illegal Request [current]
[57624.218738] sd 2:0:0:0: [sdc] tag#1 Add. Sense: Unaligned write command
[57624.218745] sd 2:0:0:0: [sdc] tag#1 CDB: Read(16) 88 00 00 00 00 00 54 45 21 30 00 00 01 00 00 00
[57624.218753] blk_update_request: I/O error, dev sdc, sector 1413816624 op 0x0:(READ) flags 0x700 phys_seg 2 prio class 0
[57624.218762] zio pool=HDDPool vdev=/dev/disk/by-partuuid/b5aa7dfb-4bcd-4206-803f-0162340c1d92 error=5 type=1 offset=721726562304 size=131072 flags=1808b0
[57624.218783] sd 2:0:0:0: [sdc] tag#2 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
[57624.218791] sd 2:0:0:0: [sdc] tag#2 Sense Key : Illegal Request [current]
[57624.218798] sd 2:0:0:0: [sdc] tag#2 Add. Sense: Unaligned write command
[57624.218804] sd 2:0:0:0: [sdc] tag#2 CDB: Read(16) 88 00 00 00 00 00 54 45 22 30 00 00 01 00 00 00
[57624.218812] blk_update_request: I/O error, dev sdc, sector 1413816880 op 0x0:(READ) flags 0x700 phys_seg 2 prio class 0
[57624.218820] zio pool=HDDPool vdev=/dev/disk/by-partuuid/b5aa7dfb-4bcd-4206-803f-0162340c1d92 error=5 type=1 offset=721726693376 size=131072 flags=1808b0
[57624.218836] ata3: EH complete
[57840.459720] ata3.00: exception Emask 0x10 SAct 0x7000 SErr 0x4050000 action 0xe frozen
[57840.459732] ata3.00: irq_stat 0x00000040, connection status changed
[57840.459739] ata3: SError: { PHYRdyChg CommWake DevExch }
[57840.459746] ata3.00: failed command: READ FPDMA QUEUED
[57840.459757] ata3.00: cmd 60/00:60:28:c9:ba/01:00:6b:03:00/40 tag 12 ncq dma 131072 in
res 40/00:b8:28:c8:ba/00:00:6b:03:00/40 Emask 0x10 (ATA bus error)
[57840.459765] ata3.00: status: { DRDY }
[57840.459770] ata3.00: failed command: READ FPDMA QUEUED
[57840.459780] ata3.00: cmd 60/00:68:28:ca:ba/01:00:6b:03:00/40 tag 13 ncq dma 131072 in
[57840.459788] ata3.00: status: { DRDY }
[57840.459793] ata3.00: failed command: READ FPDMA QUEUED
[57840.459802] ata3.00: cmd 60/00:70:28:cb:ba/01:00:6b:03:00/40 tag 14 ncq dma 131072 in
[57840.459810] ata3.00: status: { DRDY }
[57840.459817] ata3: hard resetting link
[57841.171912] ata3: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[57841.266115] ata3.00: configured for UDMA/133
[57841.318683] sd 2:0:0:0: [sdc] tag#12 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
[57841.318701] sd 2:0:0:0: [sdc] tag#12 Sense Key : Illegal Request [current]
[57841.318709] sd 2:0:0:0: [sdc] tag#12 Add. Sense: Unaligned write command
[57841.318717] sd 2:0:0:0: [sdc] tag#12 CDB: Read(16) 88 00 00 00 00 03 6b ba c9 28 00 00 01 00 00 00
[57841.318728] blk_update_request: I/O error, dev sdc, sector 14692305192 op 0x0:(READ) flags 0x700 phys_seg 2 prio class 0
[57841.318744] zio pool=HDDPool vdev=/dev/disk/by-partuuid/b5aa7dfb-4bcd-4206-803f-0162340c1d92 error=5 type=1 offset=7520312709120 size=131072 flags=1808b0
[57841.318779] sd 2:0:0:0: [sdc] tag#13 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
[57841.318792] sd 2:0:0:0: [sdc] tag#13 Sense Key : Illegal Request [current]
[57841.318802] sd 2:0:0:0: [sdc] tag#13 Add. Sense: Unaligned write command
[57841.318813] sd 2:0:0:0: [sdc] tag#13 CDB: Read(16) 88 00 00 00 00 03 6b ba ca 28 00 00 01 00 00 00
[57841.318827] blk_update_request: I/O error, dev sdc, sector 14692305448 op 0x0:(READ) flags 0x700 phys_seg 2 prio class 0
[57841.318841] zio pool=HDDPool vdev=/dev/disk/by-partuuid/b5aa7dfb-4bcd-4206-803f-0162340c1d92 error=5 type=1 offset=7520312840192 size=131072 flags=1808b0
[57841.318866] sd 2:0:0:0: [sdc] tag#14 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
[57841.318879] sd 2:0:0:0: [sdc] tag#14 Sense Key : Illegal Request [current]
[57841.318890] sd 2:0:0:0: [sdc] tag#14 Add. Sense: Unaligned write command
[57841.318900] sd 2:0:0:0: [sdc] tag#14 CDB: Read(16) 88 00 00 00 00 03 6b ba cb 28 00 00 01 00 00 00
[57841.318912] blk_update_request: I/O error, dev sdc, sector 14692305704 op 0x0:(READ) flags 0x700 phys_seg 2 prio class 0
[57841.318922] zio pool=HDDPool vdev=/dev/disk/by-partuuid/b5aa7dfb-4bcd-4206-803f-0162340c1d92 error=5 type=1 offset=7520312971264 size=131072 flags=1808b0
[57841.318942] ata3: EH complete
[59829.480253] ata3.00: exception Emask 0x10 SAct 0x40040000 SErr 0x4050000 action 0xe frozen
[59829.480267] ata3.00: irq_stat 0x00000040, connection status changed
[59829.480274] ata3: SError: { PHYRdyChg CommWake DevExch }
[59829.480281] ata3.00: failed command: WRITE FPDMA QUEUED
[59829.480294] ata3.00: cmd 61/08:90:f0:d7:40/00:00:d6:03:00/40 tag 18 ncq dma 4096 out
res 40/00:88:98:c0:40/00:00:da:03:00/40 Emask 0x10 (ATA bus error)
[59829.480304] ata3.00: status: { DRDY }
[59829.480309] ata3.00: failed command: WRITE FPDMA QUEUED
[59829.480320] ata3.00: cmd 61/08:f0:e8:87:42/00:00:d4:03:00/40 tag 30 ncq dma 4096 out
[59829.480329] ata3.00: status: { DRDY }
[59829.480337] ata3: hard resetting link
[59830.192138] ata3: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[59830.279316] ata3.00: configured for UDMA/133
[59830.332071] sd 2:0:0:0: [sdc] tag#18 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
[59830.332093] sd 2:0:0:0: [sdc] tag#18 Sense Key : Illegal Request [current]
[59830.332106] sd 2:0:0:0: [sdc] tag#18 Add. Sense: Unaligned write command
[59830.332118] sd 2:0:0:0: [sdc] tag#18 CDB: Write(16) 8a 00 00 00 00 03 d6 40 d7 f0 00 00 00 08 00 00
[59830.332134] blk_update_request: I/O error, dev sdc, sector 16479475696 op 0x1:(WRITE) flags 0x700 phys_seg 1 prio class 0
[59830.332154] zio pool=HDDPool vdev=/dev/disk/by-partuuid/b5aa7dfb-4bcd-4206-803f-0162340c1d92 error=5 type=2 offset=8435344007168 size=4096 flags=180880
[59830.332195] sd 2:0:0:0: [sdc] tag#30 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
[59830.332208] sd 2:0:0:0: [sdc] tag#30 Sense Key : Illegal Request [current]
[59830.332220] sd 2:0:0:0: [sdc] tag#30 Add. Sense: Unaligned write command
[59830.332229] sd 2:0:0:0: [sdc] tag#30 CDB: Write(16) 8a 00 00 00 00 03 d4 42 87 e8 00 00 00 08 00 00
[59830.332241] blk_update_request: I/O error, dev sdc, sector 16446031848 op 0x1:(WRITE) flags 0x700 phys_seg 1 prio class 0
[59830.332254] zio pool=HDDPool vdev=/dev/disk/by-partuuid/b5aa7dfb-4bcd-4206-803f-0162340c1d92 error=5 type=2 offset=8418220756992 size=4096 flags=180880
[59830.332280] ata3: EH complete
[61862.883879] ata3.00: exception Emask 0x10 SAct 0x100000 SErr 0x4050000 action 0xe frozen
[61862.883891] ata3.00: irq_stat 0x00000040, connection status changed
[61862.883897] ata3: SError: { PHYRdyChg CommWake DevExch }
[61862.883903] ata3.00: failed command: READ FPDMA QUEUED
[61862.883913] ata3.00: cmd 60/00:a0:38:e3:2a/01:00:70:02:00/40 tag 20 ncq dma 131072 in
[61862.883921] ata3.00: status: { DRDY }
[61862.883928] ata3: hard resetting link
[61863.596122] ata3: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[61863.678434] ata3.00: configured for UDMA/133
[61863.714160] sd 2:0:0:0: [sdc] tag#20 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
[61863.714176] sd 2:0:0:0: [sdc] tag#20 Sense Key : Illegal Request [current]
[61863.714185] sd 2:0:0:0: [sdc] tag#20 Add. Sense: Unaligned write command
[61863.714194] sd 2:0:0:0: [sdc] tag#20 CDB: Read(16) 88 00 00 00 00 02 70 2a e3 38 00 00 01 00 00 00
[61863.714204] blk_update_request: I/O error, dev sdc, sector 10471793464 op 0x0:(READ) flags 0x700 phys_seg 2 prio class 0
[61863.714219] zio pool=HDDPool vdev=/dev/disk/by-partuuid/b5aa7dfb-4bcd-4206-803f-0162340c1d92 error=5 type=1 offset=5359410704384 size=131072 flags=1808b0
[61863.714252] ata3: EH complete
[63701.915477] ata3.00: exception Emask 0x10 SAct 0x6 SErr 0x4050000 action 0xe frozen
[63701.915491] ata3.00: irq_stat 0x00000040, connection status changed
[63701.915499] ata3: SError: { PHYRdyChg CommWake DevExch }
[63701.915506] ata3.00: failed command: WRITE FPDMA QUEUED
[63701.915518] ata3.00: cmd 61/08:08:08:6d:40/00:00:dc:03:00/40 tag 1 ncq dma 4096 out
res 40/00:78:e8:1d:41/00:00:da:03:00/40 Emask 0x10 (ATA bus error)
[63701.915528] ata3.00: status: { DRDY }
[63701.915534] ata3.00: failed command: WRITE FPDMA QUEUED
[63701.915545] ata3.00: cmd 61/08:10:a8:67:40/00:00:de:03:00/40 tag 2 ncq dma 4096 out
[63701.915554] ata3.00: status: { DRDY }
[63701.915562] ata3: hard resetting link
[63702.627420] ata3: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[63702.718950] ata3.00: configured for UDMA/133
[63702.763267] sd 2:0:0:0: [sdc] tag#1 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
[63702.763285] sd 2:0:0:0: [sdc] tag#1 Sense Key : Illegal Request [current]
[63702.763293] sd 2:0:0:0: [sdc] tag#1 Add. Sense: Unaligned write command
[63702.763301] sd 2:0:0:0: [sdc] tag#1 CDB: Write(16) 8a 00 00 00 00 03 dc 40 6d 08 00 00 00 08 00 00
[63702.763311] blk_update_request: I/O error, dev sdc, sector 16580111624 op 0x1:(WRITE) flags 0x700 phys_seg 1 prio class 0
[63702.763327] zio pool=HDDPool vdev=/dev/disk/by-partuuid/b5aa7dfb-4bcd-4206-803f-0162340c1d92 error=5 type=2 offset=8486869602304 size=4096 flags=180880
[63702.763354] sd 2:0:0:0: [sdc] tag#2 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
[63702.763362] sd 2:0:0:0: [sdc] tag#2 Sense Key : Illegal Request [current]
[63702.763369] sd 2:0:0:0: [sdc] tag#2 Add. Sense: Unaligned write command
[63702.763376] sd 2:0:0:0: [sdc] tag#2 CDB: Write(16) 8a 00 00 00 00 03 de 40 67 a8 00 00 00 08 00 00
[63702.763384] blk_update_request: I/O error, dev sdc, sector 16613664680 op 0x1:(WRITE) flags 0x700 phys_seg 1 prio class 0
[63702.763393] zio pool=HDDPool vdev=/dev/disk/by-partuuid/b5aa7dfb-4bcd-4206-803f-0162340c1d92 error=5 type=2 offset=8504048766976 size=4096 flags=180880
[63702.763411] ata3: EH complete
[66331.970396] ata3.00: exception Emask 0x10 SAct 0xf0 SErr 0x4040000 action 0xe frozen
[66331.970409] ata3.00: irq_stat 0x00000040, connection status changed
[66331.970417] ata3: SError: { CommWake DevExch }
[66331.970424] ata3.00: failed command: WRITE FPDMA QUEUED
[66331.970436] ata3.00: cmd 61/08:20:58:02:40/00:00:00:00:00/40 tag 4 ncq dma 4096 out
[66331.970446] ata3.00: status: { DRDY }
[66331.970451] ata3.00: failed command: WRITE FPDMA QUEUED
[66331.970461] ata3.00: cmd 61/08:28:58:04:40/00:00:00:00:00/40 tag 5 ncq dma 4096 out
[66331.970470] ata3.00: status: { DRDY }
[66331.970475] ata3.00: failed command: WRITE FPDMA QUEUED
[66331.970485] ata3.00: cmd 61/08:30:58:fc:7f/00:00:2f:08:00/40 tag 6 ncq dma 4096 out
[66331.970493] ata3.00: status: { DRDY }
[66331.970498] ata3.00: failed command: WRITE FPDMA QUEUED
[66331.970508] ata3.00: cmd 61/08:38:58:fe:7f/00:00:2f:08:00/40 tag 7 ncq dma 4096 out
[66331.970517] ata3.00: status: { DRDY }
[66331.970525] ata3: hard resetting link
[66332.682598] ata3: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[66332.768624] ata3.00: configured for UDMA/133
[66332.796208] sd 2:0:0:0: [sdc] tag#4 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
[66332.796226] sd 2:0:0:0: [sdc] tag#4 Sense Key : Illegal Request [current]
[66332.796234] sd 2:0:0:0: [sdc] tag#4 Add. Sense: Unaligned write command
[66332.796242] sd 2:0:0:0: [sdc] tag#4 CDB: Write(16) 8a 00 00 00 00 00 00 40 02 58 00 00 00 08 00 00
[66332.796252] blk_update_request: I/O error, dev sdc, sector 4194904 op 0x1:(WRITE) flags 0x700 phys_seg 1 prio class 0
[66332.796268] zio pool=HDDPool vdev=/dev/disk/by-partuuid/b5aa7dfb-4bcd-4206-803f-0162340c1d92 error=5 type=2 offset=241664 size=4096 flags=180ac0
[66332.796301] sd 2:0:0:0: [sdc] tag#5 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
[66332.796309] sd 2:0:0:0: [sdc] tag#5 Sense Key : Illegal Request [current]
[66332.796316] sd 2:0:0:0: [sdc] tag#5 Add. Sense: Unaligned write command
[66332.796323] sd 2:0:0:0: [sdc] tag#5 CDB: Write(16) 8a 00 00 00 00 00 00 40 04 58 00 00 00 08 00 00
[66332.796331] blk_update_request: I/O error, dev sdc, sector 4195416 op 0x1:(WRITE) flags 0x700 phys_seg 1 prio class 0
[66332.796340] zio pool=HDDPool vdev=/dev/disk/by-partuuid/b5aa7dfb-4bcd-4206-803f-0162340c1d92 error=5 type=2 offset=503808 size=4096 flags=180ac0
[66332.796353] sd 2:0:0:0: [sdc] tag#6 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
[66332.796360] sd 2:0:0:0: [sdc] tag#6 Sense Key : Illegal Request [current]
[66332.796367] sd 2:0:0:0: [sdc] tag#6 Add. Sense: Unaligned write command
[66332.796374] sd 2:0:0:0: [sdc] tag#6 CDB: Write(16) 8a 00 00 00 00 08 2f 7f fc 58 00 00 00 08 00 00
[66332.796381] blk_update_request: I/O error, dev sdc, sector 35156655192 op 0x1:(WRITE) flags 0x700 phys_seg 1 prio class 0
[66332.796390] zio pool=HDDPool vdev=/dev/disk/by-partuuid/b5aa7dfb-4bcd-4206-803f-0162340c1d92 error=5 type=2 offset=17998059909120 size=4096 flags=180ac0
[66332.796402] sd 2:0:0:0: [sdc] tag#7 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
[66332.796409] sd 2:0:0:0: [sdc] tag#7 Sense Key : Illegal Request [current]
[66332.796416] sd 2:0:0:0: [sdc] tag#7 Add. Sense: Unaligned write command
[66332.796422] sd 2:0:0:0: [sdc] tag#7 CDB: Write(16) 8a 00 00 00 00 08 2f 7f fe 58 00 00 00 08 00 00
[66332.796430] blk_update_request: I/O error, dev sdc, sector 35156655704 op 0x1:(WRITE) flags 0x700 phys_seg 1 prio class 0
[66332.796438] zio pool=HDDPool vdev=/dev/disk/by-partuuid/b5aa7dfb-4bcd-4206-803f-0162340c1d92 error=5 type=2 offset=17998060171264 size=4096 flags=180ac0
[66332.796448] ata3: EH complete
[67411.139856] ata1.00: exception Emask 0x10 SAct 0x80000000 SErr 0x4050000 action 0xe frozen
[67411.139870] ata1.00: irq_stat 0x00000040, connection status changed
[67411.139878] ata1: SError: { PHYRdyChg CommWake DevExch }
[67411.139885] ata1.00: failed command: READ FPDMA QUEUED
[67411.139897] ata1.00: cmd 60/00:f8:80:20:40/01:00:be:00:00/40 tag 31 ncq dma 131072 in
[67411.139907] ata1.00: status: { DRDY }
[67411.139915] ata1: hard resetting link
[67411.851744] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[67411.937521] ata1.00: configured for UDMA/133
[67411.981845] sd 0:0:0:0: [sda] tag#31 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
[67411.981861] sd 0:0:0:0: [sda] tag#31 Sense Key : Illegal Request [current]
[67411.981869] sd 0:0:0:0: [sda] tag#31 Add. Sense: Unaligned write command
[67411.981876] sd 0:0:0:0: [sda] tag#31 CDB: Read(16) 88 00 00 00 00 00 be 40 20 80 00 00 01 00 00 00
[67411.981885] blk_update_request: I/O error, dev sda, sector 3191873664 op 0x0:(READ) flags 0x700 phys_seg 2 prio class 0
[67411.981897] zio pool=HDDPool vdev=/dev/disk/by-partuuid/0599b3e6-1589-424a-8a26-69e9bd6c3896 error=5 type=1 offset=1632091766784 size=131072 flags=1808b0
[67411.981917] ata1: EH complete
[67673.580154] ata1.00: exception Emask 0x10 SAct 0x600 SErr 0x4050000 action 0xe frozen
[67673.580167] ata1.00: irq_stat 0x00000040, connection status changed
[67673.580175] ata1: SError: { PHYRdyChg CommWake DevExch }
[67673.580182] ata1.00: failed command: WRITE FPDMA QUEUED
[67673.580194] ata1.00: cmd 61/08:48:b8:62:42/00:00:a6:03:00/40 tag 9 ncq dma 4096 out
res 40/00:38:98:62:42/00:00:a6:03:00/40 Emask 0x10 (ATA bus error)
[67673.580203] ata1.00: status: { DRDY }
[67673.580209] ata1.00: failed command: WRITE FPDMA QUEUED
[67673.580220] ata1.00: cmd 61/08:50:20:5d:42/00:00:a8:03:00/40 tag 10 ncq dma 4096 out
[67673.580229] ata1.00: status: { DRDY }
[67673.580237] ata1: hard resetting link
[67674.292348] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[67674.371388] ata1.00: configured for UDMA/133
[67674.423998] sd 0:0:0:0: [sda] tag#9 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
[67674.424015] sd 0:0:0:0: [sda] tag#9 Sense Key : Illegal Request [current]
[67674.424023] sd 0:0:0:0: [sda] tag#9 Add. Sense: Unaligned write command
[67674.424031] sd 0:0:0:0: [sda] tag#9 CDB: Write(16) 8a 00 00 00 00 03 a6 42 62 b8 00 00 00 08 00 00
[67674.424042] blk_update_request: I/O error, dev sda, sector 15674270392 op 0x1:(WRITE) flags 0x700 phys_seg 1 prio class 0
[67674.424121] zio pool=HDDPool vdev=/dev/disk/by-partuuid/0599b3e6-1589-424a-8a26-69e9bd6c3896 error=5 type=2 offset=8023078891520 size=4096 flags=180880
[67674.424162] sd 0:0:0:0: [sda] tag#10 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
[67674.424174] sd 0:0:0:0: [sda] tag#10 Sense Key : Illegal Request [current]
[67674.424184] sd 0:0:0:0: [sda] tag#10 Add. Sense: Unaligned write command
[67674.424200] sd 0:0:0:0: [sda] tag#10 CDB: Write(16) 8a 00 00 00 00 03 a8 42 5d 20 00 00 00 08 00 00
[67674.424213] blk_update_request: I/O error, dev sda, sector 15707823392 op 0x1:(WRITE) flags 0x700 phys_seg 1 prio class 0
[67674.424226] zio pool=HDDPool vdev=/dev/disk/by-partuuid/0599b3e6-1589-424a-8a26-69e9bd6c3896 error=5 type=2 offset=8040258027520 size=4096 flags=180880
[67674.424253] ata1: EH complete
[67751.992237] ata3.00: exception Emask 0x10 SAct 0x0 SErr 0x4040000 action 0xe frozen
[67751.992252] ata3.00: irq_stat 0x00000040, connection status changed
[67751.992259] ata3: SError: { CommWake DevExch }
[67751.992264] ata3.00: failed command: FLUSH CACHE EXT
[67751.992276] ata3.00: cmd ea/00:00:00:00:00/00:00:00:00:00/a0 tag 8
res 40/00:68:08:fe:7f/00:00:2f:08:00/40 Emask 0x10 (ATA bus error)
[67751.992285] ata3.00: status: { DRDY }
[67751.992293] ata3: hard resetting link
[67752.704419] ata3: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[67752.786641] ata3.00: configured for UDMA/133
[67752.786660] ata3.00: retrying FLUSH 0xea Emask 0x10
[67752.847169] ata3: EH complete
[68307.293052] ata3.00: exception Emask 0x10 SAct 0x1c000000 SErr 0x4040000 action 0xe frozen
[68307.293072] ata3.00: irq_stat 0x00000040, connection status changed
[68307.293082] ata3: SError: { CommWake DevExch }
[68307.293094] ata3.00: failed command: READ FPDMA QUEUED
[68307.293110] ata3.00: cmd 60/00:d0:18:30:5a/01:00:da:01:00/40 tag 26 ncq dma 131072 in
res 40/00:c8:18:2f:5a/00:00:da:01:00/40 Emask 0x10 (ATA bus error)
[68307.293124] ata3.00: status: { DRDY }
[68307.293133] ata3.00: failed command: READ FPDMA QUEUED
[68307.293152] ata3.00: cmd 60/00:d8:18:31:5a/01:00:da:01:00/40 tag 27 ncq dma 131072 in
[68307.293168] ata3.00: status: { DRDY }
[68307.293177] ata3.00: failed command: READ FPDMA QUEUED
[68307.293192] ata3.00: cmd 60/00:e0:18:32:5a/01:00:da:01:00/40 tag 28 ncq dma 131072 in
[68307.293207] ata3.00: status: { DRDY }
[68307.293218] ata3: hard resetting link
[68308.033059] ata3: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[68308.119183] ata3.00: configured for UDMA/133
[68308.172156] sd 2:0:0:0: [sdc] tag#26 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
[68308.172172] sd 2:0:0:0: [sdc] tag#26 Sense Key : Illegal Request [current]
[68308.172181] sd 2:0:0:0: [sdc] tag#26 Add. Sense: Unaligned write command
[68308.172188] sd 2:0:0:0: [sdc] tag#26 CDB: Read(16) 88 00 00 00 00 01 da 5a 30 18 00 00 01 00 00 00
[68308.172199] blk_update_request: I/O error, dev sdc, sector 7958310936 op 0x0:(READ) flags 0x700 phys_seg 2 prio class 0
[68308.172215] zio pool=HDDPool vdev=/dev/disk/by-partuuid/b5aa7dfb-4bcd-4206-803f-0162340c1d92 error=5 type=1 offset=4072507650048 size=131072 flags=1808b0
[68308.172247] sd 2:0:0:0: [sdc] tag#27 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
[68308.172256] sd 2:0:0:0: [sdc] tag#27 Sense Key : Illegal Request [current]
[68308.172263] sd 2:0:0:0: [sdc] tag#27 Add. Sense: Unaligned write command
[68308.172269] sd 2:0:0:0: [sdc] tag#27 CDB: Read(16) 88 00 00 00 00 01 da 5a 31 18 00 00 01 00 00 00
[68308.172278] blk_update_request: I/O error, dev sdc, sector 7958311192 op 0x0:(READ) flags 0x700 phys_seg 2 prio class 0
[68308.172287] zio pool=HDDPool vdev=/dev/disk/by-partuuid/b5aa7dfb-4bcd-4206-803f-0162340c1d92 error=5 type=1 offset=4072507781120 size=131072 flags=1808b0
[68308.172304] sd 2:0:0:0: [sdc] tag#28 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
[68308.172316] sd 2:0:0:0: [sdc] tag#28 Sense Key : Illegal Request [current]
[68308.172327] sd 2:0:0:0: [sdc] tag#28 Add. Sense: Unaligned write command
[68308.172338] sd 2:0:0:0: [sdc] tag#28 CDB: Read(16) 88 00 00 00 00 01 da 5a 32 18 00 00 01 00 00 00
[68308.172351] blk_update_request: I/O error, dev sdc, sector 7958311448 op 0x0:(READ) flags 0x700 phys_seg 2 prio class 0
[68308.172365] zio pool=HDDPool vdev=/dev/disk/by-partuuid/b5aa7dfb-4bcd-4206-803f-0162340c1d92 error=5 type=1 offset=4072507912192 size=131072 flags=1808b0
[68308.172390] ata3: EH complete
[68730.885689] ata3.00: exception Emask 0x10 SAct 0x20400 SErr 0x4050000 action 0xe frozen
[68730.885701] ata3.00: irq_stat 0x00000040, connection status changed
[68730.885708] ata3: SError: { PHYRdyChg CommWake DevExch }
[68730.885715] ata3.00: failed command: WRITE FPDMA QUEUED
[68730.885726] ata3.00: cmd 61/08:50:08:a9:41/00:00:d6:03:00/40 tag 10 ncq dma 4096 out
res 40/00:e8:d0:e8:b8/00:00:b4:01:00/40 Emask 0x10 (ATA bus error)
[68730.885735] ata3.00: status: { DRDY }
[68730.885740] ata3.00: failed command: WRITE FPDMA QUEUED
[68730.885749] ata3.00: cmd 61/08:88:f8:8e:40/00:00:dc:03:00/40 tag 17 ncq dma 4096 out
[68730.885758] ata3.00: status: { DRDY }
[68730.885765] ata3: hard resetting link
[68731.597816] ata3: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[68731.681750] ata3.00: configured for UDMA/133
[68731.734149] sd 2:0:0:0: [sdc] tag#10 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
[68731.734166] sd 2:0:0:0: [sdc] tag#10 Sense Key : Illegal Request [current]
[68731.734175] sd 2:0:0:0: [sdc] tag#10 Add. Sense: Unaligned write command
[68731.734183] sd 2:0:0:0: [sdc] tag#10 CDB: Write(16) 8a 00 00 00 00 03 d6 41 a9 08 00 00 00 08 00 00
[68731.734193] blk_update_request: I/O error, dev sdc, sector 16479529224 op 0x1:(WRITE) flags 0x700 phys_seg 1 prio class 0
[68731.734208] zio pool=HDDPool vdev=/dev/disk/by-partuuid/b5aa7dfb-4bcd-4206-803f-0162340c1d92 error=5 type=2 offset=8435371413504 size=4096 flags=180880
[68731.734242] sd 2:0:0:0: [sdc] tag#17 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
[68731.734250] sd 2:0:0:0: [sdc] tag#17 Sense Key : Illegal Request [current]
[68731.734257] sd 2:0:0:0: [sdc] tag#17 Add. Sense: Unaligned write command
[68731.734264] sd 2:0:0:0: [sdc] tag#17 CDB: Write(16) 8a 00 00 00 00 03 dc 40 8e f8 00 00 00 08 00 00
[68731.734272] blk_update_request: I/O error, dev sdc, sector 16580120312 op 0x1:(WRITE) flags 0x700 phys_seg 1 prio class 0
[68731.734282] zio pool=HDDPool vdev=/dev/disk/by-partuuid/b5aa7dfb-4bcd-4206-803f-0162340c1d92 error=5 type=2 offset=8486874050560 size=4096 flags=180880
[68731.734300] ata3: EH complete
[69025.189866] ata1.00: exception Emask 0x10 SAct 0x100001 SErr 0x4050000 action 0xe frozen
[69025.189877] ata1.00: irq_stat 0x00000040, connection status changed
[69025.189883] ata1: SError: { PHYRdyChg CommWake DevExch }
[69025.189889] ata1.00: failed command: WRITE FPDMA QUEUED
[69025.189899] ata1.00: cmd 61/08:00:60:5f:45/00:00:d4:03:00/40 tag 0 ncq dma 4096 out
res 40/00:f0:18:a2:42/00:00:a8:03:00/40 Emask 0x10 (ATA bus error)
[69025.189907] ata1.00: status: { DRDY }
[69025.189912] ata1.00: failed command: WRITE FPDMA QUEUED
[69025.189921] ata1.00: cmd 61/08:a0:c8:90:40/00:00:dc:03:00/40 tag 20 ncq dma 4096 out
[69025.189929] ata1.00: status: { DRDY }
[69025.189935] ata1: hard resetting link
[69025.902045] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[69025.984255] ata1.00: configured for UDMA/133
[69026.036881] sd 0:0:0:0: [sda] tag#0 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
[69026.036897] sd 0:0:0:0: [sda] tag#0 Sense Key : Illegal Request [current]
[69026.036905] sd 0:0:0:0: [sda] tag#0 Add. Sense: Unaligned write command
[69026.036913] sd 0:0:0:0: [sda] tag#0 CDB: Write(16) 8a 00 00 00 00 03 d4 45 5f 60 00 00 00 08 00 00
[69026.036923] blk_update_request: I/O error, dev sda, sector 16446218080 op 0x1:(WRITE) flags 0x700 phys_seg 1 prio class 0
[69026.036939] zio pool=HDDPool vdev=/dev/disk/by-partuuid/0599b3e6-1589-424a-8a26-69e9bd6c3896 error=5 type=2 offset=8418316107776 size=4096 flags=180880
[69026.036977] sd 0:0:0:0: [sda] tag#20 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
[69026.036989] sd 0:0:0:0: [sda] tag#20 Sense Key : Illegal Request [current]
[69026.036999] sd 0:0:0:0: [sda] tag#20 Add. Sense: Unaligned write command
[69026.037009] sd 0:0:0:0: [sda] tag#20 CDB: Write(16) 8a 00 00 00 00 03 dc 40 90 c8 00 00 00 08 00 00
[69026.037021] blk_update_request: I/O error, dev sda, sector 16580120776 op 0x1:(WRITE) flags 0x700 phys_seg 1 prio class 0
[69026.037036] zio pool=HDDPool vdev=/dev/disk/by-partuuid/0599b3e6-1589-424a-8a26-69e9bd6c3896 error=5 type=2 offset=8486874288128 size=4096 flags=180880
[69026.037059] ata1: EH complete
[69190.933957] ata3.00: exception Emask 0x10 SAct 0x0 SErr 0x4040000 action 0xe frozen
[69190.933971] ata3.00: irq_stat 0x00000040, connection status changed
[69190.933978] ata3: SError: { CommWake DevExch }
[69190.933984] ata3.00: failed command: FLUSH CACHE EXT
[69190.933996] ata3.00: cmd ea/00:00:00:00:00/00:00:00:00:00/a0 tag 31
res 40/00:38:28:aa:42/00:00:a8:03:00/40 Emask 0x10 (ATA bus error)
[69190.934005] ata3.00: status: { DRDY }
[69190.934013] ata3: hard resetting link
[69191.658140] ata3: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[69191.739423] ata3.00: configured for UDMA/133
[69191.739438] ata3.00: retrying FLUSH 0xea Emask 0x10
[69191.783394] ata3: EH complete
[69346.310311] ata3.00: exception Emask 0x10 SAct 0x780 SErr 0x4050000 action 0xe frozen
[69346.310325] ata3.00: irq_stat 0x00000040, connection status changed
[69346.310332] ata3: SError: { PHYRdyChg CommWake DevExch }
[69346.310340] ata3.00: failed command: WRITE FPDMA QUEUED
[69346.310352] ata3.00: cmd 61/08:38:b0:01:40/00:00:00:00:00/40 tag 7 ncq dma 4096 out
[69346.310362] ata3.00: status: { DRDY }
[69346.310367] ata3.00: failed command: WRITE FPDMA QUEUED
[69346.310377] ata3.00: cmd 61/08:40:b0:03:40/00:00:00:00:00/40 tag 8 ncq dma 4096 out
[69346.310387] ata3.00: status: { DRDY }
[69346.310391] ata3.00: failed command: WRITE FPDMA QUEUED
[69346.310401] ata3.00: cmd 61/08:48:b0:fb:7f/00:00:2f:08:00/40 tag 9 ncq dma 4096 out
[69346.310410] ata3.00: status: { DRDY }
[69346.310415] ata3.00: failed command: WRITE FPDMA QUEUED
[69346.310425] ata3.00: cmd 61/08:50:b0:fd:7f/00:00:2f:08:00/40 tag 10 ncq dma 4096 out
[69346.310433] ata3.00: status: { DRDY }
[69346.310442] ata3: hard resetting link
[69347.026302] ata3: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[69347.110497] ata3.00: configured for UDMA/133
[69347.154724] sd 2:0:0:0: [sdc] tag#7 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
[69347.154741] sd 2:0:0:0: [sdc] tag#7 Sense Key : Illegal Request [current]
[69347.154750] sd 2:0:0:0: [sdc] tag#7 Add. Sense: Unaligned write command
[69347.154758] sd 2:0:0:0: [sdc] tag#7 CDB: Write(16) 8a 00 00 00 00 00 00 40 01 b0 00 00 00 08 00 00
[69347.154768] blk_update_request: I/O error, dev sdc, sector 4194736 op 0x1:(WRITE) flags 0x700 phys_seg 1 prio class 0
[69347.154782] zio pool=HDDPool vdev=/dev/disk/by-partuuid/b5aa7dfb-4bcd-4206-803f-0162340c1d92 error=5 type=2 offset=155648 size=4096 flags=180ac0
[69347.154817] sd 2:0:0:0: [sdc] tag#8 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
[69347.154830] sd 2:0:0:0: [sdc] tag#8 Sense Key : Illegal Request [current]
[69347.154842] sd 2:0:0:0: [sdc] tag#8 Add. Sense: Unaligned write command
[69347.154852] sd 2:0:0:0: [sdc] tag#8 CDB: Write(16) 8a 00 00 00 00 00 00 40 03 b0 00 00 00 08 00 00
[69347.154865] blk_update_request: I/O error, dev sdc, sector 4195248 op 0x1:(WRITE) flags 0x700 phys_seg 1 prio class 0
[69347.154875] zio pool=HDDPool vdev=/dev/disk/by-partuuid/b5aa7dfb-4bcd-4206-803f-0162340c1d92 error=5 type=2 offset=417792 size=4096 flags=180ac0
[69347.154892] sd 2:0:0:0: [sdc] tag#9 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
[69347.154899] sd 2:0:0:0: [sdc] tag#9 Sense Key : Illegal Request [current]
[69347.154906] sd 2:0:0:0: [sdc] tag#9 Add. Sense: Unaligned write command
[69347.154913] sd 2:0:0:0: [sdc] tag#9 CDB: Write(16) 8a 00 00 00 00 08 2f 7f fb b0 00 00 00 08 00 00
[69347.154921] blk_update_request: I/O error, dev sdc, sector 35156655024 op 0x1:(WRITE) flags 0x700 phys_seg 1 prio class 0
[69347.154929] zio pool=HDDPool vdev=/dev/disk/by-partuuid/b5aa7dfb-4bcd-4206-803f-0162340c1d92 error=5 type=2 offset=17998059823104 size=4096 flags=180ac0
[69347.154942] sd 2:0:0:0: [sdc] tag#10 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
[69347.154949] sd 2:0:0:0: [sdc] tag#10 Sense Key : Illegal Request [current]
[69347.154956] sd 2:0:0:0: [sdc] tag#10 Add. Sense: Unaligned write command
[69347.154963] sd 2:0:0:0: [sdc] tag#10 CDB: Write(16) 8a 00 00 00 00 08 2f 7f fd b0 00 00 00 08 00 00
[69347.154970] blk_update_request: I/O error, dev sdc, sector 35156655536 op 0x1:(WRITE) flags 0x700 phys_seg 1 prio class 0
[69347.154978] zio pool=HDDPool vdev=/dev/disk/by-partuuid/b5aa7dfb-4bcd-4206-803f-0162340c1d92 error=5 type=2 offset=17998060085248 size=4096 flags=180ac0
[69347.154988] ata3: EH complete
[69540.098275] ata3.00: exception Emask 0x10 SAct 0x1c000000 SErr 0x4050000 action 0xe frozen
[69540.098288] ata3.00: irq_stat 0x00000040, connection status changed
[69540.098295] ata3: SError: { PHYRdyChg CommWake DevExch }
[69540.098302] ata3.00: failed command: READ FPDMA QUEUED
[69540.098313] ata3.00: cmd 60/00:d0:a8:bf:4f/01:00:2c:02:00/40 tag 26 ncq dma 131072 in
res 40/00:c8:a8:bd:4f/00:00:2c:02:00/40 Emask 0x10 (ATA bus error)
[69540.098322] ata3.00: status: { DRDY }
[69540.098326] ata3.00: failed command: READ FPDMA QUEUED
[69540.098336] ata3.00: cmd 60/00:d8:a8:c0:4f/01:00:2c:02:00/40 tag 27 ncq dma 131072 in
[69540.098344] ata3.00: status: { DRDY }
[69540.098349] ata3.00: failed command: READ FPDMA QUEUED
[69540.098358] ata3.00: cmd 60/00:e0:a8:c1:4f/01:00:2c:02:00/40 tag 28 ncq dma 131072 in
[69540.098366] ata3.00: status: { DRDY }
[69540.098373] ata3: hard resetting link
[69540.814223] ata3: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[69540.893271] ata3.00: configured for UDMA/133
[69540.921073] sd 2:0:0:0: [sdc] tag#26 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
[69540.921088] sd 2:0:0:0: [sdc] tag#26 Sense Key : Illegal Request [current]
[69540.921096] sd 2:0:0:0: [sdc] tag#26 Add. Sense: Unaligned write command
[69540.921103] sd 2:0:0:0: [sdc] tag#26 CDB: Read(16) 88 00 00 00 00 02 2c 4f bf a8 00 00 01 00 00 00
[69540.921112] blk_update_request: I/O error, dev sdc, sector 9333358504 op 0x0:(READ) flags 0x700 phys_seg 2 prio class 0
[69540.921124] zio pool=HDDPool vdev=/dev/disk/by-partuuid/b5aa7dfb-4bcd-4206-803f-0162340c1d92 error=5 type=1 offset=4776532004864 size=131072 flags=1808b0
[69540.921147] sd 2:0:0:0: [sdc] tag#27 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
[69540.921155] sd 2:0:0:0: [sdc] tag#27 Sense Key : Illegal Request [current]
[69540.921161] sd 2:0:0:0: [sdc] tag#27 Add. Sense: Unaligned write command
[69540.921167] sd 2:0:0:0: [sdc] tag#27 CDB: Read(16) 88 00 00 00 00 02 2c 4f c0 a8 00 00 01 00 00 00
[69540.921174] blk_update_request: I/O error, dev sdc, sector 9333358760 op 0x0:(READ) flags 0x700 phys_seg 2 prio class 0
[69540.921183] zio pool=HDDPool vdev=/dev/disk/by-partuuid/b5aa7dfb-4bcd-4206-803f-0162340c1d92 error=5 type=1 offset=4776532135936 size=131072 flags=1808b0
[69540.921200] sd 2:0:0:0: [sdc] tag#28 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
[69540.921207] sd 2:0:0:0: [sdc] tag#28 Sense Key : Illegal Request [current]
[69540.921213] sd 2:0:0:0: [sdc] tag#28 Add. Sense: Unaligned write command
[69540.921222] sd 2:0:0:0: [sdc] tag#28 CDB: Read(16) 88 00 00 00 00 02 2c 4f c1 a8 00 00 01 00 00 00
[69540.921232] blk_update_request: I/O error, dev sdc, sector 9333359016 op 0x0:(READ) flags 0x700 phys_seg 2 prio class 0
[69540.921246] zio pool=HDDPool vdev=/dev/disk/by-partuuid/b5aa7dfb-4bcd-4206-803f-0162340c1d92 error=5 type=1 offset=4776532267008 size=131072 flags=1808b0
[69540.921262] ata3: EH complete
[69749.018576] ata3: limiting SATA link speed to 3.0 Gbps
[69749.018592] ata3.00: exception Emask 0x10 SAct 0x0 SErr 0x4050000 action 0xe frozen
[69749.018600] ata3.00: irq_stat 0x00000040, connection status changed
[69749.018606] ata3: SError: { PHYRdyChg CommWake DevExch }
[69749.018612] ata3.00: failed command: FLUSH CACHE EXT
[69749.018624] ata3.00: cmd ea/00:00:00:00:00/00:00:00:00:00/a0 tag 20
res 40/00:70:a0:af:41/00:00:da:03:00/40 Emask 0x10 (ATA bus error)
[69749.018634] ata3.00: status: { DRDY }
[69749.018642] ata3: hard resetting link
[69749.730574] ata3: SATA link up 3.0 Gbps (SStatus 123 SControl 320)
[69749.813244] ata3.00: configured for UDMA/133
[69749.813260] ata3.00: retrying FLUSH 0xea Emask 0x10
[69749.857271] ata3: EH complete
[70058.018405] ata1.00: exception Emask 0x10 SAct 0xe000 SErr 0x4040000 action 0xe frozen
[70058.018424] ata1.00: irq_stat 0x00000040, connection status changed
[70058.018434] ata1: SError: { CommWake DevExch }
[70058.018445] ata1.00: failed command: READ FPDMA QUEUED
[70058.018464] ata1.00: cmd 60/00:68:88:cc:ae/01:00:b8:02:00/40 tag 13 ncq dma 131072 in
res 40/00:98:88:ca:ae/00:00:b8:02:00/40 Emask 0x10 (ATA bus error)
[70058.018480] ata1.00: status: { DRDY }
[70058.018489] ata1.00: failed command: READ FPDMA QUEUED
[70058.018506] ata1.00: cmd 60/00:70:88:cd:ae/01:00:b8:02:00/40 tag 14 ncq dma 131072 in
[70058.018521] ata1.00: status: { DRDY }
[70058.018529] ata1.00: failed command: READ FPDMA QUEUED
[70058.018546] ata1.00: cmd 60/00:78:88:ce:ae/01:00:b8:02:00/40 tag 15 ncq dma 131072 in
[70058.018560] ata1.00: status: { DRDY }
[70058.018571] ata1: hard resetting link
[70058.730582] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[70058.808336] ata1.00: configured for UDMA/133
[70058.852429] sd 0:0:0:0: [sda] tag#13 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
[70058.852446] sd 0:0:0:0: [sda] tag#13 Sense Key : Illegal Request [current]
[70058.852455] sd 0:0:0:0: [sda] tag#13 Add. Sense: Unaligned write command
[70058.852463] sd 0:0:0:0: [sda] tag#13 CDB: Read(16) 88 00 00 00 00 02 b8 ae cc 88 00 00 01 00 00 00
[70058.852473] blk_update_request: I/O error, dev sda, sector 11688397960 op 0x0:(READ) flags 0x700 phys_seg 2 prio class 0
[70058.852489] zio pool=HDDPool vdev=/dev/disk/by-partuuid/0599b3e6-1589-424a-8a26-69e9bd6c3896 error=5 type=1 offset=5982312206336 size=131072 flags=1808b0
[70058.852525] sd 0:0:0:0: [sda] tag#14 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
[70058.852533] sd 0:0:0:0: [sda] tag#14 Sense Key : Illegal Request [current]
[70058.852540] sd 0:0:0:0: [sda] tag#14 Add. Sense: Unaligned write command
[70058.852547] sd 0:0:0:0: [sda] tag#14 CDB: Read(16) 88 00 00 00 00 02 b8 ae cd 88 00 00 01 00 00 00
[70058.852555] blk_update_request: I/O error, dev sda, sector 11688398216 op 0x0:(READ) flags 0x700 phys_seg 2 prio class 0
[70058.852564] zio pool=HDDPool vdev=/dev/disk/by-partuuid/0599b3e6-1589-424a-8a26-69e9bd6c3896 error=5 type=1 offset=5982312337408 size=131072 flags=1808b0
[70058.852583] sd 0:0:0:0: [sda] tag#15 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
[70058.852596] sd 0:0:0:0: [sda] tag#15 Sense Key : Illegal Request [current]
[70058.852606] sd 0:0:0:0: [sda] tag#15 Add. Sense: Unaligned write command
[70058.852617] sd 0:0:0:0: [sda] tag#15 CDB: Read(16) 88 00 00 00 00 02 b8 ae ce 88 00 00 01 00 00 00
[70058.852629] blk_update_request: I/O error, dev sda, sector 11688398472 op 0x0:(READ) flags 0x700 phys_seg 2 prio class 0
[70058.852645] zio pool=HDDPool vdev=/dev/disk/by-partuuid/0599b3e6-1589-424a-8a26-69e9bd6c3896 error=5 type=1 offset=5982312468480 size=131072 flags=1808b0
[70058.852672] ata1: EH complete
[70774.414885] ata1.00: exception Emask 0x10 SAct 0x70000001 SErr 0x4040000 action 0xe frozen
[70774.414899] ata1.00: irq_stat 0x00000040, connection status changed
[70774.414907] ata1: SError: { CommWake DevExch }
[70774.414914] ata1.00: failed command: WRITE FPDMA QUEUED
[70774.414926] ata1.00: cmd 61/08:00:58:fe:7f/00:00:2f:08:00/40 tag 0 ncq dma 4096 out
[70774.414936] ata1.00: status: { DRDY }
[70774.414942] ata1.00: failed command: WRITE FPDMA QUEUED
[70774.414953] ata1.00: cmd 61/08:e0:58:02:40/00:00:00:00:00/40 tag 28 ncq dma 4096 out
[70774.414962] ata1.00: status: { DRDY }
[70774.414967] ata1.00: failed command: WRITE FPDMA QUEUED
[70774.414977] ata1.00: cmd 61/08:e8:58:04:40/00:00:00:00:00/40 tag 29 ncq dma 4096 out
[70774.414986] ata1.00: status: { DRDY }
[70774.414991] ata1.00: failed command: WRITE FPDMA QUEUED
[70774.415001] ata1.00: cmd 61/08:f0:58:fc:7f/00:00:2f:08:00/40 tag 30 ncq dma 4096 out
[70774.415010] ata1.00: status: { DRDY }
[70774.415018] ata1: hard resetting link
[70775.126878] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[70775.208944] ata1.00: configured for UDMA/133
[70775.244702] sd 0:0:0:0: [sda] tag#0 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
[70775.244720] sd 0:0:0:0: [sda] tag#0 Sense Key : Illegal Request [current]
[70775.244728] sd 0:0:0:0: [sda] tag#0 Add. Sense: Unaligned write command
[70775.244737] sd 0:0:0:0: [sda] tag#0 CDB: Write(16) 8a 00 00 00 00 08 2f 7f fe 58 00 00 00 08 00 00
[70775.244747] blk_update_request: I/O error, dev sda, sector 35156655704 op 0x1:(WRITE) flags 0x700 phys_seg 1 prio class 0
[70775.244763] zio pool=HDDPool vdev=/dev/disk/by-partuuid/0599b3e6-1589-424a-8a26-69e9bd6c3896 error=5 type=2 offset=17998060171264 size=4096 flags=180ac0
[70775.244795] sd 0:0:0:0: [sda] tag#28 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
[70775.244803] sd 0:0:0:0: [sda] tag#28 Sense Key : Illegal Request [current]
[70775.244810] sd 0:0:0:0: [sda] tag#28 Add. Sense: Unaligned write command
[70775.244817] sd 0:0:0:0: [sda] tag#28 CDB: Write(16) 8a 00 00 00 00 00 00 40 02 58 00 00 00 08 00 00
[70775.244826] blk_update_request: I/O error, dev sda, sector 4194904 op 0x1:(WRITE) flags 0x700 phys_seg 1 prio class 0
[70775.244835] zio pool=HDDPool vdev=/dev/disk/by-partuuid/0599b3e6-1589-424a-8a26-69e9bd6c3896 error=5 type=2 offset=241664 size=4096 flags=180ac0
[70775.244848] sd 0:0:0:0: [sda] tag#29 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
[70775.244856] sd 0:0:0:0: [sda] tag#29 Sense Key : Illegal Request [current]
[70775.244863] sd 0:0:0:0: [sda] tag#29 Add. Sense: Unaligned write command
[70775.244870] sd 0:0:0:0: [sda] tag#29 CDB: Write(16) 8a 00 00 00 00 00 00 40 04 58 00 00 00 08 00 00
[70775.244877] blk_update_request: I/O error, dev sda, sector 4195416 op 0x1:(WRITE) flags 0x700 phys_seg 1 prio class 0
[70775.244886] zio pool=HDDPool vdev=/dev/disk/by-partuuid/0599b3e6-1589-424a-8a26-69e9bd6c3896 error=5 type=2 offset=503808 size=4096 flags=180ac0
[70775.244899] sd 0:0:0:0: [sda] tag#30 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
[70775.244906] sd 0:0:0:0: [sda] tag#30 Sense Key : Illegal Request [current]
[70775.244913] sd 0:0:0:0: [sda] tag#30 Add. Sense: Unaligned write command
[70775.244920] sd 0:0:0:0: [sda] tag#30 CDB: Write(16) 8a 00 00 00 00 08 2f 7f fc 58 00 00 00 08 00 00
[70775.244927] blk_update_request: I/O error, dev sda, sector 35156655192 op 0x1:(WRITE) flags 0x700 phys_seg 1 prio class 0
[70775.244941] zio pool=HDDPool vdev=/dev/disk/by-partuuid/0599b3e6-1589-424a-8a26-69e9bd6c3896 error=5 type=2 offset=17998059909120 size=4096 flags=180ac0
[70775.244951] ata1: EH complete
[71121.210872] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[71121.288340] ata1.00: configured for UDMA/133
[77069.600638] ata1.00: invalid command format 2
[77069.600684] ata1.00: invalid command format 2
[77069.600721] ata1.00: invalid command format 2
[77069.600857] ata1.00: invalid command format 2
[77069.600953] ata1.00: invalid command format 2
[77069.601004] ata1.00: invalid command format 2
[77069.601055] ata1.00: invalid command format 2
[77069.601270] ata1.00: invalid command format 2
[77431.829536] ata1.00: invalid command format 2
[77431.829656] ata1.00: invalid command format 2
[77431.829707] ata1.00: invalid command format 2
[77431.829774] ata1.00: invalid command format 2
[77431.829809] ata1.00: invalid command format 2
[77431.829896] ata1.00: invalid command format 2
[77431.829938] ata1.00: invalid command format 2
[77431.830091] ata1.00: invalid command format 2
[77448.497831] ata1.00: exception Emask 0x10 SAct 0x2e0 SErr 0x4040000 action 0xe frozen
[77448.497845] ata1.00: irq_stat 0x00000040, connection status changed
[77448.497852] ata1: SError: { CommWake DevExch }
[77448.497859] ata1.00: failed command: WRITE FPDMA QUEUED
[77448.497871] ata1.00: cmd 61/08:28:d8:01:40/00:00:00:00:00/40 tag 5 ncq dma 4096 out
res 50/00:00:00:00:00/00:00:00:00:00/a0 Emask 0x10 (ATA bus error)
[77448.497881] ata1.00: status: { DRDY }
[77448.497886] ata1.00: failed command: WRITE FPDMA QUEUED
[77448.497897] ata1.00: cmd 61/08:30:d8:03:40/00:00:00:00:00/40 tag 6 ncq dma 4096 out
[77448.497906] ata1.00: status: { DRDY }
[77448.497911] ata1.00: failed command: WRITE FPDMA QUEUED
[77448.497920] ata1.00: cmd 61/08:38:d8:fb:7f/00:00:2f:08:00/40 tag 7 ncq dma 4096 out
[77448.497929] ata1.00: status: { DRDY }
[77448.497934] ata1.00: failed command: WRITE FPDMA QUEUED
[77448.497944] ata1.00: cmd 61/08:48:d8:fd:7f/00:00:2f:08:00/40 tag 9 ncq dma 4096 out
[77448.497953] ata1.00: status: { DRDY }
[77448.497961] ata1: hard resetting link
[77449.209843] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[77449.293942] ata1.00: configured for UDMA/133
[77449.346358] sd 0:0:0:0: [sda] tag#5 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
[77449.346376] sd 0:0:0:0: [sda] tag#5 Sense Key : Illegal Request [current]
[77449.346384] sd 0:0:0:0: [sda] tag#5 Add. Sense: Unaligned write command
[77449.346392] sd 0:0:0:0: [sda] tag#5 CDB: Write(16) 8a 00 00 00 00 00 00 40 01 d8 00 00 00 08 00 00
[77449.346403] blk_update_request: I/O error, dev sda, sector 4194776 op 0x1:(WRITE) flags 0x700 phys_seg 1 prio class 0
[77449.346418] zio pool=HDDPool vdev=/dev/disk/by-partuuid/0599b3e6-1589-424a-8a26-69e9bd6c3896 error=5 type=2 offset=176128 size=4096 flags=180ac0
[77449.346457] sd 0:0:0:0: [sda] tag#6 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
[77449.346466] sd 0:0:0:0: [sda] tag#6 Sense Key : Illegal Request [current]
[77449.346473] sd 0:0:0:0: [sda] tag#6 Add. Sense: Unaligned write command
[77449.346479] sd 0:0:0:0: [sda] tag#6 CDB: Write(16) 8a 00 00 00 00 00 00 40 03 d8 00 00 00 08 00 00
[77449.346488] blk_update_request: I/O error, dev sda, sector 4195288 op 0x1:(WRITE) flags 0x700 phys_seg 1 prio class 0
[77449.346499] zio pool=HDDPool vdev=/dev/disk/by-partuuid/0599b3e6-1589-424a-8a26-69e9bd6c3896 error=5 type=2 offset=438272 size=4096 flags=180ac0
[77449.346519] sd 0:0:0:0: [sda] tag#7 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
[77449.346532] sd 0:0:0:0: [sda] tag#7 Sense Key : Illegal Request [current]
[77449.346539] sd 0:0:0:0: [sda] tag#7 Add. Sense: Unaligned write command
[77449.346546] sd 0:0:0:0: [sda] tag#7 CDB: Write(16) 8a 00 00 00 00 08 2f 7f fb d8 00 00 00 08 00 00
[77449.346554] blk_update_request: I/O error, dev sda, sector 35156655064 op 0x1:(WRITE) flags 0x700 phys_seg 1 prio class 0
[77449.346563] zio pool=HDDPool vdev=/dev/disk/by-partuuid/0599b3e6-1589-424a-8a26-69e9bd6c3896 error=5 type=2 offset=17998059843584 size=4096 flags=180ac0
[77449.346575] sd 0:0:0:0: [sda] tag#9 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
[77449.346583] sd 0:0:0:0: [sda] tag#9 Sense Key : Illegal Request [current]
[77449.346589] sd 0:0:0:0: [sda] tag#9 Add. Sense: Unaligned write command
[77449.346596] sd 0:0:0:0: [sda] tag#9 CDB: Write(16) 8a 00 00 00 00 08 2f 7f fd d8 00 00 00 08 00 00
[77449.346603] blk_update_request: I/O error, dev sda, sector 35156655576 op 0x1:(WRITE) flags 0x700 phys_seg 1 prio class 0
[77449.346612] zio pool=HDDPool vdev=/dev/disk/by-partuuid/0599b3e6-1589-424a-8a26-69e9bd6c3896 error=5 type=2 offset=17998060105728 size=4096 flags=180ac0
[77449.346621] ata1: EH complete
[78701.763191] ata1.00: exception Emask 0x10 SAct 0x30c0 SErr 0x4040000 action 0xe frozen
[78701.763205] ata1.00: irq_stat 0x00000040, connection status changed
[78701.763212] ata1: SError: { CommWake DevExch }
[78701.763219] ata1.00: failed command: WRITE FPDMA QUEUED
[78701.763231] ata1.00: cmd 61/08:30:70:02:40/00:00:00:00:00/40 tag 6 ncq dma 4096 out
[78701.763241] ata1.00: status: { DRDY }
[78701.763246] ata1.00: failed command: WRITE FPDMA QUEUED
[78701.763257] ata1.00: cmd 61/08:38:70:04:40/00:00:00:00:00/40 tag 7 ncq dma 4096 out
[78701.763266] ata1.00: status: { DRDY }
[78701.763271] ata1.00: failed command: WRITE FPDMA QUEUED
[78701.763281] ata1.00: cmd 61/08:60:70:fc:7f/00:00:2f:08:00/40 tag 12 ncq dma 4096 out
[78701.763290] ata1.00: status: { DRDY }
[78701.763295] ata1.00: failed command: WRITE FPDMA QUEUED
[78701.763305] ata1.00: cmd 61/08:68:70:fe:7f/00:00:2f:08:00/40 tag 13 ncq dma 4096 out
[78701.763314] ata1.00: status: { DRDY }
[78701.763322] ata1: hard resetting link
[78702.475345] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[78702.574229] ata1.00: configured for UDMA/133
[78702.651705] sd 0:0:0:0: [sda] tag#6 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
[78702.651722] sd 0:0:0:0: [sda] tag#6 Sense Key : Illegal Request [current]
[78702.651730] sd 0:0:0:0: [sda] tag#6 Add. Sense: Unaligned write command
[78702.651738] sd 0:0:0:0: [sda] tag#6 CDB: Write(16) 8a 00 00 00 00 00 00 40 02 70 00 00 00 08 00 00
[78702.651748] blk_update_request: I/O error, dev sda, sector 4194928 op 0x1:(WRITE) flags 0x700 phys_seg 1 prio class 0
[78702.651764] zio pool=HDDPool vdev=/dev/disk/by-partuuid/0599b3e6-1589-424a-8a26-69e9bd6c3896 error=5 type=2 offset=253952 size=4096 flags=180ac0
[78702.651801] sd 0:0:0:0: [sda] tag#7 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
[78702.651809] sd 0:0:0:0: [sda] tag#7 Sense Key : Illegal Request [current]
[78702.651816] sd 0:0:0:0: [sda] tag#7 Add. Sense: Unaligned write command
[78702.651823] sd 0:0:0:0: [sda] tag#7 CDB: Write(16) 8a 00 00 00 00 00 00 40 04 70 00 00 00 08 00 00
[78702.651831] blk_update_request: I/O error, dev sda, sector 4195440 op 0x1:(WRITE) flags 0x700 phys_seg 1 prio class 0
[78702.651840] zio pool=HDDPool vdev=/dev/disk/by-partuuid/0599b3e6-1589-424a-8a26-69e9bd6c3896 error=5 type=2 offset=516096 size=4096 flags=180ac0
[78702.651854] sd 0:0:0:0: [sda] tag#12 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
[78702.651862] sd 0:0:0:0: [sda] tag#12 Sense Key : Illegal Request [current]
[78702.651869] sd 0:0:0:0: [sda] tag#12 Add. Sense: Unaligned write command
[78702.651876] sd 0:0:0:0: [sda] tag#12 CDB: Write(16) 8a 00 00 00 00 08 2f 7f fc 70 00 00 00 08 00 00
[78702.651884] blk_update_request: I/O error, dev sda, sector 35156655216 op 0x1:(WRITE) flags 0x700 phys_seg 1 prio class 0
[78702.651892] zio pool=HDDPool vdev=/dev/disk/by-partuuid/0599b3e6-1589-424a-8a26-69e9bd6c3896 error=5 type=2 offset=17998059921408 size=4096 flags=180ac0
[78702.651905] sd 0:0:0:0: [sda] tag#13 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
[78702.651913] sd 0:0:0:0: [sda] tag#13 Sense Key : Illegal Request [current]
[78702.651920] sd 0:0:0:0: [sda] tag#13 Add. Sense: Unaligned write command
[78702.651926] sd 0:0:0:0: [sda] tag#13 CDB: Write(16) 8a 00 00 00 00 08 2f 7f fe 70 00 00 00 08 00 00
[78702.651933] blk_update_request: I/O error, dev sda, sector 35156655728 op 0x1:(WRITE) flags 0x700 phys_seg 1 prio class 0
[78702.651942] zio pool=HDDPool vdev=/dev/disk/by-partuuid/0599b3e6-1589-424a-8a26-69e9bd6c3896 error=5 type=2 offset=17998060183552 size=4096 flags=180ac0
[78702.651952] ata1: EH complete
