AMD Radeon Software 16.8.2 mit No Man`s Sky Unterstützung
0
Über das Wochenende hat AMD einen neue Version der Radeon Software veröffentlicht. Die Version 16.8.2 bietet unter anderem die Unterstützung für No Man's Sky und die Open-Beta von Paragon. Natürlich beinhaltet die Radeon Software 16.8.2 auch die Optimierungen der Version 16.8.1, die unter anderem einen Leistungsschub von 10 Prozent für Rise of the Tomb Raider zu bieten hatte.
AMD nennt folgende behobene Probleme:
  • Overwatch™ may experience an intermittent application crash when browsing the hero gallery.
  • With a Freesync supported display and Freesync enabled, some users may experience flickering on desktop during system idle.
  • A small number of Windows 10 Anniversary Edition systems may experience install issues with secure boot enabled.
Allerdings sind auch noch einige Probleme bekannt:
  • A few game titles may fail to launch or crash if the AMD Gaming Evolved overlay is enabled. A temporary workaround is to disable the AMD Gaming Evolved "In Game Overlay".
  • Grand Theft Auto V™ may experience an application hang on Radeon RX 400 Series Graphics when playing at 4K resolution in story mode.
  • A small number of 144hz non-Freesync enabled displays may exhibit flickering during gaming or on desktop.
  • Ark Survival Evolved™ may experience an error message when trying to launch the game in some configurations.
  • DOTA2™ may experience an application hang when using the Vulkan™ API and changing resolution or game/quality settings.
  • Corruption may be experienced in Rise of the Tomb Raider using the DirectX®12 API on some Hybrid Graphics configurations when performing a task switch.
  • Shader Cache may remain be enabled when set to "off" in Radeon Settings on some Hybrid Graphics configurations.
  • Radeon RX 480 graphics may experience intermittent stuttering in The Division™ when high game settings are used and vsync is enabled.
  • Battlefield™ 4 may experience intermittent crashes when using Mantle. As a work around users are suggested to switch to DirectX®11.
  • Radeon Pro Duo may experience a black screen in Total War™: Warhammer with the games API set to DirectX®12 and V-Sync enabled.
  • World of Tanks™ may experience stuttering after performing a task switch in AMD CrossFire mode.
  • Rocket League™ may experience flickering when in AMD CrossFire mode.
  • Ashes of the Singularity™ may experience an application crash with "crazy" in game settings and Multi-GPU enabled.
Der Download der Radeon Software 16.8.2 ist wie immer direkt bei AMD möglich. Unterstützt werden alle aktuellen AMD-Grafikkarten, inklusive der neuen Radeon RX 460 und Radeon RX 470.
Quellen und weitere Links KOMMENTARE (0)
