NVIDIA hat mit dem GeForce 398.82 einen neuen Treiber mit WHQL-Zertifikat vorgestellt. In dieser Version sieht die Chipschmiede alle bisherigen Optimierungen für "World of Warcraft: Battle for Azeroth" und damit die Unterstützung für DirectX 12 vor. Hinzu kommt eine Anpassung an "Monster Hunter: World".
Außerdem enthält der Treiber entsprechend angepasste SLI-Profile für "Call of Duty: Black Ops 4" und "World of Warcraft: Battle for Azeroth".
Zudem hat NVIDIA folgende Fehler behoben:
- [Surround][G-SYNC]: In Surround mode, the G-SYNC link in the NVIDIA Control Panel is missing. [200425004]
- [Surround]: 1×3 Surround configuration cannot be set from the NVIDIA Control Panel. [200415178]
- [SLI][GeForce GTX 1080][G-SYNC][World of Warcraft: Legion][HDR]: Severe color corruption appears in the game after launching with the Windows HDR setting enabled. [200418344]
- [SLI][Dark Souls Remastered]: Ghosting occurs in the game when using in-game temporal anti-aliasing. [2218297]
- [NVIDIA Control Panel][Surround]: NVIDIA Surround hot keys do not work. [200394749]
- [Dead by Daylight][GeForce Experience]: NVIDIA Freestyle does not work with the game. [2116198]
- [GeForce GTX 1080 Ti][GameStream]: White dots may appear while Gamestreaming on overclocked GPU. [2194899]
- [Unreal Engine 4]: Resource creation leak occurs in the driver when running Unreal Engine 4 games. [2204854]
- [Wolfenstein II]: Graphical effects are missing in the game. [2248780]
- [G-Sync][Multiple Apps]: Applications don’t run in IFlip when using the native resolution, preventing G-Sync from triggering. [200416974]
- [Wolfenstein II: The New Colossus]: Black textures appear in Wolfenstein II: The New Colossus. [200419742]
- [GeForce GTX 1080]: Dolby Vision no longer works after updating LG TV firmware to 4.70.x. [200420847]
Noch bekannt sind die folgenden Probleme:
- [G-SYNC]: Windowed G-Sync mode may stutter after upgrading to Windows 10 Spring Creators Update. [2097340]
- [Euro Truck Simulator 2][DirectX NVCamera]: Performance drop occurs after enabling Freestyle for the game. [200435356]
- [Netflix Edge Browser]: When playing a game in full-screen mode and playing a video from the Netflix Edge Browser, blue-screen crash occurs after multiple [Alt+Tab] switching between the two. [200415750] The issue does not occur when playing the Netflix video in a Chrome browser.
- [Firefox]: Cursor shows brief corruption when hovering on certain links in Firefox. [2107201]
- Windowed G-Sync mode may stutter after upgrading to Windows 10 Spring Creators Update. [2097340]
- Random DPC watchdog violation errors occur when using multiple GPUs on motherboards with PLX chips. [2079538]
- Using power monitoring in GPU monitor tools causes micro stutter. [2110289/2049879]
Der GeForce 398.82 kann direkt bei NVIDIA heruntergeladen werden.
