NVIDIA hat den GeForce Game Ready 388.00 mit WHQL-Zertifikat veröffentlicht. Mit dem Treiber bereitet sich NVIDIA bzw. seine Hardwarekunden auf die baldigen Veröffentlichung von Assassin’s Creed Origins und Destiny 2 vor.
Weiterhin behoben wurden die folgenden Fehler:
- [Notebook][GeForce GTX 1080][G-Sync]: Stuttering occurs while playing games such as Doom, CS Go, and Witcher 3 on the external display. [1995267]
- [Notebook][GM204]: Alienware laptops with GM204 GPUs are not included in this driver release. Support for these products will be added in the next driver. [20033387]
Weiterhin bekannte Probleme sind:
- [SLI][GeForce GTX 780 Ti]: There is no display output when connecting the DisplayPort and two DVI monitors. [1835763]
- [GeForce GTX 1070][Adobe Reader 3D]: There is corruption in the PDF. [1992456]
- [GeForce TITAN (Kepler-based)]: The OS fails after installing the graphics card on a Threadripper-enabled motherboard. [197330]
- [Photoshop CC 2017]: “Photoshop has encountered a problem with the display driver…” error message appears when selecting Path Blur after first launch of the application. [200352926]
- [Notebook][MS Hybrid][HDR]: On Hybrid systems where the discrete GPU drives the primary display, there is momentary corruption before a streaming game goes into full-screen mode. [200349552]
- 2007663 – EU/OEM: [EndUser] 387.92: Scrambled picture after updating to Windows 10 Fall Creators Update on some HDTVs supporting only 8bpc (driver update put it to 12bpc) [2007663]
Der Download des NVIDIA GeForce Game Ready 388.00 ist für die verschiedenen Windows-Versionen direkt bei NVIDIA möglich.
