Treiber
NVIDIA veröffentlicht den GeForce Game Ready 398.36
9
NVIDIA hat mit dem GeForce einen weiteren Game-Ready-Treiber in der Version 398.36 veröffentlicht. Dieser richtet sich explizit an Spieler von The Crew 2. Außerdem gibt es SLI-Profile für Dark Souls Remastered, Hand of Fate 2, Need for Speed Payback und Super Mega Baseball 2.
Zudem behebt NVIDIA die folgenden Probleme:
  • [Pascal GPUs][Gears of War 4][DirectX12]: Blue-screen crash may occur while playing the game. [2008731]
  • [Sterescopic 3D][NVIDIA Control Panel]: Switching the 3D display setting On and Off from the Windows display settings page has no effect on the NVIDIA Control Panel stereoscopic 3D settings page. [2045222]
  • [G-SYNC]: G-SYNC may still be active after closing a game, causing the desktop to stutter.
  • [Surround]: Multiple games crash when launched in Surround mode. [2181329]
  • [HDR]: With HDR turned on, non HDR full-screen video playback may cause corruption/flickering in the video. [200410646]
  • [Notebook]: Blue-screen crash occurs with Driver_Power_State_Failure error upon bootup. [2168487]
  • Black Screen appears when booting Windows after installing the 397.93 display driver. [200418217]
Weiterhin bekannt sind die folgenden Probleme:
  • [SLI][GeForce GTX 1080][G-SYNC][World of Warcraft: Legion][HDR]: Severe color corruption appears in the game after launching with the Windows HDR setting enabled. [200418344] This issue does not occur with the Windows HDR setting disabled.
  • [Surround][G-SYNC]: In Surround mode, the G-SYNC link in the NVIDIA Control Panel is missing. [200425004]
  • [Surround SLI][G-SYNC][Overwatch]: There is constant flickering in the game when played in a specific SLI Surround configuration (2 displays on master GPU and 1 display on slave GPU) with G-Sync mode enabled. [2130430]
  • [G-SYNC]: Windowed G-Sync mode may stutter after upgrading to Windows 10 Spring Creators Update. [2097340]
  • [Shadow Warrior 2][TITAN V]: After launching the game with Windows HDR setting enabled, there is flickering corruption when hovering the mouse over the game screen. [200408410] The issue does not occur with Windows HDR setting disabled.
  • [GeForce TITAN (Kepler-based)]: The OS fails after installing the graphics card on a Threadripper-enabled motherboard. [1973303]
  • [Netflix Edge Browser]: When playing a game in full-screen mode and playing a video from the Netflix Edge Browser, blue-screen crash occurs after multiple [Alt+Tab] switching between the two. [200415750] The issue does not occur when playing the Netflix video in a Chrome browser.
  • [Firefox]: Cursor shows brief corruption when hovering on certain links in Firefox. [2107201]
  • [NVIDIA Control Panel][Surround]: NVIDIA Surround hot keys do not work. [200394749] Random DPC watchdog violation errors occur when using multiple GPUs on motherboards with PLX chips. [2079538]
  • Using power monitoring in GPU monitor tools causes micro stutter. [2110289/2049879]
Der Download des GeForce Game Ready 398.36 ist wie immer direkt bei NVIDIA möglich.
