NVIDIA hat einen weiteren Game Ready Driver (GRD) veröffentlicht. Der GeForce 419.67 konzentriert sich dabei zunächst auf Optimierungen für die Spiele und Erweiterungen Battlefield V: Firestorm, Anthem, Shadow of the Tomb Raider und Sekiro: Shadows Die Twice.
Außerdem sind werden die beiden Monitore ASUS VG278QR und ASUS VG258 nun als Gsync Compatible aufgeführt.
Folgende Probleme wurden mit dem GeForce 419.67 behoben:
- [DaVinci Resolve]: Performance drop occurs. [2532482]
- [Ghost Recon: Wildlands][Ansel]: The game experiences low performance and stuttering and then crashes when using Ansel. [2515076]
- [HDR][Far Cry:New Dawn DirectX 11]: Desktop brightness and color gets overexposed with ALT + TAB when Windows HDR is disabled and in-game HDR is enabled. [200495279]
- [Total War: Warhammer 2]: Poor performance when using antialiasing. [2506465]
- [Adobe]: Artifacts may appear in Adobe applications (fixed for single-GPU case). [2533911]
- [Apex Legends]: Screen gets corrupted when switching from windowed mode to full-screen mode when Windows HDR is enabled.[2523309]
- [GeForce Experience]: Parts of the screen are cut off when recording video with Shadowplay. [2517587]
- [Turing][Star Citizen]: The game flickers and then crashes to the desktop. [2518104]
- [GeForce GTX 980]: NVAPI calls take a large amount of CPU time. [2418933]
- [Titan RTX]: Graphics card rises about 20 degrees Celsius when running NVLINK command to enable TCC mode. [2504836]
- [GeForce RTX 2080][Notebook][Resolume Arena 6]: The game exhibits slow performance. [2511725]
- [GeForce RTX 2070]: With two monitors connected and active, the second monitor flickers. [2517103]
Wie immer sind aber noch einige Probleme offen bzw. neue hinzugekommen:
- [SLI][Adobe]: With SLI enabled, artifacts may appear in Adobe applications. [2533911]
- [SLI][HDR][Tom Clancy's The division II]: The game screen becomes unresponsive or goes blank when in-game HDR options are toggled. [200496967]
- [ARK Survival]: Multiple errors and then blue-screen crash may occur when playing the game. [2453173]
- [Shadow of the Tomb Raider][Ansel]: Invoking Ansel in the game causes the game to slow down or crash. [2507125]
- [Ghost Recon Wildlands]: The game crashes when accessing the inventory menu. [2404783]
- Random desktop flicker occurs on some multi-display PCs [2453059]
Der GeForce 419.67 kann ab sofort direkt bei NVIDIA heruntergeladen werden.
