Treiber
NVIDIA veröffentlicht den GeForce 397.93
10
NVIDIA hat den GeForce 397.93 mit WHQL-Zertifikat veröffentlicht, der unter anderem die optimierte Unterstützung für The Crew Closed Beta und State of Decay 2 bietet. Außerdem fügt NVIDIA die Unterstützung von CUDA 9.2 ein. Der Treiber bietet auch neue SLI-Profile für DRG Initiative und Star Wars: Battlefront II.
NVIDIA führt folgende Probleme auf, die behoben sein sollen:
  • [Notebook][GeForce GTX 870M]: GPU acceleration is being used for Windows Explorer. [2003577]
  • [SLI][Steam]: Steam must be closed to enable or disable SLI mode. [2091966]
  • [Surround][Digital Vibrance]: Digital Vibrance setting is not persistent, and reverts to the default setting when rebooting with Surround mode enabled. [2097240]
  • [Wolfenstein II]: The game may freeze in the Roosevelt area. [2114563]
  • [NVIDIA Control Panel]: When Windows HDR is enabled, some color formats are missing from the NVIDIA Control Panel->Display->Change Resolution page. [2117226]
  • [Pascal GPU + Kepler GPU]: After installing the driver and rebooting the system, the drive may fail to load. [200394820]
  • [Far Cry 5]: Green flickering occurs in the game when using HDR with non-native resolution. [200399992]
Folgende Probleme sollen noch bestehen:
  • [SLI][Hitman Pro: DirectX 12]: With SLI mode enabled, the game crashes if in-game HDR is ON and Windows HDR setting is OFF at lower resolutions. [200415553]
  • [Surround SLI][G-Sync][Overwatch]: There is constant flickering in the game when played in a specific SLI Surround configuration (2 displays on master GPU and 1 display on slave GPU) with G-Sync mode enabled. [2130430]
  • [Shadow Warrior 2][TITAN V]: After launching the game with Windows HDR setting enabled, there is flickering corruption when hovering the mouse over the game screen. [200408410] The issue does not occur with Windows HDR setting disabled.
  • [GeForce TITAN (Kepler-based)]: The OS fails after installing the graphics card on a Threadripper-enabled motherboard. [1973303]
  • [Pascal GPUs][Gears of War 4]: Blue-screen crash may occur while playing the game. [2008731]
  • [GeForce GTX 1080 Ti]{Warhammer Vermintide 2][DirectX 12]: TDR errors may occur when changing resolutions in game. [200395335]. To work around, use the DirectX 11 game option.
  • [Notebook][GeForce GTX 1060]: The external HDMI display blinks when playing a video from the Netflix Edge Browser or Blu-ray video in full-screen mode with Windows HDR enabled. [200410646] The issue does not occur when playing the Netflix video in a Chrome, Firefox, or Internet Explorer 11 browser.
  • [Netflix Edge Browser]: When playing a game in full-screen mode and playing a video from the Netflix Edge Browser, blue-screen crash occurs after multiple [Alt+Tab] switching between the two. [200415750] The issue does not occur when playing the Netflix video in a Chrome browser.
  • [DOTA 2][Vulkan API]: With Vulkan mode enabled, the game item slot glitches. [1877720]
  • [Dead by Daylight]: NVIDIA Freestyle does not work with the game. [2116198]
  • [Call of Duty: WWII][Surround]: With Surround enabled, the center Surround display is blank during gameplay. [200370257]
  • [NVIDIA Control Panel][Surround]: NVIDIA Surround hot keys do not work. [200394749]
  • [GeForce Experience][ShadowPlay]: The “In-Game Overlay” option cannot be enabled, nor does Shadowplay recording work. [200390642] The Microsoft Media Foundation library must be installed in order to use these features. Be sure to first install the Media Foundation package.
  • Random DPC watchdog violation errors occur when using multiple GPUs on motherboards with PLX chips. [2079538]
  • With HDR turned on, non HDR full-screen video playback may cause corruption/ flicker in the video. [200410646] To avoid this scenario, disable Windows HDR setting before launching the video. ()
Der NVIDIA GeForce 397.93 kann direkt bei NVIDIA heruntergeladen werden.
